09-10-2011 08:00 PM - edited 03-01-2019 10:03 AM
Is it possible to have servers connect by FCoE to nexus 5000 switches as well as native FC attached disk arrays and tape librarys without requiring an additional FC switch like the MDS 9000? The reason I ask is that all the diagrams I have seen on consolidated I/O to this point show MDS switches connected to the native FC ports on the nexus 5000. I had assumed the Nexus 5000 would be able to replace the MDS attaching both FCoE devices and native Fiber Channel devices. Not seeing such a diagram has me second guessing my initial thinking.
Solved! Go to Solution.
09-12-2011 07:20 AM
Yes, you can use FCoE and FC of Nexus 5000 for connecting to arrays. I tested and works fine without any issue.
For FCoE you should have FCoE module in arrays and appropriate licence.
Ram
09-12-2011 07:20 AM
Ram
09-12-2011 07:29 AM
ram,
Thank you for the reply. Just to verify, are you saying that you can have servers and arrays connected to the Nexus 5000 either through FCoE or FC and would not require an external FC switch like the MDS 9000 or Brocade? Would the Nexus 5000 act as the FC switch in this scenario for zone configuration and all the other FC switch functions? Sorry, I'm not quite up to speed on storage terminology at this point. Your reply is greatly appreciated.
Mark
09-12-2011 08:36 AM
Mark,
That is correct. You will need to run the N5K in "switch" mode (rather than npv mode) which will enable the FC services such as name server, zoning etc, which will function as your FC switching device.
More information here:
Robert
09-12-2011 09:56 AM
Robert,
Thanks for the confirmation. The link was forbiden for me. Do you have a link that will work for the average joe?
Mark
09-12-2011 12:30 PM
Sorry about that, I've updated the link above, you can use it now.
Let me know if you have any other questions.
Robert
09-12-2011 01:12 PM
Robert,
Still got a forbidden message.
Mark
09-12-2011 01:23 PM
09-12-2011 01:24 PM
Got it. Thanks much.
Mark
04-27-2017 10:10 AM
Hello guys.
Could you confirm that you are talking about scenario like below? And if it works?
04-27-2017 10:10 AM
Yes this is the scenario we were discussing. Below is additional information from Robert.
04-27-2017 10:50 AM
I hope you tested it as well then.
Like a summary. In order to get scenario like on attached diagram we need Cisco Nexus 5k:
- N5K FC "switch mode" enabled
- FCoE module and license installed
- correct N5k config
Do you have any config sample that you can share maybe for this particular scenario as a quick start guide?
Thank you!
04-27-2017 10:59 AM
This will work. You may also choose to run native FC between the servers and the N5K, unless cabling consolidation is the means for choosing FCoE.
Wes
04-27-2017 11:04 AM
"cabling consolidation is the means for choosing FCoE"
Yes, this is the reason.
I understand that in FC only "switch mode" I can archive FC-N5K-FC connectivity but FC-N5K-FCoE scenario with N5K "switch mode" concerns me.
