Could you please help me to understand about IMC supervisor operation?
junhong
Hello, This is Jungwo Hong from E-tech system in Korea
My customer want to know about the simple process between IMC Supervisor and CIMC on the server.
Would it be possible to know how they communicate each other (like using some protocol )?
and what is the method for the communication? (installing some agent on the server or just using CIMC)
and the last question is, could it be possible to use the supervisor when the server (supervisor rack account server)have some problem with its CIMC?
It would be really helpful if you could give me some advice about above issue.
Best Regards,
Jungwo
Jeffrey Foster
The communication between IMC Supervisor and IMC is using the IMC XML API. You can view this communication by capturing debug logging on IMC Supervisor. We collect the following information:
- Fault Data (Every 15 Minutes)
- Inventory Data (Every 24 Hours)
There are no agents requires, but ability to reach the IMC is necessary. Depending on the issue that IMC is facing it may be possible to use Supervisor to reach IMC (assuming it is not an OOB communication issue).
There is a Tech Talk here with more data on IMC Supervisor:
UCS Tech Talk: Introducing IMC Supervisor for Standalone C-Series and E-Series Servers
Thank you for your interest!
Jeff
Jeffrey Foster
Jeff
Thank you for your fast reply and It would be more helpfule to my customer to understand this issue.
Best Regards,
Jungwo
