UCS C220M3 won't power up
richb1971
Level 4
Level 4
LEDs: The Amber LED below is not in the Server Installation & Service guide :(
Front panel:
LEDs are green
CIMC 3.0(1c).36
BIOS C220M3.3.0.1a.0
Inventory - No MegaRAID (was there previously). No Hard Discs are showing even though all 8 have been reseated
Overall DIMM Status:Good
Both Power Supplies are reporting 4 watts! (I've swapped with a known working PSU and same issue)
Inside:
Amber LED to the left of DIMM C1
No output to local screen and KVM shows "No Video"
Any clues would be greatly appreciated
Rich
11 Replies 11
richb1971
Level 4
Level 4
Reseated CPUs, DIMMs, Raid Card,PSUs and drives. Still can't power up.
Kirk J
Greetings.
Does your CIMC still function?
SSH to the CIMC ip and run the following:
#sensors
#obfl
The obfl will scroll through a bunch of lines, but I am interested in what are the last few lines that may say something about power or errors.  Likewise, any of the sensors that might actually show an error status (given most will not have running values as server is not powering on).
Kirk...
Hi Kirk,
Thanks for reply.I tried the commands but they didn't take:
CIMC-LON-01# sensors
% invalid command detected at '^' marker.
CIMC-LON-01# obfl
Is there any commands that may help?
Rich
Sorry, forgot this is rack server.
After connecting to CIMC first run:
#connect debug-shell
then run the obfl, and sensors
Kirk...
Thanks Kirk. I've ran em and output is below. Really appreciate your help.
CIMC-LON-01# connect debug-shell
CIMC Debug Firmware Utility Shell [ cli ]
[ help ]# sensors
Sensor Name      | Reading | Unit         | Status | LNR     | LC      | LNC     | UNC     | UC      | UNR     |
FP_ID_LED        | disc -> | discrete     | 0x4100 | na      | na      | na      | na      | na      | na      |
BIOS_POST_CMPLT  | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
P_CATERR_N       | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
RISER1_CNIC_PRS  | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
SAS_MEZZ_PRENT   | disc -> | discrete     | 0x0100 | na      | na      | na      | na      | na      | na      |
MAIN_POWER_PRS   | disc -> | discrete     | 0x0100 | na      | na      | na      | na      | na      | na      |
SEL_FULLNESS     | 46.000  | unspecified  | OK     | na      | na      | na      | 80.000  | 90.000  | 99.000  |
BIOSPOST_TIMEOUT | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
POWER_ON_FAIL    | disc -> | discrete     | 0x0100 | na      | na      | na      | na      | na      | na      |
FAN1_PRSNT       | disc -> | discrete     | 0x0200 | na      | na      | na      | na      | na      | na      |
FAN2_PRSNT       | disc -> | discrete     | 0x0200 | na      | na      | na      | na      | na      | na      |
FAN3_PRSNT       | disc -> | discrete     | 0x0200 | na      | na      | na      | na      | na      | na      |
FAN4_PRSNT       | disc -> | discrete     | 0x0200 | na      | na      | na      | na      | na      | na      |
FAN5_PRSNT       | disc -> | discrete     | 0x0200 | na      | na      | na      | na      | na      | na      |
FAN1_TACH1       | na      | RPM          | na     | 856.000 | 1284.000 | 1712.000 | na      | na      | na      |
FAN1_TACH2       | na      | RPM          | na     | 856.000 | 1284.000 | 1712.000 | na      | na      | na      |
FAN2_TACH1       | na      | RPM          | na     | 856.000 | 1284.000 | 1712.000 | na      | na      | na      |
FAN2_TACH2       | na      | RPM          | na     | 856.000 | 1284.000 | 1712.000 | na      | na      | na      |
FAN3_TACH1       | na      | RPM          | na     | 856.000 | 1284.000 | 1712.000 | na      | na      | na      |
FAN3_TACH2       | na      | RPM          | na     | 856.000 | 1284.000 | 1712.000 | na      | na      | na      |
FAN4_TACH1       | na      | RPM          | na     | 856.000 | 1284.000 | 1712.000 | na      | na      | na      |
FAN4_TACH2       | na      | RPM          | na     | 856.000 | 1284.000 | 1712.000 | na      | na      | na      |
FAN5_TACH1       | na      | RPM          | na     | 856.000 | 1284.000 | 1712.000 | na      | na      | na      |
FAN5_TACH2       | na      | RPM          | na     | 856.000 | 1284.000 | 1712.000 | na      | na      | na      |
LED_FAN1_FAULT   | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
LED_FAN2_FAULT   | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
LED_FAN3_FAULT   | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
LED_FAN4_FAULT   | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
LED_FAN5_FAULT   | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
FM_TPM_CARD_PRS  | disc -> | discrete     | 0x0100 | na      | na      | na      | na      | na      | na      |
RISER2_PRESENT   | disc -> | discrete     | 0x0200 | na      | na      | na      | na      | na      | na      |
RISER1_PRESENT   | disc -> | discrete     | 0x0200 | na      | na      | na      | na      | na      | na      |
RISER2_PRESENT_2 | disc -> | discrete     | 0x0100 | na      | na      | na      | na      | na      | na      |
RISER1_PRESENT_3 | disc -> | discrete     | 0x0100 | na      | na      | na      | na      | na      | na      |
RISER1_PRESENT_2 | disc -> | discrete     | 0x0100 | na      | na      | na      | na      | na      | na      |
RISER2_PRESENT_1 | disc -> | discrete     | 0x0200 | na      | na      | na      | na      | na      | na      |
RISER1_PRESENT_1 | disc -> | discrete     | 0x0200 | na      | na      | na      | na      | na      | na      |
PSU1_STATUS      | disc -> | discrete     | 0x0100 | na      | na      | na      | na      | na      | na      |
PSU2_STATUS      | disc -> | discrete     | 0x0100 | na      | na      | na      | na      | na      | na      |
P1_PROCHOT       | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
P2_PROCHOT       | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
PVCCD_P1_VRHOT   | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
PVCCP_P1_VRHOT   | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
PVCCD_P2_VRHOT   | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
PVCCP_P2_VRHOT   | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
MLOM_PRESENT     | disc -> | discrete     | 0x0100 | na      | na      | na      | na      | na      | na      |
PSU1_PWRGD       | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
PSU1_AC_OK       | disc -> | discrete     | 0x0200 | na      | na      | na      | na      | na      | na      |
PSU2_PWRGD       | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
PSU2_AC_OK       | disc -> | discrete     | 0x0200 | na      | na      | na      | na      | na      | na      |
P1_MEM23_MEMHOT  | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
P1_MEM01_MEMHOT  | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
P2_MEM23_MEMHOT  | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
P2_MEM01_MEMHOT  | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
LED_PSU_STATUS   | disc -> | discrete     | 0x1200 | na      | na      | na      | na      | na      | na      |
LED_TEMP_STATUS  | disc -> | discrete     | 0x1200 | na      | na      | na      | na      | na      | na      |
LED_FAN_STATUS   | disc -> | discrete     | 0x1200 | na      | na      | na      | na      | na      | na      |
LED_HLTH_STATUS  | disc -> | discrete     | 0x1200 | na      | na      | na      | na      | na      | na      |
PS_RDNDNT_MODE   | disc -> | discrete     | 0x0100 | na      | na      | na      | na      | na      | na      |
P1_TEMP_SENS     | na      | degrees C    | na     | na      | na      | na      | na      | 72.000  | 82.000  |
P2_TEMP_SENS     | na      | degrees C    | na     | na      | na      | na      | na      | 72.000  | 82.000  |
RISER1_INLET_TMP | 26.000  | degrees C    | OK     | na      | na      | na      | 60.000  | 70.000  | 80.000  |
RISER2_INLET_TMP | 24.000  | degrees C    | OK     | na      | na      | na      | 60.000  | 70.000  | 80.000  |
RISER1_OUTLETTMP | 24.000  | degrees C    | OK     | na      | na      | na      | 60.000  | 70.000  | 80.000  |
RISER2_OUTLETTMP | 23.000  | degrees C    | OK     | na      | na      | na      | 60.000  | 70.000  | 80.000  |
FP_TEMP_SENSOR   | 22.000  | degrees C    | OK     | na      | na      | na      | 45.000  | 50.000  | 55.000  |
HDD1_STATUS      | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
HDD2_STATUS      | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
HDD3_STATUS      | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
HDD4_STATUS      | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
HDD5_STATUS      | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
HDD6_STATUS      | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
HDD7_STATUS      | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
HDD8_STATUS      | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
DDR3_P1_A1_PRS   | disc -> | discrete     | 0x0200 | na      | na      | na      | na      | na      | na      |
DDR3_P1_A1_TEMP  | na      | degrees C    | na     | na      | na      | na      | 65.000  | 85.000  | 90.000  |
P1_DIMM_A1_LED   | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
DDR3_P1_A2_PRS   | disc -> | discrete     | 0x0100 | na      | na      | na      | na      | na      | na      |
DDR3_P1_A2_TEMP  | na      | degrees C    | na     | na      | na      | na      | 65.000  | 85.000  | 90.000  |
P1_DIMM_A2_LED   | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
DDR3_P1_B1_PRS   | disc -> | discrete     | 0x0200 | na      | na      | na      | na      | na      | na      |
DDR3_P1_B1_TEMP  | na      | degrees C    | na     | na      | na      | na      | 65.000  | 85.000  | 90.000  |
P1_DIMM_B1_LED   | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
DDR3_P1_B2_PRS   | disc -> | discrete     | 0x0100 | na      | na      | na      | na      | na      | na      |
DDR3_P1_B2_TEMP  | na      | degrees C    | na     | na      | na      | na      | 65.000  | 85.000  | 90.000  |
P1_DIMM_B2_LED   | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
DDR3_P1_C1_PRS   | disc -> | discrete     | 0x0200 | na      | na      | na      | na      | na      | na      |
DDR3_P1_C1_TEMP  | na      | degrees C    | na     | na      | na      | na      | 65.000  | 85.000  | 90.000  |
P1_DIMM_C1_LED   | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
DDR3_P1_C2_PRS   | disc -> | discrete     | 0x0100 | na      | na      | na      | na      | na      | na      |
DDR3_P1_C2_TEMP  | na      | degrees C    | na     | na      | na      | na      | 65.000  | 85.000  | 90.000  |
P1_DIMM_C2_LED   | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
DDR3_P1_D1_PRS   | disc -> | discrete     | 0x0200 | na      | na      | na      | na      | na      | na      |
DDR3_P1_D1_TEMP  | na      | degrees C    | na     | na      | na      | na      | 65.000  | 85.000  | 90.000  |
P1_DIMM_D1_LED   | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
DDR3_P1_D2_PRS   | disc -> | discrete     | 0x0100 | na      | na      | na      | na      | na      | na      |
DDR3_P1_D2_TEMP  | na      | degrees C    | na     | na      | na      | na      | 65.000  | 85.000  | 90.000  |
P1_DIMM_D2_LED   | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
DDR3_P2_E1_PRS   | disc -> | discrete     | 0x0200 | na      | na      | na      | na      | na      | na      |
DDR3_P2_E1_TEMP  | na      | degrees C    | na     | na      | na      | na      | 65.000  | 85.000  | 90.000  |
P2_DIMM_E1_LED   | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
DDR3_P2_E2_PRS   | disc -> | discrete     | 0x0100 | na      | na      | na      | na      | na      | na      |
DDR3_P2_E2_TEMP  | na      | degrees C    | na     | na      | na      | na      | 65.000  | 85.000  | 90.000  |
P2_DIMM_E2_LED   | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
DDR3_P2_F1_PRS   | disc -> | discrete     | 0x0200 | na      | na      | na      | na      | na      | na      |
DDR3_P2_F1_TEMP  | na      | degrees C    | na     | na      | na      | na      | 65.000  | 85.000  | 90.000  |
P2_DIMM_F1_LED   | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
DDR3_P2_F2_PRS   | disc -> | discrete     | 0x0100 | na      | na      | na      | na      | na      | na      |
DDR3_P2_F2_TEMP  | na      | degrees C    | na     | na      | na      | na      | 65.000  | 85.000  | 90.000  |
P2_DIMM_F2_LED   | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
DDR3_P2_G1_PRS   | disc -> | discrete     | 0x0200 | na      | na      | na      | na      | na      | na      |
DDR3_P2_G1_TEMP  | na      | degrees C    | na     | na      | na      | na      | 65.000  | 85.000  | 90.000  |
P2_DIMM_G1_LED   | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
DDR3_P2_G2_PRS   | disc -> | discrete     | 0x0100 | na      | na      | na      | na      | na      | na      |
DDR3_P2_G2_TEMP  | na      | degrees C    | na     | na      | na      | na      | 65.000  | 85.000  | 90.000  |
P2_DIMM_G2_LED   | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
DDR3_P2_H1_PRS   | disc -> | discrete     | 0x0200 | na      | na      | na      | na      | na      | na      |
DDR3_P2_H1_TEMP  | na      | degrees C    | na     | na      | na      | na      | 65.000  | 85.000  | 90.000  |
P2_DIMM_H1_LED   | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
DDR3_P2_H2_PRS   | disc -> | discrete     | 0x0100 | na      | na      | na      | na      | na      | na      |
DDR3_P2_H2_TEMP  | na      | degrees C    | na     | na      | na      | na      | 65.000  | 85.000  | 90.000  |
P2_DIMM_H2_LED   | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
P12V_STBY_V_MOIN | na      | Volts        | na     | 10.148  | 10.797  | na      | na      | 13.157  | 13.806  |
P12V_AUX_V_MOIN  | na      | Volts        | na     | 10.148  | 10.797  | na      | na      | 13.157  | 13.806  |
P5V_AUX_V_MOIN   | na      | Volts        | na     | 4.312   | 4.557   | na      | na      | 5.439   | 5.684   |
P12V_V_MOIN      | na      | Volts        | na     | 10.148  | 10.797  | na      | na      | 12.744  | 12.921  |
P5V_V_MOIN       | na      | Volts        | na     | 4.312   | 4.557   | na      | na      | 5.439   | 5.684   |
P3V3_V_MOIN      | na      | Volts        | na     | 2.848   | 3.008   | na      | na      | 3.584   | 3.744   |
P1V5_SSB         | na      | Volts        | na     | 1.295   | 1.373   | na      | na      | 1.622   | 1.700   |
P1V1_SSB         | na      | Volts        | na     | 0.952   | 1.006   | na      | na      | 1.193   | 1.248   |
P3V3_BAT_V_MOIN  | na      | Volts        | na     | 2.240   | 2.544   | na      | na      | 3.440   | 3.744   |
PVTT_DDR_AB      | na      | Volts        | na     | 0.648   | 0.679   | na      | na      | 0.814   | 0.853   |
PVTT_DDR_CD      | na      | Volts        | na     | 0.648   | 0.679   | na      | na      | 0.814   | 0.853   |
PVTT_DDR_EF      | na      | Volts        | na     | 0.648   | 0.679   | na      | na      | 0.814   | 0.853   |
PVTT_DDR_GH      | na      | Volts        | na     | 0.648   | 0.679   | na      | na      | 0.814   | 0.853   |
MLOM_TEMP_SENS   | na      | degrees C    | na     | na      | na      | na      | 65.000  | 74.000  | 79.000  |
PVTT_P1          | na      | Volts        | na     | 0.850   | 0.905   | na      | na      | 1.139   | 1.186   |
PVDDQ_AB         | na      | Volts        | na     | 1.287   | 1.369   | na      | na      | 1.626   | 1.708   |
PVDDQ_CD         | na      | Volts        | na     | 1.287   | 1.369   | na      | na      | 1.626   | 1.708   |
PVSA_P1          | na      | Volts        | na     | 0.546   | 0.569   | na      | na      | 1.240   | 1.303   |
PVPLL_P1         | na      | Volts        | na     | 1.498   | 1.591   | na      | na      | 1.907   | 2.001   |
PVCCP_P1         | na      | Volts        | na     | 0.546   | 0.569   | na      | na      | 1.357   | 1.365   |
PVTT_P2          | na      | Volts        | na     | 0.850   | 0.905   | na      | na      | 1.139   | 1.186   |
PVSA_P2          | na      | Volts        | na     | 0.546   | 0.569   | na      | na      | 1.240   | 1.303   |
PVCCP_P2         | na      | Volts        | na     | 0.546   | 0.569   | na      | na      | 1.357   | 1.365   |
PVDDQ_EF         | na      | Volts        | na     | 1.287   | 1.369   | na      | na      | 1.626   | 1.708   |
PVDDQ_GH         | na      | Volts        | na     | 1.287   | 1.369   | na      | na      | 1.626   | 1.708   |
PVPLL_P2         | na      | Volts        | na     | 1.498   | 1.591   | na      | na      | 1.907   | 2.001   |
POWER_USAGE      | 0.000   | Watts        | OK     | na      | na      | na      | na      | 800.000 | 904.000 |
PSU1_VOUT        | na      | Volts        | na     | na      | na      | na      | na      | 14.000  | 15.000  |
PSU1_IOUT        | na      | Amps         | na     | na      | na      | na      | 119.000 | 125.000 | 128.000 |
PSU1_POUT        | na      | Watts        | na     | na      | na      | na      | 744.000 | 800.000 | 896.000 |
PSU2_VOUT        | na      | Volts        | na     | na      | na      | na      | na      | 14.000  | 15.000  |
PSU2_IOUT        | na      | Amps         | na     | na      | na      | na      | 119.000 | 125.000 | 128.000 |
PSU2_POUT        | na      | Watts        | na     | na      | na      | na      | 744.000 | 800.000 | 896.000 |
VICP81E_0_PRS    | disc -> | discrete     | 0x0100 | na      | na      | na      | na      | na      | na      |
VICP81E_0_OVRTMP | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
VICP81E_0_TMP1   | na      | degrees C    | na     | na      | na      | na      | 0.000   | 0.000   | 0.000   |
VICP81E_0_TMP2   | na      | degrees C    | na     | na      | na      | na      | 0.000   | 0.000   | 0.000   |
VICP81E_0_TMP3   | na      | degrees C    | na     | na      | na      | na      | 0.000   | 0.000   | 0.000   |
P1_PRESENT       | disc -> | discrete     | 0x0200 | na      | na      | na      | na      | na      | na      |
P2_PRESENT       | disc -> | discrete     | 0x0200 | na      | na      | na      | na      | na      | na      |
DDR3_P1_A1_ECC   | na      | error        | na     | na      | na      | na      | na      | na      | 60250.000 |
DDR3_P1_A2_ECC   | na      | error        | na     | na      | na      | na      | na      | na      | 60250.000 |
DDR3_P1_B1_ECC   | na      | error        | na     | na      | na      | na      | na      | na      | 60250.000 |
DDR3_P1_B2_ECC   | na      | error        | na     | na      | na      | na      | na      | na      | 60250.000 |
DDR3_P1_C1_ECC   | na      | error        | na     | na      | na      | na      | na      | na      | 60250.000 |
DDR3_P1_C2_ECC   | na      | error        | na     | na      | na      | na      | na      | na      | 60250.000 |
DDR3_P1_D1_ECC   | na      | error        | na     | na      | na      | na      | na      | na      | 60250.000 |
DDR3_P1_D2_ECC   | na      | error        | na     | na      | na      | na      | na      | na      | 60250.000 |
DDR3_P2_E1_ECC   | na      | error        | na     | na      | na      | na      | na      | na      | 60250.000 |
DDR3_P2_E2_ECC   | na      | error        | na     | na      | na      | na      | na      | na      | 60250.000 |
DDR3_P2_F1_ECC   | na      | error        | na     | na      | na      | na      | na      | na      | 60250.000 |
DDR3_P2_F2_ECC   | na      | error        | na     | na      | na      | na      | na      | na      | 60250.000 |
DDR3_P2_G1_ECC   | na      | error        | na     | na      | na      | na      | na      | na      | 60250.000 |
DDR3_P2_G2_ECC   | na      | error        | na     | na      | na      | na      | na      | na      | 60250.000 |
DDR3_P2_H1_ECC   | na      | error        | na     | na      | na      | na      | na      | na      | 60250.000 |
DDR3_P2_H2_ECC   | na      | error        | na     | na      | na      | na      | na      | na      | 60250.000 |
P3V3_AUX         | na      | Volts        | na     | 2.848   | 3.008   | na      | na      | 3.584   | 3.744   |
P1V8_AUX         | na      | Volts        | na     | 1.591   | 1.677   | na      | na      | 1.911   | 1.981   |
P1V5_AUX         | na      | Volts        | na     | 1.326   | 1.404   | na      | na      | 1.599   | 1.677   |
P1V0_AUX         | na      | Volts        | na     | 0.881   | 0.936   | na      | na      | 1.069   | 1.115   |
P1V1_AUX         | na      | Volts        | na     | 0.975   | 1.030   | na      | na      | 1.170   | 1.232   |
P0V75_AUX        | na      | Volts        | na     | 0.648   | 0.687   | na      | na      | 0.814   | 0.853   |
PSU1_PIN         | na      | Watts        | na     | na      | na      | na      | 744.000 | 800.000 | 896.000 |
PSU2_PIN         | na      | Watts        | na     | na      | na      | na      | 744.000 | 800.000 | 896.000 |
PSU1_TEMP        | 19.000  | degrees C    | OK     | na      | na      | na      | 60.000  | 65.000  | 70.000  |
PSU2_TEMP        | 18.000  | degrees C    | OK     | na      | na      | na      | 60.000  | 65.000  | 70.000  |
PCH_TEMP_SENS    | na      | degrees C    | na     | na      | na      | na      | 80.000  | 85.000  | 90.000  |
P1_THERMTRIP_N   | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
P2_THERMTRIP_N   | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
PCH_THERMTRIP_N  | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
STOR_STATUS      | disc -> | discrete     | 0x0100 | na      | na      | na      | na      | na      | na      |
BMC_WATCHDOG     | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
OS_WATCHDOG      | na      | unspecified  | na     | na      | na      | na      | na      | na      | na      |
LEGEND:
LNR: Lower Non Recoverable Threshold
LC : Lower Critical Threshold
LNC: Lower Non Critical Threshold
UNC: Upper Non Critical Threshold
UC : Upper Critical Threshold
UNR: Upper Non Recoverable Threshold
na : Not available at this time or not applicable
[ sensors ]#
LEGEND:
[ sensors ]# exit
CIMC-LON-01#
connect debug-shell
[ help ]# obfl
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>Creating 15 MTD partitions on "Concat Ractrends":
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000000000000-0x000006000000 : "all"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000000000000-0x000000080000 : "U-Boot"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000000080000-0x0000000c0000 : "boot.conf"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x0000000c0000-0x000000100000 : "RSVD"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000000100000-0x000000880000 : "Linux1"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000000880000-0x000001000000 : "Linux2"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000001000000-0x000001800000 : "NV_0"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000001800000-0x000002000000 : "OBFL"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000002000000-0x000003000000 : "NV_1"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000003000000-0x000004000000 : "NV_2"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000004000000-0x000004800000 : "P2_NV_0"
5:2016 Dec 13 12:33:44 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [gdsd]
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000004800000-0x000004940000 : "P2_OBFL"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000004940000-0x000004c80000 : "NV_3"
5:2016 Dec 13 12:33:44 GMT:BMC:doctor-bmc:1759: app_monitor.c:234:Process, gdsd, successfully started.
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000004c80000-0x000004fc0000 : "NV_4"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000004fc0000-0x000005000000 : "RSVD_NVRAM"
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Major number for pwmtach driver is - 235
5:2016 Dec 13 12:33:44 GMT:BMC:lv_dimm:1739: lv_dimm.c:200:[transition_function]Starting Transition to [High Voltage Mode] from [Unknown Mode]
5:2016 Dec 13 12:33:44 GMT:BMC:lv_dimm:1739: common.c:941:Disabling Sensor scan for sensor 0x83.
5:2016 Dec 13 12:33:44 GMT:BMC:lv_dimm:1739: common.c:941:Disabling Sensor scan for sensor 0x84.
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4> PWM and Fan tach configuration registers
5:2016 Dec 13 12:33:44 GMT:BMC:lv_dimm:1739: common.c:941:Disabling Sensor scan for sensor 0x85.
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>PWCFG: 55  addr: c7946000
5:2016 Dec 13 12:33:44 GMT:BMC:lv_dimm:1739: common.c:941:Disabling Sensor scan for sensor 0x86.
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>FMCFG: ff  addr: c7946004
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>PWOCF: 0  addr: c7946008
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4> Fan tach  Interrupt Register
5:2016 Dec 13 12:33:44 GMT:BMC:lv_dimm:1739: common.c:941:Disabling Sensor scan for sensor 0x89.
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>FTISR: 0  addr: c794600c
5:2016 Dec 13 12:33:45 GMT:BMC:lv_dimm:1739: common.c:941:Disabling Sensor scan for sensor 0x8a.
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> PWM control & stat reg , enables counter resolution
5:2016 Dec 13 12:33:45 GMT:BMC:lv_dimm:1739: common.c:941:Disabling Sensor scan for sensor 0x91.
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCRCSR: 55, addr: c7946010
5:2016 Dec 13 12:33:45 GMT:BMC:lv_dimm:1739: common.c:941:Disabling Sensor scan for sensor 0x92.
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>Counter resolution reg, sets no of clock cycles for PWM
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCRVR0: 1e, addr: c7946014
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCRVR1: 1e, addr: c7946018
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCRVR2: 1e, addr: c794601c
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCRVR3: 1e, addr: c7946020
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> PWM pre scale register, sets clock divider for PWM
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> PWM  duty cycle reg, sets no of high pulses
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWPSR0: a, addr: c7946040
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWDCR0: 15, addr: c7946044
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWPSR1: a
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWDCR1: 15
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWPSR2: a
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWDCR2: 15
5:2016 Dec 13 12:33:45 GMT:BMC:lv_dimm:1739: lv_dimm.c:220:[transition_function]Transition to [High Voltage Mode] Success
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWPSR3: a
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWDCR3: 15
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> Fan tach threshold reg, sets max no of clock between pulses
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR0: ff, addr: c7946060
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR1: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR2: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR3: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR4: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR5: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR6: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR7: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> Fan tach speed reg, set automatically
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR0: 0, addr c7946064
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR1: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR2: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR3: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR4: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR5: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR6: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR7: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> Fan tach control& stat reg,
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR0: 60 addr c7946068
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR1: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR2: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR3: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR4: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR5: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR6: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR7: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> Fan Tach filter select reg, sets filter value if filter is enabled
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMPFSR0: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMPFSR1: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> SET2 - PWM and Fan tach configuration registers
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCFG1: 55  addr: c7946100
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCFG1: ff  addr: c7946104
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWOCF1: 0  addr: c7946108
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> Fan tach  Interrupt Register
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FTISR1: 0  addr: c794610c
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCRCSR1: 55, addr: c7946110
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCRVR4: 1e, addr: c7946114
5:2016 Dec 13 12:33:45 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [mem_throttled]
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCRVR5: 1e, addr: c7946118
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCRVR6: 1e, addr: c794611c
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCRVR7: 1e, addr: c7946120
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWPSR4: a, addr: c7946140
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWDCR4: 15, addr: c7946144
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWPSR5: a
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWDCR5: 15
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWPSR6: a
5:2016 Dec 13 12:33:45 GMT:BMC:doctor-bmc:1767: app_monitor.c:234:Process, mem_throttled, successfully started.
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWDCR6: 15
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWPSR7: a
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWDCR7: 15
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR8: ff, addr: c7946160
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR9: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR10: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR11: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR12: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR13: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR14: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR15: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR8: 0 addr c7946164
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR9: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR10: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR11: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR12: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR13: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR14: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR15: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR8: 60 addr c7946168
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR9: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR10: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR11: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR12: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR13: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR14: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR15: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMPFSR2: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMPFSR3: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>***************PWM Driver has been initialized****************
5:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2773:USB FS: VDD Power Good = OFF
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> CyAnDevice: Cannot get firmware version. Reason code: 81
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> CyAnDevice: CyAsMiscConfigureDevice: No Firmware loaded: 81
5:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<5> CyAnDevice: Downloading Astoria firmware 1
5:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<5> CyAnDevice: Astoria firmware has been initialized
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>setting perfect hw filtering mode (c63d34f8)
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>setting perfect hw filtering mode (c705f4f8)
5:2016 Dec 13 12:33:45 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [qpi_loggerd]
5:2016 Dec 13 12:33:45 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[10]: Turning LED[10] (LED_FAN2_FAULT) OFF
5:2016 Dec 13 12:33:45 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[12]: Turning LED[12] (LED_FAN4_FAULT) OFF
5:2016 Dec 13 12:33:45 GMT:BMC:doctor-bmc:1775: app_monitor.c:234:Process, qpi_loggerd, successfully started.
