How do I see power draw per chassis/UCS?
v-crsimp
How do I see power draw per chassis in the UCSM?
Also is there a way to see a SUM of that per UCS?
Thanks!
Craig
2 Accepted Solutions
Eric Rose
Hi Craig,
You can browse to chassis #x in the left pane -> Statistics(or power) tab. When you expand the power counter this will provide the chassis power draw. you can then expand down to a single blade as well.
For the sum - you can look under equipment -> policies -> power group. If you never created any power capping group the default group will list the total power consumed.
Thanks.
Eric Rose
chrisb2
You can see the power draw of an indiviual chassis by navigating to the Statistics tab of the chassis.  The first line item there should be "Power Counters."
Expand out that to see the current, average, maximum, and minium output power seen so far (the input power is seen there too)
Eric Rose
Hi Craig,
Thanks.
Eric Rose
chrisb2
v-crsimp
Thanks all very much, that was the trick.
Craig
