Default vsan (vsan0001) is showing as Admin okay but Operational down
ciscoucs
Default vsan (vsan0001) in UCSM is showing as Admin status okay but Operational status down (major alarm from Monintoring system)
It is causing an inconvinience for us as we are getting alarm generated for this default VSAN which we are not using in our
UCS Fabric interconnects. But somehow as All unused FC ports (Disabled) are pointing or member of this default vsan. Is there any way
to get rid of this without causing any problems. See below for details;
A(nx-os)# show vsan
vsan 1 information
name:VSAN0001 state:active
interoperability mode:default
loadbalancing:src-id/dst-id/oxid
operational state:down
vsan 1111 information
name:VSAN1111 state:active
operational state:up
fc-uplink # show vsan
VSAN:
Name Id FCoE VLAN Fabric ID FC Zoning Overall status
default 1 4048 Dual Disabled Ok
Top 1111 1111 A Disabled Ok
*****Default VSAN and not in use************
A(nx-os)# show vsan 1 membership
vsan 1 interfaces:
fc1/5 fc1/6 fc1/7
fc1/8 fc1/9 fc1/10
fc1/11 fc1/12 fc1/13
fc1/14 fc1/15 fc1/16
**********Working and in use VSan**********
A(nx-os)# show vsan 1111 membership
vsan 1111 interfaces:
fc1/1 fc1/2 fc1/3
fc1/4 vfc3867 vfc4248
vfc4353 vfc4354 vfc4517
vfc4518 vfc4573 vfc4574
vfc4578 vfc4583 vfc4584
vfc4644 vfc4648 vfc4650
vfc4659 vfc4660 vfc4669
vfc4670 vfc4694 vfc4769
vfc4770 vfc4784 vfc4785
vfc4833 vfc4834 vfc4839
vfc4840 vfc4845 vfc4846
vfc4876 vfc4877 vfc4882
vfc4883 vfc4910 vfc4911
vfc4922 vfc4923 vfc4941
vfc4953 vfc4959 vfc4998
vfc4999 vfc5010 vfc5011
vfc5027 vfc5055 vfc5083
vfc5085 vfc5143 vfc5162
vfc5163 vfc5173 vfc5179
vfc5187 vfc5195 vfc5201
vfc5209 vfc5211 vfc5219
vfc5221 vfc5227 vfc5233
vfc5239 vfc5243 vfc5250
vfc5251 vfc5261 vfc5267
vfc5281 vfc5289 vfc5299
vfc5305 vfc5315 vfc5321
vfc5331 vfc5343 vfc5373
vfc5379 vfc5385 vfc5391
vfc5405 vfc5411 vfc5417
vfc5423
ciscoucs
Any Answer will be appreciated.
I don't see any way to delete the "default" VSAN within UCSM.
Reading through the docs it sounds as though the "default" VSAN has a purpose for incorrect VSAN configurations.
Hmmm. is there any way to basically disable / suspend this vsan in order to avoid the alarms for VSAN0001 being down.
All we want to accomplish is to get rid of the alarms for the VSAN0001 by not breaking anything in the environment.
