SoL - Connection Issue
probinson
Community Member
We have applied a simple SoL policy to our service profiles however when I SSH to the KVM address it connects but I see nothing back like I do when connecting via the KVM in UCS Manager.
Am I missing a setting somewhere?
Many Thanks, Paul
Walter Dey
Which OS are you running ? eg. for RH
  • To enable, create a SoL policy in UCSM
                Just one setting: baud rate – select 38400 (standard)
  • Apply policy through Service Profile
  • You can then ssh to the BMC directly
                Authenticate using UCSM credentials this time (unlike IPMI)
  • Console output now redirected over SSH
                IPMI v2.0 would normally do this over UDP/623 – UCS is more secure and automatically remaps the output to ssh
  • What will you see on the SoL session?
Server startup sequence (BIOS, etc.)
                If Linux OS installed, you can redirect ttyS0 to SoL (/etc/inittab) and log in through that console