4:2016 Dec 13 12:33:45 GMT:BMC:IPMI:1591: PSRedundantMode.c:51:PSRdntMode_Read --> Failed to open file /var/pmbus/ps_redundancy_state for read.
5:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>EXT2-fs (loop0): warning: mounting unchecked fs, running e2fsck is recommended
5:2016 Dec 13 12:33:46 GMT:BMC:selparser:1662: selparser.c:706: # 0F 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 24 08 00 00 00 04 00 FF FF # 40f | 12/13/2016 12:33:45 | CIMC | Platform alert POWER_ON_FAIL #0x08 | Predictive Failure deasserted | Asserted
5:2016 Dec 13 12:33:49 GMT:BMC:selparser:1662: selparser.c:706: # 10 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 25 0A 00 00 00 08 01 FF FF # 410 | 12/13/2016 12:33:45 | CIMC | Entity presence FAN2_PRSNT #0x0a | Device Present | Asserted
5:2016 Dec 13 12:33:49 GMT:BMC:selparser:1662: selparser.c:706: # 11 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 25 0C 00 00 00 08 01 FF FF # 411 | 12/13/2016 12:33:45 | CIMC | Entity presence FAN4_PRSNT #0x0c | Device Present | Asserted
5:2016 Dec 13 12:33:49 GMT:BMC:selparser:1662: selparser.c:706: # 12 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 25 1E 00 00 00 08 01 FF FF # 412 | 12/13/2016 12:33:45 | CIMC | Entity presence RISER2_PRESENT #0x1e | Device Present | Asserted
5:2016 Dec 13 12:33:49 GMT:BMC:selparser:1662: selparser.c:706: # 13 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 25 24 00 00 00 08 01 FF FF # 413 | 12/13/2016 12:33:45 | CIMC | Entity presence RISER1_PRESENT_1 #0x24 | Device Present | Asserted
5:2016 Dec 13 12:33:49 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x30 : Status = 0x83
5:2016 Dec 13 12:33:49 GMT:BMC:selparser:1662: selparser.c:706: # 14 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 24 36 00 00 00 7F 01 FF FF # 414 | 12/13/2016 12:33:45 | CIMC | Platform alert LED_PSU_STATUS #0x36 | LED is on | Asserted
5:2016 Dec 13 12:33:49 GMT:BMC:selparser:1662: selparser.c:706: # 15 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 24 36 00 00 00 7F 04 FF FF # 415 | 12/13/2016 12:33:45 | CIMC | Platform alert LED_PSU_STATUS #0x36 | LED color is green | Asserted
5:2016 Dec 13 12:33:49 GMT:BMC:selparser:1662: selparser.c:706: # 16 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 24 38 00 00 00 7F 01 FF FF # 416 | 12/13/2016 12:33:45 | CIMC | Platform alert LED_FAN_STATUS #0x38 | LED is on | Asserted
5:2016 Dec 13 12:33:49 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x31 : Status = 0x80
5:2016 Dec 13 12:33:49 GMT:BMC:selparser:1662: selparser.c:706: # 17 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 24 38 00 00 00 7F 04 FF FF # 417 | 12/13/2016 12:33:45 | CIMC | Platform alert LED_FAN_STATUS #0x38 | LED color is green | Asserted
5:2016 Dec 13 12:33:49 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [xapid]
5:2016 Dec 13 12:33:49 GMT:BMC:doctor-bmc:1805: app_monitor.c:234:Process, xapid, successfully started.
5:2016 Dec 13 12:33:50 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x33 : Status = 0x83
5:2016 Dec 13 12:33:50 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[9]: Turning LED[9] (LED_FAN1_FAULT) OFF
5:2016 Dec 13 12:33:50 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [fcgi]
5:2016 Dec 13 12:33:50 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x34 : Status = 0x80
5:2016 Dec 13 12:33:50 GMT:BMC:lv_dimm:1739: lv_dimm.c:403:[handle_event_enable_tick]enable sensor event
5:2016 Dec 13 12:33:50 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x20 : Status = 0x83
5:2016 Dec 13 12:33:50 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[11]: Turning LED[11] (LED_FAN3_FAULT) OFF
5:2016 Dec 13 12:33:50 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x83.
5:2016 Dec 13 12:33:50 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x21 : Status = 0x80
5:2016 Dec 13 12:33:50 GMT:BMC:selparser:1662: selparser.c:706: # 18 04 00 00 01 02 00 00 AD EA 4F 58 20 00 04 25 09 00 00 00 08 01 FF FF # 418 | 12/13/2016 12:33:49 | CIMC | Entity presence FAN1_PRSNT #0x09 | Device Present | Asserted
5:2016 Dec 13 12:33:50 GMT:BMC:doctor-bmc:1811: app_monitor.c:234:Process, fcgi, successfully started.
5:2016 Dec 13 12:33:50 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x84.
5:2016 Dec 13 12:33:50 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x23 : Status = 0x83
5:2016 Dec 13 12:33:50 GMT:BMC:selparser:1662: selparser.c:706: # 19 04 00 00 01 02 00 00 AD EA 4F 58 20 00 04 25 0B 00 00 00 08 01 FF FF # 419 | 12/13/2016 12:33:49 | CIMC | Entity presence FAN3_PRSNT #0x0b | Device Present | Asserted
5:2016 Dec 13 12:33:50 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x85.
5:2016 Dec 13 12:33:50 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x86.
5:2016 Dec 13 12:33:50 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x24 : Status = 0x80
5:2016 Dec 13 12:33:50 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x89.
5:2016 Dec 13 12:33:50 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x8a.
5:2016 Dec 13 12:33:50 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x91.
5:2016 Dec 13 12:33:50 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x10 : Status = 0x83
5:2016 Dec 13 12:33:50 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x92.
5:2016 Dec 13 12:33:50 GMT:BMC:lv_dimm:1739: sanluis1/platform.c:117:platform_event_enable_tick_end: Configuring IR from CIMC
5:2016 Dec 13 12:33:50 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[13]: Turning LED[13] (LED_FAN5_FAULT) OFF
5:2016 Dec 13 12:33:50 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[255]: Turning LED[25] (LED_DIMM_FAULT_P1_A2) OFF
5:2016 Dec 13 12:33:50 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x11 : Status = 0x80
5:2016 Dec 13 12:33:50 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[255]: Turning LED[27] (LED_DIMM_FAULT_P1_B2) OFF
5:2016 Dec 13 12:33:50 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x13 : Status = 0x83
5:2016 Dec 13 12:33:50 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[255]: Turning LED[29] (LED_DIMM_FAULT_P1_C2) OFF
5:2016 Dec 13 12:33:50 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x14 : Status = 0x80
5:2016 Dec 13 12:33:50 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[255]: Turning LED[31] (LED_DIMM_FAULT_P1_D2) OFF
5:2016 Dec 13 12:33:50 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[255]: Turning LED[33] (LED_DIMM_FAULT_P2_E2) OFF
5:2016 Dec 13 12:33:50 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x0 : Status = 0x83
5:2016 Dec 13 12:33:50 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[255]: Turning LED[35] (LED_DIMM_FAULT_P2_F2) OFF
5:2016 Dec 13 12:33:50 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x1 : Status = 0x80
5:2016 Dec 13 12:33:50 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[255]: Turning LED[37] (LED_DIMM_FAULT_P2_G2) OFF
5:2016 Dec 13 12:33:50 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[255]: Turning LED[39] (LED_DIMM_FAULT_P2_H2) OFF
5:2016 Dec 13 12:33:50 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x3 : Status = 0x83
5:2016 Dec 13 12:33:50 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x4 : Status = 0x80
5:2016 Dec 13 12:33:50 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x31 : Status = 0x80
5:2016 Dec 13 12:33:51 GMT:BMC:selparser:1662: selparser.c:706: # 1A 04 00 00 01 02 00 00 AE EA 4F 58 20 00 04 25 0D 00 00 00 08 01 FF FF # 41a | 12/13/2016 12:33:50 | CIMC | Entity presence FAN5_PRSNT #0x0d | Device Present | Asserted
5:2016 Dec 13 12:33:51 GMT:BMC:selparser:1662: selparser.c:706: # 1B 04 00 00 01 02 00 00 AE EA 4F 58 20 00 04 25 1F 00 00 00 08 01 FF FF # 41b | 12/13/2016 12:33:50 | CIMC | Entity presence RISER1_PRESENT #0x1f | Device Present | Asserted
5:2016 Dec 13 12:33:51 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x14 : Status = 0x80
5:2016 Dec 13 12:33:51 GMT:BMC:selparser:1662: selparser.c:706: # 1C 04 00 00 01 02 00 00 AE EA 4F 58 20 00 04 25 23 00 00 00 08 01 FF FF # 41c | 12/13/2016 12:33:50 | CIMC | Entity presence RISER2_PRESENT_1 #0x23 | Device Present | Asserted
5:2016 Dec 13 12:33:51 GMT:BMC:selparser:1662: selparser.c:706: # 1D 04 00 00 01 02 00 00 AE EA 4F 58 20 00 04 24 37 00 00 00 7F 01 FF FF # 41d | 12/13/2016 12:33:50 | CIMC | Platform alert LED_TEMP_STATUS #0x37 | LED is on | Asserted
5:2016 Dec 13 12:33:51 GMT:BMC:selparser:1662: selparser.c:706: # 1E 04 00 00 01 02 00 00 AE EA 4F 58 20 00 04 24 37 00 00 00 7F 04 FF FF # 41e | 12/13/2016 12:33:50 | CIMC | Platform alert LED_TEMP_STATUS #0x37 | LED color is green | Asserted
5:2016 Dec 13 12:33:51 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x1 : Status = 0x80
5:2016 Dec 13 12:33:51 GMT:BMC:selparser:1662: selparser.c:706: # 1F 04 00 00 01 02 00 00 AE EA 4F 58 20 00 04 24 39 00 00 00 7F 01 FF FF # 41f | 12/13/2016 12:33:50 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED is on | Asserted
5:2016 Dec 13 12:33:51 GMT:BMC:selparser:1662: selparser.c:706: # 20 04 00 00 01 02 00 00 AE EA 4F 58 20 00 04 24 39 00 00 00 7F 04 FF FF # 420 | 12/13/2016 12:33:50 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED color is green | Asserted
5:2016 Dec 13 12:33:51 GMT:BMC:selparser:1662: selparser.c:706: # 21 04 00 00 01 02 00 00 AE EA 4F 58 20 00 04 25 A1 00 00 00 08 01 FF FF # 421 | 12/13/2016 12:33:50 | CIMC | Entity presence P2_PRESENT #0xa1 | Device Present | Asserted
5:2016 Dec 13 12:33:51 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x4 : Status = 0x80
5:2016 Dec 13 12:33:51 GMT:BMC:selparser:1662: selparser.c:706: # 22 04 00 00 01 02 00 00 AE EA 4F 58 20 00 04 25 A0 00 00 00 08 01 FF FF # 422 | 12/13/2016 12:33:50 | CIMC | Entity presence P1_PRESENT #0xa0 | Device Present | Asserted
5:2016 Dec 13 12:33:51 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x31 : Status = 0x80
5:2016 Dec 13 12:33:51 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x34 : Status = 0x80
5:2016 Dec 13 12:33:51 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x21 : Status = 0x80
5:2016 Dec 13 12:33:51 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x24 : Status = 0x80
5:2016 Dec 13 12:33:51 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x11 : Status = 0x80
5:2016 Dec 13 12:33:51 GMT:BMC:kernel:-:<5>[__do_power_off]:325:__do_power_off
5:2016 Dec 13 12:33:52 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [monkey]
5:2016 Dec 13 12:33:52 GMT:BMC:doctor-bmc:1852: app_monitor.c:234:Process, monkey, successfully started.
5:2016 Dec 13 12:33:53 GMT:BMC:bios-update:1865: main.c:236:Running as Daemon
4:2016 Dec 13 12:33:53 GMT:BMC:IPMI:1591: PSRedundantMode.c:51:PSRdntMode_Read --> Failed to open file /var/pmbus/ps_redundancy_state for read.
5:2016 Dec 13 12:33:53 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [alertmgr]
5:2016 Dec 13 12:33:53 GMT:BMC:doctor-bmc:1882: app_monitor.c:234:Process, alertmgr, successfully started.
5:2016 Dec 13 12:33:55 GMT:BMC:bios-update:1865: activate.c:142:Setting BIOS Version
5:2016 Dec 13 12:33:58 GMT:BMC:selparser:1662: selparser.c:706: # 23 04 00 00 01 02 00 00 B5 EA 4F 58 20 00 04 08 25 00 00 00 6F 30 FF 00 # 423 | 12/13/2016 12:33:57 | CIMC | Power supply PSU1_STATUS #0x25 | Presence detected |  | Asserted
5:2016 Dec 13 12:33:58 GMT:BMC:selparser:1662: selparser.c:706: # 24 04 00 00 01 02 00 00 B6 EA 4F 58 20 00 04 08 26 00 00 00 6F 30 FF 00 # 424 | 12/13/2016 12:33:58 | CIMC | Power supply PSU2_STATUS #0x26 | Presence detected |  | Asserted
5:2016 Dec 13 12:33:58 GMT:BMC:selparser:1662: selparser.c:706: # 25 04 00 00 01 02 00 00 B6 EA 4F 58 20 00 04 08 26 00 00 00 6F 33 FF 00 # 425 | 12/13/2016 12:33:58 | CIMC | Power supply PSU2_STATUS #0x26 | Power supply input lost (AC/DC) |  | Asserted
5:2016 Dec 13 12:33:58 GMT:BMC:selparser:1662: selparser.c:706: # 26 04 00 00 01 02 00 00 B6 EA 4F 58 20 00 04 24 36 00 00 00 7F 05 FF FF # 426 | 12/13/2016 12:33:58 | CIMC | Platform alert LED_PSU_STATUS #0x36 | LED color is amber | Asserted
5:2016 Dec 13 12:33:58 GMT:BMC:selparser:1662: selparser.c:706: # 27 04 00 00 01 02 00 00 B6 EA 4F 58 20 00 04 24 36 00 00 00 FF 04 FF FF # 427 | 12/13/2016 12:33:58 | CIMC | Platform alert LED_PSU_STATUS #0x36 | LED color is green | Deasserted
5:2016 Dec 13 12:33:58 GMT:BMC:selparser:1662: selparser.c:706: # 28 04 00 00 01 02 00 00 B6 EA 4F 58 20 00 04 24 39 00 00 00 7F 05 FF FF # 428 | 12/13/2016 12:33:58 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED color is amber | Asserted
5:2016 Dec 13 12:33:58 GMT:BMC:selparser:1662: selparser.c:706: # 29 04 00 00 01 02 00 00 B6 EA 4F 58 20 00 04 24 39 00 00 00 FF 04 FF FF # 429 | 12/13/2016 12:33:58 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED color is green | Deasserted
5:2016 Dec 13 12:34:00 GMT:BMC:selparser:1662: selparser.c:706: # 2A 04 00 00 01 02 00 00 B7 EA 4F 58 20 00 04 08 3A 00 00 00 0B 03 FF FF # 42a | 12/13/2016 12:33:59 | CIMC | Power supply PS_RDNDNT_MODE #0x3a | Non-redundant | Asserted
5:2016 Dec 13 12:34:00 GMT:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2402:USB1 VDD power off
5:2016 Dec 13 12:34:03 GMT:BMC:selparser:1662: selparser.c:706: # 2B 04 00 00 01 02 00 00 BA EA 4F 58 20 00 04 08 2F 00 00 00 03 01 FF FF # 42b | 12/13/2016 12:34:02 | CIMC | Power supply PSU1_AC_OK #0x2f | State Asserted | Asserted
5:2016 Dec 13 12:34:03 GMT:BMC:selparser:1662: selparser.c:706: # 2C 04 00 00 01 02 00 00 BA EA 4F 58 20 00 04 08 31 00 00 00 03 00 FF FF # 42c | 12/13/2016 12:34:02 | CIMC | Power supply PSU2_AC_OK #0x31 | State Deasserted | Asserted
5:2016 Dec 13 12:34:05 GMT:BMC:DimmBL-DbSyncTask:1471: DimmBL-DbSyncTask.c:224:InitializeDimmBLSyncTask: SUCCESS
5:2016 Dec 13 12:34:06 GMT:BMC:kernel:-:<5>Slow work thread pool: Starting up
5:2016 Dec 13 12:34:06 GMT:BMC:kernel:-:<5>Slow work thread pool: Ready
5:2016 Dec 13 12:34:09 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [kvm]
5:2016 Dec 13 12:34:09 GMT:BMC:doctor-bmc:1988: app_monitor.c:234:Process, kvm, successfully started.
5:2016 Dec 13 12:34:10 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [vkvm_pm]
5:2016 Dec 13 12:34:10 GMT:BMC:doctor-bmc:1995: app_monitor.c:234:Process, vkvm_pm, successfully started.
5:2016 Dec 13 12:34:11 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [sshd]
5:2016 Dec 13 12:34:12 GMT:BMC:doctor-bmc:2018: app_monitor.c:234:Process, sshd, successfully started.
5:2016 Dec 13 12:34:12 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [cisco_pm]
5:2016 Dec 13 12:34:12 GMT:BMC:doctor-bmc:2032: app_monitor.c:234:Process, cisco_pm, successfully started.
5:2016 Dec 13 12:34:13 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [ciscoNET]
5:2016 Dec 13 12:34:13 GMT:BMC:doctor-bmc:2041: app_monitor.c:234:Process, ciscoNET, successfully started.
5:2016 Dec 13 12:34:14 GMT:BMC:ciscoNET:2043: ciscoNET.c:122:Application Starting
5:2016 Dec 13 12:34:14 GMT:BMC:doctor-bmc-app-mon:2082: app_monitor.c:726:Started application monitor (2082)
5:2016 Dec 13 12:34:14 GMT:BMC:doctor-bmc-app-mon:2082: app_monitor.c:481:cmp_proc_node_ctime: stat(/proc/1609) failed, errno 2 (No such file or directory)
5:2016 Dec 13 12:34:14 GMT:BMC:doctor-bmc-app-mon:2082: app_monitor.c:636:cmp_proc_node_ctime sel_pigeon_cntrd stat(/proc/1609) returned errno 2 (No such file or directory)
4:2016 Dec 13 12:34:14 GMT:BMC:doctor-bmc-app-mon:2082: app_monitor.c:592:Restarting Process sel_pigeon_cntrd
5:2016 Dec 13 12:34:14 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [ucsm_state_manager]
5:2016 Dec 13 12:34:14 GMT:BMC:doctor-bmc:2083: app_monitor.c:234:Process, ucsm_state_manager, successfully started.
5:2016 Dec 13 12:34:15 GMT:BMC:ciscoNET:2043: network_manager.c:549:Configuring the network.
5:2016 Dec 13 12:34:15 GMT:BMC:sel_pigeon_cntr:2086: sel_pigeon_cntr.c:917:Opening connection to SEL_PIGEON_CNTR_FIFO
5:2016 Dec 13 12:34:15 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [GDSCommDmn]
5:2016 Dec 13 12:34:15 GMT:BMC:doctor-bmc:2092: app_monitor.c:234:Process, GDSCommDmn, successfully started.
5:2016 Dec 13 12:34:15 GMT:BMC:GDSCommDmn:-: GDSCommSVC.c:116:GDSComm SVC started
5:2016 Dec 13 12:34:16 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [rack_monitor]
5:2016 Dec 13 12:34:16 GMT:BMC:doctor-bmc:2098: app_monitor.c:234:Process, rack_monitor, successfully started.
5:2016 Dec 13 12:34:16 GMT:BMC:rack_monitor:-: rack_monitor.c:397:RACK Montior in Stand-alone mode
5:2016 Dec 13 12:34:16 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [sam_master]
5:2016 Dec 13 12:34:16 GMT:BMC:doctor-bmc:2102: app_monitor.c:234:Process, sam_master, successfully started.
5:2016 Dec 13 12:34:17 GMT:BMC:sam_master:-: sam_master.c:61:Stopping PTPD on Monitor Request
5:2016 Dec 13 12:34:17 GMT:BMC:ciscoNET:2043: network_manager.c:793:Error: killall udhcpc returned exit code: 256
5:2016 Dec 13 12:34:17 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [ciscovmd]
5:2016 Dec 13 12:34:17 GMT:BMC:doctor-bmc:2108: app_monitor.c:234:Process, ciscovmd, successfully started.
5:2016 Dec 13 12:34:17 GMT:BMC:doctor-bmc:-: doctor-bmc.c:308:doctor-bmc-app stop [ptpd]
5:2016 Dec 13 12:34:17 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [video_triggerd]
5:2016 Dec 13 12:34:17 GMT:BMC:doctor-bmc:2116: app_monitor.c:234:Process, video_triggerd, successfully started.
5:2016 Dec 13 12:34:17 GMT:BMC:ciscoNET:2043: network_manager.c:795:Error: killall udhcpc6 returned exit code: 256
4:2016 Dec 13 12:34:18 GMT:BMC:kernel:-:<4>setting perfect hw filtering mode (c705f4f8)
5:2016 Dec 13 12:34:25 GMT:BMC:hw-ether:2199: hw-ether.c:254:eth0's hardware address changed to f8:72:ea:a3:d6:ee
4:2016 Dec 13 12:34:25 GMT:BMC:kernel:-:<4>setting perfect hw filtering mode (c705f4f8)
4:2016 Dec 13 12:34:28 GMT:BMC:kernel:-:last message repeated 6 times
4:2016 Dec 13 12:34:28 GMT:BMC:ciscoNET:2043: network_manager.c:2082:Error: Can not open file, /etc/resolv.conf, with mode, r: 0x2.
5:2016 Dec 13 12:34:29 GMT:BMC:ciscoNET:2043: cisco_cards_manager.c:204:There are no cisco configurable cards attached.
5:2016 Dec 13 12:34:30 GMT:BMC:GDSCommDmn:-: GDSCommSVC.c:209:GDSComm started taking input connections.
5:2016 Dec 13 12:34:30 GMT:BMC:IPMI:1591: Bridge.c:1468:audit from:kcs Fn:0x6 Cmd:0x56 Data: 0x1 0x0 0x1
5:2016 Dec 13 12:34:30 GMT:BMC:IPMI:1591: Bridge.c:1474:audit Resp:0x0
5:2016 Dec 13 12:34:37 GMT:BMC:dataserver:1796: eventsubscribemgnt.c:91:IsShmRestoreRequired: Restoration required!
5:2016 Dec 13 12:34:37 GMT:BMC:dataserver:1796: eventsubscribemgnt.c:1193:RestoreEvtSubscCfg: Restored event subscription configuration successfully!
5:2016 Dec 13 12:34:39 GMT:BMC:doctor-bmc:-: doctor-bmc.c:308:doctor-bmc-app stop [snmp-subagentd]
5:2016 Dec 13 12:34:39 GMT:BMC:root:-: CIMC booted after a chassis power on!!
5:2016 Dec 13 12:34:39 GMT:BMC:root:-: Waiting for MB FRU data to get populated..
5:2016 Dec 13 12:34:40 GMT:BMC:root:-: MB FRU data populated successfully
5:2016 Dec 13 12:34:45 GMT:BMC:root:-: NTP: CIMC IP acquired: 192.168.1.207
5:2016 Dec 13 12:34:46 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [ntpd]
5:2016 Dec 13 12:34:46 GMT:BMC:doctor-bmc:2408: app_monitor.c:234:Process, ntpd, successfully started.
3:2016 Dec 13 12:34:49 GMT:BMC:update-ir:2352: ../../src/update-ir.c:234:Host should be powered-on for IR configuration update
5:2016 Dec 13 12:35:05 GMT:BMC:root:-: DDNS: CIMC IP acquired: 192.168.1.207
5:2016 Dec 13 12:35:05 GMT:BMC:root:-: DDNS: GATEWAY IP acquired: 192.168.1.254
3:2016 Dec 13 12:35:14 GMT:BMC:fcgi:1821: validatePassword() - user password failed validation.
3:2016 Dec 13 12:35:14 GMT:BMC:fcgi:1821: validateUserPW() - user password failed validation
2:2016 Dec 13 12:35:14 GMT:BMC:fcgi:1821: pam_local_manager(webgui:auth): Authentication Failure
3:2016 Dec 13 12:35:14 GMT:BMC:fcgi:1821: pam_auth_status(webgui:auth): Login Failed for host=192.168.1.129
5:2016 Dec 13 12:35:14 GMT:BMC:AUDIT:1821: Login failed (ip:192.168.1.129, service:webgui)
4:2016 Dec 13 12:35:15 GMT:BMC:kernel:-:<4>process `doctor-bmc' is using deprecated sysctl (syscall) net.ipv6.neigh.default.retrans_time; Use net.ipv6.neigh.default.retrans_time_ms instead.
5:2016 Dec 13 12:35:17 GMT:BMC:fcgi:1821: pam_local_manager(webgui:account): requirement "privilege=0x01" was met by user "admin"
5:2016 Dec 13 12:35:17 GMT:BMC:AUDIT:1821: Login success (user:admin, ip:192.168.1.129, service:webgui)
5:2016 Dec 13 12:35:18 GMT:BMC:AUDIT:2034: Session open (user:admin, ip:192.168.1.129, id:1, type:webgui)
5:2016 Dec 13 12:35:18 GMT:BMC:AUDIT:1821: Session open (user:admin, ip:192.168.1.129, id:1, type:webgui)
3:2017 May 29 12:26:09 BST:BMC:crond:1296: time disparity of 240411 minutes detected
5:2017 May 29 12:26:31 BST:BMC:IPMI:1591: Bridge.c:1468:audit from:kcs Fn:0x0 Cmd:0x2 Data: 0x1
5:2017 May 29 12:26:31 BST:BMC:IPMI:1591: Bridge.c:1474:audit Resp:0x0
5:2017 May 29 12:26:31 BST:BMC:kernel:-:<5>[__do_power_on]:385:__do_power_on
5:2017 May 29 12:26:31 BST:BMC:kernel:-:<5>[__do_power_on]:401:Power Driver: Power On Logic Pulse for 250ms @ 4294889566
5:2017 May 29 12:26:31 BST:BMC:AUDIT:1796: Server power state modify (op:power-on)
2:2017 May 29 12:26:52 BST:BMC:kernel:-:<2>[__do_power_on]:428:Power Driver: Power On Fail Asserted @ 4294909897 RegInfo -> SWSTAT0[0x11] WKCFG0[0x11]
5:2017 May 29 12:26:52 BST:BMC:IPMI:1591: Pilot2SrvPower.c:189:Pilot2SrvPowerOn
4:2017 May 29 12:26:52 BST:BMC:IPMI:1591: Pilot2SrvPower.c:191:Pilot2SrvPowerOn: Failed to Power On [Timer expired]
0:2017 May 29 12:26:52 BST:BMC:POF_MONITOR_DAEMON:1381: pof_monitord.c:93:Host Failed Power On Please Check [ /var/log/power-on-fail.log ]
5:2017 May 29 12:26:52 BST:BMC:IPMI:1591: Pilot2SrvPower.c:466:Blade Power Changed To: [ ON ]
5:2017 May 29 12:26:52 BST:BMC:video_trigger:-: video_trigger.c:280:Sending event_ipmi_power_state_change (ON) ..
5:2017 May 29 12:26:52 BST:BMC:IPMI:1591: Rack_FanCtrl.c:1272:fscUpdateActualFanPolicyFile: Applied Policy: N/A, Configuration Status: PENDING - BIOS POST not completed
5:2017 May 29 12:26:53 BST:BMC:selparser:1662: selparser.c:706: # 2D 04 00 00 01 02 00 00 7D 05 2C 59 20 00 04 24 08 00 00 00 04 01 FF FF # 42d | 05/29/2017 12:26:53 | CIMC | Platform alert POWER_ON_FAIL #0x08 | Predictive Failure asserted | Asserted
5:2017 May 29 12:26:54 BST:BMC:video_trigger:-: video_trigger.c:207:Sending event_server_crash for host NMI ..
