Connecting Fabric Interconnect to Cisco MDS Switch
abbasali5
I am new to Unified Fabric, and trying to understand this.
There are customers who connect Fabric Interconnects directly to MDS switch without any Nexus 5K in between.  If Fabric Interconnects are capable of providing connectivity to LAN and SAN islands then why you would install Nexus 5K switches in between to add an extra hop.
Most customers do the following:
- connect FI to upstream e.g. N5k with vPC for Ethernet (and IP)
- connect FI to upstream e.g. MDS for classical FC
This implies, that between blade in the chassis and FI you run  FCoE, integrating FC and Ethernet on the same transport; then on the FI, FC and Ethernet is disagregated.
The other choice would be multihop FCoE, running FCoE also between FI and N5k, and do the disagregation there.
However, if your storage subsystem is FC and not FCoE, I would not recommend multihop FCoE (I see only a minority of customers doing it).
Walter.
Qiese Dides
Hi Abbasail5,
So the Fabric Interconnect is a switch and (the brains) behind UCSM. There are two different modes End host mode and Switching Mode.
In Switching mode your Fabric Interconnect can act as a switch and can be directly connected to a storage array, you can completely by pass having a N5K or MDS switch.
While End Host Mode you have: Unicast Fowarding
DeJaVu - Loop Preventation mechanism, when a Mac Address from Server 2 try's to come to
Server 1 it will be dropped.
Did that make sense Abbas?
Qiese Dides
Hi Qiese,
I agree with your reply and it totally makes sense.  What I am trying to understand the need for Nexus5K between FI and LAN/SAN Islands.  Most of the customers would connect FIs to TOR switches such as Nexus 5500s.  5500s then connect to Fiber Channel Switches or directly to SAN and LAN networks.
Can you shed some light?
Walter.
abbasali5
Thank you Walter!
