Fault and Logs clarification - Cisco Integrated Management Controller
QMUxer
We noticed we have an issue with faulty fans on a Cisco Integrated Management Controller. After reviewing the logs, I need some clarification on what fans are failing.
2024-09-06T11:01:20
 Critical
F0397
sys/rack-unit-1/fan-module-1-5/fan-2
performance-problem
MOD5_FAN2_SPEED: Fan speed for fan-10 is lower non recoverable : Check the air intake to the server
2024-09-06T11:01:20
 Critical
F0397
sys/rack-unit-1/fan-module-1-3/fan-2
performance-problem
MOD3_FAN2_SPEED: Fan speed for fan-6 is lower non recoverable : Check the air intake to the server
We replaced fans 2 and 6 per this notification we received via email from the controller
Server HostName:C220-WZP23300NTG
Severity: critical
Fault Code: F0397
Problem Cause: performance-problem
Entity DN: sys/rack-unit-1/fan-module-1-3/fan-2
Description: MOD3_FAN2_SPEED: Fan speed for fan-6 is lower non recoverable : Check the air intake to the server
PLATFORM:
CIMC Ver: 4.0(4b)
BIOS Ver: C220M5.4.0.4b.0.0407190256
I need some clarification on how to read this. From the data in the table I shared are the fans 5 and 3 need to be replaced or 10 and 6?
Thank you
Mark Elsen
  Ref : https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/sw/fault/reference/guide/Cisco_UCS_C-Series_Servers_CIMC_Faults/CIMC_Faults.html
           Start reading from : fltEquipmentFanPerfThresholdNonRecoverable
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
From the serial number you provided, it’s a UCS 220 M5 with 7 fans. According to the OP, there are issues with Modules 3 and 5. Please replace Fans 3 and 5 and check if that resolves the problem
Response Signature
Steven Tardy
UCS C-Series fan error messages are obtuse at best.
Each fan module has two spinning fans.
So divide the Alarm Description "fan-#" by two or only pay attention to the "MOD#".
Human comprehension Alarm DNs Alarm Description
Fan 1
sys/rack-unit-1/fan-module-1-1/fan-1
sys/rack-unit-1/fan-module-1-1/fan-2
MOD1_FAN1_SPEED: Fan speed for fan-1
MOD1_FAN2_SPEED: Fan speed for fan-2
Fan 2 sys/rack-unit-1/fan-module-1-2/fan-1
sys/rack-unit-1/fan-module-1-2/fan-2
MOD2_FAN1_SPEED: Fan speed for fan-3
MOD2_FAN2_SPEED: Fan speed for fan-4
Fan 3 sys/rack-unit-1/fan-module-1-3/fan-1
MOD3_FAN1_SPEED: Fan speed for fan-5
Fan 4 sys/rack-unit-1/fan-module-1-4/fan-1
sys/rack-unit-1/fan-module-1-4/fan-2
MOD4_FAN1_SPEED: Fan speed for fan-7
MOD4_FAN2_SPEED: Fan speed for fan-8
Fan 5 sys/rack-unit-1/fan-module-1-5/fan-1
MOD5_FAN1_SPEED: Fan speed for fan-9
Fan 6 sys/rack-unit-1/fan-module-1-6/fan-1
sys/rack-unit-1/fan-module-1-6/fan-2
MOD6_FAN1_SPEED: Fan speed for fan-11
MOD6_FAN2_SPEED: Fan speed for fan-12
Fan 7 sys/rack-unit-1/fan-module-1-7/fan-1
sys/rack-unit-1/fan-module-1-7/fan-2
MOD7_FAN1_SPEED: Fan speed for fan-13
MOD7_FAN2_SPEED: Fan speed for fan-14