4:2017 May 29 12:26:57 BST:BMC:IPMI:1591: Pilot3Peci.c:87:Pilot_PECI: Transaction aborted! --> [0xFFFFFFFF], ResultCode = 0, LPC Reset State = 1
5:2017 May 29 12:26:57 BST:BMC:IPMI:1591: Pilot3Peci.c:1034:Pilot_PECI: PECI Temp Transaction To CPU-0 Failed!  RC: 0
4:2017 May 29 12:26:57 BST:BMC:IPMI:1591: Pilot3Peci.c:87:Pilot_PECI: Transaction aborted! --> [0xFFFFFFFF], ResultCode = 77, LPC Reset State = 1
5:2017 May 29 12:26:57 BST:BMC:IPMI:1591: Pilot3Peci.c:1034:Pilot_PECI: PECI Temp Transaction To CPU-1 Failed!  RC: 4d
5:2017 May 29 12:26:59 BST:BMC:selparser:1662: selparser.c:706: # 2E 04 00 00 01 02 00 00 81 05 2C 59 20 00 04 25 01 00 00 00 08 01 FF FF # 42e | 05/29/2017 12:26:57 | CIMC | Entity presence BIOS_POST_CMPLT #0x01 | Device Present | Asserted
5:2017 May 29 12:26:59 BST:BMC:selparser:1662: selparser.c:706: # 2F 04 00 00 01 02 00 00 81 05 2C 59 20 00 04 07 02 00 00 00 04 01 FF FF # 42f | 05/29/2017 12:26:57 | CIMC | Processor P_CATERR_N #0x02 | Predictive Failure asserted | Asserted
5:2017 May 29 12:26:59 BST:BMC:selparser:1662: selparser.c:706: # 30 04 00 00 01 02 00 00 81 05 2C 59 20 00 04 07 27 00 00 00 05 01 FF FF # 430 | 05/29/2017 12:26:57 | CIMC | Processor P1_PROCHOT #0x27 | Limit Exceeded | Asserted
5:2017 May 29 12:26:59 BST:BMC:IPMI:1591: Pilot3Peci.c:1034:Pilot_PECI: PECI Temp Transaction To CPU-1 Failed!  RC: 4d
5:2017 May 29 12:26:59 BST:BMC:selparser:1662: selparser.c:706: # 31 04 00 00 01 02 00 00 81 05 2C 59 20 00 04 07 28 00 00 00 05 01 FF FF # 431 | 05/29/2017 12:26:57 | CIMC | Processor P2_PROCHOT #0x28 | Limit Exceeded | Asserted
5:2017 May 29 12:26:59 BST:BMC:selparser:1662: selparser.c:706: # 32 04 00 00 01 02 00 00 81 05 2C 59 20 00 04 07 29 00 00 00 05 01 FF FF # 432 | 05/29/2017 12:26:57 | CIMC | Processor PVCCD_P1_VRHOT #0x29 | Limit Exceeded | Asserted
5:2017 May 29 12:26:59 BST:BMC:selparser:1662: selparser.c:706: # 33 04 00 00 01 02 00 00 81 05 2C 59 20 00 04 07 2A 00 00 00 05 01 FF FF # 433 | 05/29/2017 12:26:57 | CIMC | Processor PVCCP_P1_VRHOT #0x2a | Limit Exceeded | Asserted
5:2017 May 29 12:26:59 BST:BMC:selparser:1662: selparser.c:706: # 34 04 00 00 01 02 00 00 81 05 2C 59 20 00 04 07 2B 00 00 00 05 01 FF FF # 434 | 05/29/2017 12:26:57 | CIMC | Processor PVCCD_P2_VRHOT #0x2b | Limit Exceeded | Asserted
5:2017 May 29 12:26:59 BST:BMC:selparser:1662: selparser.c:706: # 35 04 00 00 01 02 00 00 81 05 2C 59 20 00 04 07 2C 00 00 00 05 01 FF FF # 435 | 05/29/2017 12:26:57 | CIMC | Processor PVCCP_P2_VRHOT #0x2c | Limit Exceeded | Asserted
5:2017 May 29 12:26:59 BST:BMC:selparser:1662: selparser.c:706: # 36 04 00 00 01 02 00 00 81 05 2C 59 20 00 04 08 2E 00 00 00 03 00 FF FF # 436 | 05/29/2017 12:26:57 | CIMC | Power supply PSU1_PWRGD #0x2e | State Deasserted | Asserted
5:2017 May 29 12:26:59 BST:BMC:selparser:1662: selparser.c:706: # 37 04 00 00 01 02 00 00 81 05 2C 59 20 00 04 08 30 00 00 00 03 00 FF FF # 437 | 05/29/2017 12:26:57 | CIMC | Power supply PSU2_PWRGD #0x30 | State Deasserted | Asserted
5:2017 May 29 12:26:59 BST:BMC:selparser:1662: selparser.c:706: # 38 04 00 00 01 02 00 00 81 05 2C 59 20 00 04 07 32 00 00 00 05 01 FF FF # 438 | 05/29/2017 12:26:57 | CIMC | Processor P1_MEM23_MEMHOT #0x32 | Limit Exceeded | Asserted
5:2017 May 29 12:26:59 BST:BMC:selparser:1662: selparser.c:706: # 39 04 00 00 01 02 00 00 81 05 2C 59 20 00 04 07 33 00 00 00 05 01 FF FF # 439 | 05/29/2017 12:26:57 | CIMC | Processor P1_MEM01_MEMHOT #0x33 | Limit Exceeded | Asserted
5:2017 May 29 12:26:59 BST:BMC:selparser:1662: selparser.c:706: # 3A 04 00 00 01 02 00 00 81 05 2C 59 20 00 04 07 34 00 00 00 05 01 FF FF # 43a | 05/29/2017 12:26:57 | CIMC | Processor P2_MEM23_MEMHOT #0x34 | Limit Exceeded | Asserted
5:2017 May 29 12:26:59 BST:BMC:selparser:1662: selparser.c:706: # 3B 04 00 00 01 02 00 00 81 05 2C 59 20 00 04 07 35 00 00 00 05 01 FF FF # 43b | 05/29/2017 12:26:57 | CIMC | Processor P2_MEM01_MEMHOT #0x35 | Limit Exceeded | Asserted
5:2017 May 29 12:27:00 BST:BMC:update-ir:2352: ../../src/update-ir.c:99:lock state = 0
3:2017 May 29 12:27:00 BST:BMC:update-ir:2352: ../../src/update-ir.c:111:Cannot modify/get front panel locks: 0xd  0xffffffff
5:2017 May 29 12:27:00 BST:BMC:selparser:1662: selparser.c:706: # 3C 04 00 00 01 02 00 00 83 05 2C 59 20 00 04 0D 42 00 00 00 6F 00 FF FF # 43c | 05/29/2017 12:26:59 | CIMC | Drive slot(Bay) HDD1_STATUS #0x42 | Drive Presence | Asserted
5:2017 May 29 12:27:00 BST:BMC:IPMI:1591: Rack_FanCtrl.c:1272:fscUpdateActualFanPolicyFile: Applied Policy: Balanced, Configuration Status: SUCCESS
5:2017 May 29 12:27:01 BST:BMC:selparser:1662: selparser.c:706: # 3D 04 00 00 01 02 00 00 85 05 2C 59 20 00 04 0D 43 00 00 00 6F 00 FF FF # 43d | 05/29/2017 12:27:01 | CIMC | Drive slot(Bay) HDD2_STATUS #0x43 | Drive Presence | Asserted
5:2017 May 29 12:27:01 BST:BMC:selparser:1662: selparser.c:706: # 3E 04 00 00 01 02 00 00 85 05 2C 59 20 00 04 0D 44 00 00 00 6F 00 FF FF # 43e | 05/29/2017 12:27:01 | CIMC | Drive slot(Bay) HDD3_STATUS #0x44 | Drive Presence | Asserted
5:2017 May 29 12:27:01 BST:BMC:selparser:1662: selparser.c:706: # 3F 04 00 00 01 02 00 00 85 05 2C 59 20 00 04 0D 45 00 00 00 6F 00 FF FF # 43f | 05/29/2017 12:27:01 | CIMC | Drive slot(Bay) HDD4_STATUS #0x45 | Drive Presence | Asserted
5:2017 May 29 12:27:01 BST:BMC:selparser:1662: selparser.c:706: # 40 04 00 00 01 02 00 00 85 05 2C 59 20 00 04 0D 46 00 00 00 6F 00 FF FF # 440 | 05/29/2017 12:27:01 | CIMC | Drive slot(Bay) HDD5_STATUS #0x46 | Drive Presence | Asserted
5:2017 May 29 12:27:01 BST:BMC:selparser:1662: selparser.c:706: # 41 04 00 00 01 02 00 00 85 05 2C 59 20 00 04 0D 47 00 00 00 6F 00 FF FF # 441 | 05/29/2017 12:27:01 | CIMC | Drive slot(Bay) HDD6_STATUS #0x47 | Drive Presence | Asserted
5:2017 May 29 12:27:01 BST:BMC:selparser:1662: selparser.c:706: # 42 04 00 00 01 02 00 00 85 05 2C 59 20 00 04 0D 48 00 00 00 6F 00 FF FF # 442 | 05/29/2017 12:27:01 | CIMC | Drive slot(Bay) HDD7_STATUS #0x48 | Drive Presence | Asserted
5:2017 May 29 12:27:01 BST:BMC:selparser:1662: selparser.c:706: # 43 04 00 00 01 02 00 00 85 05 2C 59 20 00 04 0D 49 00 00 00 6F 00 FF FF # 443 | 05/29/2017 12:27:01 | CIMC | Drive slot(Bay) HDD8_STATUS #0x49 | Drive Presence | Asserted
5:2017 May 29 12:27:01 BST:BMC:selparser:1662: selparser.c:706: # 44 04 00 00 01 02 00 00 85 05 2C 59 20 00 04 24 4C 00 00 00 7F 01 FF FF # 444 | 05/29/2017 12:27:01 | CIMC | Platform alert P1_DIMM_A1_LED #0x4c | LED is on | Asserted
5:2017 May 29 12:27:01 BST:BMC:selparser:1662: selparser.c:706: # 45 04 00 00 01 02 00 00 85 05 2C 59 20 00 04 24 4C 00 00 00 7F 05 FF FF # 445 | 05/29/2017 12:27:01 | CIMC | Platform alert P1_DIMM_A1_LED #0x4c | LED color is amber | Asserted
5:2017 May 29 12:27:01 BST:BMC:selparser:1662: selparser.c:706: # 46 04 00 00 01 02 00 00 85 05 2C 59 20 00 04 24 52 00 00 00 7F 01 FF FF # 446 | 05/29/2017 12:27:01 | CIMC | Platform alert P1_DIMM_B1_LED #0x52 | LED is on | Asserted
5:2017 May 29 12:27:01 BST:BMC:selparser:1662: selparser.c:706: # 47 04 00 00 01 02 00 00 85 05 2C 59 20 00 04 24 52 00 00 00 7F 05 FF FF # 447 | 05/29/2017 12:27:01 | CIMC | Platform alert P1_DIMM_B1_LED #0x52 | LED color is amber | Asserted
5:2017 May 29 12:27:01 BST:BMC:selparser:1662: selparser.c:706: # 48 04 00 00 01 02 00 00 85 05 2C 59 20 00 04 24 58 00 00 00 7F 01 FF FF # 448 | 05/29/2017 12:27:01 | CIMC | Platform alert P1_DIMM_C1_LED #0x58 | LED is on | Asserted
5:2017 May 29 12:27:01 BST:BMC:selparser:1662: selparser.c:706: # 49 04 00 00 01 02 00 00 85 05 2C 59 20 00 04 24 58 00 00 00 7F 05 FF FF # 449 | 05/29/2017 12:27:01 | CIMC | Platform alert P1_DIMM_C1_LED #0x58 | LED color is amber | Asserted
5:2017 May 29 12:27:01 BST:BMC:selparser:1662: selparser.c:706: # 4A 04 00 00 01 02 00 00 85 05 2C 59 20 00 04 24 5E 00 00 00 7F 01 FF FF # 44a | 05/29/2017 12:27:01 | CIMC | Platform alert P1_DIMM_D1_LED #0x5e | LED is on | Asserted
5:2017 May 29 12:27:01 BST:BMC:selparser:1662: selparser.c:706: # 4B 04 00 00 01 02 00 00 85 05 2C 59 20 00 04 24 5E 00 00 00 7F 05 FF FF # 44b | 05/29/2017 12:27:01 | CIMC | Platform alert P1_DIMM_D1_LED #0x5e | LED color is amber | Asserted
5:2017 May 29 12:27:01 BST:BMC:selparser:1662: selparser.c:706: # 4C 04 00 00 01 02 00 00 85 05 2C 59 20 00 04 24 64 00 00 00 7F 01 FF FF # 44c | 05/29/2017 12:27:01 | CIMC | Platform alert P2_DIMM_E1_LED #0x64 | LED is on | Asserted
5:2017 May 29 12:27:01 BST:BMC:selparser:1662: selparser.c:706: # 4D 04 00 00 01 02 00 00 85 05 2C 59 20 00 04 24 64 00 00 00 7F 05 FF FF # 44d | 05/29/2017 12:27:01 | CIMC | Platform alert P2_DIMM_E1_LED #0x64 | LED color is amber | Asserted
5:2017 May 29 12:27:01 BST:BMC:selparser:1662: selparser.c:706: # 4E 04 00 00 01 02 00 00 85 05 2C 59 20 00 04 24 6A 00 00 00 7F 01 FF FF # 44e | 05/29/2017 12:27:01 | CIMC | Platform alert P2_DIMM_F1_LED #0x6a | LED is on | Asserted
5:2017 May 29 12:27:01 BST:BMC:selparser:1662: selparser.c:706: # 4F 04 00 00 01 02 00 00 85 05 2C 59 20 00 04 24 6A 00 00 00 7F 05 FF FF # 44f | 05/29/2017 12:27:01 | CIMC | Platform alert P2_DIMM_F1_LED #0x6a | LED color is amber | Asserted
5:2017 May 29 12:27:01 BST:BMC:selparser:1662: selparser.c:706: # 50 04 00 00 01 02 00 00 85 05 2C 59 20 00 04 24 70 00 00 00 7F 01 FF FF # 450 | 05/29/2017 12:27:01 | CIMC | Platform alert P2_DIMM_G1_LED #0x70 | LED is on | Asserted
5:2017 May 29 12:27:01 BST:BMC:selparser:1662: selparser.c:706: # 51 04 00 00 01 02 00 00 85 05 2C 59 20 00 04 24 70 00 00 00 7F 05 FF FF # 451 | 05/29/2017 12:27:01 | CIMC | Platform alert P2_DIMM_G1_LED #0x70 | LED color is amber | Asserted
5:2017 May 29 12:27:01 BST:BMC:selparser:1662: selparser.c:706: # 52 04 00 00 01 02 00 00 85 05 2C 59 20 00 04 24 76 00 00 00 7F 01 FF FF # 452 | 05/29/2017 12:27:01 | CIMC | Platform alert P2_DIMM_H1_LED #0x76 | LED is on | Asserted
5:2017 May 29 12:27:01 BST:BMC:selparser:1662: selparser.c:706: # 53 04 00 00 01 02 00 00 85 05 2C 59 20 00 04 24 76 00 00 00 7F 05 FF FF # 453 | 05/29/2017 12:27:01 | CIMC | Platform alert P2_DIMM_H1_LED #0x76 | LED color is amber | Asserted
5:2017 May 29 12:27:01 BST:BMC:selparser:1662: selparser.c:706: # 54 04 00 00 01 02 00 00 85 05 2C 59 20 00 04 07 BD 00 00 00 05 01 FF FF # 454 | 05/29/2017 12:27:01 | CIMC | Processor P1_THERMTRIP_N #0xbd | Limit Exceeded | Asserted
5:2017 May 29 12:27:01 BST:BMC:selparser:1662: selparser.c:706: # 55 04 00 00 01 02 00 00 85 05 2C 59 20 00 04 07 BE 00 00 00 05 01 FF FF # 455 | 05/29/2017 12:27:01 | CIMC | Processor P2_THERMTRIP_N #0xbe | Limit Exceeded | Asserted
2:2017 May 29 12:27:04 BST:BMC:IPMI:1591: PowerOnFail.c:55:PowerOnFail_Read:PowerOnFail on for 10 Scan Cycles Turning Power Off
2:2017 May 29 12:27:04 BST:BMC:kernel:-:<2>[host_power_ioctl]:957:POWER ON FAILURE has been detected
5:2017 May 29 12:27:04 BST:BMC:kernel:-:<5>[__do_power_off]:325:__do_power_off
5:2017 May 29 12:27:05 BST:BMC:IPMI:1591: Pilot2SrvPower.c:346:Pilot2SrvPowerOff
5:2017 May 29 12:27:05 BST:BMC:IPMI:1591: Pilot2SrvPower.c:466:Blade Power Changed To: [ OFF ]
5:2017 May 29 12:27:05 BST:BMC:IPMI:1591: Rack_FanCtrl.c:1272:fscUpdateActualFanPolicyFile: Applied Policy: N/A, Configuration Status: PENDING - Host powered off
5:2017 May 29 12:27:05 BST:BMC:video_trigger:-: video_trigger.c:280:Sending event_ipmi_power_state_change (OFF) ..
5:2017 May 29 12:27:06 BST:BMC:selparser:1662: selparser.c:706: # 56 04 00 00 01 02 00 00 8A 05 2C 59 20 00 04 24 08 00 00 00 04 00 FF FF # 456 | 05/29/2017 12:27:06 | CIMC | Platform alert POWER_ON_FAIL #0x08 | Predictive Failure deasserted | Asserted
5:2017 May 29 12:27:12 BST:BMC:IPMI:1591: Bridge.c:1468:audit from:kcs Fn:0x0 Cmd:0x2 Data: 0x0
5:2017 May 29 12:27:12 BST:BMC:IPMI:1591: Bridge.c:1474:audit Resp:0x0
5:2017 May 29 12:27:12 BST:BMC:AUDIT:1796: Server power state modify (op:power-off)
5:2017 May 29 12:27:14 BST:BMC:blade-power:3918: host-power.c:53:POWER Off
5:2017 May 29 12:27:14 BST:BMC:kernel:-:<5>[__do_power_off]:325:__do_power_off
5:2017 May 29 12:27:14 BST:BMC:run-update:3920: ../../src/runupdate.c:550:Run-update Process Starting.
5:2017 May 29 12:27:14 BST:BMC:run-update:3920: ../../src/runupdate.c:54:lock state = 0
5:2017 May 29 12:27:19 BST:BMC:run-update:3920: ../../src/runupdate.c:711:
5:2017 May 29 12:27:19 BST:BMC:run-update:3920: ../../src/runupdate.c:712:  Device 1 - CPLD
5:2017 May 29 12:27:19 BST:BMC:run-update:3920: ../../src/runupdate.c:713:    File Version: 31553032
5:2017 May 29 12:27:20 BST:BMC:run-update:3920: ../../src/runupdate.c:735:    Chip Version: 31553032
5:2017 May 29 12:27:20 BST:BMC:run-update:3920: cpld.c:97:  CPLD version compare
5:2017 May 29 12:27:20 BST:BMC:run-update:3920: cpld.c:101:    Chip and file version match.
5:2017 May 29 12:27:20 BST:BMC:run-update:3920: ../../src/runupdate.c:761:    Skipping device.
5:2017 May 29 12:27:20 BST:BMC:run-update:3920: ../../src/runupdate.c:711:
5:2017 May 29 12:27:20 BST:BMC:run-update:3920: ../../src/runupdate.c:712:  Device 2 - FPGA
5:2017 May 29 12:27:20 BST:BMC:run-update:3920: ../../src/runupdate.c:713:    File Version: C8061554
5:2017 May 29 12:27:20 BST:BMC:run-update:3920: ../../src/runupdate.c:735:    Chip Version: C8061554
5:2017 May 29 12:27:20 BST:BMC:run-update:3920: fpga.c:152:  FPGA version compare
5:2017 May 29 12:27:20 BST:BMC:run-update:3920: fpga.c:156:    Chip and file version match.
5:2017 May 29 12:27:20 BST:BMC:run-update:3920: ../../src/runupdate.c:712:  Device 3 - PWRSEQ_MAIN
5:2017 May 29 12:27:20 BST:BMC:run-update:3920: ../../src/runupdate.c:713:    File Version: PILOT-V3.1
5:2017 May 29 12:27:20 BST:BMC:run-update:3920: ../../src/runupdate.c:735:    Chip Version: PILOT-V3.1
5:2017 May 29 12:27:20 BST:BMC:run-update:3920: pwrsequencer.c:97:  PWRSEQ_MAIN version compare
5:2017 May 29 12:27:20 BST:BMC:run-update:3920: pwrsequencer.c:101:    Chip and file version match.
5:2017 May 29 12:27:20 BST:BMC:run-update:3920: ../../src/runupdate.c:712:  Device 4 - PWRSEQ_CPU
5:2017 May 29 12:27:21 BST:BMC:run-update:3920: ../../src/runupdate.c:735:    Chip Version: PILOT-V3.1
5:2017 May 29 12:27:21 BST:BMC:run-update:3920: pwrsequencer.c:97:  PWRSEQ_CPU version compare
5:2017 May 29 12:27:21 BST:BMC:run-update:3920: pwrsequencer.c:101:    Chip and file version match.
5:2017 May 29 12:27:21 BST:BMC:run-update:3920: ../../src/runupdate.c:761:    Skipping device.
5:2017 May 29 12:27:21 BST:BMC:run-update:3920: ../../src/runupdate.c:711:
5:2017 May 29 12:27:21 BST:BMC:run-update:3920: ../../src/runupdate.c:712:  Device 5 - PWRSEQ_STANDBY
5:2017 May 29 12:27:21 BST:BMC:run-update:3920: ../../src/runupdate.c:713:    File Version: PILOT-V3.1
5:2017 May 29 12:27:21 BST:BMC:run-update:3920: pwrsequencer.c:97:  PWRSEQ_STANDBY version compare
5:2017 May 29 12:27:21 BST:BMC:run-update:3920: ../../src/runupdate.c:712:  Device 6 - ASTORIA
5:2017 May 29 12:27:21 BST:BMC:run-update:3920: ../../src/runupdate.c:713:    File Version: 1.2 build 258#012
5:2017 May 29 12:27:22 BST:BMC:run-update:3920: ../../src/runupdate.c:735:    Chip Version: 1.2 build 258#012
5:2017 May 29 12:27:22 BST:BMC:run-update:3920: ../../src/devices/astoria.c:58:  Astoria version compare
5:2017 May 29 12:27:22 BST:BMC:run-update:3920: ../../src/runupdate.c:761:    Skipping device.
5:2017 May 29 12:27:22 BST:BMC:run-update:3920: ../../src/runupdate.c:711:
5:2017 May 29 12:27:22 BST:BMC:run-update:3920: ../../src/runupdate.c:712:  Device 7 - PSU1
5:2017 May 29 12:27:22 BST:BMC:run-update:3920: ../../src/runupdate.c:713:    File Version: 12022215
5:2017 May 29 12:27:22 BST:BMC:run-update:3920: ../../src/runupdate.c:735:    Chip Version: 12022215
5:2017 May 29 12:27:22 BST:BMC:run-update:3920: psu.c:131:  PSU1 update NOT required
5:2017 May 29 12:27:23 BST:BMC:run-update:3920: ../../src/runupdate.c:711:
5:2017 May 29 12:27:23 BST:BMC:run-update:3920: ../../src/runupdate.c:712:  Device 8 - PSU2
5:2017 May 29 12:27:23 BST:BMC:run-update:3920: ../../src/runupdate.c:713:    File Version: 12022215
5:2017 May 29 12:27:23 BST:BMC:run-update:3920: ../../src/runupdate.c:735:    Chip Version: 12022215
5:2017 May 29 12:27:23 BST:BMC:run-update:3920: psu.c:131:  PSU2 update NOT required
5:2017 May 29 12:27:23 BST:BMC:run-update:3920: ../../src/runupdate.c:761:    Skipping device.
5:2017 May 29 12:27:23 BST:BMC:run-update:3920: ../../src/runupdate.c:930:Run-update Process Complete. rc: 0#012
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ19
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ20
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ21
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ22
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ23
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ24
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ25
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ26
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ27
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ28
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ29
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ30
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ31
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ32
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ33
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ34
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ35
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ36
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ37
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ38
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ39
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ40
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ41
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ42
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ43
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ44
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ45
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ46
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ47
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ48
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ49
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ50
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ51
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ52
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ53
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ54
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ55
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ56
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ57
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ58
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ59
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ60
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ61
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ62
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ63
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ64
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ65
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ66
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ67
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ68
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ69
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ70
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ71
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ72
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ73
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ74
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ75
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ76
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ77
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ78
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Pilot3 Interrupt Controller Enabled and Configured.
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Pilot-II Timer Initialized
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Pilot-II Timer Started
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Console: colour dummy device 80x30
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>Mount-cache hash table entries: 512
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>bio: create slab <bio-0> at 0
4:2017 May 29 13:19:39 BST:BMC:kernel:-:<4>NetWinder Floating Point Emulator V0.97 (double precision)
5:2017 May 29 13:19:39 BST:BMC:pmbus_pwrsply_mngr:1552: pmbus_pwrsply_mngr.c:1757:Power Supply 0x1 Presence Changed to present.
5:2017 May 29 13:19:39 BST:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [sm]
5:2017 May 29 13:19:39 BST:BMC:doctor-bmc:1721: app_monitor.c:234:Process, sm, successfully started.
5:2017 May 29 13:19:40 BST:BMC:pmbus_pwrsply_mngr:1552: pmbus_pwrsply_mngr.c:1757:Power Supply 0x2 Presence Changed to present.
5:2017 May 29 13:19:40 BST:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [bioscomd]
5:2017 May 29 13:19:40 BST:BMC:doctor-bmc:1729: app_monitor.c:234:Process, bioscomd, successfully started.
5:2017 May 29 13:19:40 BST:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [lv_dimmd]
5:2017 May 29 13:19:40 BST:BMC:doctor-bmc:1738: app_monitor.c:234:Process, lv_dimmd, successfully started.
5:2017 May 29 13:19:41 BST:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [fault-engined]
5:2017 May 29 13:19:41 BST:BMC:doctor-bmc:1746: app_monitor.c:234:Process, fault-engined, successfully started.
4:2017 May 29 13:19:41 BST:BMC:kernel:-:<4>name is Pilot3 Tulip
4:2017 May 29 13:19:41 BST:BMC:kernel:-:<4>BROADCOM: PHY found at phy address 19!!
4:2017 May 29 13:19:41 BST:BMC:kernel:-:<4>MV Switch Port 5 Enable status: 7f
5:2017 May 29 13:19:41 BST:BMC:kernel:-:<5>Nand Astoria Mark 17
4:2017 May 29 13:19:41 BST:BMC:kernel:-:<4>EMS CLI Work queue is created successfully
4:2017 May 29 13:19:41 BST:BMC:kernel:-:<4>Entered m25pxx_init
4:2017 May 29 13:19:41 BST:BMC:kernel:-:<4>Fast clk is set
4:2017 May 29 13:19:41 BST:BMC:kernel:-:<4>C220 EVT1/P1 board detected. If wrong, fix CPLD programming
4:2017 May 29 13:19:41 BST:BMC:kernel:-:<4>Strap is SET for HOST spi
4:2017 May 29 13:19:41 BST:BMC:kernel:-:<4>Warning: unable to open an initial console.
5:2017 May 29 13:19:41 BST:BMC:kernel:-:<5>[host_power_init]:1458:INIT Blade Power State is ... [ OFF ]
5:2017 May 29 13:19:41 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 13:19:41 BST:BMC:kernel:-:<5>Pilot3 SPI Flash mapping: 0x4000000 at 0x0
4:2017 May 29 13:19:41 BST:BMC:kernel:-:<4>No of banks = 6
4:2017 May 29 13:19:41 BST:BMC:kernel:-:<4>Probing for Flash at Bank # 0
4:2017 May 29 13:19:41 BST:BMC:kernel:-:<4>SPI: probing for intel s33 devices ...
4:2017 May 29 13:19:41 BST:BMC:kernel:-:<4>SPI: probing for atmel devices ...
4:2017 May 29 13:19:41 BST:BMC:kernel:-:<4>SPI: probing for m25pxx devices ...
