04-09-2020 04:59 PM - edited 04-09-2020 08:09 PM
Hello all
Suddenly, I turn on my cisco c220 m3 server and this light came up on. I can not plug any cable, USB, or even VGA nothing works but it turns on.
The orange light on d38 r1075
Please see the attached Pic.
Any idea of the problem?
04-14-2020 09:57 AM
Greetings.
Since the DIMM LED is lit up, I would removing all but the minimum required DIMMs (usually one per processor).
Please keep track of which DIMM was in which slot originally.
I would start by removing all but DIMM in slot A1, and E1.
If the system is still in same situation, then swap DIMMs A1 and E1 with other DIMMs.
If this does not have positive impact, then please check/reseat all riser cards, and make sure CPUs are seated firmly.
If no progress, please remove any PCI-E cards including raid controller (if present)
Did you ever configure the CIMC? It would be very helpful as it would show the SEL logs, and possibly more details of the failure.
Kirk...
