04-06-2011 11:24 AM - edited 03-01-2019 09:52 AM
When we shutdown a ESX host in vCenter the UCSM just reboots the server. The desired power state is "up" but where do you configure that setting so the server stays down after a shutdown?
vSphere DPM is NOT enabled.
I have looked all of UCSM for any setting that would be causing this and no luck.
04-06-2011 02:53 PM
The "Desired Power State" should have no impact on your server rebooting it when you opt to shut it down. This only affects a server being powered on/off following an association or re-ack.
How exactly are you shutting down the hosts? vCenter, command line (if so, what command)?
Robert
04-06-2011 05:05 PM
Found the solution. It was a BIOS version mismatch.
04-07-2011 04:14 AM
JC,
What do you mean a BIOS version mis-match? The BIOS does necessarily have to be the same version of your UCSM. I would suspect a BIOS setting however which would have caused this. Resetting the CMOS settings via UCSM should have rendered the same result.
Robert
