Firmware Versions & B230M2 ESX5.5
CCertified85
Hi All,
I need to know from which link can i get versions of BIOS , CIMC , Host firmware packages versions ... I am making LLD so i need to include this information
Another question i have is that ..  I have M81KR with B230 M2  cisco compatibility matrix is not showing vsphere 5.5 supported but VMware website is showing supported ...
Please help me its urgent
CCertified85
Cisco and VMware website is showing that only OS is supported with UCS release 2.3.1  but Cisco matrix not showing compatible M81KR with ESXi5.5
Please help me
Syed,
Do you mean where you can download the BIOS and CIMC firmware? If so, that would be fromthe below link for example :
http://software.cisco.com/download/release.html?mdfid=283853163&flowid=25821&softwareid=283655681&release=2.2%281b%29&relind=AVAILABLE&rellifecycle=&reltype=latest
Now, the host firmware package is a Policy you define in UCSM, not something that can be downloaded.
From here
http://www.cisco.com/web/techdoc/ucs/interoperability/matrix/matrix.html you can see the b230-M2 compatible with ESXi 5.5 if using UCSM version 2.1(3x).
-Kenny
Hi Keny..
I mean to say i need below information ... from where i can get this ?
Adapter
Cisco    Systems
UCS    M81KR
2.1.1f
Server BIOS
Cisco Systems
UCS B230 M2
B230.2.0.1d.0.111620111513
Board Controller
Cisco Systems
B230-BASE-M2
B230100C
RAID Controller
LSI Logic – Symbios Logic
LSI MegaSAS 9260
12.12.0-0050|3.22.00|NA
Moreover I know that B230M2 can support ESXi 5.5 but   the website u mentioned does not include M81KR CNA
I want to M81KR is compatible with ESXi5.5 or not ?
