clear counters interface command on FabricInterConnect
after logging in nxos on FabricInterconnect ,
I used "clear counters interface all" command in order to delete all of the packet-infomations
after than I checked whether the infomations has deleted .
I know All packet-infomations have deleted ,
regardless of deleting These Infomations , I found "Last clearing of  show interface counters" has not changed "
when i used "show int " command .
As For FC port , I found "last clearing of  show interface" counters has changed .
Is this a bug ?
Keny Perez
Level 11
Level 11
I see the same in my lab:
F241-01-08-UCS2-A(nxos)# sh inter fc 2/1
fc2/1 is down (SFP not present)
    Hardware is Fibre Channel
    Port WWN is 20:41:8c:60:4f:5f:00:00
    Admin port mode is NP, trunk mode is off
    snmp link state traps are enabled
    Port vsan is 5
    Receive data field Size is 2112
    Beacon is turned off
    1 minute input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
    1 minute output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
      0 frames input, 0 bytes
        0 discards, 0 errors
        0 CRC,  0 unknown class
        0 too long, 0 too short
      0 frames output, 0 bytes
      0 input OLS, 0 LRR, 0 NOS, 0 loop inits
      0 output OLS, 0 LRR, 0 NOS, 0 loop inits
    last clearing of "show interface" counters never
F241-01-08-UCS2-A(nxos)# clear counters
    Port vsan is 5
    last clearing of "show interface" counters Tue May 12 12:51:44 2015
F241-01-08-UCS2-A(nxos)# sh cloc
12:52:06.573 UTC Tue May 12 2015
F241-01-08-UCS2-A(nxos)# sh inter et 1/1
Ethernet1/1 is up
 Dedicated Interface
  Hardware: 1000/10000 Ethernet, address: 8c60.4f5f.87a8 (bia 8c60.4f5f.87a8)
  Description: S: Server
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
  Encapsulation ARPA
  Port mode is fex-fabric
  full-duplex, 10 Gb/s, media type is 10G
  Input flow-control is off, output flow-control is off
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  Last link flapped 1week(s) 6day(s)
  30 seconds input rate 18512 bits/sec, 2 packets/sec
  30 seconds output rate 548096 bits/sec, 224 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 16.83 Kbps, 2 pps; output rate 536.42 Kbps, 695 pps
  RX
    304 unicast packets  46 multicast packets  245 broadcast packets
    595 input packets  330242 bytes
    135 jumbo packets  0 storm suppression bytes
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    406 unicast packets  218 multicast packets  8049 broadcast packets
    8673 output packets  2463556 bytes
    0 jumbo packets
    0 output errors  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble 0 output discard
    0 Tx pause
  0 interface resets
What version of UCSM are you running?
-Kenny
Hi kenny
I checked two UCS
one is FI6248 whose version is  2.2(3a), nxos is 5.2(3)N2(2.23a)
the other is FI6324 which is 3.0(2c), nxos is 5.0(3)N2(3.02c)
