Connectivity options between Fabric Interconnect and Nexus 2000
ChristianPaz
I'd like to know what models of nexus 2000 fabric extenders can i use if i want to connect them to a pair of fabric interconnects 6248UP in a FEX deployment, so i can move service profiles between blade and rack servers.
Thanks for your answers.
Christian
2 Accepted Solutions
Robert Burns
Just to add, in the next release (2.1) coming out tentatively this month, we will be adding support for Single Wire Management (SWM) where both data and Management can utilize the same wire between the Rack servers and 2232 FEX's.   This does require the 2nd Gen Cisco Virtual Interface Card (UCSC-PCIE-CSC-02) adapter as well which will be released along with UCS version 2.1.  Existing adaptors will continue to utilize the two wire integration model documented in the guide above.
Robert
Robert Burns
Christian,
Have a look at this guide.  It should answer all your questions:
http://www.cisco.com/en/US/customer/docs/unified_computing/ucs/c-series_integration/ucsm2.0.2/b_UCSM_202_C-Integration.html
Robert
Robert
Thanks Robert, this is the document i needed.
