ESXI 5.1 Problem
jpiedra07
                   Estoy intentando instalar en un UCS c22-m3s, un esxi 5.1, pero no consigo instalarlo. Tengo creado un RAID1, y cuando inicio la instalacion, no me ve el volumen, unicamente los discos por independiente. Cuando acaba la instalacion no arranca y es mas, degrada el RAID.
¿Me podeis ayudar a solucionar este problema?
Gracias de antemano.
I'm trying to install a c22-m3s UCS, a esxi 5.1, but I can not install it. I have created a RAID1, and when you start the installation, I do not see the volume, only by independent disks. When the installation has just started and is no more, degraded the RAID.
Can you help to solve this problem?
Thanks in advance.
Robert Burns
Which RAID controller do you have in the C22?
Robert
Hi Robert, the RAID controler is LSI Megaraid C620, integrated motherboard
I dont think C22-m3s's support ESXi 5.1. Please, refer to Cisco's UCS HW and SW Interoperability matrix :
http://www.cisco.com/web/techdoc/ucs/interoperability/matrix/matrix.html
Zaira Vega
Juan,
ESXi 5.1 is not supported in the firmware release 1.4(6) for UCS-C220 M3 yet.
What you can install is ESXi 5.0 U1.
