installing 2nd power supply in C210 M1 - downtime needed ?
todjohns
I have several UCS C210 M1 servers that have just one power supply, I need to install a second one.   Will I need to shut down the servers to install the second power supply?
I found details on installing them here...
http://www.cisco.com/en/US/docs/unified_computing/ucs/c/hw/C210M1/install/replace.html
and see that they're hot pluggable but it's not clear if downtime is required to install a second pwr supply.  I'm thinking it may be needed so that the system boots with two power supplies and is then aware of that configuration.
Todd
simon.geary
You don't need to power off the server to install the second power supply.
simon.geary
