08-12-2011 12:42 PM - edited 03-01-2019 10:01 AM
How do I see power draw per chassis in the UCSM?
Also is there a way to see a SUM of that per UCS?
Thanks!
Craig
Solved! Go to Solution.
08-12-2011 12:53 PM
Hi Craig,
You can browse to chassis #x in the left pane -> Statistics(or power) tab. When you expand the power counter this will provide the chassis power draw. you can then expand down to a single blade as well.
For the sum - you can look under equipment -> policies -> power group. If you never created any power capping group the default group will list the total power consumed.
Thanks.
Eric Rose
08-12-2011 12:58 PM
You can see the power draw of an indiviual chassis by navigating to the Statistics tab of the chassis. The first line item there should be "Power Counters."
Expand out that to see the current, average, maximum, and minium output power seen so far (the input power is seen there too)
08-12-2011 12:53 PM
Hi Craig,
Thanks.
Eric Rose
08-12-2011 12:58 PM
08-12-2011 05:02 PM
Thanks all very much, that was the trick.
Craig
