ā04-27-2017 02:49 AM - edited ā03-01-2019 01:09 PM
Hello Guys,
Need you expert comments on one of the doubt i have came across.
This is regarding out-of-band (OOB) IPv4 address assigned directly to the Blade server
or IPv4 address assigned thro service profile from global ext-mgmt pool.
My question is, in one of my environment blade servers are getting CIMC IP directly to the Blade server and thro service profile as well.
Means to say that by both the way B series server are getting IP. But when i am trying to access the KVM console it is going on CIMC IP of service profile.
Is Service Profile IP assignment overriding blade server CIMC IP assignment.
Is this the correct behavior or correct setting. Whats the best practice.
Is it possible to assign CIMC IP from Service profile only?? only means only :).
Cheers
Andy !!
Solved! Go to Solution.
ā04-27-2017 04:20 AM
Hi Andy
By default, each blade in a slot gets an IP address from the pool, independent if a service profile is associated or not. This is the CIMC IP address.
Caveat: if you move a SP from one blade to another, the CIMC address will change.
Therefore you have the option to assign an IP address (from the same pool) to a service profile, which has precedence over the one assigned by the slot. Moving the service profile doesn't change the CIMC IP address.
Caveat: you need more IP address's.
Yes
IP address assigned to SP makes sense, if you want eg. a static DNS entry for the CIMC management
No
Hi Andy
Yes
No
ā04-27-2017 05:04 AM
Thank You Walter for this nice clarification !!
