01-18-2020 10:10 PM - edited 01-18-2020 10:10 PM
Hi Experts,
I'm familiar with the way HA works with UCS B-Series Chassis - the Chassis has a SEEPROM that stores the cluster state which both Fabric Interconnects can see (and write to)
But how does HA work if you have only C-Series Blade servers attached, such as a Hyperflex CLuster?
I will assume that the Cluster State is written to one of servers (which one? the first one discovered???) but where? I imagine it has to be some FLASH somewhere, and I'm guessing the logical answer is the CIMC configuration storage.
But I'm only guessing.
Can anyone confirm this, or point me to a reference that explains it?
Solved! Go to Solution.
01-18-2020 10:47 PM
01-18-2020 10:47 PM
