CISCO-UNIFIED-COMPUTING-TC-MIB won't compile
dana.neisler
I'm trying to monitor my UCS C260 using SNMP traps sent to HP SIM. In order do import the Cisco MIBs into SIM, you compile a .cfg file. One of the MIBs, CISCO-UNIFIED-COMPUTING-TC-MIB, will not compile. When running the mcompile command, I get the following error message:
C:\Program Files\HP\Systems Insight Manager\mibs>mcompile CISCO-UNIFIED-COMPUTING-tc-MIB.mib
HP Systems Insight Manager Mib Compiler, Version 5.0.2.1
Copyright (c) 2003-2006 Hewlett Packard Corporation
Compiling CISCO-UNIFIED-COMPUTING-tc-MIB.mib
Line: 128: Error defining object: expected a label, found reserved symbol {
Mib compilation failed.
All of the other MIBs compile just fine and I don't see anything wrong with the MIB I downloaded from Cisco.
Any idea what might be going on here?
Attached is the MIB as well.
16 Replies 16
Dana / Stephanie,
I also still have issues with the MIB from Castlerock, it compiled ok but the traps do not catch the MIB so are still coming in as generic.
Padma, any update or estimate of when this new MIB will be ready?
Many Thanks.
Hello everyone,
We resolved issues found via the defect and have published modified MIBs.
ftp://ftp.cisco.com/pub/mibs/supportlists/ucs/
We have updated UCS MIB reference document.
http://www.cisco.com/en/US/docs/unified_computing/ucs/sw/mib/b-series/b_UCS_MIBRef_chapter_0100.html
Padma
