ERR-IBMC-fru-retrieval-error Could not get Fru from 7f060207, dn=fabric/server/chassis-2/slot-7
redrain002
I faced a big problem. UCS B200-M3 FRU information disappeared after firmware upgrade.
 Can I recover the fru information?
5 Replies 5
Konstantin Batrakov
I would suggest top open a Service Request to TAC. You will possibly end up with RMA.
Konstantin
Do not have a file recovery tool?
For example, to recover from a fru.bak file
This equipment is a warranty expiration device.
Thank you.
Can you attempt to SSH to UCSM and run a 'reset slot x/y'. For example, Chassis 1, Server 6:
UCS#reset slot 1/6
I proceeded to reset but it is the same
Thanks. The motherboard will likely need to be replaced.
