F0637 Power Cap Fault
Dan Laden
Running UCS 3.2.2f with B480M5s with same firmware.  I have a Power Control policy to impose "No-Cap" Power Control.  Each server where it is applied, i get the F0637 fault.  If I remove the policy, the fault clears.  I had seen  a bug in 3.1 but resolved in same.  CSCvc02297.  I had trying the work-around of power down via the OS and boot via UCSM.  This did not clear the fault.
Anyone seen this elsewhere?
Thank you for any insight,
Dan Laden
5 Replies 5
Kirk J
Greetings.
Trying pulling some power related settings from the cli:
#scope chassis x
#scope server y
#show power-budget expand detail
#scope chassis x
#show power-budget detail
exit out to top level of ucsm cli
#connect iom x (where x is chassis with blade in question)
#show platform software cmcctrl power config
#show platform software cmcctrl dmclient psreadings  (if output is all zeros, then connect to other IOM in same chassis
You may want to try re-acking server if you haven't already...
Kirk...
ucs-A /chassis/server # show power-budget expand detail
Budget:
AdminCommitted (W): 0
ucs-A /chassis # show power-budget detail
Budget:
Device Id: blade 1/1
Power Cap (W): 0
Applied Power Cap (W): 25
Admin Priority: No Cap
Maximum power (W): 0
Minimum power (W): 0
Group: default
Average Usage (W): 301
Power Profiling: No
Method: Nodemgr
OperMethod: Static
OperState: Non Compliant
Psu State: Ok
Power Cap Support: Yes
Device Id: blade 1/3
Power Cap (W): 0
Group: default
Average Usage (W): 322
Power Profiling: No
Method: Nodemgr
OperMethod: Static
Psu State: Ok
Device Id: blade 1/5
Power Cap (W): 0
Group: default
Average Usage (W): 289
Power Profiling: No
Method: Nodemgr
OperMethod: Static
Psu State: Ok
Device Id: blade 1/7
Power Cap (W): 0
Group: default
Average Usage (W): 288
Power Profiling: No
Method: Nodemgr
OperMethod: Static
Psu State: Ok
Device Id: chassis 1
Power Cap (W): 800
Applied Power Cap (W): 800
Admin Priority: Utility
Group: default
Average Usage (W): 756
Power Profiling: No
Method: Unknown
OperMethod: Unknown
Psu State: Ok
Power Cap Support: No
Device Id: blade 2/1
Power Cap (W): 0
Group: default
Average Usage (W): 10
Power Profiling: No
Method: Nodemgr
OperMethod: Static
OperState: Unbudgeted
Psu State: Ok
Device Id: blade 2/3
Power Cap (W): 0
Group: default
Average Usage (W): 279
Power Profiling: No
Method: Nodemgr
OperMethod: Static
Psu State: Ok
Device Id: blade 2/5
Power Cap (W): 0
Group: default
Average Usage (W): 310
Power Profiling: No
Method: Nodemgr
OperMethod: Static
Psu State: Ok
Device Id: blade 2/7
Power Cap (W): 0
Group: default
Average Usage (W): 320
Power Profiling: No
Method: Nodemgr
OperMethod: Static
Psu State: Ok
Device Id: chassis 2
Power Cap (W): 800
Group: default
Average Usage (W): 726
Power Profiling: No
Method: Unknown
OperMethod: Unknown
Psu State: Ok
Device Id: blade 3/1
Power Cap (W): 0
Group: default
Average Usage (W): 316
Power Profiling: No
Method: Nodemgr
OperMethod: Static
Psu State: Ok
Device Id: blade 3/3
Power Cap (W): 0
Group: default
Average Usage (W): 287
Power Profiling: No
Method: Nodemgr
OperMethod: Static
Psu State: Ok
Device Id: blade 3/5
Power Cap (W): 0
Group: default
Average Usage (W): 280
Power Profiling: No
Method: Nodemgr
OperMethod: Static
Psu State: Ok
Device Id: blade 3/7
Power Cap (W): 0
Group: default
Average Usage (W): 293
Power Profiling: No
Method: Nodemgr
OperMethod: Static
Psu State: Ok
Device Id: chassis 3
Power Cap (W): 800
Group: default
Average Usage (W): 724
Power Profiling: No
Method: Unknown
OperMethod: Unknown
Psu State: Ok
Device Id: switch A
Power Cap (W): 335
Applied Power Cap (W): 335
Maximum power (W): 335
Minimum power (W): 335
Group: default
Average Usage (W): 335
Power Profiling: No
Method: Static
OperMethod: Static
OperState: Deployed
Psu State: Ok
Device Id: switch B
Power Cap (W): 335
Group: default
Power Profiling: No
Method: Static
OperMethod: Static
OperState: Deployed
Psu State: Ok
ucs-A /chassis #
ucs- A# connect iom 1
Attaching to FEX 1 ...
To exit type 'exit', to abort type '$.'