4:2017 May 29 13:19:41 BST:BMC:kernel:-:<4>20 0 0 262144
4:2017 May 29 13:19:41 BST:BMC:kernel:-:<4>Probing for Flash at Bank # 1
4:2017 May 29 13:19:41 BST:BMC:kernel:-:<4>19 0 0 262144
4:2017 May 29 13:19:41 BST:BMC:kernel:-:<4>Probing for Flash at Bank # 2
4:2017 May 29 13:19:41 BST:BMC:kernel:-:<4>18 0 0 262144
4:2017 May 29 13:19:41 BST:BMC:kernel:-:<4>Probing for Flash at Bank # 3
4:2017 May 29 13:19:41 BST:BMC:kernel:-:<4>17 0 0 262144
4:2017 May 29 13:19:41 BST:BMC:kernel:-:<4>Probing for Flash at Bank # 4
4:2017 May 29 13:19:41 BST:BMC:kernel:-:<4>16 0 0 262144
4:2017 May 29 13:19:41 BST:BMC:kernel:-:<4>Probing for Flash at Bank # 5
4:2017 May 29 13:19:41 BST:BMC:kernel:-:<4>15 0 0 262144
5:2017 May 29 13:19:41 BST:BMC:kernel:-:<5>Concatenating MTD devices:
5:2017 May 29 13:19:41 BST:BMC:kernel:-:<5>(0): "Pilot3 SPI MAP"
5:2017 May 29 13:19:41 BST:BMC:kernel:-:<5>(1): "Pilot3 SPI MAP"
5:2017 May 29 13:19:41 BST:BMC:kernel:-:<5>(2): "Pilot3 SPI MAP"
5:2017 May 29 13:19:41 BST:BMC:kernel:-:<5>(3): "Pilot3 SPI MAP"
5:2017 May 29 13:19:41 BST:BMC:kernel:-:<5>(4): "Pilot3 SPI MAP"
5:2017 May 29 13:19:41 BST:BMC:kernel:-:<5>(5): "Pilot3 SPI MAP"
5:2017 May 29 13:19:41 BST:BMC:kernel:-:<5>into device "Concat Ractrends"
5:2017 May 29 13:19:41 BST:BMC:kernel:-:<5>Creating 15 MTD partitions on "Concat Ractrends":
5:2017 May 29 13:19:41 BST:BMC:kernel:-:<5>0x000000000000-0x000006000000 : "all"
5:2017 May 29 13:19:41 BST:BMC:kernel:-:<5>0x000000000000-0x000000080000 : "U-Boot"
5:2017 May 29 13:19:41 BST:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [gdsd]
5:2017 May 29 13:19:41 BST:BMC:kernel:-:<5>0x000000080000-0x0000000c0000 : "boot.conf"
5:2017 May 29 13:19:41 BST:BMC:doctor-bmc:1760: app_monitor.c:234:Process, gdsd, successfully started.
5:2017 May 29 13:19:41 BST:BMC:kernel:-:<5>0x0000000c0000-0x000000100000 : "RSVD"
5:2017 May 29 13:19:41 BST:BMC:kernel:-:<5>0x000000100000-0x000000880000 : "Linux1"
5:2017 May 29 13:19:41 BST:BMC:kernel:-:<5>0x000000880000-0x000001000000 : "Linux2"
5:2017 May 29 13:19:41 BST:BMC:kernel:-:<5>0x000001000000-0x000001800000 : "NV_0"
5:2017 May 29 13:19:41 BST:BMC:kernel:-:<5>0x000001800000-0x000002000000 : "OBFL"
5:2017 May 29 13:19:41 BST:BMC:lv_dimm:1740: lv_dimm.c:200:[transition_function]Starting Transition to [High Voltage Mode] from [Unknown Mode]
5:2017 May 29 13:19:41 BST:BMC:kernel:-:<5>0x000002000000-0x000003000000 : "NV_1"
5:2017 May 29 13:19:41 BST:BMC:lv_dimm:1740: common.c:941:Disabling Sensor scan for sensor 0x83.
5:2017 May 29 13:19:41 BST:BMC:lv_dimm:1740: common.c:941:Disabling Sensor scan for sensor 0x84.
5:2017 May 29 13:19:41 BST:BMC:lv_dimm:1740: common.c:941:Disabling Sensor scan for sensor 0x85.
5:2017 May 29 13:19:41 BST:BMC:kernel:-:<5>0x000003000000-0x000004000000 : "NV_2"
5:2017 May 29 13:19:41 BST:BMC:lv_dimm:1740: common.c:941:Disabling Sensor scan for sensor 0x86.
5:2017 May 29 13:19:41 BST:BMC:lv_dimm:1740: common.c:941:Disabling Sensor scan for sensor 0x89.
5:2017 May 29 13:19:42 BST:BMC:lv_dimm:1740: common.c:941:Disabling Sensor scan for sensor 0x8a.
5:2017 May 29 13:19:42 BST:BMC:lv_dimm:1740: common.c:941:Disabling Sensor scan for sensor 0x91.
5:2017 May 29 13:19:42 BST:BMC:lv_dimm:1740: common.c:941:Disabling Sensor scan for sensor 0x92.
5:2017 May 29 13:19:42 BST:BMC:kernel:-:<5>0x000004000000-0x000004800000 : "P2_NV_0"
5:2017 May 29 13:19:42 BST:BMC:kernel:-:<5>0x000004800000-0x000004940000 : "P2_OBFL"
5:2017 May 29 13:19:42 BST:BMC:kernel:-:<5>0x000004940000-0x000004c80000 : "NV_3"
5:2017 May 29 13:19:42 BST:BMC:kernel:-:<5>0x000004c80000-0x000004fc0000 : "NV_4"
5:2017 May 29 13:19:42 BST:BMC:lv_dimm:1740: lv_dimm.c:220:[transition_function]Transition to [High Voltage Mode] Success
5:2017 May 29 13:19:42 BST:BMC:kernel:-:<5>0x000004fc0000-0x000005000000 : "RSVD_NVRAM"
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>Major number for pwmtach driver is - 235
5:2017 May 29 13:19:42 BST:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [mem_throttled]
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4> PWM and Fan tach configuration registers
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>PWCFG: 55  addr: c7946000
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMCFG: ff  addr: c7946004
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>PWOCF: 0  addr: c7946008
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4> Fan tach  Interrupt Register
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FTISR: 0  addr: c794600c
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4> PWM control & stat reg , enables counter resolution
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>PWCRCSR: 55, addr: c7946010
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>Counter resolution reg, sets no of clock cycles for PWM
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>PWCRVR0: 1e, addr: c7946014
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>PWCRVR1: 1e, addr: c7946018
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>PWCRVR2: 1e, addr: c794601c
5:2017 May 29 13:19:42 BST:BMC:doctor-bmc:1768: app_monitor.c:234:Process, mem_throttled, successfully started.
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>PWCRVR3: 1e, addr: c7946020
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4> PWM pre scale register, sets clock divider for PWM
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4> PWM  duty cycle reg, sets no of high pulses
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>PWPSR0: a, addr: c7946040
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>PWDCR0: 15, addr: c7946044
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>PWPSR1: a
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>PWDCR1: 15
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>PWPSR2: a
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>PWDCR2: 15
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>PWPSR3: a
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>PWDCR3: 15
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4> Fan tach threshold reg, sets max no of clock between pulses
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMTHR0: ff, addr: c7946060
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMTHR1: ff
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMTHR2: ff
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMTHR3: ff
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMTHR4: ff
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMTHR5: ff
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMTHR6: ff
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMTHR7: ff
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4> Fan tach speed reg, set automatically
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMSPR0: 0, addr c7946064
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMSPR1: 0
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMSPR2: 0
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMSPR3: 0
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMSPR4: 0
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMSPR5: 0
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMSPR6: 0
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMSPR7: 0
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4> Fan tach control& stat reg,
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMCSR0: 60 addr c7946068
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMCSR1: 60
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMCSR2: 60
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMCSR3: 60
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMCSR4: 60
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMCSR5: 60
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMCSR6: 60
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMCSR7: 60
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4> Fan Tach filter select reg, sets filter value if filter is enabled
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMPFSR0: 0
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMPFSR1: 0
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4> SET2 - PWM and Fan tach configuration registers
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>PWCFG1: 55  addr: c7946100
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMCFG1: ff  addr: c7946104
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>PWOCF1: 0  addr: c7946108
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FTISR1: 0  addr: c794610c
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>PWCRCSR1: 55, addr: c7946110
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>PWCRVR4: 1e, addr: c7946114
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>PWCRVR5: 1e, addr: c7946118
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>PWCRVR6: 1e, addr: c794611c
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>PWCRVR7: 1e, addr: c7946120
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>PWPSR4: a, addr: c7946140
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>PWDCR4: 15, addr: c7946144
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>PWPSR5: a
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>PWDCR5: 15
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>PWPSR6: a
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>PWDCR6: 15
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>PWPSR7: a
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>PWDCR7: 15
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMTHR8: ff, addr: c7946160
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMTHR9: ff
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMTHR10: ff
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMTHR11: ff
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMTHR12: ff
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMTHR13: ff
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMTHR14: ff
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMTHR15: ff
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMSPR8: 0 addr c7946164
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMSPR9: 0
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMSPR10: 0
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMSPR11: 0
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMSPR12: 0
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMSPR13: 0
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMSPR14: 0
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMSPR15: 0
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMCSR8: 60 addr c7946168
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMCSR9: 60
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMCSR10: 60
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMCSR11: 60
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMCSR12: 60
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMCSR13: 60
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMCSR14: 60
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMCSR15: 60
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMPFSR2: 0
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>FMPFSR3: 0
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>***************PWM Driver has been initialized****************
5:2017 May 29 13:19:42 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2773:USB FS: VDD Power Good = OFF
5:2017 May 29 13:19:42 BST:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [qpi_loggerd]
5:2017 May 29 13:19:42 BST:BMC:IPMI:1592: LED_Control.c:81:    -> Sensor[10]: Turning LED[10] (LED_FAN2_FAULT) OFF
5:2017 May 29 13:19:42 BST:BMC:IPMI:1592: LED_Control.c:81:    -> Sensor[12]: Turning LED[12] (LED_FAN4_FAULT) OFF
5:2017 May 29 13:19:42 BST:BMC:doctor-bmc:1776: app_monitor.c:234:Process, qpi_loggerd, successfully started.
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4> CyAnDevice: Cannot get firmware version. Reason code: 81
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4> CyAnDevice: CyAsMiscConfigureDevice: No Firmware loaded: 81
5:2017 May 29 13:19:42 BST:BMC:kernel:-:<5> CyAnDevice: Downloading Astoria firmware 1
5:2017 May 29 13:19:42 BST:BMC:kernel:-:<5> CyAnDevice: Astoria firmware has been initialized
4:2017 May 29 13:19:42 BST:BMC:IPMI:1592: PSRedundantMode.c:51:PSRdntMode_Read --> Failed to open file /var/pmbus/ps_redundancy_state for read.
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>setting perfect hw filtering mode (c63d34f8)
4:2017 May 29 13:19:42 BST:BMC:kernel:-:<4>setting perfect hw filtering mode (c70554f8)
4:2017 May 29 13:19:46 BST:BMC:kernel:-:last message repeated 5 times
4:2017 May 29 13:19:43 BST:BMC:kernel:-:<4>EXT2-fs (loop0): warning: mounting unchecked fs, running e2fsck is recommended
5:2017 May 29 13:19:43 BST:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x30 : Status = 0x83
5:2017 May 29 13:19:43 BST:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x31 : Status = 0x80
5:2017 May 29 13:19:43 BST:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x33 : Status = 0x83
5:2017 May 29 13:19:43 BST:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x34 : Status = 0x80
5:2017 May 29 13:19:43 BST:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x20 : Status = 0x83
5:2017 May 29 13:19:43 BST:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x21 : Status = 0x80
5:2017 May 29 13:19:43 BST:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x23 : Status = 0x83
5:2017 May 29 13:19:43 BST:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x24 : Status = 0x80
5:2017 May 29 13:19:43 BST:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x10 : Status = 0x83
5:2017 May 29 13:19:43 BST:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x11 : Status = 0x80
5:2017 May 29 13:19:43 BST:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x13 : Status = 0x83
5:2017 May 29 13:19:43 BST:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x14 : Status = 0x80
5:2017 May 29 13:19:43 BST:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x0 : Status = 0x83
5:2017 May 29 13:19:43 BST:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x1 : Status = 0x80
5:2017 May 29 13:19:43 BST:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x3 : Status = 0x83
5:2017 May 29 13:19:43 BST:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x4 : Status = 0x80
5:2017 May 29 13:19:43 BST:BMC:selparser:1663: selparser.c:706: # 57 04 00 00 01 02 00 00 DE 11 2C 59 20 00 04 24 08 00 00 00 04 00 FF FF # 457 | 05/29/2017 13:19:42 | CIMC | Platform alert POWER_ON_FAIL #0x08 | Predictive Failure deasserted | Asserted
5:2017 May 29 13:19:43 BST:BMC:selparser:1663: selparser.c:706: # 58 04 00 00 01 02 00 00 DE 11 2C 59 20 00 04 25 0A 00 00 00 08 01 FF FF # 458 | 05/29/2017 13:19:42 | CIMC | Entity presence FAN2_PRSNT #0x0a | Device Present | Asserted
5:2017 May 29 13:19:43 BST:BMC:selparser:1663: selparser.c:706: # 59 04 00 00 01 02 00 00 DE 11 2C 59 20 00 04 25 0C 00 00 00 08 01 FF FF # 459 | 05/29/2017 13:19:42 | CIMC | Entity presence FAN4_PRSNT #0x0c | Device Present | Asserted
5:2017 May 29 13:19:43 BST:BMC:selparser:1663: selparser.c:706: # 5A 04 00 00 01 02 00 00 DE 11 2C 59 20 00 04 25 1E 00 00 00 08 01 FF FF # 45a | 05/29/2017 13:19:42 | CIMC | Entity presence RISER2_PRESENT #0x1e | Device Present | Asserted
5:2017 May 29 13:19:43 BST:BMC:selparser:1663: selparser.c:706: # 5B 04 00 00 01 02 00 00 DE 11 2C 59 20 00 04 25 24 00 00 00 08 01 FF FF # 45b | 05/29/2017 13:19:42 | CIMC | Entity presence RISER1_PRESENT_1 #0x24 | Device Present | Asserted
5:2017 May 29 13:19:43 BST:BMC:selparser:1663: selparser.c:706: # 5C 04 00 00 01 02 00 00 DE 11 2C 59 20 00 04 24 36 00 00 00 7F 01 FF FF # 45c | 05/29/2017 13:19:42 | CIMC | Platform alert LED_PSU_STATUS #0x36 | LED is on | Asserted
5:2017 May 29 13:19:43 BST:BMC:selparser:1663: selparser.c:706: # 5D 04 00 00 01 02 00 00 DE 11 2C 59 20 00 04 24 36 00 00 00 7F 04 FF FF # 45d | 05/29/2017 13:19:42 | CIMC | Platform alert LED_PSU_STATUS #0x36 | LED color is green | Asserted
5:2017 May 29 13:19:43 BST:BMC:selparser:1663: selparser.c:706: # 5E 04 00 00 01 02 00 00 DE 11 2C 59 20 00 04 24 38 00 00 00 7F 01 FF FF # 45e | 05/29/2017 13:19:42 | CIMC | Platform alert LED_FAN_STATUS #0x38 | LED is on | Asserted
5:2017 May 29 13:19:43 BST:BMC:selparser:1663: selparser.c:706: # 5F 04 00 00 01 02 00 00 DE 11 2C 59 20 00 04 24 38 00 00 00 7F 04 FF FF # 45f | 05/29/2017 13:19:42 | CIMC | Platform alert LED_FAN_STATUS #0x38 | LED color is green | Asserted
5:2017 May 29 13:19:43 BST:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [xapid]
5:2017 May 29 13:19:43 BST:BMC:doctor-bmc:1799: app_monitor.c:234:Process, xapid, successfully started.
5:2017 May 29 13:19:43 BST:BMC:IPMI:1592: LED_Control.c:81:    -> Sensor[9]: Turning LED[9] (LED_FAN1_FAULT) OFF
5:2017 May 29 13:19:43 BST:BMC:IPMI:1592: LED_Control.c:81:    -> Sensor[11]: Turning LED[11] (LED_FAN3_FAULT) OFF
5:2017 May 29 13:19:43 BST:BMC:IPMI:1592: LED_Control.c:81:    -> Sensor[13]: Turning LED[13] (LED_FAN5_FAULT) OFF
5:2017 May 29 13:19:44 BST:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x14 : Status = 0x80
5:2017 May 29 13:19:44 BST:BMC:IPMI:1592: LED_Control.c:81:    -> Sensor[255]: Turning LED[25] (LED_DIMM_FAULT_P1_A2) OFF
5:2017 May 29 13:19:44 BST:BMC:IPMI:1592: LED_Control.c:81:    -> Sensor[255]: Turning LED[27] (LED_DIMM_FAULT_P1_B2) OFF
5:2017 May 29 13:19:44 BST:BMC:lv_dimm:1740: lv_dimm.c:403:[handle_event_enable_tick]enable sensor event
5:2017 May 29 13:19:44 BST:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x1 : Status = 0x80
5:2017 May 29 13:19:44 BST:BMC:lv_dimm:1740: common.c:946:Enabling sensor scan for sensor 0x83.
5:2017 May 29 13:19:44 BST:BMC:lv_dimm:1740: common.c:946:Enabling sensor scan for sensor 0x84.
5:2017 May 29 13:19:44 BST:BMC:lv_dimm:1740: common.c:946:Enabling sensor scan for sensor 0x85.
5:2017 May 29 13:19:44 BST:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x4 : Status = 0x80
5:2017 May 29 13:19:44 BST:BMC:lv_dimm:1740: common.c:946:Enabling sensor scan for sensor 0x86.
5:2017 May 29 13:19:44 BST:BMC:lv_dimm:1740: common.c:946:Enabling sensor scan for sensor 0x89.
5:2017 May 29 13:19:44 BST:BMC:lv_dimm:1740: common.c:946:Enabling sensor scan for sensor 0x8a.
5:2017 May 29 13:19:44 BST:BMC:kernel:-:<5>[__do_power_off]:325:__do_power_off
5:2017 May 29 13:19:44 BST:BMC:lv_dimm:1740: common.c:946:Enabling sensor scan for sensor 0x91.
5:2017 May 29 13:19:44 BST:BMC:lv_dimm:1740: common.c:946:Enabling sensor scan for sensor 0x92.
5:2017 May 29 13:19:44 BST:BMC:lv_dimm:1740: sanluis1/platform.c:117:platform_event_enable_tick_end: Configuring IR from CIMC
5:2017 May 29 13:19:44 BST:BMC:IPMI:1592: LED_Control.c:81:    -> Sensor[255]: Turning LED[29] (LED_DIMM_FAULT_P1_C2) OFF
5:2017 May 29 13:19:44 BST:BMC:IPMI:1592: LED_Control.c:81:    -> Sensor[255]: Turning LED[31] (LED_DIMM_FAULT_P1_D2) OFF
5:2017 May 29 13:19:44 BST:BMC:IPMI:1592: LED_Control.c:81:    -> Sensor[255]: Turning LED[33] (LED_DIMM_FAULT_P2_E2) OFF
5:2017 May 29 13:19:44 BST:BMC:IPMI:1592: LED_Control.c:81:    -> Sensor[255]: Turning LED[35] (LED_DIMM_FAULT_P2_F2) OFF
5:2017 May 29 13:19:44 BST:BMC:IPMI:1592: LED_Control.c:81:    -> Sensor[255]: Turning LED[37] (LED_DIMM_FAULT_P2_G2) OFF
5:2017 May 29 13:19:44 BST:BMC:IPMI:1592: LED_Control.c:81:    -> Sensor[255]: Turning LED[39] (LED_DIMM_FAULT_P2_H2) OFF
5:2017 May 29 13:19:44 BST:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [fcgi]
5:2017 May 29 13:19:44 BST:BMC:doctor-bmc:1805: app_monitor.c:234:Process, fcgi, successfully started.
5:2017 May 29 13:19:44 BST:BMC:selparser:1663: selparser.c:706: # 60 04 00 00 01 02 00 00 DF 11 2C 59 20 00 04 25 09 00 00 00 08 01 FF FF # 460 | 05/29/2017 13:19:43 | CIMC | Entity presence FAN1_PRSNT #0x09 | Device Present | Asserted
5:2017 May 29 13:19:44 BST:BMC:selparser:1663: selparser.c:706: # 61 04 00 00 01 02 00 00 DF 11 2C 59 20 00 04 25 0B 00 00 00 08 01 FF FF # 461 | 05/29/2017 13:19:43 | CIMC | Entity presence FAN3_PRSNT #0x0b | Device Present | Asserted
5:2017 May 29 13:19:44 BST:BMC:selparser:1663: selparser.c:706: # 62 04 00 00 01 02 00 00 DF 11 2C 59 20 00 04 25 0D 00 00 00 08 01 FF FF # 462 | 05/29/2017 13:19:43 | CIMC | Entity presence FAN5_PRSNT #0x0d | Device Present | Asserted
5:2017 May 29 13:19:44 BST:BMC:selparser:1663: selparser.c:706: # 63 04 00 00 01 02 00 00 DF 11 2C 59 20 00 04 25 1F 00 00 00 08 01 FF FF # 463 | 05/29/2017 13:19:43 | CIMC | Entity presence RISER1_PRESENT #0x1f | Device Present | Asserted
5:2017 May 29 13:19:44 BST:BMC:selparser:1663: selparser.c:706: # 64 04 00 00 01 02 00 00 DF 11 2C 59 20 00 04 25 23 00 00 00 08 01 FF FF # 464 | 05/29/2017 13:19:43 | CIMC | Entity presence RISER2_PRESENT_1 #0x23 | Device Present | Asserted
5:2017 May 29 13:19:44 BST:BMC:selparser:1663: selparser.c:706: # 65 04 00 00 01 02 00 00 DF 11 2C 59 20 00 04 24 37 00 00 00 7F 01 FF FF # 465 | 05/29/2017 13:19:43 | CIMC | Platform alert LED_TEMP_STATUS #0x37 | LED is on | Asserted
5:2017 May 29 13:19:44 BST:BMC:selparser:1663: selparser.c:706: # 66 04 00 00 01 02 00 00 DF 11 2C 59 20 00 04 24 37 00 00 00 7F 04 FF FF # 466 | 05/29/2017 13:19:43 | CIMC | Platform alert LED_TEMP_STATUS #0x37 | LED color is green | Asserted
5:2017 May 29 13:19:44 BST:BMC:selparser:1663: selparser.c:706: # 67 04 00 00 01 02 00 00 E0 11 2C 59 20 00 04 24 39 00 00 00 7F 01 FF FF # 467 | 05/29/2017 13:19:44 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED is on | Asserted
5:2017 May 29 13:19:44 BST:BMC:selparser:1663: selparser.c:706: # 68 04 00 00 01 02 00 00 E0 11 2C 59 20 00 04 24 39 00 00 00 7F 04 FF FF # 468 | 05/29/2017 13:19:44 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED color is green | Asserted
5:2017 May 29 13:19:44 BST:BMC:selparser:1663: selparser.c:706: # 69 04 00 00 01 02 00 00 E0 11 2C 59 20 00 04 25 A1 00 00 00 08 01 FF FF # 469 | 05/29/2017 13:19:44 | CIMC | Entity presence P2_PRESENT #0xa1 | Device Present | Asserted
5:2017 May 29 13:19:45 BST:BMC:selparser:1663: selparser.c:706: # 6A 04 00 00 01 02 00 00 E1 11 2C 59 20 00 04 25 A0 00 00 00 08 01 FF FF # 46a | 05/29/2017 13:19:45 | CIMC | Entity presence P1_PRESENT #0xa0 | Device Present | Asserted
5:2017 May 29 13:19:46 BST:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [monkey]
5:2017 May 29 13:19:46 BST:BMC:doctor-bmc:1833: app_monitor.c:234:Process, monkey, successfully started.
5:2017 May 29 13:19:46 BST:BMC:bios-update:1844: main.c:236:Running as Daemon
5:2017 May 29 13:19:47 BST:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [alertmgr]
5:2017 May 29 13:19:47 BST:BMC:doctor-bmc:1858: app_monitor.c:234:Process, alertmgr, successfully started.
4:2017 May 29 13:19:48 BST:BMC:IPMI:1592: PSRedundantMode.c:51:PSRdntMode_Read --> Failed to open file /var/pmbus/ps_redundancy_state for read.
5:2017 May 29 13:19:49 BST:BMC:bios-update:1844: activate.c:142:Setting BIOS Version
5:2017 May 29 13:19:53 BST:BMC:selparser:1663: selparser.c:706: # 6B 04 00 00 01 02 00 00 E9 11 2C 59 20 00 04 08 25 00 00 00 6F 30 FF 00 # 46b | 05/29/2017 13:19:53 | CIMC | Power supply PSU1_STATUS #0x25 | Presence detected |  | Asserted
5:2017 May 29 13:19:53 BST:BMC:selparser:1663: selparser.c:706: # 6C 04 00 00 01 02 00 00 E9 11 2C 59 20 00 04 08 26 00 00 00 6F 30 FF 00 # 46c | 05/29/2017 13:19:53 | CIMC | Power supply PSU2_STATUS #0x26 | Presence detected |  | Asserted
5:2017 May 29 13:19:53 BST:BMC:selparser:1663: selparser.c:706: # 6D 04 00 00 01 02 00 00 E9 11 2C 59 20 00 04 08 26 00 00 00 6F 33 FF 00 # 46d | 05/29/2017 13:19:53 | CIMC | Power supply PSU2_STATUS #0x26 | Power supply input lost (AC/DC) |  | Asserted
5:2017 May 29 13:19:53 BST:BMC:selparser:1663: selparser.c:706: # 6E 04 00 00 01 02 00 00 E9 11 2C 59 20 00 04 24 36 00 00 00 7F 05 FF FF # 46e | 05/29/2017 13:19:53 | CIMC | Platform alert LED_PSU_STATUS #0x36 | LED color is amber | Asserted
5:2017 May 29 13:19:53 BST:BMC:selparser:1663: selparser.c:706: # 6F 04 00 00 01 02 00 00 E9 11 2C 59 20 00 04 24 36 00 00 00 FF 04 FF FF # 46f | 05/29/2017 13:19:53 | CIMC | Platform alert LED_PSU_STATUS #0x36 | LED color is green | Deasserted
5:2017 May 29 13:19:53 BST:BMC:selparser:1663: selparser.c:706: # 70 04 00 00 01 02 00 00 E9 11 2C 59 20 00 04 24 39 00 00 00 7F 05 FF FF # 470 | 05/29/2017 13:19:53 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED color is amber | Asserted
5:2017 May 29 13:19:53 BST:BMC:selparser:1663: selparser.c:706: # 71 04 00 00 01 02 00 00 E9 11 2C 59 20 00 04 24 39 00 00 00 FF 04 FF FF # 471 | 05/29/2017 13:19:53 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED color is green | Deasserted
5:2017 May 29 13:19:54 BST:BMC:selparser:1663: selparser.c:706: # 72 04 00 00 01 02 00 00 EA 11 2C 59 20 00 04 08 3A 00 00 00 0B 03 FF FF # 472 | 05/29/2017 13:19:54 | CIMC | Power supply PS_RDNDNT_MODE #0x3a | Non-redundant | Asserted
5:2017 May 29 13:19:54 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2402:USB1 VDD power off
5:2017 May 29 13:19:57 BST:BMC:selparser:1663: selparser.c:706: # 73 04 00 00 01 02 00 00 ED 11 2C 59 20 00 04 08 2F 00 00 00 03 01 FF FF # 473 | 05/29/2017 13:19:57 | CIMC | Power supply PSU1_AC_OK #0x2f | State Asserted | Asserted
5:2017 May 29 13:19:57 BST:BMC:selparser:1663: selparser.c:706: # 74 04 00 00 01 02 00 00 ED 11 2C 59 20 00 04 08 31 00 00 00 03 00 FF FF # 474 | 05/29/2017 13:19:57 | CIMC | Power supply PSU2_AC_OK #0x31 | State Deasserted | Asserted
5:2017 May 29 13:20:00 BST:BMC:kernel:-:<5>Slow work thread pool: Starting up
5:2017 May 29 13:20:00 BST:BMC:kernel:-:<5>Slow work thread pool: Ready
5:2017 May 29 13:20:02 BST:BMC:DimmBL-DbSyncTask:1471: DimmBL-DbSyncTask.c:224:InitializeDimmBLSyncTask: SUCCESS
5:2017 May 29 13:20:03 BST:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [kvm]
5:2017 May 29 13:20:03 BST:BMC:doctor-bmc:1986: app_monitor.c:234:Process, kvm, successfully started.
