Problems with VNIC recognition on ESX Hypervisor
satyrjosue
Hello
I have 1 Cisco UCS 5108 Chasis with 4 Cisco UCS B200M4 Blade servers, VIC 1340, adapter firmware version 4.0 (1c) and the UCS Manager firmware version 2.2 (3c)
I have one service profile with 12 VNIC for each blade and I saw the following vmnic information on ESX Hypervisor:
vmnic0          N/A (00:25:b5:10:11:17) Connected (...)
vmnic1          N/A (00:25:b5:10:12:17) Connected (...)
vmnic2          N/A (00:25:b5:10:11:15) Connected
vmnic3          N/A (00:25:b5:10:12:15) Connected
vmnic4          N/A (00:25:b5:10:11:13) Connected
vmnic5          N/A (00:25:b5:10:12:13) Connected
vmnic6          Chasis Slot....(...10:11:12) Connected
vmnic7          Chasis Slot....(...10:12:12) Connected
When i try to assign vmnic0,1,2,3,4 or 5, the ping between ESX host is lose but when i assign vmnic 6 or 7, the ping between ESX host was stablished
which is causing this problem?
Thanks for your help
Walter Dey
check your vswitch ! you created the vmnic's but according to the screen shot, only a few are really connected to vswitch. you need to select them all, and it should work.
Walter,
Thanks for your help, I'll try this option, but i don't need all vmnics for each ESX host
I don't create a vswitch yet, but i created a VCENTER  and cluster of B200M4 blades
regards.
