09-15-2016 05:14 AM - edited 03-01-2019 12:53 PM
Hello Team,
I am planing to upgrade CISCO MDS 9148 software from 5.0(xx) to 6.2 (xx) which is running with Cisco UCSM version running 2.2(6x).
Is there any compatibility matrix available to check the compatibility between MDS and UCSM. management software.
09-15-2016 05:39 AM
see eg.
http://www.cisco.com/c/dam/en/us/td/docs/unified_computing/ucs/interoperability/matrix/b_hcl_B_rel3-11.pdf
and
http://www.cisco.com/c/en/us/support/servers-unified-computing/unified-computing-system/products-technical-reference-list.html
09-15-2016 05:48 AM
Thank You Walter for your swift reply!!
I have already gone through these links but no avail.
Could you please locate specific index which i can refer.
09-15-2016 06:59 AM
Table 10 of
MDS 9100, 9200,9500 Series: 4.2.1. 1,2,9,15
Notes
1 Code levels greater than or equal to these listed versions are deemed by Cisco to be interoperable
