UCS and AD integration
senthil andavan
Hi Steve,
How did UCSM and AD integration is working . Is there any Naming convention or limitation for user ID 's for log in using Domain accounts. In my environment some of the Domain Users able to log in UCSM but some of them not,  even though they have enough admin access.any one can Help me?
cbishop22
I have it working on version 1.4 of the UCS Manager. The only sticking point I found was that you need to name your AD groups the same name as the groups in UCS. Once those matched up and I had the ldap FQDN correct, everything worked fine. Our user ID's are numbers so we did not have an issue with user names.
abbharga
Level 4
Level 4
Hi Senthil,
Let me beging with the following questions:
1) What version of UCSM are you running,
2) Can you help me with the ldap configuration, you can grab it from the CLI:
UCS-A# scope security
UCS-A /security # scope ldap
UCS-A /security/ldap # show configuration
Also here is the URL to the LDAP configuration for 1.4 version:
http://www.cisco.com/en/US/docs/unified_computing/ucs/sw/sample_configurations/UCSM_1_4_LDAP_with_AD/b_Sample_Configuration_LDAP_with_AD.html
Thanks!
./Abhinav
Hi Abhinav,
Thanks for your reply. Currently I am using UCSM 1.4 version ,I am reviewing the configuration now , will check and confirm.
senthil andavan
Hi Cathi,
Thanks for your reply. I will check my configuration
