System Board 0 SEL_FULLNESS---Upper fatal
YAARUB F. MILAD
A customer has a UCSC-C220-M3SBE
on       vsphere>Configuration>Health Status>other      I noticed an alert stating : System Board 0 SEL_FULLNESS---Upper fatal
What is the impact and how to fix this??!
7 Replies 7
Walter Dey
Most likely this means that the SEL log file is filled up ! you can delete it manually or create a SEL policy to save and clear the log.
It has no impact for the operation of the blade ! you just loose log information, because the buffer is full.
see attachment
Thank you for this!  This response is still helpful in late 2019!
Grateful for folks like you that take the time to post.
Thanks for this response! Still helpful in 2024!
Qiese Dides
Hi Milad,
This is the System Event Log on the CIMC.  You can log into the CIMC via web browser (if it has been set up), and review and clear the log.  Button on bottom right side of screen clears log.  Sometimes you have to scroll down to see it.
HTH,
Qiese Dides
Still useful in 9-23-2020
stephen1776
Still useful on 10/6/2020, thanks for posting!
bascheew
To clear this in UCS System Manager go to Equipment -> Chassis -> Chassis (Number) -> Servers -> Choose Server.  Then in the workpane go to SEL Logs and click clear at the bottom.
