IOM connecting FI error - Fabric unsupported connection
KS Lim
Hi Guys,
Not sure if anyone face the same scenario with me.
I have a B series Chassis with two IOM card ( model : 2208XP) which is 8 external port / 10Gb.
while the bundle come with 8 10Gbase-CU cables, I connect the first 4 port on IOM-1 to Fi-A and first 4 port on IOM-2 to FI-B
IOM1      FI-A
1               Port 1
2               Port 2
3               Port 3
4               Port 4
IOM2      FI-B
1               Port 1
2               Port 2
3               Port 3
4               Port 4
However base on my observation the server port role works fine on IOM1 - FI-A
on IOM 2 we can only see fabric 2/1 to 2/3 ( 3 link) while the Led light on 2/4 is up but not shown in UCS manager.
There is also a major error message :
iom1/2 current connectivity does not match discovery policy or connectivity is unsupported
I also tried to access NXOS in the FI and notice that the port is up, show port-channel summary tell me 4 port channel are up.
Please refer to the attachment for screenshot.
8 Replies 8
padramas
Please provide the following output
connect nxos b
show fex
show int fex
show run int eth 1/23 - 25
If they are not in production, can you try re-acknowledging the chassis ?
Padma
Manuel Velasco
Hi Ks,
How are you? Did you make sure port 26 (or the fourth port )on fabric B is configure as server port?  If you configured it as an uplink or something else and there is a link between them the port is going to show as UP, so make sure it is a server port.
The reason you are getting the error message is because you have ports that are un acknowledge (see ucsiom.jpg) to resolve this issue you have  to re-ack your chassis.  I recommend that before you re-ack your chassis you make sure that all ports are configure properly.  Otherwise you may have to re-ack the chassis multiple times. When you re-ack you chassis, it will bring the connectivity down for some time, so make sure to schedule a maintenance window during this time.
Please try this and let me know if it helps.
Hi Manuel. I'm facing the same problem, only one question for you.  What exactly does a reack of the chassis? It will reboot all the server in the chassis? The only thing that will be affected is the connectivity?
Best regards.
Hi Samuel,
The re-ack of the chassis does not reboot the servers in the chassis it will only bring donw the connectivity of the servers for sometime.
thanks for the replky Manuel, can you tell for how long the downtime will be?
Hi Samuel,
I don’t have specific numbers but it should be down for a short time.
Manuel Velasco
Hi Ks,
I was just wondering if you were able to try what we proposed.
KS Lim
Hi Manuel,
sorry for the late response. I tried to re-ack the chassis multiple time but not help.
Not sure why the fourth port is not able to configured into fex mode, although it is serverport in UCSM
UCS-FABRIC-A-B(nxos)# show fex
  FEX         FEX           FEX                       FEX
Number    Description      State            Model            Serial
  1        FEX0001                Online           N20-C6508   FCH17327EPD
UCS-FABRIC-A-B(nxos)# show int fex
     Fabric      Fabric       Fex                FEX
Fex  Port      Port State    Uplink    Model         Serial
  1   Eth1/23        Active     1         N20-C6508  FCH17327EPD
  1   Eth1/24        Active     2         N20-C6508  FCH17327EPD
  1   Eth1/25        Active     3         N20-C6508  FCH17327EPD
UCS-FABRIC-A-B(nxos)# show run int eth 1/23 - 26
!Command: show running-config interface Ethernet1/23-26
!Time: Wed Jan  8 03:27:19 2014
version 5.0(3)N2(2.11.3a)
  description S: Server
  no pinning server sticky
  switchport mode fex-fabric
  fex associate 1 chassis-serial FOX1734GBBQ module-serial FCH17327EPD module-slot right
  no shutdown
interface Ethernet1/24
  no shutdown
interface Ethernet1/25
  no shutdown
interface Ethernet1/26
  switchport mode trunk
  no shutdown