Bad terminal type: "dumb". Will assume vt100.
fex-1# show platform software cmcctrl power config
Redundancy policy: Grid
Chassis power budget: 720/800 # committed/peak
Chassis settings:
pwrcap enabled
dynamic rebalancing enabled
Blade 0:
Presence: PRESENT
Prio: 0
Non compliance action: None
Excursion action: None
Minimum power budget: 25
Max power budget: 25
Peak power budget: 25
Power cap support: Yes
Boot power budget: 25
Blade 1:
Presence: ABSENT
Blade 2:
Presence: PRESENT
Prio: 0
Blade 3:
Presence: ABSENT
Blade 4:
Presence: PRESENT
Prio: 0
Blade 5:
Presence: ABSENT
Blade 6:
Presence: PRESENT
Prio: 0
Blade 7:
Presence: ABSENT
fex-1#
fex-1# show platform software cmcctrl dmclient psreadings
Total Input Power consumption: -1
Total Output Power consumption: -1
Power supply: 0
Voltage (IN) : N/A
Voltage (12V) : N/A
Voltage (3V) : N/A
Current (IN) : N/A
Current (12V) : N/A
Current (3V) : N/A
Peak Current (IN) : N/A
Peak Current (12V) : N/A
Peak Current (3V) : N/A
Temperature 0 : N/A
Temperature 1 : N/A
Temperature 2 : N/A
Fan tach0 : N/A
Fan tach1 : N/A
Fan tach2 : N/A
Fan tach3 : N/A
ShutDown Events : 0x0
Warning Input Events : 0x0
Warning Output Events : 0x0
Warning Env Events : 0x0
Status Register : N/A
Operating range : N/A
Max Power : N/A
Power supply: 1
Voltage (IN) : N/A
Voltage (12V) : N/A
Voltage (3V) : N/A
Current (IN) : N/A
Current (12V) : N/A
Current (3V) : N/A
Temperature 0 : N/A
Temperature 1 : N/A
Temperature 2 : N/A
Fan tach0 : 0 rpm
Fan tach1 : 0 rpm
Fan tach2 : 0 rpm
Fan tach3 : 0 rpm
Max Power : N/A
Power supply: 2
Voltage (IN) : N/A
Voltage (12V) : N/A
Voltage (3V) : N/A
Current (IN) : N/A
Current (12V) : N/A
Current (3V) : N/A
Temperature 0 : N/A
Temperature 1 : N/A
Temperature 2 : N/A
Fan tach0 : N/A
Fan tach1 : N/A
Fan tach2 : N/A
Fan tach3 : N/A
Max Power : N/A
Power supply: 3
Voltage (IN) : N/A
Voltage (12V) : N/A
Voltage (3V) : N/A
Current (IN) : N/A
Current (12V) : N/A
Current (3V) : N/A
Temperature 0 : N/A
Temperature 1 : N/A
Temperature 2 : N/A
Fan tach0 : 0 rpm
Fan tach1 : 0 rpm
Fan tach2 : 0 rpm
Fan tach3 : 0 rpm
Max Power : N/A
fex-1#
ucs-B# connect iom 1
fex-1#
fex-1#
Chassis settings:
pwrcap enabled
Blade 0:
Presence: PRESENT
Prio: 0
Blade 1:
Presence: ABSENT
Blade 2:
Presence: PRESENT
Prio: 0
Blade 3:
Presence: ABSENT
Blade 4:
Presence: PRESENT
Prio: 0
Blade 5:
Presence: ABSENT
Blade 6:
Presence: PRESENT
Prio: 0
Blade 7:
Presence: ABSENT
Total Input Power consumption: 2322
Total Output Power consumption: 2188
Power supply: 0
Voltage (IN) : 234 V
Voltage (12V) : 12082 mV
Voltage (3V) : 3367 mV
Current (IN) : 4984 mA
Current (12V) : 90250 mA
Current (3V) : 15 mA
Peak Current (IN) : 5140 mA
Peak Current (12V) : 92718 mA
Peak Current (3V) : 31 mA
Temperature 0 : 26 C
Temperature 1 : 0 C
Temperature 2 : 0 C
Fan tach0 : 5520 rpm
Fan tach1 : 0 rpm
Fan tach2 : 0 rpm
Fan tach3 : 0 rpm
Status Register : 0x30
Operating range : First
Max Power : 2500 W
Power supply: 1
Voltage (IN) : 236 V
Voltage (12V) : N/A
Voltage (3V) : N/A
Current (IN) : N/A
Current (12V) : N/A
Current (3V) : N/A
Temperature 0 : 24 C
Temperature 1 : 0 C
Temperature 2 : 0 C
Fan tach0 : 0 rpm
Fan tach1 : 0 rpm
Fan tach2 : 0 rpm
Fan tach3 : 0 rpm
Status Register : 0x1
Max Power : 2500 W
Power supply: 2
Voltage (IN) : 232 V
Voltage (12V) : 12070 mV
Voltage (3V) : 3363 mV
Current (12V) : 90968 mA
Current (3V) : 0 mA
Peak Current (12V) : 93984 mA
Peak Current (3V) : 0 mA
Temperature 0 : 25 C
Temperature 1 : 0 C
Temperature 2 : 0 C
Fan tach0 : 5790 rpm
Fan tach1 : 0 rpm
Fan tach2 : 0 rpm
Fan tach3 : 0 rpm
Max Power : 2500 W
Power supply: 3
Voltage (IN) : 238 V
Voltage (12V) : N/A
Voltage (3V) : N/A
Current (IN) : N/A
Current (12V) : N/A
Current (3V) : N/A
Temperature 1 : 0 C
Temperature 2 : 0 C
Fan tach0 : 0 rpm
Fan tach1 : 0 rpm
Fan tach2 : 0 rpm
Fan tach3 : 0 rpm
Max Power : 2500 W
fex-1#
Thank You,
Dan Laden
I have not be able to re-ack the blade.  How likely is it to resolve the issue?
I have this issue with only M4 blades.  The re-acknowledge is the only thing that seems to clear out the error.
flynmooney
Seeing this after trying out VMware DPM which uses IPMI to shutdown and start up blades.  Running 3.2.2f with B200M4 & M5.
