06-08-2023 11:02 AM - edited 06-08-2023 11:04 AM
I am attempting to connect a UCS C220M5 node with SFP-10G-T-X in the SFP ports and Cat6a to a 10G RJ-45 port on a Catalyst 9300 stack. No link is being established. Are there specific commands to enable that SFP in the UCS node?
NIC: UCSC-PCIE-C25Q-04 which says the optic is supported
06-08-2023 12:50 PM - edited 06-08-2023 12:54 PM
Checking the spec sheet at https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/unified-computing-system-adapters/datasheet-c78-741130.html
06-08-2023 01:56 PM - edited 06-08-2023 01:57 PM
IMC is 4.2(3b) and VIC firmware is 5.2(3c), which shows as supported. Cables types are not being mixed.
08-21-2023 10:09 AM
I have this problem as well. I have learned that the VIC 1455 running version 5.2(2b) works with the SFP-10G-T-X SFP; however, and upgrade to version 5.2(3c) breaks this functionality. The NIC shows SFPs as being present, but in a "disconnect" state.
What I did to resolve the issue was downgrade to version 4.2(2a) that contains the VIC 1455 version 5.2(2b) firmware and then upgrade to 4.2(3b) using the "advanced method" and selecting updates individually; however, leaving the VIC 1455 as "unchecked".
I have a TAC case open for this issue.
Dallas
08-21-2023 10:53 AM
I used a third party optic which is now working. TAC said the SFP is not supported on standalone CIMC server, only on UCSM software.
08-22-2023 01:04 PM
It's a bug:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwh06536
CIMC: Links with SFP-10G-T-X on VIC are showing down when running Adapter firmware version 5.2(3c)
Dallas
11-21-2023 12:58 AM
The issue seems to be fixed in 4.3.2.230270.
