03-08-2019 07:32 AM
Dears,
I have 2 no's of Fabric Interconnect and from each FI i have 2 no's of connection to 2 no's of core switches 6509 ( in VSS) , My port channeling is not coming up,on the switch end i see the the bundle is in waiting state but from FI end i dont know how to check the status, the same connection i have done with nexus 7000 switches it works fine but i m facing difficulties with 6509,
how i should troubleshoot this problem.
03-08-2019 08:59 AM
Suggest to post the configuration and any logs
look at good thread for the same :
03-08-2019 12:18 PM
Dear Balaji,
the link above doesn't say about troubleshooting only it mentioned that we can connect, that i also know by logic that we can connect but the port channel is not coming up, what can be the reason ??
i don't have logs to share and what logs i have to collect from FI please suggest.
03-09-2019 06:01 AM
we can virtually think what is configured until you post config and what steps you followed. based on the input we can suggest what is to be done to test and fix the issue if we can.
03-10-2019 10:59 AM - edited 03-10-2019 11:01 AM
It would be helpful if you pasted the #show run int .... for both the interfaces and the port-channels on both the 6500 and the UCSM FIs.
Also do a #show int eth x/y transceiver details as well as
#show int eth x/y for any of the interfaces involved in the port-channels in question.
Kirk...
03-14-2019 02:40 AM
Dears
The configuration are very similar as per the cisco guide,
int range 1/1/1-2, int 2/1/1-2
switchport mode trunk
channel-group 100 mode active
int po100
The strange thing is ports on Core 1 are formed with ether channel but the ports on core switch 2 is in waiting stage.
