06-07-2017 01:39 PM - edited 03-01-2019 01:12 PM
Hi!
in the same chassis, with two different servers (B230 M2), it could has different mezzanine cards?
i've already checked the version and there is no problem there, but i don't know if this is possible.
Thanks in advance
kind reggards
Solved! Go to Solution.
06-07-2017 01:54 PM
If you are asking if it is possible to have two B230-M2 with different adapters, the answer is yes.
Based on the spec sheet, these are the possible adapters:
06-07-2017 01:54 PM
