ESXi 5.0.0 Not Recognizing RAID Volume on LSI MegaRAID.
j.dewiele
I Have a C220M3 with the LSI MegaRAID SAS 9266-8i controller. I used the MegaRAID utility to create a RAID volume, which shows up as virtual drive 0 in CIMC. My ESXi 5.0.0 installation (on flex flash) does not recognize this volume and I cannot use it as a datastore.
Any ideas?
Joey
Zaira Vega
Try using the OEM Customize Installer for Cisco image as a virtual CD installation using KVM or, you can also burn it to a CD:
https://my.vmware.com/web/vmware/details/esxi50/dHRAYnQldGViZHAlJQ==#drivers_tools
Zaira
5 Replies 5
Robert Burns
Did you try "Adding Storage" in ESX?
From the CLI have a look the output of lspci and see if there's any LSI drive entries.
Robert
Yes I did try adding storage in ESX but there's no disk found.
I assume that the lspci command is a vmware command. I'll have to install the CLI.
Joey
Hello Joey,
You can SSH into ESXi host and execute the commands.
lspci
esxcfg-scsidevs -l
Padma
Zaira Vega
Zaira
Thanks!
That worked perfectly.
Joey
