Nexus module N77-F348XP-23 firmware problems
Tomasz Truty
H,
I hope you had great Christmas time! I'm currently working on the new Nexus lab and I have one challenge.
I'm trying to get 1/10 Gbps Ethernet Module up and running. Do you know where firmware is located for this modules and how to set boot variable for it? What I get so far:
show module:
Mod Ports Module-Type Model Status
1 48 1/10 Gbps Ethernet Module N77-F348XP-23 ok
2 48 1/10 Gbps Ethernet Module N77-F348XP-23 powered-dn !! this one I'm having problem with
3 0 Supervisor Module-2 N77-SUP2E active *
4 0 Supervisor Module-2 N77-SUP2E ha-standby
when I'm trying to power it on by entering
(config)# no poweroff module 2
I'm getting following logs:
2015 Dec 16 00:38:23 xxx %PLATFORM-2-MOD_DETECT: Module 2 detected (Serial number JAE19290A6J) Module-Type 1/10 Gbps Ethernet Module Model N77-F348XP-23
2015 Dec 16 00:38:23 xxx %PLATFORM-2-MOD_PWRUP: Module 2 powered up (Serial number JAE19290A6J)
2015 Dec 16 00:38:23 xxx %PLATFORM-5-MOD_STATUS: Module 2 current-status is MOD_STATUS_POWERED_UP
2015 Dec 16 00:40:02 xxx %BIOS_DAEMON-SLOT2-5-BIOS_DAEMON_LC_PRI_BOOT: System booted from Primary BIOS Flash
2015 Dec 16 00:40:05 xxx %FW_APP-SLOT2-2-FIRMWARE_IMAGE_LOAD_ERROR: Firmware extraction and load error: Flash and software firmware images are bad
2015 Dec 16 00:40:06 xxx %MODULE-2-MOD_FAIL: Initialization of module 2 (Serial number: JAE19290A6J) failed
2015 Dec 16 00:40:06 xxx last message repeated 1 time
2015 Dec 16 00:40:06 xxx %PLATFORM-2-MOD_PWRDN: Module 2 powered down (Serial number JAE19290A6J)
2015 Dec 16 00:40:06 xxx %PLATFORM-5-MOD_STATUS: Module 2 current-status is MOD_STATUS_CONFIGPOWERED_DOWN
2015 Dec 16 00:40:06 xxx %PLATFORM-5-MOD_STATUS: Module 2 current-status is MOD_STATUS_POWERED_DOWN
I take the problem is with firmware, but I can't locate the path for it. There is no boot variable set for either module 1 nor 2, but module 1 booted without issues.
xxx# show boot module 1
No module boot variable set
xxx# show boot module 2
I can see bin files under
xxx# cd bootflash://module-4/
bootflash://module-4/20150808_221923_poap_7580_init.log bootflash://module-4/vdc_3
bootflash://module-4/20151211_010151_poap_8037_init.log bootflash://module-4/vdc_4
bootflash://module-4/20151211_015441_poap_7723_init.log bootflash://module-4/vdc_5
bootflash://module-4/lost+found bootflash://module-4/vdc_6
bootflash://module-4/n7700-s2-dk9.6.2.12.bin bootflash://module-4/vdc_7
bootflash://module-4/n7700-s2-kickstart.6.2.12.bin bootflash://module-4/vdc_8
bootflash://module-4/scripts bootflash://module-4/vdc_9
bootflash://module-4/vdc_2
but I'm not able to set boot variable to module, I can see sup-1 and sup-2 only
xxx(config)# boot system bootflash://module-4/n7700-s2-dk9.6.2.12.bin ?
<CR>
sup-1 Enter sup-1 to configure the 1st sup
sup-2 Enter sup-2 to configure the 2nd sup
I hope you would be able to help!
Happ New Year as well! :)
Wes Austin
Did you get these linecards at the same time? I see that module 1 is same model and not having issues. Have you opened a TAC SR for the same? I have seen some similar instances where these messages could be result of bad hardware, but you may want to open a TAC case to investigate further.
HTH,
Wes
Wes Austin
HTH,
Wes
Hi Wes,
Thank you for quick answer!
Yes both cards where delivered at the same time, but only one booted correctly. I didn't open a TAC SR yet, as agreement is still processing... It looks to me as something very basic missing like boot path or IOS .bin file. Is there anything else I could check before opening SR / hardware replace? Nexus architecture is still something new for me
Thanks!
Hello Tomasz,
I was wondering if you ever got this to work or not? I am seeing the same error on same type of cards.
Chris
******* I worked with TAC and it is a confirmed bug. You will have to either upgrade to 7.x track or work with TAC and get a specific file to upgrade module. *******
