Firewall openings for Automatic Firmware Update Sync-ups from Cisco.com in UCS Central
Jonas T
I'm running UCS Central 1.4 and I want to activate Automatic Firmware Update Sync-ups. I've tried to make firewall openings to cisco.com but the log show a bunch of connections to akamai networks.
Does anyone have a list of required firewall openings to make the update service work? I havn't managed to find one (and I'm not allowed to make a general opening from this network).
Jonas
AFROJ AHMAD
Hi Jonas,
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/ucs-central/install-upgrade/1-3/b_Cisco_UCSC_Install_and_Upgrade_Guide_1-3/b_Cisco_UCSC_Install_and_Upgrade_Guide_1-3_chapter_011.html#reference_D4E8C86D189B45CBBA6D28AED51759BF
Communication between Cisco UCS Central and Client browser
The following ports must be open on Cisco UCS Manager. The ports are accessed by Cisco UCS Central to enable communication between Cisco UCS Central and the client browser:
Port Number
Daemon
Protocol
Usage
443
HTTPS_PORT
TCP
Enable communication from Cisco UCS Central to UCS domains. This port is always required.
80
HTTP
TCP
Communication from Cisco UCS Central to UCS domains with the Flash UI. This port can be configured using the Cisco UCS Central CLI.
Note
This port is not required if you are using the Cisco UCS Manager HTML5 UI.
Thanks-
Afroz
***Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Thanks for the reply, but that is not what I'm looking for. Client browser <-> UCS Central works fine. I'm looking for what IP's or URL's does Cisco use for UCS Central auto upgrade.
According to this link firewall needs to be opened for Cisco.com but that does not work for me and my firewall log show connections towards akamai networks.
Cheers,
Jonas
