Nexus - UCS FI vPC connection channel mode mismatch.
brucesheppard
When trying to connect a vpc from a nexus 5548up to a UCS FI I get this error.  Any suggestions ?
(config-if)# sh vpc consistency-parameters vpc 20
    Legend:
        Type 1 : vPC will be suspended in case of mismatch
Name                        Type  Local Value            Peer Value
Shut Lan                         1     No                     No
STP Port Type               1     Edge Trunk Port        Edge Trunk Port
STP Port Guard                   1     None                   None
STP MST Simulate PVST       1     Default                Default
mode                             1     on                     active
Speed                       1     10 Gb/s                10 Gb/s
Duplex                      1     full                   full
Port Mode                   1     trunk                  trunk
Native Vlan                 1     1                      1
MTU                         1     1500                   1500
Admin port mode             1
lag-id                      1     -                      [(7f9b,
                                                         0-23-4-ee-be-1, 8014,
                                                         0, 0), (8000,
                                                         54-7f-ee-99-6e-c1, 13,
                                                          0, 0)]
Allowed VLANs               -     200-204,213,216-219,23      200-204,213,216-219,23
                                  0,232-233,399                              0,232-233,399
Local suspended VLANs       -  200-204,213,216-219,23 -
                                  0,232-233,399
(config-if)# sh vpc
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                     : 1
Peer status                       : peer adjacency formed ok
vPC keep-alive status             : peer is alive
Configuration consistency status  : success
Per-vlan consistency status       : success
Type-2 consistency status         : success
vPC role                          : primary, operational secondary
Number of vPCs configured         : 1
Peer Gateway                      : Disabled
Dual-active excluded VLANs        : -
Graceful Consistency Check        : Disabled
Auto-recovery status              : Disabled
vPC Peer-link status
id   Port   Status Active vlans
1    Po10   up     1
vPC status
id     Port        Status Consistency Reason                     Active vlans
20     Po1         up     failed      vpc port channel mode      -
                                      mismatch
billjoh
You have LACP on one PO and the other is static..
mode        on      active
