problems with gracefully shutdown of a server with esxi 5.0
jsotooplk
hi,
I have some problem when i try to do a gracefully shutdown to a blade (b230-m2) that have a an esxi 5.0 OS, i do all the procedure but when i see the kvm session he dont do a gracefully shutdown it reboots, i´ll has been checking and i saw a possibility that the os does not supports this but i need to know it exactly, please if you can help me with this.
thanks.
Robert Burns
This may be a known issue.  I'll confirm and update this thread shortly.
Robert
ok, thank you very much, please let me know as soon as possible .
thanks.
Hi Jesus ,
If I understood your issue on the blade, it seems that the issue is related to a known issue as Rob mentioned.
You can check on the following bug CSCtx08476.
Hope that help
- David
