High Fan Speed after Upgrade from 1.4(7c) to 1.5(1f)
Nico Bellack
after Upgrading the Firmware from 1.4(7c) to 1.5(1f) via HUU on my two C220M3 the speed of all fan is higher than before (8500-9000 RPM).
Is this normal?
the servers are very noisy.
best regards
Nico
padramas
Hello Nico,
Yes, it is normal in 1.5.1f version as we have increased the FAN speed to work around known issues.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCue68150
The next major release of firmware will accommodate additional logic that drive down the FAN speeds.
Padma
padramas
Hello Nico,
Padma
Hello Padma,
thx for ur help.
best regards
Nico
Hello Padma,
When can we expect this major release I have 1.5.1j? The server is still noisy and the fun speed is around 9500.
Best Regards,
Bojan