5:2017 May 29 13:20:03 BST:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [vkvm_pm]
5:2017 May 29 13:20:03 BST:BMC:doctor-bmc:1993: app_monitor.c:234:Process, vkvm_pm, successfully started.
5:2017 May 29 13:20:04 BST:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [sshd]
5:2017 May 29 13:20:04 BST:BMC:doctor-bmc:2017: app_monitor.c:234:Process, sshd, successfully started.
5:2017 May 29 13:20:04 BST:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [cisco_pm]
5:2017 May 29 13:20:04 BST:BMC:doctor-bmc:2031: app_monitor.c:234:Process, cisco_pm, successfully started.
5:2017 May 29 13:20:04 BST:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [ciscoNET]
5:2017 May 29 13:20:05 BST:BMC:doctor-bmc:2041: app_monitor.c:234:Process, ciscoNET, successfully started.
5:2017 May 29 13:20:05 BST:BMC:ciscoNET:2043: ciscoNET.c:122:Application Starting
5:2017 May 29 13:20:05 BST:BMC:doctor-bmc-app-mon:2061: app_monitor.c:726:Started application monitor (2061)
5:2017 May 29 13:20:05 BST:BMC:doctor-bmc-app-mon:2061: app_monitor.c:481:cmp_proc_node_ctime: stat(/proc/1610) failed, errno 2 (No such file or directory)
5:2017 May 29 13:20:05 BST:BMC:doctor-bmc-app-mon:2061: app_monitor.c:636:cmp_proc_node_ctime sel_pigeon_cntrd stat(/proc/1610) returned errno 2 (No such file or directory)
4:2017 May 29 13:20:05 BST:BMC:doctor-bmc-app-mon:2061: app_monitor.c:592:Restarting Process sel_pigeon_cntrd
5:2017 May 29 13:20:05 BST:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [ucsm_state_manager]
5:2017 May 29 13:20:05 BST:BMC:doctor-bmc:2071: app_monitor.c:234:Process, ucsm_state_manager, successfully started.
5:2017 May 29 13:20:06 BST:BMC:ciscoNET:2043: network_manager.c:549:Configuring the network.
5:2017 May 29 13:20:06 BST:BMC:sel_pigeon_cntr:2067: sel_pigeon_cntr.c:917:Opening connection to SEL_PIGEON_CNTR_FIFO
5:2017 May 29 13:20:06 BST:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [GDSCommDmn]
5:2017 May 29 13:20:06 BST:BMC:doctor-bmc:2092: app_monitor.c:234:Process, GDSCommDmn, successfully started.
5:2017 May 29 13:20:07 BST:BMC:GDSCommDmn:-: GDSCommSVC.c:116:GDSComm SVC started
5:2017 May 29 13:20:07 BST:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [rack_monitor]
5:2017 May 29 13:20:07 BST:BMC:doctor-bmc:2098: app_monitor.c:234:Process, rack_monitor, successfully started.
5:2017 May 29 13:20:07 BST:BMC:rack_monitor:-: rack_monitor.c:397:RACK Montior in Stand-alone mode
5:2017 May 29 13:20:08 BST:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [sam_master]
5:2017 May 29 13:20:08 BST:BMC:doctor-bmc:2102: app_monitor.c:234:Process, sam_master, successfully started.
5:2017 May 29 13:20:08 BST:BMC:sam_master:-: sam_master.c:61:Stopping PTPD on Monitor Request
5:2017 May 29 13:20:08 BST:BMC:ciscoNET:2043: network_manager.c:793:Error: killall udhcpc returned exit code: 256
5:2017 May 29 13:20:08 BST:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [ciscovmd]
5:2017 May 29 13:20:08 BST:BMC:doctor-bmc:2108: app_monitor.c:234:Process, ciscovmd, successfully started.
5:2017 May 29 13:20:09 BST:BMC:doctor-bmc:-: doctor-bmc.c:308:doctor-bmc-app stop [ptpd]
5:2017 May 29 13:20:09 BST:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [video_triggerd]
5:2017 May 29 13:20:09 BST:BMC:doctor-bmc:2116: app_monitor.c:234:Process, video_triggerd, successfully started.
5:2017 May 29 13:20:09 BST:BMC:ciscoNET:2043: network_manager.c:795:Error: killall udhcpc6 returned exit code: 256
4:2017 May 29 13:20:10 BST:BMC:kernel:-:<4>setting perfect hw filtering mode (c70554f8)
5:2017 May 29 13:20:17 BST:BMC:hw-ether:2195: hw-ether.c:254:eth0's hardware address changed to f8:72:ea:a3:d6:ee
4:2017 May 29 13:20:17 BST:BMC:kernel:-:<4>setting perfect hw filtering mode (c70554f8)
4:2017 May 29 13:20:21 BST:BMC:kernel:-:last message repeated 6 times
4:2017 May 29 13:20:21 BST:BMC:ciscoNET:2043: network_manager.c:2082:Error: Can not open file, /etc/resolv.conf, with mode, r: 0x2.
5:2017 May 29 13:20:21 BST:BMC:ciscoNET:2043: cisco_cards_manager.c:204:There are no cisco configurable cards attached.
5:2017 May 29 13:20:22 BST:BMC:GDSCommDmn:-: GDSCommSVC.c:209:GDSComm started taking input connections.
5:2017 May 29 13:20:22 BST:BMC:IPMI:1592: Bridge.c:1468:audit from:kcs Fn:0x6 Cmd:0x56 Data: 0x1 0x0 0x1
5:2017 May 29 13:20:22 BST:BMC:IPMI:1592: Bridge.c:1474:audit Resp:0x0
5:2017 May 29 13:20:30 BST:BMC:dataserver:1795: eventsubscribemgnt.c:91:IsShmRestoreRequired: Restoration required!
5:2017 May 29 13:20:30 BST:BMC:dataserver:1795: eventsubscribemgnt.c:1193:RestoreEvtSubscCfg: Restored event subscription configuration successfully!
5:2017 May 29 13:20:32 BST:BMC:doctor-bmc:-: doctor-bmc.c:308:doctor-bmc-app stop [snmp-subagentd]
5:2017 May 29 13:20:32 BST:BMC:root:-: CIMC booted after a chassis power on!!
5:2017 May 29 13:20:32 BST:BMC:root:-: Waiting for MB FRU data to get populated..
5:2017 May 29 13:20:32 BST:BMC:root:-: MB FRU data populated successfully
5:2017 May 29 13:20:38 BST:BMC:root:-: NTP: CIMC IP acquired: 192.168.1.207
5:2017 May 29 13:20:38 BST:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [ntpd]
5:2017 May 29 13:20:38 BST:BMC:doctor-bmc:2408: app_monitor.c:234:Process, ntpd, successfully started.
3:2017 May 29 13:20:42 BST:BMC:update-ir:2352: ../../src/update-ir.c:234:Host should be powered-on for IR configuration update
5:2017 May 29 13:20:57 BST:BMC:root:-: DDNS: CIMC IP acquired: 192.168.1.207
5:2017 May 29 13:20:57 BST:BMC:root:-: DDNS: GATEWAY IP acquired: 192.168.1.254
4:2017 May 29 13:21:08 BST:BMC:kernel:-:<4>process `doctor-bmc' is using deprecated sysctl (syscall) net.ipv6.neigh.default.retrans_time; Use net.ipv6.neigh.default.retrans_time_ms instead.
2:2017 May 29 12:40:53 BST:BMC:fcgi:-: pam_local_manager(webgui:auth): Authentication Failure
3:2017 May 29 12:40:53 BST:BMC:fcgi:-: pam_auth_status(webgui:auth): Login Failed for host=192.168.1.129
5:2017 May 29 12:40:53 BST:BMC:AUDIT:1808: Login failed (ip:192.168.1.129, service:webgui)
5:2017 May 29 12:41:03 BST:BMC:fcgi:1808: pam_local_manager(webgui:account): requirement "privilege=0x01" was met by user "admin"
5:2017 May 29 12:41:03 BST:BMC:AUDIT:1808: Login success (user:admin, ip:192.168.1.129, service:webgui)
5:2017 May 29 12:41:03 BST:BMC:AUDIT:2033: Session open (user:admin, ip:192.168.1.129, id:1, type:webgui)
5:2017 May 29 12:41:03 BST:BMC:AUDIT:1808: Session open (user:admin, ip:192.168.1.129, id:1, type:webgui)
5:2017 May 29 12:44:05 BST:BMC:LLBL:1331: llbl.c:35:Locate Button Triggered
5:2017 May 29 12:44:06 BST:BMC:selparser:1663: selparser.c:706: # 75 04 00 00 01 02 00 00 85 09 2C 59 20 00 04 24 00 00 00 00 7F 02 FF FF # 475 | 05/29/2017 12:44:05 | CIMC | Platform alert FP_ID_LED #0x00 | LED is blinking fast | Asserted
5:2017 May 29 12:44:21 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 12:44:21 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 12:44:21 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 12:44:22 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 12:44:22 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 12:44:22 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 12:44:34 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 12:44:34 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 12:44:34 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 12:44:35 BST:BMC:LLBL:1331: llbl.c:35:Locate Button Triggered
5:2017 May 29 12:44:36 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 12:44:36 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 12:44:36 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 12:44:37 BST:BMC:selparser:1663: selparser.c:706: # 76 04 00 00 01 02 00 00 A4 09 2C 59 20 00 04 24 00 00 00 00 7F 00 FF FF # 476 | 05/29/2017 12:44:36 | CIMC | Platform alert FP_ID_LED #0x00 | LED is off | Asserted
5:2017 May 29 12:44:39 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 12:44:39 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 12:44:39 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 12:44:40 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 12:44:40 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 12:44:40 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 12:50:59 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 12:50:59 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 12:50:59 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 12:52:40 BST:BMC:selparser:1663: selparser.c:706: # 77 04 00 00 01 02 00 00 87 0B 2C 59 20 00 04 08 31 00 00 00 03 01 FF FF # 477 | 05/29/2017 12:52:39 | CIMC | Power supply PSU2_AC_OK #0x31 | State Asserted | Asserted
5:2017 May 29 12:52:44 BST:BMC:selparser:1663: selparser.c:706: # 78 04 00 00 01 02 00 00 8C 0B 2C 59 20 00 04 08 26 00 00 00 EF 33 FF 00 # 478 | 05/29/2017 12:52:44 | CIMC | Power supply PSU2_STATUS #0x26 | Power supply input lost (AC/DC) |  | Deasserted
5:2017 May 29 12:52:44 BST:BMC:selparser:1663: selparser.c:706: # 79 04 00 00 01 02 00 00 8C 0B 2C 59 20 00 04 24 36 00 00 00 7F 04 FF FF # 479 | 05/29/2017 12:52:44 | CIMC | Platform alert LED_PSU_STATUS #0x36 | LED color is green | Asserted
5:2017 May 29 12:52:44 BST:BMC:selparser:1663: selparser.c:706: # 7A 04 00 00 01 02 00 00 8C 0B 2C 59 20 00 04 24 36 00 00 00 FF 05 FF FF # 47a | 05/29/2017 12:52:44 | CIMC | Platform alert LED_PSU_STATUS #0x36 | LED color is amber | Deasserted
5:2017 May 29 12:52:44 BST:BMC:selparser:1663: selparser.c:706: # 7B 04 00 00 01 02 00 00 8C 0B 2C 59 20 00 04 24 39 00 00 00 7F 04 FF FF # 47b | 05/29/2017 12:52:44 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED color is green | Asserted
5:2017 May 29 12:52:44 BST:BMC:selparser:1663: selparser.c:706: # 7C 04 00 00 01 02 00 00 8C 0B 2C 59 20 00 04 24 39 00 00 00 FF 05 FF FF # 47c | 05/29/2017 12:52:44 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED color is amber | Deasserted
5:2017 May 29 12:52:44 BST:BMC:selparser:1663: selparser.c:706: # 7D 04 00 00 01 02 00 00 8C 0B 2C 59 20 00 04 08 3A 00 00 00 0B 00 FF FF # 47d | 05/29/2017 12:52:44 | CIMC | Power supply PS_RDNDNT_MODE #0x3a | Fully Redundant | Asserted
3:2017 May 29 12:52:53 BST:BMC:pmbus_pwrsply_mngr:1552: pmbus_pwrsply_mngr.c:2082:Power Supply 1 failure occurred: 0x0 0x0, ps_status=0x2849,  vin=0xa5, iin=0x3e, pin=0x2, pout=0x0, vout=0x0, iout=0x0
3:2017 May 29 12:52:53 BST:BMC:pmbus_pwrsply_mngr:1552: pmbus_pwrsply_mngr.c:2093:Power Supply 1 failured status registers: Vout 0x0 Iout 0x0 Input 0x38 Temp 0x0 CML 0x0 Fan 0x0
5:2017 May 29 12:52:54 BST:BMC:selparser:1663: selparser.c:706: # 7E 04 00 00 01 02 00 00 96 0B 2C 59 20 00 04 08 2F 00 00 00 03 00 FF FF # 47e | 05/29/2017 12:52:54 | CIMC | Power supply PSU1_AC_OK #0x2f | State Deasserted | Asserted
5:2017 May 29 12:52:54 BST:BMC:selparser:1663: selparser.c:706: # 7F 04 00 00 01 02 00 00 96 0B 2C 59 20 00 04 08 3A 00 00 00 0B 01 FF FF # 47f | 05/29/2017 12:52:54 | CIMC | Power supply PS_RDNDNT_MODE #0x3a | Redundancy Lost | Asserted
5:2017 May 29 12:52:55 BST:BMC:selparser:1663: selparser.c:706: # 80 04 00 00 01 02 00 00 97 0B 2C 59 20 00 04 08 25 00 00 00 6F 33 FF 00 # 480 | 05/29/2017 12:52:55 | CIMC | Power supply PSU1_STATUS #0x25 | Power supply input lost (AC/DC) |  | Asserted
5:2017 May 29 12:52:55 BST:BMC:selparser:1663: selparser.c:706: # 81 04 00 00 01 02 00 00 97 0B 2C 59 20 00 04 24 36 00 00 00 7F 05 FF FF # 481 | 05/29/2017 12:52:55 | CIMC | Platform alert LED_PSU_STATUS #0x36 | LED color is amber | Asserted
5:2017 May 29 12:52:55 BST:BMC:selparser:1663: selparser.c:706: # 82 04 00 00 01 02 00 00 97 0B 2C 59 20 00 04 24 36 00 00 00 FF 04 FF FF # 482 | 05/29/2017 12:52:55 | CIMC | Platform alert LED_PSU_STATUS #0x36 | LED color is green | Deasserted
5:2017 May 29 12:52:55 BST:BMC:selparser:1663: selparser.c:706: # 83 04 00 00 01 02 00 00 97 0B 2C 59 20 00 04 24 39 00 00 00 7F 05 FF FF # 483 | 05/29/2017 12:52:55 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED color is amber | Asserted
5:2017 May 29 12:52:55 BST:BMC:selparser:1663: selparser.c:706: # 84 04 00 00 01 02 00 00 97 0B 2C 59 20 00 04 24 39 00 00 00 FF 04 FF FF # 484 | 05/29/2017 12:52:55 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED color is green | Deasserted
5:2017 May 29 12:53:12 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 12:53:12 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 12:53:12 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 12:53:16 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 12:53:16 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 12:53:16 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 12:53:17 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 12:53:17 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 12:53:17 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 12:53:17 BST:BMC:LLBL:1331: llbl.c:35:Locate Button Triggered
5:2017 May 29 12:53:18 BST:BMC:selparser:1663: selparser.c:706: # 85 04 00 00 01 02 00 00 AE 0B 2C 59 20 00 04 24 00 00 00 00 7F 02 FF FF # 485 | 05/29/2017 12:53:18 | CIMC | Platform alert FP_ID_LED #0x00 | LED is blinking fast | Asserted
5:2017 May 29 12:53:19 BST:BMC:LLBL:1331: llbl.c:35:Locate Button Triggered
5:2017 May 29 12:53:20 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 12:53:20 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 12:53:20 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 12:53:21 BST:BMC:selparser:1663: selparser.c:706: # 86 04 00 00 01 02 00 00 B0 0B 2C 59 20 00 04 24 00 00 00 00 7F 00 FF FF # 486 | 05/29/2017 12:53:20 | CIMC | Platform alert FP_ID_LED #0x00 | LED is off | Asserted
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ37
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ38
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ39
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ40
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ41
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ42
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ43
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ44
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ45
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ46
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ47
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ48
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ49
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ50
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ51
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ52
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ53
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ54
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ55
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ56
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ57
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ58
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ59
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ60
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ61
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ62
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ63
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ64
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ65
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ66
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ67
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ68
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ69
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ70
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ71
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ72
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ73
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ74
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ75
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ76
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ77
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ78
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Pilot3 Interrupt Controller Enabled and Configured.
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Pilot-II Timer Initialized
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Pilot-II Timer Started
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Console: colour dummy device 80x30
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Mount-cache hash table entries: 512
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>bio: create slab <bio-0> at 0
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>NetWinder Floating Point Emulator V0.97 (double precision)
5:2016 Dec 13 12:33:42 GMT:BMC:pmbus_pwrsply_mngr:1552: pmbus_pwrsply_mngr.c:1757:Power Supply 0x1 Presence Changed to present.
5:2016 Dec 13 12:33:42 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [sm]
5:2016 Dec 13 12:33:42 GMT:BMC:doctor-bmc:1720: app_monitor.c:234:Process, sm, successfully started.
5:2016 Dec 13 12:33:43 GMT:BMC:pmbus_pwrsply_mngr:1552: pmbus_pwrsply_mngr.c:1757:Power Supply 0x2 Presence Changed to present.
5:2016 Dec 13 12:33:43 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [bioscomd]
5:2016 Dec 13 12:33:43 GMT:BMC:doctor-bmc:1729: app_monitor.c:234:Process, bioscomd, successfully started.
5:2016 Dec 13 12:33:43 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [lv_dimmd]
5:2016 Dec 13 12:33:43 GMT:BMC:doctor-bmc:1737: app_monitor.c:234:Process, lv_dimmd, successfully started.
5:2016 Dec 13 12:33:44 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [fault-engined]
5:2016 Dec 13 12:33:44 GMT:BMC:doctor-bmc:1745: app_monitor.c:234:Process, fault-engined, successfully started.
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>name is Pilot3 Tulip
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>BROADCOM: PHY found at phy address 19!!
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>MV Switch Port 5 Enable status: 7f
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>Nand Astoria Mark 17
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>EMS CLI Work queue is created successfully
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Entered m25pxx_init
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Fast clk is set
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>C220 EVT1/P1 board detected. If wrong, fix CPLD programming
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Strap is SET for HOST spi
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Warning: unable to open an initial console.
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>[host_power_init]:1458:INIT Blade Power State is ... [ OFF ]
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>Pilot3 SPI Flash mapping: 0x4000000 at 0x0
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>No of banks = 6
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Probing for Flash at Bank # 0
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>SPI: probing for intel s33 devices ...
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>SPI: probing for atmel devices ...
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>SPI: probing for m25pxx devices ...
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>20 0 0 262144
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Probing for Flash at Bank # 1
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>19 0 0 262144
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Probing for Flash at Bank # 2
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>18 0 0 262144
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Probing for Flash at Bank # 3
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>17 0 0 262144
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Probing for Flash at Bank # 4
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>16 0 0 262144
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Probing for Flash at Bank # 5
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>15 0 0 262144
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>Concatenating MTD devices:
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>(0): "Pilot3 SPI MAP"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>(1): "Pilot3 SPI MAP"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>(2): "Pilot3 SPI MAP"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>(3): "Pilot3 SPI MAP"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>(4): "Pilot3 SPI MAP"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>(5): "Pilot3 SPI MAP"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>into device "Concat Ractrends"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>Creating 15 MTD partitions on "Concat Ractrends":
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000000000000-0x000006000000 : "all"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000000000000-0x000000080000 : "U-Boot"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000000080000-0x0000000c0000 : "boot.conf"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x0000000c0000-0x000000100000 : "RSVD"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000000100000-0x000000880000 : "Linux1"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000000880000-0x000001000000 : "Linux2"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000001000000-0x000001800000 : "NV_0"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000001800000-0x000002000000 : "OBFL"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000002000000-0x000003000000 : "NV_1"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000003000000-0x000004000000 : "NV_2"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000004000000-0x000004800000 : "P2_NV_0"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000004800000-0x000004940000 : "P2_OBFL"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000004940000-0x000004c80000 : "NV_3"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000004c80000-0x000004fc0000 : "NV_4"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000004fc0000-0x000005000000 : "RSVD_NVRAM"
5:2016 Dec 13 12:33:44 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [gdsd]
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Major number for pwmtach driver is - 235
5:2016 Dec 13 12:33:44 GMT:BMC:doctor-bmc:1759: app_monitor.c:234:Process, gdsd, successfully started.
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4> PWM and Fan tach configuration registers
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>PWCFG: 55  addr: c7946000
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>FMCFG: ff  addr: c7946004
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>PWOCF: 0  addr: c7946008
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4> Fan tach  Interrupt Register
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>FTISR: 0  addr: c794600c
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4> PWM control & stat reg , enables counter resolution
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>PWCRCSR: 55, addr: c7946010
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Counter resolution reg, sets no of clock cycles for PWM
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>PWCRVR0: 1e, addr: c7946014
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>PWCRVR1: 1e, addr: c7946018
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>PWCRVR2: 1e, addr: c794601c
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>PWCRVR3: 1e, addr: c7946020
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4> PWM pre scale register, sets clock divider for PWM
5:2016 Dec 13 12:33:44 GMT:BMC:lv_dimm:1739: lv_dimm.c:200:[transition_function]Starting Transition to [High Voltage Mode] from [Unknown Mode]
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4> PWM  duty cycle reg, sets no of high pulses
5:2016 Dec 13 12:33:44 GMT:BMC:lv_dimm:1739: common.c:941:Disabling Sensor scan for sensor 0x83.
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>PWPSR0: a, addr: c7946040
5:2016 Dec 13 12:33:44 GMT:BMC:lv_dimm:1739: common.c:941:Disabling Sensor scan for sensor 0x84.
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>PWDCR0: 15, addr: c7946044
5:2016 Dec 13 12:33:44 GMT:BMC:lv_dimm:1739: common.c:941:Disabling Sensor scan for sensor 0x85.
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>PWPSR1: a
5:2016 Dec 13 12:33:44 GMT:BMC:lv_dimm:1739: common.c:941:Disabling Sensor scan for sensor 0x86.
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>PWDCR1: 15
5:2016 Dec 13 12:33:44 GMT:BMC:lv_dimm:1739: common.c:941:Disabling Sensor scan for sensor 0x89.
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>PWPSR2: a
5:2016 Dec 13 12:33:44 GMT:BMC:lv_dimm:1739: common.c:941:Disabling Sensor scan for sensor 0x8a.
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>PWDCR2: 15
5:2016 Dec 13 12:33:44 GMT:BMC:lv_dimm:1739: common.c:941:Disabling Sensor scan for sensor 0x91.
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWPSR3: a
5:2016 Dec 13 12:33:45 GMT:BMC:lv_dimm:1739: common.c:941:Disabling Sensor scan for sensor 0x92.
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWDCR3: 15
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> Fan tach threshold reg, sets max no of clock between pulses
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR0: ff, addr: c7946060
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR1: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR2: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR3: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR4: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR5: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR6: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR7: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> Fan tach speed reg, set automatically
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR0: 0, addr c7946064
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR1: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR2: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR3: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR4: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR5: 0
5:2016 Dec 13 12:33:45 GMT:BMC:lv_dimm:1739: lv_dimm.c:220:[transition_function]Transition to [High Voltage Mode] Success
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR6: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR7: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> Fan tach control& stat reg,
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR0: 60 addr c7946068
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR1: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR2: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR3: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR4: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR5: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR6: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR7: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> Fan Tach filter select reg, sets filter value if filter is enabled
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMPFSR0: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMPFSR1: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> SET2 - PWM and Fan tach configuration registers
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCFG1: 55  addr: c7946100
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCFG1: ff  addr: c7946104
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWOCF1: 0  addr: c7946108
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> Fan tach  Interrupt Register
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FTISR1: 0  addr: c794610c
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> PWM control & stat reg , enables counter resolution
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCRCSR1: 55, addr: c7946110
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>Counter resolution reg, sets no of clock cycles for PWM
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCRVR4: 1e, addr: c7946114
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCRVR5: 1e, addr: c7946118
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCRVR6: 1e, addr: c794611c
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCRVR7: 1e, addr: c7946120
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> PWM pre scale register, sets clock divider for PWM
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> PWM  duty cycle reg, sets no of high pulses
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWPSR4: a, addr: c7946140
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWDCR4: 15, addr: c7946144
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWPSR5: a
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWDCR5: 15
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWPSR6: a
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWDCR6: 15
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWPSR7: a
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWDCR7: 15
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR8: ff, addr: c7946160
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR9: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR10: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR11: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR12: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR13: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR14: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR15: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR8: 0 addr c7946164
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR9: 0
5:2016 Dec 13 12:33:45 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [mem_throttled]
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR10: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR11: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR12: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR13: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR14: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR15: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR8: 60 addr c7946168
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR9: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR10: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR11: 60
5:2016 Dec 13 12:33:45 GMT:BMC:doctor-bmc:1767: app_monitor.c:234:Process, mem_throttled, successfully started.
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR12: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR13: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR14: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR15: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMPFSR2: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMPFSR3: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>***************PWM Driver has been initialized****************
5:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2773:USB FS: VDD Power Good = OFF
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> CyAnDevice: Cannot get firmware version. Reason code: 81
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> CyAnDevice: CyAsMiscConfigureDevice: No Firmware loaded: 81
5:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<5> CyAnDevice: Downloading Astoria firmware 1
5:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<5> CyAnDevice: Astoria firmware has been initialized
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>setting perfect hw filtering mode (c63d34f8)
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>setting perfect hw filtering mode (c705f4f8)
4:2016 Dec 13 12:33:51 GMT:BMC:kernel:-:last message repeated 5 times
5:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2016 Dec 13 12:33:45 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [qpi_loggerd]
5:2016 Dec 13 12:33:45 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[10]: Turning LED[10] (LED_FAN2_FAULT) OFF
5:2016 Dec 13 12:33:45 GMT:BMC:doctor-bmc:1776: app_monitor.c:234:Process, qpi_loggerd, successfully started.
5:2016 Dec 13 12:33:45 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[12]: Turning LED[12] (LED_FAN4_FAULT) OFF
4:2016 Dec 13 12:33:45 GMT:BMC:IPMI:1591: PSRedundantMode.c:51:PSRdntMode_Read --> Failed to open file /var/pmbus/ps_redundancy_state for read.
