Downgrade firmware on Cisco UCS B200 M5 servers
heman7
Hi Team,
There is a requirement to downgrade the blade firmware from 4.2(3) to 4.1.3h, and subsequently to 3.1, in order to match the UCS Infrastructure version.
As this involves a blade server, I would like to clarify: will all the servers be downgraded at once, or is it possible to downgrade each host individually, one by one?
I couldn’t find any official guide for this process. If anyone has prior experience with a similar scenario or documentation to assist, your input would be greatly appreciated.
Moved your post to the UCS section as it’s not related to Collaboration.
Response Signature
Steven Tardy
Google:
cisco UCS upgrade path
Leads to:
Which links to:
To answer your question:
Yes. One singular server can be upgraded/downgraded. Detailed server firmware guides are published.
UCSM 3.x is EoL and probably should not be used.
Do you have hardware that will not work on newer UCSM 4.x firmware?
Does your new server which has 4.2(3) firmware support 3.1 firmware?
You don't specify PIDs or models so I'm curious why not upgrade everything else instead of downgrade the one?
