GLC-T Connector in nexus 5549
Mohsin Hussain
Hello everyone,
I have configured the Nexus speed at 1000 speed. SFP is GLC-T . As you can see below the SFP is model number GLC-T. It is supported on the Nexus 5549UP.
Also set duplex to auto on interface but no luck,still getting not connected issue,name is also OEM not Cisco and serial also why ??
NOTE: this problem is happening on 10 new SFP , no a single SFP working
!Command: show running-config interface Ethernet1/38
!Time: Wed Nov 28 16:14:18 2012
version 5.1(3)N2(1)
speed 1000
  duplex full
Switch# show  int ethernet 1/38 transceiver details
Ethernet1/38
    transceiver is present
    type is SFP-1000BASE-T
    name is OEM
    part number is GLC-T
    revision is 03
    serial number is M0312040106
    nominal bitrate is 0 MBit/sec
    Link length supported for copper is 100 m
    cisco id is --
    cisco extended id number is 4
Switch# show int eth 1/38
Ethernet1/38 is down (Link not connected)
  Hardware: 1000/10000 Ethernet, address: 547f.ee83.08ad (bia 547f.ee83.08ad)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec
  Encapsulation ARPA
  Port mode is access
  full-duplex, 1000 Mb/s, media type is 10G
  Beacon is turned off
  Input flow-control is off, output flow-control is off
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  Last link flapped never
  Last clearing of "show interface" counters 00:03:17
  30 seconds input rate 0 bits/sec, 0 packets/sec
  30 seconds output rate 0 bits/sec, 0 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
  RX
    0 unicast packets  0 multicast packets  0 broadcast packets
    0 input packets  0 bytes
    0 jumbo packets  0 storm suppression bytes
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
Eth1/37       --                 sfpAbsent 1         full    10G     --
Eth1/38       --                 notconnec 1         full    1000    SFP-1000BAS
Eth1/39       --                 sfpAbsent 1         full    10G     --
0 Replies 0
