Pinging a public IP address from an ESXi shell
leam2
Hello.
My question is about pinging a public IP address from an ESXi shell.
The context is the following:
- a Cisco ISR4331,
- a NIM E-Series NCE (UCSE) module inside the ISR4331,
- a VMware ESXi host installed on the UCSE.
Some configuration from the ISR4331:
interface GigabitEthernet0/0/1.60
 encapsulation dot1Q 60 native
 ip address 192.168.3.1 255.255.255.0
interface ucse0/1/0
 ip unnumbered GigabitEthernet0/0/1.60
 no negotiation auto
 switchport mode access
interface ucse0/1/1
 no ip address
 shutdown
 no negotiation auto
! ucse subslot 0/1
 imc access-port shared-lom console
 imc ip address 192.168.3.61 255.255.255.0 default-gateway 192.168.3.1
! ip route 192.168.3.61 255.255.255.255 ucse0/1/0
ip route 192.168.3.62 255.255.255.255 ucse0/1/0
Pinging the CIMC interface (192.168.3.61) and the ESXi vmk0 interface (192.168.3.62) from the ISR4331 works:
isr4331(config)# do ping 192.168.3.61
Sending 5, 100-byte ICMP Echos to 192.168.3.61, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 2/2/5 ms
isr4331# ping 192.168.3.62
Sending 5, 100-byte ICMP Echos to 192.168.3.62, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
Some commands output from the ESXi shell:
esxi_shell# esxcli network ip interface ipv4 get
Name  IPv4 Address  IPv4 Netmask   IPv4 Broadcast  Address Type  DHCP DNS
vmk0  192.168.3.62  255.255.255.0  192.168.3.255   STATIC           false
esxi_shell# ping 192.168.3.1
PING 192.168.3.1 (192.168.3.1): 56 data bytes
64 bytes from 192.168.3.1: icmp_seq=0 ttl=255 time=1.261 ms
64 bytes from 192.168.3.1: icmp_seq=1 ttl=255 time=0.715 ms
64 bytes from 192.168.3.1: icmp_seq=2 ttl=255 time=0.826 ms
--- 192.168.3.1 ping statistics ---
3 packets transmitted, 3 packets received, 0% packet loss
round-trip min/avg/max = 0.715/0.934/1.261 ms
esxi_shell# ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8): 56 data bytes
--- 8.8.8.8 ping statistics ---
3 packets transmitted, 0 packets received, 100% packet loss
I can ping the gateway (192.168.3.1) from the ESXi shell.
But I cannot ping any external address (like for instance Google's IP address 8.8.8.8).
Can you please help me find out what's wrong in my configuration?
Thank you and best regards.
Wes Austin
Have you tried a traceroute to see where the traffic is getting dropped?
Hello.
esxi_shell# traceroute 8.8.8.8
traceroute to 8.8.8.8 (8.8.8.8), 30 hops max, 40 byte packets
 1  192.168.3.1 (192.168.3.1)  0.811 ms  0.209 ms  0.193 ms
 2  * * *
30 times
Thanks.
Hello.
And from the ISR4331:
isr4331# traceroute 8.8.8.8
Tracing the route to google-public-dns-a.google.com (8.8.8.8)
VRF info: (vrf in name/id, vrf out name/id)
  1 80.10.115.222 11 msec 10 msec 11 msec
  2 10.123.205.206 11 msec
    10.123.205.202 11 msec
    10.123.205.206 10 msec
  3 ae42-0.niidf301.Paris15eArrondissement.francetelecom.net (193.252.159.149) 10 msec
    ae42-0.niidf302.Paris13eArrondissement.francetelecom.net (193.252.159.153) 13 msec
    ae42-0.niidf301.Paris15eArrondissement.francetelecom.net (193.252.159.149) 11 msec
  4 193.252.137.78 14 msec 16 msec
    ae40-0.niidf302.Paris13eArrondissement.francetelecom.net (193.252.103.38) 11 msec
  5 193.252.137.78 14 msec 13 msec 16 msec
  6  *  *
    72.14.219.114 11 msec
  7 209.85.251.146 13 msec
    66.249.95.102 11 msec *
  8 108.170.231.5 11 msec
    108.170.238.106 12 msec
    66.249.94.177 12 msec
  9 google-public-dns-a.google.com (8.8.8.8) 11 msec
    108.170.231.3 12 msec
Thank you.
