ucs 6454 40G uplinks to core and port channels
tdubb123
hi
i am trying to cable up trhe ucs 6454. I got 2 40G mopdules on port 53 and 54 on each fabric.
I got 2 core switches to connect therm to
FABRIC 1
port 53 ----> port 1 on Core switch A
Port 54 -----> port 1 on Core Switch B
FABRIC 2
port 53 ------> port 2 on Core Switch A
port 54 ------> port 2 on Core switch B
Is this correct cablingand how do i configure the port channels?
9 Replies 9
balaji.bandi
You can configure Layer2 Port-channel if this is nexus vpc you can configure mesh network :
https://www.cisco.com/c/dam/en/us/solutions/collateral/data-center-virtualization/unified-computing/white_paper_c11-692008.pdf
BB
these will be trunked links carrying multiple vlans
possible, depends on requirement and other side switch capabilites. you should carry multple vlan to meet the requirement on virtual requirement.
BB
Steven Tardy
Follow any Cisco CVD. Just googled this one:
+ https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/UCS_CVDs/flexpod_xseries_vmware_7u2.html
See sections:
+ Create Port Channels
+ Configure Port Channel Parameters
this is my diagram. do i need creatre port channels with single 40G link per fabric to each core?
i dont understasnd
i am confused how the port channel will be created on the core. if only 1 link per fabric is connected?
Steven Tardy
UCS uplink docs:
https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/ucs-manager/GUI-User-Guides/Network-Mgmt/4-2/b_UCSM_Network_Mgmt_Guide_4_2/b_UCSM_Network_Mgmt_Guide_chapter_011.html#concept_91D93C80D2B0462AB190A7F18CE60421
Are your core switches vPC/MC-LAG capable?
https://en.wikipedia.org/wiki/Multi-chassis_link_aggregation_group
If so, then follow the CVD to create:
  1. First port-channel from FI-A to core1+core2
  2. Second port-channel from FI-B to core1+core2
If not, then I would probably forget about port-channels and make each wire an individual uplink.
UCS will "pin" each vNICs to a single uplink (with multiple vNICs in multiple servers getting "pinned" across all uplinks) and fail over to remaining uplinks when one uplink goes down.
i looked at the cvd, why isnt po11 include E1/50? I onl;y see E1/49. should a po be at least 2 links?
Steven Tardy
From the upstream switch (pair) perspective there are two independent (vPC) port-channels.
One port-channel 11 to UCS FI-A.
One port-channel 12 to UCS FI-B.
Both upstream switches would have both vPC port-channels.
UCS Fabric Interconnects do NOT support back-to-back vPC where all 4 links would be in one single (vPC) port-channel.
