ldap problem with UCSM2.1 to get roles
I tried to configure an ldap authentification on UCSM2.1. My connexion is OK but I can't get the "role" of my user. To finish my role is Read-only.
When I test as :
     UCSM01-B(nxos)# test aaa server ldap  <ldapserver> <user> <password>
     user has been authenticated
... but i haven't an answer :
Attributes downloaded from remote server:
User Groups:
CN=ucsadmin,OU=CiscoUCS,DC=sampledesign,DC=com
Roles:
admin
Of course, i defined group maps.
Thank you for your help.
Stéphane
Brian Morrissey
Hi Stéphane,
Make sure you have a group map defined and "Group Authorization" is enabled under the ldap provider settings.  Once these are both set you should see the roles when doing a test aaa server ldap.
Thank you Brian for your help.
Group maps are defined and Group Authorization is enabled.
But i just discover the "debug ldap all" command, and now i can see the exaclty DN is waiting,  in my complex org ldap enterprise.
My DN in group maps contained mistake, and now all is ok .
Thank you.
