Quad Port Intel i350 1GbE RJ45 MLOM NIC --- Does it exist?
pkoshar
Looking at this:
    Cisco UCS C220 M6 Server Installation and Service Guide
    https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/hw/c220m6/install/c220m6/C220M5_chapter_00.html
Particularly, this section's reference highlighted in blue:
Modular LAN over Motherboard (mLOM) slot
The dedicated mLOM slot on the motherboard can flexibly accommodate the following cards:
  • Cisco Virtual Interface Cards (VICs)
  • Quad Port Intel i350 1GbE RJ45 Network Interface Card (NIC)
Note
The four Intel i350 ports are provided on an optional card that plugs into the mLOM slot, and are separate from the two embedded (on the motherboard) LAN ports
I'm unable to find anything online regarding a "Quad Port Intel i350" NIC that "plugs into the mLOM slot."
Is this discontinued? If not, is there an associated Part #?
Thanks!
Steven Tardy
That may be a copy/paste remnant from C220 M5 or somewhere else.
The M5 spec sheet does list a i350 MLOM (UCSC-MLOM-IRJ45).
The M6 spec sheet does NOT list a i350 MLOM.
The M6 spec sheet does list the regular (non-MLOM) i350 PCIe card (UCSC-PCIE-IRJ45).
The only M6 + i350 references on some internal docs is the PCIe card.
Steven Tardy