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>EXT2-fs (loop0): warning: mounting unchecked fs, running e2fsck is recommended
5:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x30 : Status = 0x83
5:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x31 : Status = 0x80
5:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x33 : Status = 0x83
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x34 : Status = 0x80
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x20 : Status = 0x83
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x21 : Status = 0x80
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x23 : Status = 0x83
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x24 : Status = 0x80
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x10 : Status = 0x83
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x11 : Status = 0x80
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x13 : Status = 0x83
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x14 : Status = 0x80
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x0 : Status = 0x83
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x1 : Status = 0x80
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x3 : Status = 0x83
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x4 : Status = 0x80
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x31 : Status = 0x80
5:2016 Dec 13 12:33:46 GMT:BMC:selparser:1662: selparser.c:706: # 87 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 24 08 00 00 00 04 00 FF FF # 487 | 12/13/2016 12:33:45 | CIMC | Platform alert POWER_ON_FAIL #0x08 | Predictive Failure deasserted | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # 88 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 25 0A 00 00 00 08 01 FF FF # 488 | 12/13/2016 12:33:45 | CIMC | Entity presence FAN2_PRSNT #0x0a | Device Present | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # 89 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 25 0C 00 00 00 08 01 FF FF # 489 | 12/13/2016 12:33:45 | CIMC | Entity presence FAN4_PRSNT #0x0c | Device Present | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x34 : Status = 0x80
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # 8A 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 25 1E 00 00 00 08 01 FF FF # 48a | 12/13/2016 12:33:45 | CIMC | Entity presence RISER2_PRESENT #0x1e | Device Present | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # 8B 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 25 24 00 00 00 08 01 FF FF # 48b | 12/13/2016 12:33:45 | CIMC | Entity presence RISER1_PRESENT_1 #0x24 | Device Present | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x21 : Status = 0x80
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # 8C 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 24 36 00 00 00 7F 01 FF FF # 48c | 12/13/2016 12:33:45 | CIMC | Platform alert LED_PSU_STATUS #0x36 | LED is on | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # 8D 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 24 36 00 00 00 7F 04 FF FF # 48d | 12/13/2016 12:33:45 | CIMC | Platform alert LED_PSU_STATUS #0x36 | LED color is green | Asserted
5:2016 Dec 13 12:33:50 GMT:BMC:selparser:1662: selparser.c:706: # 8E 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 24 38 00 00 00 7F 01 FF FF # 48e | 12/13/2016 12:33:45 | CIMC | Platform alert LED_FAN_STATUS #0x38 | LED is on | Asserted
5:2016 Dec 13 12:33:50 GMT:BMC:selparser:1662: selparser.c:706: # 8F 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 24 38 00 00 00 7F 04 FF FF # 48f | 12/13/2016 12:33:45 | CIMC | Platform alert LED_FAN_STATUS #0x38 | LED color is green | Asserted
5:2016 Dec 13 12:33:50 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x24 : Status = 0x80
5:2016 Dec 13 12:33:50 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [xapid]
5:2016 Dec 13 12:33:50 GMT:BMC:doctor-bmc:1798: app_monitor.c:234:Process, xapid, successfully started.
5:2016 Dec 13 12:33:50 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x11 : Status = 0x80
5:2016 Dec 13 12:33:50 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[9]: Turning LED[9] (LED_FAN1_FAULT) OFF
5:2016 Dec 13 12:33:50 GMT:BMC:lv_dimm:1739: lv_dimm.c:403:[handle_event_enable_tick]enable sensor event
5:2016 Dec 13 12:33:50 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [fcgi]
5:2016 Dec 13 12:33:50 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x14 : Status = 0x80
5:2016 Dec 13 12:33:50 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[11]: Turning LED[11] (LED_FAN3_FAULT) OFF
5:2016 Dec 13 12:33:50 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x83.
5:2016 Dec 13 12:33:50 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x1 : Status = 0x80
5:2016 Dec 13 12:33:50 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x84.
5:2016 Dec 13 12:33:50 GMT:BMC:doctor-bmc:1804: app_monitor.c:234:Process, fcgi, successfully started.
5:2016 Dec 13 12:33:50 GMT:BMC:selparser:1662: selparser.c:706: # 90 04 00 00 01 02 00 00 AB EA 4F 58 20 00 04 25 09 00 00 00 08 01 FF FF # 490 | 12/13/2016 12:33:47 | CIMC | Entity presence FAN1_PRSNT #0x09 | Device Present | Asserted
5:2016 Dec 13 12:33:50 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x4 : Status = 0x80
5:2016 Dec 13 12:33:50 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x85.
5:2016 Dec 13 12:33:50 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x31 : Status = 0x80
5:2016 Dec 13 12:33:50 GMT:BMC:selparser:1662: selparser.c:706: # 91 04 00 00 01 02 00 00 AB EA 4F 58 20 00 04 25 0B 00 00 00 08 01 FF FF # 491 | 12/13/2016 12:33:47 | CIMC | Entity presence FAN3_PRSNT #0x0b | Device Present | Asserted
5:2016 Dec 13 12:33:50 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x86.
5:2016 Dec 13 12:33:50 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x89.
5:2016 Dec 13 12:33:50 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x8a.
5:2016 Dec 13 12:33:50 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x34 : Status = 0x80
5:2016 Dec 13 12:33:50 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x91.
5:2016 Dec 13 12:33:50 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x92.
5:2016 Dec 13 12:33:50 GMT:BMC:lv_dimm:1739: sanluis1/platform.c:117:platform_event_enable_tick_end: Configuring IR from CIMC
5:2016 Dec 13 12:33:50 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x21 : Status = 0x80
5:2016 Dec 13 12:33:50 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[13]: Turning LED[13] (LED_FAN5_FAULT) OFF
5:2016 Dec 13 12:33:50 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[255]: Turning LED[25] (LED_DIMM_FAULT_P1_A2) OFF
5:2016 Dec 13 12:33:50 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[255]: Turning LED[27] (LED_DIMM_FAULT_P1_B2) OFF
5:2016 Dec 13 12:33:50 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[255]: Turning LED[29] (LED_DIMM_FAULT_P1_C2) OFF
5:2016 Dec 13 12:33:50 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[255]: Turning LED[31] (LED_DIMM_FAULT_P1_D2) OFF
5:2016 Dec 13 12:33:50 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[255]: Turning LED[33] (LED_DIMM_FAULT_P2_E2) OFF
5:2016 Dec 13 12:33:50 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[255]: Turning LED[35] (LED_DIMM_FAULT_P2_F2) OFF
5:2016 Dec 13 12:33:50 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[255]: Turning LED[37] (LED_DIMM_FAULT_P2_G2) OFF
5:2016 Dec 13 12:33:50 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[255]: Turning LED[39] (LED_DIMM_FAULT_P2_H2) OFF
5:2016 Dec 13 12:33:50 GMT:BMC:kernel:-:<5>[__do_power_off]:325:__do_power_off
5:2016 Dec 13 12:33:50 GMT:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2016 Dec 13 12:33:50 GMT:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2016 Dec 13 12:33:51 GMT:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2016 Dec 13 12:33:51 GMT:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2016 Dec 13 12:33:51 GMT:BMC:selparser:1662: selparser.c:706: # 92 04 00 00 01 02 00 00 AE EA 4F 58 20 00 04 25 0D 00 00 00 08 01 FF FF # 492 | 12/13/2016 12:33:50 | CIMC | Entity presence FAN5_PRSNT #0x0d | Device Present | Asserted
5:2016 Dec 13 12:33:51 GMT:BMC:selparser:1662: selparser.c:706: # 93 04 00 00 01 02 00 00 AE EA 4F 58 20 00 04 25 1F 00 00 00 08 01 FF FF # 493 | 12/13/2016 12:33:50 | CIMC | Entity presence RISER1_PRESENT #0x1f | Device Present | Asserted
5:2016 Dec 13 12:33:51 GMT:BMC:selparser:1662: selparser.c:706: # 94 04 00 00 01 02 00 00 AE EA 4F 58 20 00 04 25 23 00 00 00 08 01 FF FF # 494 | 12/13/2016 12:33:50 | CIMC | Entity presence RISER2_PRESENT_1 #0x23 | Device Present | Asserted
5:2016 Dec 13 12:33:51 GMT:BMC:selparser:1662: selparser.c:706: # 95 04 00 00 01 02 00 00 AE EA 4F 58 20 00 04 24 37 00 00 00 7F 01 FF FF # 495 | 12/13/2016 12:33:50 | CIMC | Platform alert LED_TEMP_STATUS #0x37 | LED is on | Asserted
5:2016 Dec 13 12:33:51 GMT:BMC:selparser:1662: selparser.c:706: # 96 04 00 00 01 02 00 00 AE EA 4F 58 20 00 04 24 37 00 00 00 7F 04 FF FF # 496 | 12/13/2016 12:33:50 | CIMC | Platform alert LED_TEMP_STATUS #0x37 | LED color is green | Asserted
5:2016 Dec 13 12:33:51 GMT:BMC:selparser:1662: selparser.c:706: # 97 04 00 00 01 02 00 00 AE EA 4F 58 20 00 04 24 39 00 00 00 7F 01 FF FF # 497 | 12/13/2016 12:33:50 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED is on | Asserted
5:2016 Dec 13 12:33:51 GMT:BMC:selparser:1662: selparser.c:706: # 98 04 00 00 01 02 00 00 AE EA 4F 58 20 00 04 24 39 00 00 00 7F 04 FF FF # 498 | 12/13/2016 12:33:50 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED color is green | Asserted
5:2016 Dec 13 12:33:51 GMT:BMC:selparser:1662: selparser.c:706: # 99 04 00 00 01 02 00 00 AE EA 4F 58 20 00 04 25 A1 00 00 00 08 01 FF FF # 499 | 12/13/2016 12:33:50 | CIMC | Entity presence P2_PRESENT #0xa1 | Device Present | Asserted
5:2016 Dec 13 12:33:51 GMT:BMC:selparser:1662: selparser.c:706: # 9A 04 00 00 01 02 00 00 AE EA 4F 58 20 00 04 25 A0 00 00 00 08 01 FF FF # 49a | 12/13/2016 12:33:50 | CIMC | Entity presence P1_PRESENT #0xa0 | Device Present | Asserted
5:2016 Dec 13 12:33:52 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [monkey]
5:2016 Dec 13 12:33:52 GMT:BMC:doctor-bmc:1844: app_monitor.c:234:Process, monkey, successfully started.
5:2016 Dec 13 12:33:52 GMT:BMC:bios-update:1855: main.c:236:Running as Daemon
4:2016 Dec 13 12:33:53 GMT:BMC:IPMI:1591: PSRedundantMode.c:51:PSRdntMode_Read --> Failed to open file /var/pmbus/ps_redundancy_state for read.
5:2016 Dec 13 12:33:53 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [alertmgr]
5:2016 Dec 13 12:33:53 GMT:BMC:doctor-bmc:1870: app_monitor.c:234:Process, alertmgr, successfully started.
5:2016 Dec 13 12:33:55 GMT:BMC:bios-update:1855: activate.c:142:Setting BIOS Version
5:2016 Dec 13 12:33:55 GMT:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2016 Dec 13 12:33:55 GMT:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2016 Dec 13 12:33:55 GMT:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2016 Dec 13 12:33:57 GMT:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2016 Dec 13 12:33:57 GMT:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2016 Dec 13 12:33:57 GMT:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2016 Dec 13 12:33:58 GMT:BMC:selparser:1662: selparser.c:706: # 9B 04 00 00 01 02 00 00 B6 EA 4F 58 20 00 04 08 25 00 00 00 6F 30 FF 00 # 49b | 12/13/2016 12:33:58 | CIMC | Power supply PSU1_STATUS #0x25 | Presence detected |  | Asserted
5:2016 Dec 13 12:33:58 GMT:BMC:selparser:1662: selparser.c:706: # 9C 04 00 00 01 02 00 00 B6 EA 4F 58 20 00 04 08 26 00 00 00 6F 30 FF 00 # 49c | 12/13/2016 12:33:58 | CIMC | Power supply PSU2_STATUS #0x26 | Presence detected |  | Asserted
5:2016 Dec 13 12:33:59 GMT:BMC:selparser:1662: selparser.c:706: # 9D 04 00 00 01 02 00 00 B7 EA 4F 58 20 00 04 08 3A 00 00 00 0B 00 FF FF # 49d | 12/13/2016 12:33:59 | CIMC | Power supply PS_RDNDNT_MODE #0x3a | Fully Redundant | Asserted
5:2016 Dec 13 12:34:00 GMT:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2402:USB1 VDD power off
5:2016 Dec 13 12:34:03 GMT:BMC:selparser:1662: selparser.c:706: # 9E 04 00 00 01 02 00 00 BA EA 4F 58 20 00 04 08 2F 00 00 00 03 01 FF FF # 49e | 12/13/2016 12:34:02 | CIMC | Power supply PSU1_AC_OK #0x2f | State Asserted | Asserted
5:2016 Dec 13 12:34:03 GMT:BMC:selparser:1662: selparser.c:706: # 9F 04 00 00 01 02 00 00 BA EA 4F 58 20 00 04 08 31 00 00 00 03 01 FF FF # 49f | 12/13/2016 12:34:02 | CIMC | Power supply PSU2_AC_OK #0x31 | State Asserted | Asserted
5:2016 Dec 13 12:34:05 GMT:BMC:DimmBL-DbSyncTask:1471: DimmBL-DbSyncTask.c:224:InitializeDimmBLSyncTask: SUCCESS
5:2016 Dec 13 12:34:06 GMT:BMC:kernel:-:<5>Slow work thread pool: Starting up
5:2016 Dec 13 12:34:06 GMT:BMC:kernel:-:<5>Slow work thread pool: Ready
5:2016 Dec 13 12:34:09 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [kvm]
5:2016 Dec 13 12:34:09 GMT:BMC:doctor-bmc:1980: app_monitor.c:234:Process, kvm, successfully started.
5:2016 Dec 13 12:34:09 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [vkvm_pm]
5:2016 Dec 13 12:34:09 GMT:BMC:doctor-bmc:1987: app_monitor.c:234:Process, vkvm_pm, successfully started.
5:2016 Dec 13 12:34:11 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [sshd]
5:2016 Dec 13 12:34:11 GMT:BMC:doctor-bmc:2010: app_monitor.c:234:Process, sshd, successfully started.
5:2016 Dec 13 12:34:11 GMT:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2016 Dec 13 12:34:11 GMT:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2016 Dec 13 12:34:11 GMT:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2016 Dec 13 12:34:12 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [cisco_pm]
5:2016 Dec 13 12:34:12 GMT:BMC:doctor-bmc:2020: app_monitor.c:234:Process, cisco_pm, successfully started.
5:2016 Dec 13 12:34:12 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [ciscoNET]
5:2016 Dec 13 12:34:12 GMT:BMC:doctor-bmc:2033: app_monitor.c:234:Process, ciscoNET, successfully started.
5:2016 Dec 13 12:34:13 GMT:BMC:ciscoNET:2035: ciscoNET.c:122:Application Starting
5:2016 Dec 13 12:34:13 GMT:BMC:doctor-bmc-app-mon:2066: app_monitor.c:726:Started application monitor (2066)
5:2016 Dec 13 12:34:14 GMT:BMC:doctor-bmc-app-mon:2066: app_monitor.c:481:cmp_proc_node_ctime: stat(/proc/1609) failed, errno 2 (No such file or directory)
5:2016 Dec 13 12:34:14 GMT:BMC:doctor-bmc-app-mon:2066: app_monitor.c:636:cmp_proc_node_ctime sel_pigeon_cntrd stat(/proc/1609) returned errno 2 (No such file or directory)
4:2016 Dec 13 12:34:14 GMT:BMC:doctor-bmc-app-mon:2066: app_monitor.c:592:Restarting Process sel_pigeon_cntrd
5:2016 Dec 13 12:34:14 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [ucsm_state_manager]
5:2016 Dec 13 12:34:14 GMT:BMC:doctor-bmc:2076: app_monitor.c:234:Process, ucsm_state_manager, successfully started.
5:2016 Dec 13 12:34:14 GMT:BMC:ciscoNET:2035: network_manager.c:549:Configuring the network.
5:2016 Dec 13 12:34:14 GMT:BMC:sel_pigeon_cntr:2072: sel_pigeon_cntr.c:917:Opening connection to SEL_PIGEON_CNTR_FIFO
5:2016 Dec 13 12:34:15 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [GDSCommDmn]
5:2016 Dec 13 12:34:15 GMT:BMC:doctor-bmc:2084: app_monitor.c:234:Process, GDSCommDmn, successfully started.
5:2016 Dec 13 12:34:15 GMT:BMC:GDSCommDmn:-: GDSCommSVC.c:116:GDSComm SVC started
5:2016 Dec 13 12:34:15 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [rack_monitor]
5:2016 Dec 13 12:34:15 GMT:BMC:doctor-bmc:2089: app_monitor.c:234:Process, rack_monitor, successfully started.
5:2016 Dec 13 12:34:15 GMT:BMC:rack_monitor:-: rack_monitor.c:397:RACK Montior in Stand-alone mode
5:2016 Dec 13 12:34:16 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [sam_master]
5:2016 Dec 13 12:34:16 GMT:BMC:doctor-bmc:2094: app_monitor.c:234:Process, sam_master, successfully started.
5:2016 Dec 13 12:34:16 GMT:BMC:sam_master:-: sam_master.c:61:Stopping PTPD on Monitor Request
5:2016 Dec 13 12:34:16 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [ciscovmd]
5:2016 Dec 13 12:34:16 GMT:BMC:doctor-bmc:2100: app_monitor.c:234:Process, ciscovmd, successfully started.
5:2016 Dec 13 12:34:16 GMT:BMC:ciscoNET:2035: network_manager.c:793:Error: killall udhcpc returned exit code: 256
5:2016 Dec 13 12:34:17 GMT:BMC:doctor-bmc:-: doctor-bmc.c:308:doctor-bmc-app stop [ptpd]
5:2016 Dec 13 12:34:17 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [video_triggerd]
5:2016 Dec 13 12:34:17 GMT:BMC:doctor-bmc:2108: app_monitor.c:234:Process, video_triggerd, successfully started.
5:2016 Dec 13 12:34:17 GMT:BMC:ciscoNET:2035: network_manager.c:795:Error: killall udhcpc6 returned exit code: 256
4:2016 Dec 13 12:34:18 GMT:BMC:kernel:-:<4>setting perfect hw filtering mode (c705f4f8)
5:2016 Dec 13 12:34:21 GMT:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2016 Dec 13 12:34:21 GMT:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2016 Dec 13 12:34:21 GMT:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2016 Dec 13 12:34:24 GMT:BMC:hw-ether:2193: hw-ether.c:254:eth0's hardware address changed to f8:72:ea:a3:d6:ee
4:2016 Dec 13 12:34:24 GMT:BMC:kernel:-:<4>setting perfect hw filtering mode (c705f4f8)
4:2016 Dec 13 12:34:28 GMT:BMC:kernel:-:last message repeated 6 times
4:2016 Dec 13 12:34:28 GMT:BMC:ciscoNET:2035: network_manager.c:2082:Error: Can not open file, /etc/resolv.conf, with mode, r: 0x2.
5:2016 Dec 13 12:34:29 GMT:BMC:ciscoNET:2035: cisco_cards_manager.c:204:There are no cisco configurable cards attached.
5:2016 Dec 13 12:34:29 GMT:BMC:GDSCommDmn:-: GDSCommSVC.c:209:GDSComm started taking input connections.
5:2016 Dec 13 12:34:30 GMT:BMC:IPMI:1591: Bridge.c:1468:audit from:kcs Fn:0x6 Cmd:0x56 Data: 0x1 0x0 0x1
5:2016 Dec 13 12:34:30 GMT:BMC:IPMI:1591: Bridge.c:1474:audit Resp:0x0
5:2016 Dec 13 12:34:31 GMT:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2016 Dec 13 12:34:31 GMT:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2016 Dec 13 12:34:31 GMT:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2016 Dec 13 12:34:36 GMT:BMC:dataserver:1794: eventsubscribemgnt.c:91:IsShmRestoreRequired: Restoration required!
5:2016 Dec 13 12:34:36 GMT:BMC:dataserver:1794: eventsubscribemgnt.c:1193:RestoreEvtSubscCfg: Restored event subscription configuration successfully!
5:2016 Dec 13 12:34:38 GMT:BMC:doctor-bmc:-: doctor-bmc.c:308:doctor-bmc-app stop [snmp-subagentd]
5:2016 Dec 13 12:34:39 GMT:BMC:root:-: CIMC booted after a chassis power on!!
5:2016 Dec 13 12:34:39 GMT:BMC:root:-: Waiting for MB FRU data to get populated..
5:2016 Dec 13 12:34:39 GMT:BMC:root:-: MB FRU data populated successfully
5:2016 Dec 13 12:34:41 GMT:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2016 Dec 13 12:34:41 GMT:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2016 Dec 13 12:34:41 GMT:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2016 Dec 13 12:34:42 GMT:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2016 Dec 13 12:34:42 GMT:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2016 Dec 13 12:34:42 GMT:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2016 Dec 13 12:34:43 GMT:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2016 Dec 13 12:34:43 GMT:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2016 Dec 13 12:34:43 GMT:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2016 Dec 13 12:34:45 GMT:BMC:root:-: NTP: CIMC IP acquired: 192.168.1.207
5:2016 Dec 13 12:34:45 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [ntpd]
5:2016 Dec 13 12:34:45 GMT:BMC:doctor-bmc:2408: app_monitor.c:234:Process, ntpd, successfully started.
3:2016 Dec 13 12:34:49 GMT:BMC:update-ir:2344: ../../src/update-ir.c:234:Host should be powered-on for IR configuration update
5:2016 Dec 13 12:35:04 GMT:BMC:root:-: DDNS: CIMC IP acquired: 192.168.1.207
5:2016 Dec 13 12:35:04 GMT:BMC:root:-: DDNS: GATEWAY IP acquired: 192.168.1.254
4:2016 Dec 13 12:35:15 GMT:BMC:kernel:-:<4>process `doctor-bmc' is using deprecated sysctl (syscall) net.ipv6.neigh.default.retrans_time; Use net.ipv6.neigh.default.retrans_time_ms instead.
3:2017 May 29 12:57:45 BST:BMC:crond:1296: time disparity of 240442 minutes detected
5:2017 May 29 12:58:32 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 12:58:32 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 12:58:32 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 12:58:36 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 12:58:36 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 12:58:36 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 12:58:37 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 12:58:37 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 12:58:37 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 12:58:38 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 12:58:38 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 12:58:38 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 12:58:56 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 12:58:56 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 12:58:56 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 12:59:04 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 12:59:04 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 12:59:04 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 12:59:16 BST:BMC:fcgi:-: pam_local_manager(webgui:account): requirement "privilege=0x01" was met by user "admin"
5:2017 May 29 12:59:16 BST:BMC:AUDIT:1808: Login success (user:admin, ip:192.168.1.129, service:webgui)
5:2017 May 29 12:59:16 BST:BMC:AUDIT:2025: Session open (user:admin, ip:192.168.1.129, id:1, type:webgui)
5:2017 May 29 12:59:16 BST:BMC:AUDIT:1808: Session open (user:admin, ip:192.168.1.129, id:1, type:webgui)
5:2017 May 29 12:59:16 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 12:59:16 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 12:59:16 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 12:59:17 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 12:59:17 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 12:59:17 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 12:59:18 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 12:59:18 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 12:59:18 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 12:59:19 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 12:59:19 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 12:59:19 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 12:59:20 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 12:59:20 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 12:59:20 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 12:59:21 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 12:59:21 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 12:59:21 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 12:59:24 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 12:59:24 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 12:59:24 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 12:59:42 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 12:59:42 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 12:59:42 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 12:59:43 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 12:59:43 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 12:59:43 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 13:01:42 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 13:01:42 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 13:01:42 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 13:01:53 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 13:01:53 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 13:01:53 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 13:03:20 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 13:03:20 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 13:03:20 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 13:03:22 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 13:03:22 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 13:03:22 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 13:03:24 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 13:03:24 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 13:03:24 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 13:03:39 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 13:03:39 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 13:03:39 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 13:04:01 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 13:04:01 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 13:04:01 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 13:04:02 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 13:04:02 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 13:04:02 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 13:04:03 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 13:04:03 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 13:04:03 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 13:04:05 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 13:04:05 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 13:04:05 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 13:04:06 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 13:04:06 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 13:04:06 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 13:04:12 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 13:04:12 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 13:04:12 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 13:04:13 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 13:04:13 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 13:04:13 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 13:05:46 BST:BMC:dataserver:1794: bootordermgnt.cpp:1916:RestoreDevieCfg: Restored boot order configuration successfully!
5:2017 May 29 13:05:46 BST:BMC:dataserver:1794: bootordermgnt.cpp:1515:RestoreOneBootDevieCfg 1515> -1 -1
5:2017 May 29 13:05:59 BST:BMC:kernel:-:<5>[__do_power_on]:385:__do_power_on
5:2017 May 29 13:05:59 BST:BMC:kernel:-:<5>[__do_power_on]:401:Power Driver: Power On Logic Pulse for 250ms @ 394352
5:2017 May 29 13:05:59 BST:BMC:IPMI:1591: Bridge.c:1468:audit from:kcs Fn:0x0 Cmd:0x2 Data: 0x1
5:2017 May 29 13:05:59 BST:BMC:IPMI:1591: Bridge.c:1474:audit Resp:0x0
5:2017 May 29 13:05:59 BST:BMC:AUDIT:1794: Server power state modify (op:power-on)
2:2017 May 29 13:06:19 BST:BMC:kernel:-:<2>[__do_power_on]:428:Power Driver: Power On Fail Asserted @ 414684 RegInfo -> SWSTAT0[0x10] WKCFG0[0x11]
5:2017 May 29 13:06:19 BST:BMC:IPMI:1591: Pilot2SrvPower.c:189:Pilot2SrvPowerOn
4:2017 May 29 13:06:19 BST:BMC:IPMI:1591: Pilot2SrvPower.c:191:Pilot2SrvPowerOn: Failed to Power On [Timer expired]
5:2017 May 29 13:06:19 BST:BMC:IPMI:1591: Pilot2SrvPower.c:466:Blade Power Changed To: [ ON ]
5:2017 May 29 13:06:19 BST:BMC:IPMI:1591: Rack_FanCtrl.c:1272:fscUpdateActualFanPolicyFile: Applied Policy: N/A, Configuration Status: PENDING - BIOS POST not completed
0:2017 May 29 13:06:19 BST:BMC:POF_MONITOR_DAEMON:1381: pof_monitord.c:93:Host Failed Power On Please Check [ /var/log/power-on-fail.log ]
5:2017 May 29 13:06:19 BST:BMC:video_trigger:-: video_trigger.c:280:Sending event_ipmi_power_state_change (ON) ..
5:2017 May 29 13:06:20 BST:BMC:selparser:1662: selparser.c:706: # A0 04 00 00 01 02 00 00 BC 0E 2C 59 20 00 04 24 08 00 00 00 04 01 FF FF # 4a0 | 05/29/2017 13:06:20 | CIMC | Platform alert POWER_ON_FAIL #0x08 | Predictive Failure asserted | Asserted
5:2017 May 29 13:06:20 BST:BMC:selparser:1662: selparser.c:706: # A1 04 00 00 01 02 00 00 BC 0E 2C 59 20 00 04 24 39 00 00 00 7F 05 FF FF # 4a1 | 05/29/2017 13:06:20 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED color is amber | Asserted
5:2017 May 29 13:06:20 BST:BMC:selparser:1662: selparser.c:706: # A2 04 00 00 01 02 00 00 BC 0E 2C 59 20 00 04 24 39 00 00 00 FF 04 FF FF # 4a2 | 05/29/2017 13:06:20 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED color is green | Deasserted
5:2017 May 29 13:06:21 BST:BMC:video_trigger:-: video_trigger.c:207:Sending event_server_crash for host NMI ..
