Multicast / IGMP Snooping Issues / Red Hat 6.2
stevecuddy
I'm having an issue with a redhat 6.2 cluster installation and I know it's down to the IGMP Snooping on the Fabric Interconnect.
I've read all the forums and support but I'm still having issues and could do with an IGMP wizard to give me a bit of advice.
Basically (Red Hat 6.2 - B200M2 - 6248UP - Juniper 4200)
I'm using a IGMP Querier rather than a router but I don't see it....
CLUSTER-01-A(nxos)# sh ip igmp snooping querier
Vlan  IP Address       Version   Expires     Port
CLUSTER-01-A(nxos)#
The group seems to be being created.....
Vlan  Group Address      Ver  Type  Port list
3205  239.192.104.179    v2
CLUSTER-01-A(nxos)#
Other info............
CLUSTER-01-A(nxos)# sh ip igmp snooping vlan 3205
IGMP Snooping information for vlan 3205
  IGMP snooping enabled
  Optimised Multicast Flood (OMF) disabled
  IGMP querier none
  Switch-querier disabled
  IGMPv3 Explicit tracking enabled
  IGMPv2 Fast leave disabled
  IGMPv1/v2 Report suppression enabled
  IGMPv3 Report suppression disabled
  Link Local Groups suppression enabled
  Router port detection using PIM Hellos, IGMP Queries
  Number of router-ports: 0
  Number of groups: 1
  Active ports:
    Eth1/13     Veth1548        Veth1536        Veth1558
    Veth1561    Veth1616        Veth1619        Veth1604
    Veth1522
CLUSTER-01-A(nxos)#
CLUSTER-01-A(nxos)# sh ip igmp snooping statistics vlan 3205
Global IGMP snooping statistics:
  Packets received: 2257
  Packet errors: 0
  Packets for non-snooped vlans : 0
  Packets flooded: 4
  vPC PIM DR queries sent: 0
  vPC PIM DR queries rcvd: 0
  vPC PIM DR queries fail: 0
  vPC PIM DR updates sent: 0
  vPC PIM DR updates rcvd: 0
  vPC PIM DR updates fail: 0
  vPC CFS send fail: 0
  vPC CFS message response sent: 0
  vPC CFS message response rcvd: 0
  vPC CFS message response fail: 0
  vPC CFS message response fail peer-link down: 0
  vPC CFS unreliable message sent: 0
  vPC CFS unreliable message rcvd: 0
  vPC CFS unreliable message fail: 0
  vPC CFS reliable message sent: 0
  vPC CFS reliable message rcvd: 0
  vPC CFS reliable message fail: 0
  STP TCN messages rcvd: 2
  IM api failed: 0
  MFDM download requests received: 0
  MFDM download complete sent: 0
  Packets errors (invalid iod): 0
  MFDM downgrade complete sent: 0
  Number of buffers sent to MFDM: 0
  Number of buffer acks received from MFDM: 0
VLAN 3205 IGMP snooping statistics, last reset: never
  Packets received: 1430
  IGMPv1 reports received: 0
  IGMPv2 reports received: 9
  IGMPv3 reports received: 1417
  IGMPv1 queries received: 0
  IGMPv2 queries received: 2
  IGMPv3 queries received: 0
  IGMPv2 leaves received: 2
  PIM Hellos received: 0
  Invalid reports received: 1021
  Invalid queries received: 0
  IGMPv1 reports suppressed: 0
  IGMPv2 reports suppressed: 1
  IGMPv2 leaves suppressed: 0
  IGMPv3 group records suppressed: 998
  Queries originated: 0
  IGMPv2 proxy-reports originated: 0
  IGMPv2 proxy-leaves originated: 0
  IGMPv3 proxy-reports originated: 0
  Packets sent to routers: 0
  STP TCN received: 0
  VIM IGMP leave sent on failover: 1
  Report version mismatch: 66
  Unknown packets received: 0
  vPC Peer Link CFS packet statistics:
      IGMP packets (sent/recv/fail): 0/0/0
      MRD updates (sent/recv/fail): 0/0/0
CLUSTER-01-A(nxos)#
Also the group seems to be created as V2 yet the reports from the VMs are V3 and my querier is V3.
I'm also seeing lots of invalid reports and supressed records.
Any help appreciated.
Steve.
0 Replies 0
