Problemas en un virtual drive en un Cisco UCS c220 M4, esta offline
Buenas
Luego de un de un apagado abrupto el servidor muestra un virtual drive offline y por ende el vmware no inicia:
En esta server sobre el vmware corren 4 maquinas virtuales criticas como por ejemplo el call manager CUCM, me pueden ayudar a lograr levantar de nuevo este servicio? sin que las maquinas virtuales sufran alguna afectacion, gracias.
5 Replies 5
Kirk J
Kirk...
Entiendo,  con la primera opción de tratar de colocar online una de las 2 unidades que resultados tendria? el VMware lograria levantar?
Por otro lado me comentas de comprar mas unidades fisicas, pero las unidades fisicas no las tengo alarmadas estan los leds en verde, pareciera mas bien un tema de las unidades virtuales, por favor corrigeme si estoy equivocado y gracias.
Tendras algun procedmiento para intentar poner en onnline el Virtual Drive?
The screen captures you included show the physical drives 5 & 7 as missing, which is why the virtual drive is offline.
If you haven't done so already, you may want to power cycle the server.
The Webbios utility wasn't typically used in the 12Gb controllers, so I 'm thinking maybe you have a M3 server that used the 9200 series of LSI controllers.
It's possible you have an issue with either a raid controller or SAS backplane.
There's a lot more going on in your case than can be effectively troubleshot over public forum posts.
If you have the ability to open a TAC case, please do so.
In the LSI Webbios utility, there is an option to 'replace'/insert a drive back into the 'missing' drive location, but we would really need to look at logs and confirm that raid controller and backplane is healthy before doing that.
If you can actually get the physical drives to show online, and the virtual drive doesn't import them back in, shows them as foreign config, unconfigured good, etc,,,, then it may be possible to clear the config off the other drives, and re-create the array (with exact same settings i.e. raid 5, same stripe size) WITHOUT init'ing, and many times the underlying data will still be there as the virtual drive recreation (without initing) is just rewriting meta data.
You really need a TAC case at this point.
Kirk...
Las capturas de pantalla que incluyó muestran que faltan las unidades físicas 5 y 7, razón por la cual la unidad virtual está fuera de línea.
Si aún no lo ha hecho, es posible que desee apagar y encender el servidor.
La utilidad Webbios no se usaba normalmente en los controladores de 12 Gb, por lo que creo que quizás tenga un servidor M3 que usa la serie 9200 de controladores LSI.
Es posible que tenga un problema con un controlador RAID o un plano posterior SAS.
Están sucediendo muchas más cosas en su caso que las que se pueden solucionar de manera efectiva en las publicaciones de foros públicos.
Si tiene la capacidad de abrir un caso de TAC, hágalo.
En la utilidad LSI Webbios, hay una opción para 'reemplazar' / insertar una unidad en la ubicación de la unidad 'faltante', pero realmente tendríamos que mirar los registros y confirmar que el controlador de raid y la placa posterior están en buen estado antes de hacerlo.
Si realmente puede hacer que las unidades físicas se muestren en línea, y la unidad virtual no las importa de nuevo, las muestra como configuración ajena, sin configurar, etc., entonces es posible borrar la configuración de la otra unidades y volver a crear la matriz (con exactamente la misma configuración, es decir, incursión 5, mismo tamaño de banda) SIN iniciar, y muchas veces los datos subyacentes seguirán allí ya que la recreación de la unidad virtual (sin iniciar) solo está reescribiendo metadatos .
Realmente necesitas un caso TAC en este momento.
Ok entiendo, no el equipo esta fuera de contrato por tal motivo no se podra abrir caso con el TAC, sin embargo muchas gracias por el apoyo.