5:2017 May 29 13:06:23 BST:BMC:update-ir:2344: ../../src/update-ir.c:99:lock state = 0
3:2017 May 29 13:06:23 BST:BMC:update-ir:2344: ../../src/update-ir.c:111:Cannot modify/get front panel locks: 0xd  0xffffffff
5:2017 May 29 13:06:24 BST:BMC:selparser:1662: selparser.c:706: # A3 04 00 00 01 02 00 00 C0 0E 2C 59 20 00 04 25 01 00 00 00 08 01 FF FF # 4a3 | 05/29/2017 13:06:24 | CIMC | Entity presence BIOS_POST_CMPLT #0x01 | Device Present | Asserted
5:2017 May 29 13:06:24 BST:BMC:selparser:1662: selparser.c:706: # A4 04 00 00 01 02 00 00 C0 0E 2C 59 20 00 04 07 02 00 00 00 04 01 FF FF # 4a4 | 05/29/2017 13:06:24 | CIMC | Processor P_CATERR_N #0x02 | Predictive Failure asserted | Asserted
5:2017 May 29 13:06:24 BST:BMC:selparser:1662: selparser.c:706: # A5 04 00 00 01 02 00 00 C0 0E 2C 59 20 00 04 07 27 00 00 00 05 01 FF FF # 4a5 | 05/29/2017 13:06:24 | CIMC | Processor P1_PROCHOT #0x27 | Limit Exceeded | Asserted
5:2017 May 29 13:06:24 BST:BMC:selparser:1662: selparser.c:706: # A6 04 00 00 01 02 00 00 C0 0E 2C 59 20 00 04 07 28 00 00 00 05 01 FF FF # 4a6 | 05/29/2017 13:06:24 | CIMC | Processor P2_PROCHOT #0x28 | Limit Exceeded | Asserted
5:2017 May 29 13:06:24 BST:BMC:selparser:1662: selparser.c:706: # A7 04 00 00 01 02 00 00 C0 0E 2C 59 20 00 04 07 29 00 00 00 05 01 FF FF # 4a7 | 05/29/2017 13:06:24 | CIMC | Processor PVCCD_P1_VRHOT #0x29 | Limit Exceeded | Asserted
5:2017 May 29 13:06:24 BST:BMC:selparser:1662: selparser.c:706: # A8 04 00 00 01 02 00 00 C0 0E 2C 59 20 00 04 07 2A 00 00 00 05 01 FF FF # 4a8 | 05/29/2017 13:06:24 | CIMC | Processor PVCCP_P1_VRHOT #0x2a | Limit Exceeded | Asserted
5:2017 May 29 13:06:24 BST:BMC:selparser:1662: selparser.c:706: # A9 04 00 00 01 02 00 00 C0 0E 2C 59 20 00 04 07 2B 00 00 00 05 01 FF FF # 4a9 | 05/29/2017 13:06:24 | CIMC | Processor PVCCD_P2_VRHOT #0x2b | Limit Exceeded | Asserted
5:2017 May 29 13:06:24 BST:BMC:selparser:1662: selparser.c:706: # AA 04 00 00 01 02 00 00 C0 0E 2C 59 20 00 04 07 2C 00 00 00 05 01 FF FF # 4aa | 05/29/2017 13:06:24 | CIMC | Processor PVCCP_P2_VRHOT #0x2c | Limit Exceeded | Asserted
5:2017 May 29 13:06:24 BST:BMC:selparser:1662: selparser.c:706: # AB 04 00 00 01 02 00 00 C0 0E 2C 59 20 00 04 08 2E 00 00 00 03 00 FF FF # 4ab | 05/29/2017 13:06:24 | CIMC | Power supply PSU1_PWRGD #0x2e | State Deasserted | Asserted
5:2017 May 29 13:06:24 BST:BMC:selparser:1662: selparser.c:706: # AC 04 00 00 01 02 00 00 C0 0E 2C 59 20 00 04 08 30 00 00 00 03 00 FF FF # 4ac | 05/29/2017 13:06:24 | CIMC | Power supply PSU2_PWRGD #0x30 | State Deasserted | Asserted
5:2017 May 29 13:06:24 BST:BMC:selparser:1662: selparser.c:706: # AD 04 00 00 01 02 00 00 C0 0E 2C 59 20 00 04 07 32 00 00 00 05 01 FF FF # 4ad | 05/29/2017 13:06:24 | CIMC | Processor P1_MEM23_MEMHOT #0x32 | Limit Exceeded | Asserted
5:2017 May 29 13:06:24 BST:BMC:selparser:1662: selparser.c:706: # AE 04 00 00 01 02 00 00 C0 0E 2C 59 20 00 04 07 33 00 00 00 05 01 FF FF # 4ae | 05/29/2017 13:06:24 | CIMC | Processor P1_MEM01_MEMHOT #0x33 | Limit Exceeded | Asserted
5:2017 May 29 13:06:24 BST:BMC:selparser:1662: selparser.c:706: # AF 04 00 00 01 02 00 00 C0 0E 2C 59 20 00 04 07 34 00 00 00 05 01 FF FF # 4af | 05/29/2017 13:06:24 | CIMC | Processor P2_MEM23_MEMHOT #0x34 | Limit Exceeded | Asserted
4:2017 May 29 13:06:25 BST:BMC:IPMI:1591: Pilot3Peci.c:87:Pilot_PECI: Transaction aborted! --> [0xFFFFFFFF], ResultCode = 0, LPC Reset State = 1
5:2017 May 29 13:06:25 BST:BMC:IPMI:1591: Pilot3Peci.c:1034:Pilot_PECI: PECI Temp Transaction To CPU-0 Failed!  RC: 0
4:2017 May 29 13:06:25 BST:BMC:IPMI:1591: Pilot3Peci.c:87:Pilot_PECI: Transaction aborted! --> [0xFFFFFFFF], ResultCode = 77, LPC Reset State = 1
5:2017 May 29 13:06:25 BST:BMC:IPMI:1591: Pilot3Peci.c:1034:Pilot_PECI: PECI Temp Transaction To CPU-1 Failed!  RC: 4d
5:2017 May 29 13:06:25 BST:BMC:IPMI:1591: Rack_FanCtrl.c:1272:fscUpdateActualFanPolicyFile: Applied Policy: Balanced, Configuration Status: SUCCESS
5:2017 May 29 13:06:25 BST:BMC:selparser:1662: selparser.c:706: # B0 04 00 00 01 02 00 00 C1 0E 2C 59 20 00 04 07 35 00 00 00 05 01 FF FF # 4b0 | 05/29/2017 13:06:25 | CIMC | Processor P2_MEM01_MEMHOT #0x35 | Limit Exceeded | Asserted
5:2017 May 29 13:06:25 BST:BMC:selparser:1662: selparser.c:706: # B1 04 00 00 01 02 00 00 C1 0E 2C 59 20 00 04 0D 42 00 00 00 6F 00 FF FF # 4b1 | 05/29/2017 13:06:25 | CIMC | Drive slot(Bay) HDD1_STATUS #0x42 | Drive Presence | Asserted
5:2017 May 29 13:06:26 BST:BMC:selparser:1662: selparser.c:706: # B2 04 00 00 01 02 00 00 C1 0E 2C 59 20 00 04 0D 43 00 00 00 6F 00 FF FF # 4b2 | 05/29/2017 13:06:25 | CIMC | Drive slot(Bay) HDD2_STATUS #0x43 | Drive Presence | Asserted
5:2017 May 29 13:06:26 BST:BMC:selparser:1662: selparser.c:706: # B3 04 00 00 01 02 00 00 C1 0E 2C 59 20 00 04 0D 44 00 00 00 6F 00 FF FF # 4b3 | 05/29/2017 13:06:25 | CIMC | Drive slot(Bay) HDD3_STATUS #0x44 | Drive Presence | Asserted
5:2017 May 29 13:06:26 BST:BMC:selparser:1662: selparser.c:706: # B4 04 00 00 01 02 00 00 C1 0E 2C 59 20 00 04 0D 45 00 00 00 6F 00 FF FF # 4b4 | 05/29/2017 13:06:25 | CIMC | Drive slot(Bay) HDD4_STATUS #0x45 | Drive Presence | Asserted
5:2017 May 29 13:06:26 BST:BMC:selparser:1662: selparser.c:706: # B5 04 00 00 01 02 00 00 C1 0E 2C 59 20 00 04 0D 46 00 00 00 6F 00 FF FF # 4b5 | 05/29/2017 13:06:25 | CIMC | Drive slot(Bay) HDD5_STATUS #0x46 | Drive Presence | Asserted
5:2017 May 29 13:06:26 BST:BMC:selparser:1662: selparser.c:706: # B6 04 00 00 01 02 00 00 C1 0E 2C 59 20 00 04 0D 47 00 00 00 6F 00 FF FF # 4b6 | 05/29/2017 13:06:25 | CIMC | Drive slot(Bay) HDD6_STATUS #0x47 | Drive Presence | Asserted
5:2017 May 29 13:06:26 BST:BMC:selparser:1662: selparser.c:706: # B7 04 00 00 01 02 00 00 C1 0E 2C 59 20 00 04 0D 48 00 00 00 6F 00 FF FF # 4b7 | 05/29/2017 13:06:25 | CIMC | Drive slot(Bay) HDD7_STATUS #0x48 | Drive Presence | Asserted
5:2017 May 29 13:06:26 BST:BMC:selparser:1662: selparser.c:706: # B8 04 00 00 01 02 00 00 C1 0E 2C 59 20 00 04 0D 49 00 00 00 6F 00 FF FF # 4b8 | 05/29/2017 13:06:25 | CIMC | Drive slot(Bay) HDD8_STATUS #0x49 | Drive Presence | Asserted
5:2017 May 29 13:06:26 BST:BMC:selparser:1662: selparser.c:706: # B9 04 00 00 01 02 00 00 C1 0E 2C 59 20 00 04 24 4C 00 00 00 7F 01 FF FF # 4b9 | 05/29/2017 13:06:25 | CIMC | Platform alert P1_DIMM_A1_LED #0x4c | LED is on | Asserted
5:2017 May 29 13:06:26 BST:BMC:selparser:1662: selparser.c:706: # BA 04 00 00 01 02 00 00 C1 0E 2C 59 20 00 04 24 4C 00 00 00 7F 05 FF FF # 4ba | 05/29/2017 13:06:25 | CIMC | Platform alert P1_DIMM_A1_LED #0x4c | LED color is amber | Asserted
5:2017 May 29 13:06:26 BST:BMC:selparser:1662: selparser.c:706: # BB 04 00 00 01 02 00 00 C1 0E 2C 59 20 00 04 24 52 00 00 00 7F 01 FF FF # 4bb | 05/29/2017 13:06:25 | CIMC | Platform alert P1_DIMM_B1_LED #0x52 | LED is on | Asserted
5:2017 May 29 13:06:26 BST:BMC:selparser:1662: selparser.c:706: # BC 04 00 00 01 02 00 00 C1 0E 2C 59 20 00 04 24 52 00 00 00 7F 05 FF FF # 4bc | 05/29/2017 13:06:25 | CIMC | Platform alert P1_DIMM_B1_LED #0x52 | LED color is amber | Asserted
5:2017 May 29 13:06:26 BST:BMC:selparser:1662: selparser.c:706: # BD 04 00 00 01 02 00 00 C1 0E 2C 59 20 00 04 24 58 00 00 00 7F 01 FF FF # 4bd | 05/29/2017 13:06:25 | CIMC | Platform alert P1_DIMM_C1_LED #0x58 | LED is on | Asserted
5:2017 May 29 13:06:26 BST:BMC:selparser:1662: selparser.c:706: # BE 04 00 00 01 02 00 00 C1 0E 2C 59 20 00 04 24 58 00 00 00 7F 05 FF FF # 4be | 05/29/2017 13:06:25 | CIMC | Platform alert P1_DIMM_C1_LED #0x58 | LED color is amber | Asserted
5:2017 May 29 13:06:26 BST:BMC:selparser:1662: selparser.c:706: # BF 04 00 00 01 02 00 00 C1 0E 2C 59 20 00 04 24 5E 00 00 00 7F 01 FF FF # 4bf | 05/29/2017 13:06:25 | CIMC | Platform alert P1_DIMM_D1_LED #0x5e | LED is on | Asserted
5:2017 May 29 13:06:26 BST:BMC:selparser:1662: selparser.c:706: # C0 04 00 00 01 02 00 00 C1 0E 2C 59 20 00 04 24 5E 00 00 00 7F 05 FF FF # 4c0 | 05/29/2017 13:06:25 | CIMC | Platform alert P1_DIMM_D1_LED #0x5e | LED color is amber | Asserted
5:2017 May 29 13:06:26 BST:BMC:selparser:1662: selparser.c:706: # C1 04 00 00 01 02 00 00 C1 0E 2C 59 20 00 04 24 64 00 00 00 7F 01 FF FF # 4c1 | 05/29/2017 13:06:25 | CIMC | Platform alert P2_DIMM_E1_LED #0x64 | LED is on | Asserted
5:2017 May 29 13:06:26 BST:BMC:selparser:1662: selparser.c:706: # C2 04 00 00 01 02 00 00 C1 0E 2C 59 20 00 04 24 64 00 00 00 7F 05 FF FF # 4c2 | 05/29/2017 13:06:25 | CIMC | Platform alert P2_DIMM_E1_LED #0x64 | LED color is amber | Asserted
5:2017 May 29 13:06:26 BST:BMC:selparser:1662: selparser.c:706: # C3 04 00 00 01 02 00 00 C1 0E 2C 59 20 00 04 24 6A 00 00 00 7F 01 FF FF # 4c3 | 05/29/2017 13:06:25 | CIMC | Platform alert P2_DIMM_F1_LED #0x6a | LED is on | Asserted
5:2017 May 29 13:06:26 BST:BMC:selparser:1662: selparser.c:706: # C4 04 00 00 01 02 00 00 C1 0E 2C 59 20 00 04 24 6A 00 00 00 7F 05 FF FF # 4c4 | 05/29/2017 13:06:25 | CIMC | Platform alert P2_DIMM_F1_LED #0x6a | LED color is amber | Asserted
5:2017 May 29 13:06:26 BST:BMC:selparser:1662: selparser.c:706: # C5 04 00 00 01 02 00 00 C1 0E 2C 59 20 00 04 24 70 00 00 00 7F 01 FF FF # 4c5 | 05/29/2017 13:06:25 | CIMC | Platform alert P2_DIMM_G1_LED #0x70 | LED is on | Asserted
5:2017 May 29 13:06:26 BST:BMC:selparser:1662: selparser.c:706: # C6 04 00 00 01 02 00 00 C1 0E 2C 59 20 00 04 24 70 00 00 00 7F 05 FF FF # 4c6 | 05/29/2017 13:06:25 | CIMC | Platform alert P2_DIMM_G1_LED #0x70 | LED color is amber | Asserted
5:2017 May 29 13:06:26 BST:BMC:selparser:1662: selparser.c:706: # C7 04 00 00 01 02 00 00 C1 0E 2C 59 20 00 04 24 76 00 00 00 7F 01 FF FF # 4c7 | 05/29/2017 13:06:25 | CIMC | Platform alert P2_DIMM_H1_LED #0x76 | LED is on | Asserted
5:2017 May 29 13:06:26 BST:BMC:selparser:1662: selparser.c:706: # C8 04 00 00 01 02 00 00 C1 0E 2C 59 20 00 04 24 76 00 00 00 7F 05 FF FF # 4c8 | 05/29/2017 13:06:25 | CIMC | Platform alert P2_DIMM_H1_LED #0x76 | LED color is amber | Asserted
5:2017 May 29 13:06:26 BST:BMC:selparser:1662: selparser.c:706: # C9 04 00 00 01 02 00 00 C1 0E 2C 59 20 00 04 07 BD 00 00 00 05 01 FF FF # 4c9 | 05/29/2017 13:06:25 | CIMC | Processor P1_THERMTRIP_N #0xbd | Limit Exceeded | Asserted
5:2017 May 29 13:06:26 BST:BMC:selparser:1662: selparser.c:706: # CA 04 00 00 01 02 00 00 C1 0E 2C 59 20 00 04 07 BE 00 00 00 05 01 FF FF # 4ca | 05/29/2017 13:06:25 | CIMC | Processor P2_THERMTRIP_N #0xbe | Limit Exceeded | Asserted
2:2017 May 29 13:06:30 BST:BMC:IPMI:1591: PowerOnFail.c:55:PowerOnFail_Read:PowerOnFail on for 10 Scan Cycles Turning Power Off
2:2017 May 29 13:06:30 BST:BMC:kernel:-:<2>[host_power_ioctl]:957:POWER ON FAILURE has been detected
5:2017 May 29 13:06:30 BST:BMC:kernel:-:<5>[__do_power_off]:325:__do_power_off
5:2017 May 29 13:06:30 BST:BMC:IPMI:1591: Pilot2SrvPower.c:346:Pilot2SrvPowerOff
5:2017 May 29 13:06:30 BST:BMC:IPMI:1591: Pilot2SrvPower.c:466:Blade Power Changed To: [ OFF ]
5:2017 May 29 13:06:30 BST:BMC:IPMI:1591: Rack_FanCtrl.c:1272:fscUpdateActualFanPolicyFile: Applied Policy: N/A, Configuration Status: PENDING - Host powered off
5:2017 May 29 13:06:30 BST:BMC:video_trigger:-: video_trigger.c:280:Sending event_ipmi_power_state_change (OFF) ..
5:2017 May 29 13:06:32 BST:BMC:selparser:1662: selparser.c:706: # CB 04 00 00 01 02 00 00 C7 0E 2C 59 20 00 04 24 08 00 00 00 04 00 FF FF # 4cb | 05/29/2017 13:06:31 | CIMC | Platform alert POWER_ON_FAIL #0x08 | Predictive Failure deasserted | Asserted
5:2017 May 29 13:06:32 BST:BMC:selparser:1662: selparser.c:706: # CC 04 00 00 01 02 00 00 C7 0E 2C 59 20 00 04 24 39 00 00 00 7F 04 FF FF # 4cc | 05/29/2017 13:06:31 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED color is green | Asserted
5:2017 May 29 13:06:32 BST:BMC:selparser:1662: selparser.c:706: # CD 04 00 00 01 02 00 00 C7 0E 2C 59 20 00 04 24 39 00 00 00 FF 05 FF FF # 4cd | 05/29/2017 13:06:31 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED color is amber | Deasserted
5:2017 May 29 13:07:36 BST:BMC:IPMI:1591: Bridge.c:1468:audit from:kcs Fn:0x0 Cmd:0x2 Data: 0x0
5:2017 May 29 13:07:36 BST:BMC:IPMI:1591: Bridge.c:1474:audit Resp:0x0
5:2017 May 29 13:07:36 BST:BMC:AUDIT:1794: Server power state modify (op:power-off)
5:2017 May 29 13:07:38 BST:BMC:blade-power:5352: host-power.c:53:POWER Off
5:2017 May 29 13:07:38 BST:BMC:kernel:-:<5>[__do_power_off]:325:__do_power_off
5:2017 May 29 13:07:38 BST:BMC:run-update:5354: ../../src/runupdate.c:550:Run-update Process Starting.
5:2017 May 29 13:07:38 BST:BMC:run-update:5354: ../../src/runupdate.c:54:lock state = 0
5:2017 May 29 13:07:44 BST:BMC:run-update:5354: ../../src/runupdate.c:711:
5:2017 May 29 13:07:44 BST:BMC:run-update:5354: ../../src/runupdate.c:712:  Device 1 - CPLD
5:2017 May 29 13:07:44 BST:BMC:run-update:5354: ../../src/runupdate.c:713:    File Version: 31553032
5:2017 May 29 13:07:44 BST:BMC:run-update:5354: ../../src/runupdate.c:735:    Chip Version: 31553032
5:2017 May 29 13:07:44 BST:BMC:run-update:5354: cpld.c:97:  CPLD version compare
5:2017 May 29 13:07:44 BST:BMC:run-update:5354: cpld.c:101:    Chip and file version match.
5:2017 May 29 13:07:44 BST:BMC:run-update:5354: ../../src/runupdate.c:761:    Skipping device.
5:2017 May 29 13:07:44 BST:BMC:run-update:5354: ../../src/runupdate.c:712:  Device 2 - FPGA
5:2017 May 29 13:07:44 BST:BMC:run-update:5354: ../../src/runupdate.c:713:    File Version: C8061554
5:2017 May 29 13:07:44 BST:BMC:run-update:5354: ../../src/runupdate.c:735:    Chip Version: C8061554
5:2017 May 29 13:07:44 BST:BMC:run-update:5354: fpga.c:152:  FPGA version compare
5:2017 May 29 13:07:44 BST:BMC:run-update:5354: fpga.c:156:    Chip and file version match.
5:2017 May 29 13:07:45 BST:BMC:run-update:5354: ../../src/runupdate.c:711:
5:2017 May 29 13:07:45 BST:BMC:run-update:5354: ../../src/runupdate.c:712:  Device 3 - PWRSEQ_MAIN
5:2017 May 29 13:07:45 BST:BMC:run-update:5354: ../../src/runupdate.c:713:    File Version: PILOT-V3.1
5:2017 May 29 13:07:45 BST:BMC:run-update:5354: ../../src/runupdate.c:735:    Chip Version: PILOT-V3.1
5:2017 May 29 13:07:45 BST:BMC:run-update:5354: pwrsequencer.c:97:  PWRSEQ_MAIN version compare
5:2017 May 29 13:07:45 BST:BMC:run-update:5354: pwrsequencer.c:101:    Chip and file version match.
5:2017 May 29 13:07:45 BST:BMC:run-update:5354: ../../src/runupdate.c:761:    Skipping device.
5:2017 May 29 13:07:45 BST:BMC:run-update:5354: ../../src/runupdate.c:712:  Device 4 - PWRSEQ_CPU
5:2017 May 29 13:07:45 BST:BMC:run-update:5354: pwrsequencer.c:97:  PWRSEQ_CPU version compare
5:2017 May 29 13:07:45 BST:BMC:run-update:5354: ../../src/runupdate.c:712:  Device 5 - PWRSEQ_STANDBY
5:2017 May 29 13:07:45 BST:BMC:run-update:5354: pwrsequencer.c:97:  PWRSEQ_STANDBY version compare
5:2017 May 29 13:07:45 BST:BMC:run-update:5354: ../../src/runupdate.c:712:  Device 6 - ASTORIA
5:2017 May 29 13:07:45 BST:BMC:run-update:5354: ../../src/runupdate.c:713:    File Version: 1.2 build 258#012
5:2017 May 29 13:07:46 BST:BMC:run-update:5354: ../../src/runupdate.c:735:    Chip Version: 1.2 build 258#012
5:2017 May 29 13:07:46 BST:BMC:run-update:5354: ../../src/devices/astoria.c:58:  Astoria version compare
5:2017 May 29 13:07:46 BST:BMC:run-update:5354: ../../src/runupdate.c:761:    Skipping device.
5:2017 May 29 13:07:46 BST:BMC:run-update:5354: ../../src/runupdate.c:711:
5:2017 May 29 13:07:46 BST:BMC:run-update:5354: ../../src/runupdate.c:712:  Device 7 - PSU1
5:2017 May 29 13:07:46 BST:BMC:run-update:5354: ../../src/runupdate.c:713:    File Version: 12022215
5:2017 May 29 13:07:46 BST:BMC:run-update:5354: ../../src/runupdate.c:735:    Chip Version: 12022215
5:2017 May 29 13:07:46 BST:BMC:run-update:5354: psu.c:131:  PSU1 update NOT required
5:2017 May 29 13:07:46 BST:BMC:run-update:5354: ../../src/runupdate.c:712:  Device 8 - PSU2
5:2017 May 29 13:07:47 BST:BMC:run-update:5354: ../../src/runupdate.c:735:    Chip Version: 12022215
5:2017 May 29 13:07:47 BST:BMC:run-update:5354: psu.c:131:  PSU2 update NOT required
5:2017 May 29 13:07:47 BST:BMC:run-update:5354: ../../src/runupdate.c:761:    Skipping device.
5:2017 May 29 13:07:47 BST:BMC:run-update:5354: ../../src/runupdate.c:930:Run-update Process Complete. rc: 0#012
5:2017 May 29 13:08:26 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 13:08:26 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 13:08:26 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 13:08:44 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 13:08:44 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 13:08:44 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 13:12:27 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 13:12:27 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 13:12:27 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 13:12:37 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 13:12:37 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 13:12:37 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 13:12:51 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 13:12:51 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 13:12:51 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 13:12:53 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 13:12:53 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 13:12:53 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 13:15:07 BST:BMC:selparser:1662: selparser.c:706: # CE 04 00 00 01 02 00 00 CA 10 2C 59 20 00 04 08 2F 00 00 00 03 00 FF FF # 4ce | 05/29/2017 13:15:06 | CIMC | Power supply PSU1_AC_OK #0x2f | State Deasserted | Asserted
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ18
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ19
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ20
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ21
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ22
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ23
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ24
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ25
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ26
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ27
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ28
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ29
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ30
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ31
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ32
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ33
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ34
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ35
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ36
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ37
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ38
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ39
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ40
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ41
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ42
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ43
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ44
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ45
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ46
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ47
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ48
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ49
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ50
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ51
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ52
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ53
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ54
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ55
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ56
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ57
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ58
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ59
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ60
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ61
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ62
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ63
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ64
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ65
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ66
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ67
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ68
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ69
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ70
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ71
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ72
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ73
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ74
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ75
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ76
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ77
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ78
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Pilot3 Interrupt Controller Enabled and Configured.
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Pilot-II Timer Initialized
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Pilot-II Timer Started
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Console: colour dummy device 80x30
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Mount-cache hash table entries: 512
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>bio: create slab <bio-0> at 0
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>NetWinder Floating Point Emulator V0.97 (double precision)
5:2016 Dec 13 12:33:42 GMT:BMC:pmbus_pwrsply_mngr:1552: pmbus_pwrsply_mngr.c:1757:Power Supply 0x1 Presence Changed to present.
5:2016 Dec 13 12:33:42 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [sm]
5:2016 Dec 13 12:33:42 GMT:BMC:doctor-bmc:1720: app_monitor.c:234:Process, sm, successfully started.
5:2016 Dec 13 12:33:43 GMT:BMC:pmbus_pwrsply_mngr:1552: pmbus_pwrsply_mngr.c:1757:Power Supply 0x2 Presence Changed to present.
5:2016 Dec 13 12:33:43 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [bioscomd]
5:2016 Dec 13 12:33:43 GMT:BMC:doctor-bmc:1728: app_monitor.c:234:Process, bioscomd, successfully started.
5:2016 Dec 13 12:33:43 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [lv_dimmd]
5:2016 Dec 13 12:33:43 GMT:BMC:doctor-bmc:1737: app_monitor.c:234:Process, lv_dimmd, successfully started.
5:2016 Dec 13 12:33:44 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [fault-engined]
5:2016 Dec 13 12:33:44 GMT:BMC:doctor-bmc:1745: app_monitor.c:234:Process, fault-engined, successfully started.
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>name is Pilot3 Tulip
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>BROADCOM: PHY found at phy address 19!!
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>MV Switch Port 5 Enable status: 7f
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>Nand Astoria Mark 17
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>EMS CLI Work queue is created successfully
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Entered m25pxx_init
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Fast clk is set
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>C220 EVT1/P1 board detected. If wrong, fix CPLD programming
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Strap is SET for HOST spi
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Warning: unable to open an initial console.
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>[host_power_init]:1458:INIT Blade Power State is ... [ OFF ]
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>Pilot3 SPI Flash mapping: 0x4000000 at 0x0
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>No of banks = 6
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Probing for Flash at Bank # 0
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>SPI: probing for intel s33 devices ...
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>SPI: probing for atmel devices ...
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>SPI: probing for m25pxx devices ...
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>20 0 0 262144
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Probing for Flash at Bank # 1
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>19 0 0 262144
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Probing for Flash at Bank # 2
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>18 0 0 262144
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Probing for Flash at Bank # 3
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>17 0 0 262144
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Probing for Flash at Bank # 4
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>16 0 0 262144
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Probing for Flash at Bank # 5
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>15 0 0 262144
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>Concatenating MTD devices:
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>(0): "Pilot3 SPI MAP"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>(1): "Pilot3 SPI MAP"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>(2): "Pilot3 SPI MAP"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>(3): "Pilot3 SPI MAP"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>(4): "Pilot3 SPI MAP"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>(5): "Pilot3 SPI MAP"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>into device "Concat Ractrends"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>Creating 15 MTD partitions on "Concat Ractrends":
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000000000000-0x000006000000 : "all"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000000000000-0x000000080000 : "U-Boot"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000000080000-0x0000000c0000 : "boot.conf"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x0000000c0000-0x000000100000 : "RSVD"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000000100000-0x000000880000 : "Linux1"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000000880000-0x000001000000 : "Linux2"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000001000000-0x000001800000 : "NV_0"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000001800000-0x000002000000 : "OBFL"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000002000000-0x000003000000 : "NV_1"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000003000000-0x000004000000 : "NV_2"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000004000000-0x000004800000 : "P2_NV_0"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000004800000-0x000004940000 : "P2_OBFL"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000004940000-0x000004c80000 : "NV_3"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000004c80000-0x000004fc0000 : "NV_4"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000004fc0000-0x000005000000 : "RSVD_NVRAM"
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Major number for pwmtach driver is - 235
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4> PWM and Fan tach configuration registers
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>PWCFG: 55  addr: c7946000
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>FMCFG: ff  addr: c7946004
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>PWOCF: 0  addr: c7946008
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4> Fan tach  Interrupt Register
5:2016 Dec 13 12:33:44 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [gdsd]
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>FTISR: 0  addr: c794600c
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4> PWM control & stat reg , enables counter resolution
5:2016 Dec 13 12:33:44 GMT:BMC:lv_dimm:1739: lv_dimm.c:200:[transition_function]Starting Transition to [High Voltage Mode] from [Unknown Mode]
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>PWCRCSR: 55, addr: c7946010
5:2016 Dec 13 12:33:44 GMT:BMC:lv_dimm:1739: common.c:941:Disabling Sensor scan for sensor 0x83.
