Cisco Hyperflex Monitoring & HX Replication.
IC2317
Can someone please suggest me on good monitoring tool for Cisco Hyperflex solution ? We have Vrealize operations Manager what we use to monitor our Cisco UCS environment, so can we use same for Hyperflex also ? Do we have some better tool available for monitoring of Hyperflex solution.
I am also going to deploy Hyperflex solution soon with 4 nodes, so can I choos replication factor 3 in that or I only have option of replication factor 2 ?
5 Replies 5
Ruben Cocheno
@IC2317
give a look on Cisco Workload Optimization Manager
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Thanks.
Do we need license for that ?
IC2317
@Kirk J  Could you please provide your suggestions on this.
Kirk J
I'm not sure if there is an all-in-one product that covers the HX high level objects down to the detailed equipment health right now (I suspect you will eventually see this from Intersight, as Intersight does a fair amount of monitoring already).
I have seen customers use some Cisco Prime configurations to monitor UCS  compute and network level and VMware level objects, which would cover most of the component layers of Hyperflex.  See https://www.ciscolive.com/c/dam/r/ciscolive/emea/docs/2016/pdf/BRKDCT-1885.pdf on Prime.
As previous poster mentioned, Cisco Workload Optimization Manager does have monitoring capabilities for HX, https://www.cisco.com/c/dam/en/us/products/se/2018/9/Collateral/optimize-hyperconverged-hyperflex.pdf ,  although I don't have personal experience with that.
Having both your UCSM and Hyperflex smart call home correctly configured will get you pretty good health status and event alerts for both equipment and cluster health.  As for performance at VMware ESXI host and guestVM levels, you will need something like previously mentioned Prime or other products that correctly monitor UCSM, ESXi host, guestVms, network interfaces, HX cluster object health, etc.
https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/ucs-manager/GUI-User-Guides/System-Monitoring/4-0/b_UCSM_GUI_System_Monitoring_Guide_4-0/b_UCSM_GUI_System_Monitoring_Guide_4-0_chapter_01.html
https://developer.cisco.com/docs/ucs-dev-center-hyperflex/
Most of Cisco's products have REST api interfaces that expose most objects that you would want to monitor, and are usually preferred over traditional SNMP
HX does not currently have a SNMP stack, and I hope they don't create one as SNMP always seems add memory/cpu utilization overhead issues.
If you are trying to go down the opensource/free tool path, then I've seen a few customers string together Cacti, Nagios, Zabbix, etc, but that usually takes a lot of work.
Kirk...
IC2317
@RedNectar  Could you please provide your thoughts on this. I have not been able to get much help from community on this.
