UCS B6M using management port for EXSI traffic
barrycsho
We want deploy Expressway E on B6M server, however, beside management port, there has only 2 port available for DMZ internal and DMZ external. So we come up with a question, if we assign EXSI's IP address in same subnet with CIMC, is it possible to use management port to access EXSI?
armaan.rakha
You can have ESXI and CIMC IP's in same subnet, but you can't use CIMC Management Port for ESXI traffic, even while doing ESXI network configuration, you won't able to see the CIMC port to select as for ESXI Management or VM's traffic.
R0g22
I see you opened up a case with PDI today as well.
Hi All,
We are facing this issue too.
We Deployed CMS1000 in DMZ to provide Edge services for CMA app.
LAN 1 will connect to Internal Firewall.
LAN 2 will connect to External Firewall.
CIMC port for management.
No Port left for ESXI.
How would we manage and Configure ESXI port?
Please also share any config guide.
Hi All,
