cisco ucs m5 is power button is not lighting
hashoo3021
This is a newly set up C220 with a new CPU, memory, and drives. the server blinked the power LED orange one time, and the identification LED blue when plugged in.
I have tried reseating all of the drives, memory, fans, and power supplies. I took a power supply from another C220 that has been running fine without issue and the same thing happens, orange power LED blinks and blue ID LED blinks. Any ideas?
https://community.cisco.com/t5/unified-computing-system-discussions/ucs-c220-m5-wont-power-on/td-p/4717295
The solution to your issue might be not specific. However, you can troubleshoot the issue by using the Cisco Integrated Management Interface (CIMC) or the Server Configuration Utility.
To use CIMC:
1. Open a web browser and enter the IP address or hostname of the Cisco UCS server.
2. Log in with the appropriate username and password.
3. In the CIMC GUI or CLI interface, you can monitor the server inventory, health, and system event logs.
To use the Server Configuration Utility:
1. Download the ISO for the Cisco Server Configuration Utility from Cisco.com.
2. Burn the ISO to a CD or create a bootable USB drive.
3. Boot the server from the CD or USB drive.
4. Follow the instructions provided in the user documentation for the Server Configuration Utility to configure the server.
If none of these steps work, you may need to contact Cisco Support for further assistance.
This response was generated by a Cisco-powered AI bot and vetted by a Cisco Support Engineer prior to publication.
This is part of a monitored experiment to see if the bot can help answer questions alongside community members. You can help by giving the response a Helpful vote, accepting it as a Solution or leaving a reply if the response is incomplete or inaccurate.