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Counter resolution reg, sets no of clock cycles for PWM
5:2016 Dec 13 12:33:44 GMT:BMC:lv_dimm:1739: common.c:941:Disabling Sensor scan for sensor 0x84.
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>PWCRVR0: 1e, addr: c7946014
5:2016 Dec 13 12:33:44 GMT:BMC:doctor-bmc:1761: app_monitor.c:234:Process, gdsd, successfully started.
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>PWCRVR1: 1e, addr: c7946018
5:2016 Dec 13 12:33:45 GMT:BMC:lv_dimm:1739: common.c:941:Disabling Sensor scan for sensor 0x85.
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCRVR2: 1e, addr: c794601c
5:2016 Dec 13 12:33:45 GMT:BMC:lv_dimm:1739: common.c:941:Disabling Sensor scan for sensor 0x86.
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCRVR3: 1e, addr: c7946020
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> PWM pre scale register, sets clock divider for PWM
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> PWM  duty cycle reg, sets no of high pulses
5:2016 Dec 13 12:33:45 GMT:BMC:lv_dimm:1739: common.c:941:Disabling Sensor scan for sensor 0x89.
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWPSR0: a, addr: c7946040
5:2016 Dec 13 12:33:45 GMT:BMC:lv_dimm:1739: common.c:941:Disabling Sensor scan for sensor 0x8a.
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWDCR0: 15, addr: c7946044
5:2016 Dec 13 12:33:45 GMT:BMC:lv_dimm:1739: common.c:941:Disabling Sensor scan for sensor 0x91.
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWPSR1: a
5:2016 Dec 13 12:33:45 GMT:BMC:lv_dimm:1739: common.c:941:Disabling Sensor scan for sensor 0x92.
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWDCR1: 15
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWPSR2: a
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWDCR2: 15
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWPSR3: a
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWDCR3: 15
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> Fan tach threshold reg, sets max no of clock between pulses
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR0: ff, addr: c7946060
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR1: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR2: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR3: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR4: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR5: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR6: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR7: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> Fan tach speed reg, set automatically
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR0: 0, addr c7946064
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR1: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR2: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR3: 0
5:2016 Dec 13 12:33:45 GMT:BMC:lv_dimm:1739: lv_dimm.c:220:[transition_function]Transition to [High Voltage Mode] Success
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR4: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR5: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR6: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR7: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> Fan tach control& stat reg,
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR0: 60 addr c7946068
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR1: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR2: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR3: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR4: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR5: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR6: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR7: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> Fan Tach filter select reg, sets filter value if filter is enabled
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMPFSR0: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMPFSR1: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> SET2 - PWM and Fan tach configuration registers
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCFG1: 55  addr: c7946100
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCFG1: ff  addr: c7946104
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWOCF1: 0  addr: c7946108
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> Fan tach  Interrupt Register
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FTISR1: 0  addr: c794610c
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> PWM control & stat reg , enables counter resolution
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCRCSR1: 55, addr: c7946110
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>Counter resolution reg, sets no of clock cycles for PWM
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCRVR4: 1e, addr: c7946114
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCRVR5: 1e, addr: c7946118
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCRVR6: 1e, addr: c794611c
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCRVR7: 1e, addr: c7946120
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWPSR4: a, addr: c7946140
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWDCR4: 15, addr: c7946144
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWPSR5: a
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWDCR5: 15
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWPSR6: a
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWDCR6: 15
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWPSR7: a
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWDCR7: 15
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR8: ff, addr: c7946160
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR9: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR10: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR11: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR12: ff
5:2016 Dec 13 12:33:45 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [mem_throttled]
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR13: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR14: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR15: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR8: 0 addr c7946164
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR9: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR10: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR11: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR12: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR13: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR14: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR15: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR8: 60 addr c7946168
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR9: 60
5:2016 Dec 13 12:33:45 GMT:BMC:doctor-bmc:1767: app_monitor.c:234:Process, mem_throttled, successfully started.
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR10: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR11: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR12: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR13: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR14: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR15: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMPFSR2: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMPFSR3: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>***************PWM Driver has been initialized****************
5:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2773:USB FS: VDD Power Good = OFF
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> CyAnDevice: Cannot get firmware version. Reason code: 81
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> CyAnDevice: CyAsMiscConfigureDevice: No Firmware loaded: 81
5:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<5> CyAnDevice: Downloading Astoria firmware 1
5:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<5> CyAnDevice: Astoria firmware has been initialized
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>setting perfect hw filtering mode (c63d34f8)
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>setting perfect hw filtering mode (c70554f8)
4:2016 Dec 13 12:33:47 GMT:BMC:kernel:-:last message repeated 5 times
5:2016 Dec 13 12:33:45 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [qpi_loggerd]
5:2016 Dec 13 12:33:45 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[10]: Turning LED[10] (LED_FAN2_FAULT) OFF
5:2016 Dec 13 12:33:45 GMT:BMC:doctor-bmc:1775: app_monitor.c:234:Process, qpi_loggerd, successfully started.
5:2016 Dec 13 12:33:45 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[12]: Turning LED[12] (LED_FAN4_FAULT) OFF
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>EXT2-fs (loop0): warning: mounting unchecked fs, running e2fsck is recommended
5:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x30 : Status = 0x83
4:2016 Dec 13 12:33:45 GMT:BMC:IPMI:1591: PSRedundantMode.c:51:PSRdntMode_Read --> Failed to open file /var/pmbus/ps_redundancy_state for read.
5:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x31 : Status = 0x80
5:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x33 : Status = 0x83
5:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x34 : Status = 0x80
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x20 : Status = 0x83
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x21 : Status = 0x80
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x23 : Status = 0x83
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x24 : Status = 0x80
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x10 : Status = 0x83
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x11 : Status = 0x80
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x13 : Status = 0x83
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x14 : Status = 0x80
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x0 : Status = 0x83
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x1 : Status = 0x80
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x3 : Status = 0x83
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x4 : Status = 0x80
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x31 : Status = 0x80
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x34 : Status = 0x80
5:2016 Dec 13 12:33:46 GMT:BMC:selparser:1662: selparser.c:706: # CF 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 24 08 00 00 00 04 00 FF FF # 4cf | 12/13/2016 12:33:45 | CIMC | Platform alert POWER_ON_FAIL #0x08 | Predictive Failure deasserted | Asserted
5:2016 Dec 13 12:33:46 GMT:BMC:selparser:1662: selparser.c:706: # D0 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 25 0A 00 00 00 08 01 FF FF # 4d0 | 12/13/2016 12:33:45 | CIMC | Entity presence FAN2_PRSNT #0x0a | Device Present | Asserted
5:2016 Dec 13 12:33:46 GMT:BMC:selparser:1662: selparser.c:706: # D1 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 25 0C 00 00 00 08 01 FF FF # 4d1 | 12/13/2016 12:33:45 | CIMC | Entity presence FAN4_PRSNT #0x0c | Device Present | Asserted
5:2016 Dec 13 12:33:46 GMT:BMC:selparser:1662: selparser.c:706: # D2 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 25 1E 00 00 00 08 01 FF FF # 4d2 | 12/13/2016 12:33:45 | CIMC | Entity presence RISER2_PRESENT #0x1e | Device Present | Asserted
5:2016 Dec 13 12:33:46 GMT:BMC:selparser:1662: selparser.c:706: # D3 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 25 24 00 00 00 08 01 FF FF # 4d3 | 12/13/2016 12:33:45 | CIMC | Entity presence RISER1_PRESENT_1 #0x24 | Device Present | Asserted
5:2016 Dec 13 12:33:46 GMT:BMC:selparser:1662: selparser.c:706: # D4 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 24 36 00 00 00 7F 01 FF FF # 4d4 | 12/13/2016 12:33:45 | CIMC | Platform alert LED_PSU_STATUS #0x36 | LED is on | Asserted
5:2016 Dec 13 12:33:46 GMT:BMC:selparser:1662: selparser.c:706: # D5 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 24 36 00 00 00 7F 04 FF FF # 4d5 | 12/13/2016 12:33:45 | CIMC | Platform alert LED_PSU_STATUS #0x36 | LED color is green | Asserted
5:2016 Dec 13 12:33:46 GMT:BMC:selparser:1662: selparser.c:706: # D6 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 24 38 00 00 00 7F 01 FF FF # 4d6 | 12/13/2016 12:33:45 | CIMC | Platform alert LED_FAN_STATUS #0x38 | LED is on | Asserted
5:2016 Dec 13 12:33:46 GMT:BMC:selparser:1662: selparser.c:706: # D7 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 24 38 00 00 00 7F 04 FF FF # 4d7 | 12/13/2016 12:33:45 | CIMC | Platform alert LED_FAN_STATUS #0x38 | LED color is green | Asserted
5:2016 Dec 13 12:33:46 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [xapid]
5:2016 Dec 13 12:33:46 GMT:BMC:doctor-bmc:1798: app_monitor.c:234:Process, xapid, successfully started.
5:2016 Dec 13 12:33:46 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[9]: Turning LED[9] (LED_FAN1_FAULT) OFF
5:2016 Dec 13 12:33:46 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[11]: Turning LED[11] (LED_FAN3_FAULT) OFF
5:2016 Dec 13 12:33:46 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[13]: Turning LED[13] (LED_FAN5_FAULT) OFF
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[__do_power_off]:325:__do_power_off
5:2016 Dec 13 12:33:47 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[255]: Turning LED[25] (LED_DIMM_FAULT_P1_A2) OFF
5:2016 Dec 13 12:33:47 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[255]: Turning LED[27] (LED_DIMM_FAULT_P1_B2) OFF
5:2016 Dec 13 12:33:47 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[255]: Turning LED[29] (LED_DIMM_FAULT_P1_C2) OFF
5:2016 Dec 13 12:33:47 GMT:BMC:lv_dimm:1739: lv_dimm.c:403:[handle_event_enable_tick]enable sensor event
5:2016 Dec 13 12:33:47 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x83.
5:2016 Dec 13 12:33:47 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x84.
5:2016 Dec 13 12:33:47 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x85.
5:2016 Dec 13 12:33:47 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x86.
5:2016 Dec 13 12:33:47 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x89.
5:2016 Dec 13 12:33:47 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x8a.
5:2016 Dec 13 12:33:47 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x91.
5:2016 Dec 13 12:33:47 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x92.
5:2016 Dec 13 12:33:47 GMT:BMC:lv_dimm:1739: sanluis1/platform.c:117:platform_event_enable_tick_end: Configuring IR from CIMC
5:2016 Dec 13 12:33:47 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[255]: Turning LED[31] (LED_DIMM_FAULT_P1_D2) OFF
5:2016 Dec 13 12:33:47 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[255]: Turning LED[33] (LED_DIMM_FAULT_P2_E2) OFF
5:2016 Dec 13 12:33:47 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[255]: Turning LED[35] (LED_DIMM_FAULT_P2_F2) OFF
5:2016 Dec 13 12:33:47 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[255]: Turning LED[37] (LED_DIMM_FAULT_P2_G2) OFF
5:2016 Dec 13 12:33:47 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[255]: Turning LED[39] (LED_DIMM_FAULT_P2_H2) OFF
5:2016 Dec 13 12:33:47 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [fcgi]
5:2016 Dec 13 12:33:47 GMT:BMC:doctor-bmc:1804: app_monitor.c:234:Process, fcgi, successfully started.
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # D8 04 00 00 01 02 00 00 AA EA 4F 58 20 00 04 25 09 00 00 00 08 01 FF FF # 4d8 | 12/13/2016 12:33:46 | CIMC | Entity presence FAN1_PRSNT #0x09 | Device Present | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # D9 04 00 00 01 02 00 00 AA EA 4F 58 20 00 04 25 0B 00 00 00 08 01 FF FF # 4d9 | 12/13/2016 12:33:46 | CIMC | Entity presence FAN3_PRSNT #0x0b | Device Present | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # DA 04 00 00 01 02 00 00 AA EA 4F 58 20 00 04 25 0D 00 00 00 08 01 FF FF # 4da | 12/13/2016 12:33:46 | CIMC | Entity presence FAN5_PRSNT #0x0d | Device Present | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # DB 04 00 00 01 02 00 00 AA EA 4F 58 20 00 04 25 1F 00 00 00 08 01 FF FF # 4db | 12/13/2016 12:33:46 | CIMC | Entity presence RISER1_PRESENT #0x1f | Device Present | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # DC 04 00 00 01 02 00 00 AA EA 4F 58 20 00 04 25 23 00 00 00 08 01 FF FF # 4dc | 12/13/2016 12:33:46 | CIMC | Entity presence RISER2_PRESENT_1 #0x23 | Device Present | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # DD 04 00 00 01 02 00 00 AA EA 4F 58 20 00 04 24 37 00 00 00 7F 01 FF FF # 4dd | 12/13/2016 12:33:46 | CIMC | Platform alert LED_TEMP_STATUS #0x37 | LED is on | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # DE 04 00 00 01 02 00 00 AA EA 4F 58 20 00 04 24 37 00 00 00 7F 04 FF FF # 4de | 12/13/2016 12:33:46 | CIMC | Platform alert LED_TEMP_STATUS #0x37 | LED color is green | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # DF 04 00 00 01 02 00 00 AB EA 4F 58 20 00 04 24 39 00 00 00 7F 01 FF FF # 4df | 12/13/2016 12:33:47 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED is on | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # E0 04 00 00 01 02 00 00 AB EA 4F 58 20 00 04 24 39 00 00 00 7F 04 FF FF # 4e0 | 12/13/2016 12:33:47 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED color is green | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # E1 04 00 00 01 02 00 00 AB EA 4F 58 20 00 04 25 A1 00 00 00 08 01 FF FF # 4e1 | 12/13/2016 12:33:47 | CIMC | Entity presence P2_PRESENT #0xa1 | Device Present | Asserted
5:2016 Dec 13 12:33:48 GMT:BMC:selparser:1662: selparser.c:706: # E2 04 00 00 01 02 00 00 AC EA 4F 58 20 00 04 25 A0 00 00 00 08 01 FF FF # 4e2 | 12/13/2016 12:33:48 | CIMC | Entity presence P1_PRESENT #0xa0 | Device Present | Asserted
5:2016 Dec 13 12:33:49 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [monkey]
5:2016 Dec 13 12:33:49 GMT:BMC:doctor-bmc:1826: app_monitor.c:234:Process, monkey, successfully started.
5:2016 Dec 13 12:33:49 GMT:BMC:bios-update:1840: main.c:236:Running as Daemon
5:2016 Dec 13 12:33:50 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [alertmgr]
5:2016 Dec 13 12:33:50 GMT:BMC:doctor-bmc:1849: app_monitor.c:234:Process, alertmgr, successfully started.
4:2016 Dec 13 12:33:51 GMT:BMC:IPMI:1591: PSRedundantMode.c:51:PSRdntMode_Read --> Failed to open file /var/pmbus/ps_redundancy_state for read.
5:2016 Dec 13 12:33:52 GMT:BMC:bios-update:1840: activate.c:142:Setting BIOS Version
5:2016 Dec 13 12:33:56 GMT:BMC:selparser:1662: selparser.c:706: # E3 04 00 00 01 02 00 00 B4 EA 4F 58 20 00 04 08 25 00 00 00 6F 30 FF 00 # 4e3 | 12/13/2016 12:33:56 | CIMC | Power supply PSU1_STATUS #0x25 | Presence detected |  | Asserted
5:2016 Dec 13 12:33:56 GMT:BMC:selparser:1662: selparser.c:706: # E4 04 00 00 01 02 00 00 B4 EA 4F 58 20 00 04 08 26 00 00 00 6F 30 FF 00 # 4e4 | 12/13/2016 12:33:56 | CIMC | Power supply PSU2_STATUS #0x26 | Presence detected |  | Asserted
5:2016 Dec 13 12:33:57 GMT:BMC:selparser:1662: selparser.c:706: # E5 04 00 00 01 02 00 00 B5 EA 4F 58 20 00 04 08 3A 00 00 00 0B 00 FF FF # 4e5 | 12/13/2016 12:33:57 | CIMC | Power supply PS_RDNDNT_MODE #0x3a | Fully Redundant | Asserted
5:2016 Dec 13 12:33:57 GMT:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2402:USB1 VDD power off
5:2016 Dec 13 12:34:00 GMT:BMC:selparser:1662: selparser.c:706: # E6 04 00 00 01 02 00 00 B8 EA 4F 58 20 00 04 08 2F 00 00 00 03 01 FF FF # 4e6 | 12/13/2016 12:34:00 | CIMC | Power supply PSU1_AC_OK #0x2f | State Asserted | Asserted
5:2016 Dec 13 12:34:00 GMT:BMC:selparser:1662: selparser.c:706: # E7 04 00 00 01 02 00 00 B8 EA 4F 58 20 00 04 08 31 00 00 00 03 01 FF FF # 4e7 | 12/13/2016 12:34:00 | CIMC | Power supply PSU2_AC_OK #0x31 | State Asserted | Asserted
5:2016 Dec 13 12:34:03 GMT:BMC:kernel:-:<5>Slow work thread pool: Starting up
5:2016 Dec 13 12:34:03 GMT:BMC:kernel:-:<5>Slow work thread pool: Ready
5:2016 Dec 13 12:34:05 GMT:BMC:DimmBL-DbSyncTask:1471: DimmBL-DbSyncTask.c:224:InitializeDimmBLSyncTask: SUCCESS
5:2016 Dec 13 12:34:06 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [kvm]
5:2016 Dec 13 12:34:06 GMT:BMC:doctor-bmc:1977: app_monitor.c:234:Process, kvm, successfully started.
5:2016 Dec 13 12:34:06 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [vkvm_pm]
5:2016 Dec 13 12:34:06 GMT:BMC:doctor-bmc:1984: app_monitor.c:234:Process, vkvm_pm, successfully started.
5:2016 Dec 13 12:34:07 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [sshd]
5:2016 Dec 13 12:34:07 GMT:BMC:doctor-bmc:2008: app_monitor.c:234:Process, sshd, successfully started.
5:2016 Dec 13 12:34:07 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [cisco_pm]
5:2016 Dec 13 12:34:07 GMT:BMC:doctor-bmc:2022: app_monitor.c:234:Process, cisco_pm, successfully started.
5:2016 Dec 13 12:34:07 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [ciscoNET]
5:2016 Dec 13 12:34:08 GMT:BMC:doctor-bmc:2032: app_monitor.c:234:Process, ciscoNET, successfully started.
5:2016 Dec 13 12:34:08 GMT:BMC:ciscoNET:2034: ciscoNET.c:122:Application Starting
5:2016 Dec 13 12:34:08 GMT:BMC:doctor-bmc-app-mon:2054: app_monitor.c:726:Started application monitor (2054)
5:2016 Dec 13 12:34:08 GMT:BMC:doctor-bmc-app-mon:2054: app_monitor.c:481:cmp_proc_node_ctime: stat(/proc/1609) failed, errno 2 (No such file or directory)
5:2016 Dec 13 12:34:08 GMT:BMC:doctor-bmc-app-mon:2054: app_monitor.c:636:cmp_proc_node_ctime sel_pigeon_cntrd stat(/proc/1609) returned errno 2 (No such file or directory)
4:2016 Dec 13 12:34:08 GMT:BMC:doctor-bmc-app-mon:2054: app_monitor.c:592:Restarting Process sel_pigeon_cntrd
5:2016 Dec 13 12:34:08 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [ucsm_state_manager]
5:2016 Dec 13 12:34:08 GMT:BMC:doctor-bmc:2058: app_monitor.c:234:Process, ucsm_state_manager, successfully started.
5:2016 Dec 13 12:34:09 GMT:BMC:ciscoNET:2034: network_manager.c:549:Configuring the network.
5:2016 Dec 13 12:34:09 GMT:BMC:sel_pigeon_cntr:2063: sel_pigeon_cntr.c:917:Opening connection to SEL_PIGEON_CNTR_FIFO
5:2016 Dec 13 12:34:09 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [GDSCommDmn]
5:2016 Dec 13 12:34:09 GMT:BMC:doctor-bmc:2083: app_monitor.c:234:Process, GDSCommDmn, successfully started.
5:2016 Dec 13 12:34:10 GMT:BMC:GDSCommDmn:-: GDSCommSVC.c:116:GDSComm SVC started
5:2016 Dec 13 12:34:10 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [rack_monitor]
5:2016 Dec 13 12:34:10 GMT:BMC:doctor-bmc:2088: app_monitor.c:234:Process, rack_monitor, successfully started.
5:2016 Dec 13 12:34:10 GMT:BMC:rack_monitor:-: rack_monitor.c:397:RACK Montior in Stand-alone mode
5:2016 Dec 13 12:34:10 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [sam_master]
5:2016 Dec 13 12:34:11 GMT:BMC:doctor-bmc:2093: app_monitor.c:234:Process, sam_master, successfully started.
5:2016 Dec 13 12:34:11 GMT:BMC:sam_master:-: sam_master.c:61:Stopping PTPD on Monitor Request
5:2016 Dec 13 12:34:11 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [ciscovmd]
5:2016 Dec 13 12:34:11 GMT:BMC:doctor-bmc:2099: app_monitor.c:234:Process, ciscovmd, successfully started.
5:2016 Dec 13 12:34:11 GMT:BMC:ciscoNET:2034: network_manager.c:793:Error: killall udhcpc returned exit code: 256
5:2016 Dec 13 12:34:12 GMT:BMC:doctor-bmc:-: doctor-bmc.c:308:doctor-bmc-app stop [ptpd]
5:2016 Dec 13 12:34:12 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [video_triggerd]
5:2016 Dec 13 12:34:12 GMT:BMC:doctor-bmc:2106: app_monitor.c:234:Process, video_triggerd, successfully started.
5:2016 Dec 13 12:34:12 GMT:BMC:ciscoNET:2034: network_manager.c:795:Error: killall udhcpc6 returned exit code: 256
4:2016 Dec 13 12:34:15 GMT:BMC:kernel:-:<4>setting perfect hw filtering mode (c70554f8)
5:2016 Dec 13 12:34:22 GMT:BMC:hw-ether:2184: hw-ether.c:254:eth0's hardware address changed to f8:72:ea:a3:d6:ee
4:2016 Dec 13 12:34:22 GMT:BMC:kernel:-:<4>setting perfect hw filtering mode (c70554f8)
4:2016 Dec 13 12:34:36 GMT:BMC:kernel:-:last message repeated 6 times
4:2016 Dec 13 12:34:26 GMT:BMC:ciscoNET:2034: network_manager.c:2082:Error: Can not open file, /etc/resolv.conf, with mode, r: 0x2.
5:2016 Dec 13 12:34:26 GMT:BMC:ciscoNET:2034: cisco_cards_manager.c:204:There are no cisco configurable cards attached.
5:2016 Dec 13 12:34:28 GMT:BMC:GDSCommDmn:-: GDSCommSVC.c:209:GDSComm started taking input connections.
5:2016 Dec 13 12:34:28 GMT:BMC:IPMI:1591: Bridge.c:1468:audit from:kcs Fn:0x6 Cmd:0x56 Data: 0x1 0x0 0x1
5:2016 Dec 13 12:34:28 GMT:BMC:IPMI:1591: Bridge.c:1474:audit Resp:0x0
5:2016 Dec 13 12:34:36 GMT:BMC:dataserver:1794: eventsubscribemgnt.c:91:IsShmRestoreRequired: Restoration required!
5:2016 Dec 13 12:34:36 GMT:BMC:dataserver:1794: eventsubscribemgnt.c:1193:RestoreEvtSubscCfg: Restored event subscription configuration successfully!
5:2016 Dec 13 12:34:38 GMT:BMC:doctor-bmc:-: doctor-bmc.c:308:doctor-bmc-app stop [snmp-subagentd]
5:2016 Dec 13 12:34:38 GMT:BMC:root:-: CIMC booted after a chassis power on!!
5:2016 Dec 13 12:34:38 GMT:BMC:root:-: Waiting for MB FRU data to get populated..
5:2016 Dec 13 12:34:38 GMT:BMC:root:-: MB FRU data populated successfully
5:2016 Dec 13 12:34:39 GMT:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2016 Dec 13 12:34:39 GMT:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2016 Dec 13 12:34:39 GMT:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2016 Dec 13 12:34:44 GMT:BMC:root:-: NTP: CIMC IP acquired: 192.168.1.207
5:2016 Dec 13 12:34:44 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [ntpd]
5:2016 Dec 13 12:34:44 GMT:BMC:doctor-bmc:2408: app_monitor.c:234:Process, ntpd, successfully started.
3:2016 Dec 13 12:34:48 GMT:BMC:update-ir:2352: ../../src/update-ir.c:234:Host should be powered-on for IR configuration update
5:2016 Dec 13 12:35:02 GMT:BMC:root:-: DDNS: CIMC IP acquired: 192.168.1.207
5:2016 Dec 13 12:35:02 GMT:BMC:root:-: DDNS: GATEWAY IP acquired: 192.168.1.254
4:2016 Dec 13 12:35:14 GMT:BMC:kernel:-:<4>process `doctor-bmc' is using deprecated sysctl (syscall) net.ipv6.neigh.default.retrans_time; Use net.ipv6.neigh.default.retrans_time_ms instead.
3:2017 May 29 13:20:29 BST:BMC:crond:1296: time disparity of 240465 minutes detected
5:2017 May 29 13:21:25 BST:BMC:selparser:1662: selparser.c:706: # E8 04 00 00 01 02 00 00 45 12 2C 59 20 00 04 08 2F 00 00 00 03 00 FF FF # 4e8 | 05/29/2017 13:21:25 | CIMC | Power supply PSU1_AC_OK #0x2f | State Deasserted | Asserted
5:2016 Dec 13 12:33:43 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [fault-engined]
5:2016 Dec 13 12:33:44 GMT:BMC:doctor-bmc:1759: app_monitor.c:234:Process, gdsd, successfully started.
5:2016 Dec 13 12:33:44 GMT:BMC:lv_dimm:1739: common.c:941:Disabling Sensor scan for sensor 0x85.
5:2016 Dec 13 12:33:44 GMT:BMC:lv_dimm:1739: common.c:941:Disabling Sensor scan for sensor 0x86.
5:2016 Dec 13 12:33:44 GMT:BMC:lv_dimm:1739: common.c:941:Disabling Sensor scan for sensor 0x89.
5:2016 Dec 13 12:33:44 GMT:BMC:lv_dimm:1739: common.c:941:Disabling Sensor scan for sensor 0x8a.
5:2016 Dec 13 12:33:44 GMT:BMC:lv_dimm:1739: common.c:941:Disabling Sensor scan for sensor 0x91.
5:2016 Dec 13 12:33:44 GMT:BMC:lv_dimm:1739: common.c:941:Disabling Sensor scan for sensor 0x92.
5:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<5>0x000004fc0000-0x000005000000 : "RSVD_NVRAM"
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>Major number for pwmtach driver is - 235
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> PWM and Fan tach configuration registers
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCFG: 55  addr: c7946000
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCFG: ff  addr: c7946004
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWOCF: 0  addr: c7946008
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FTISR: 0  addr: c794600c
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCRCSR: 55, addr: c7946010
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCRVR0: 1e, addr: c7946014
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCRVR1: 1e, addr: c7946018
5:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
4:2016 Dec 13 12:33:48 GMT:BMC:kernel:-:last message repeated 2 times
4:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<4>EXT2-fs (loop0): warning: mounting unchecked fs, running e2fsck is recommended
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x30 : Status = 0x83
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x33 : Status = 0x83
5:2016 Dec 13 12:33:46 GMT:BMC:selparser:1662: selparser.c:706: # E9 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 24 08 00 00 00 04 00 FF FF # 4e9 | 12/13/2016 12:33:45 | CIMC | Platform alert POWER_ON_FAIL #0x08 | Predictive Failure deasserted | Asserted
5:2016 Dec 13 12:33:46 GMT:BMC:selparser:1662: selparser.c:706: # EA 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 25 0A 00 00 00 08 01 FF FF # 4ea | 12/13/2016 12:33:45 | CIMC | Entity presence FAN2_PRSNT #0x0a | Device Present | Asserted
5:2016 Dec 13 12:33:46 GMT:BMC:selparser:1662: selparser.c:706: # EB 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 25 0C 00 00 00 08 01 FF FF # 4eb | 12/13/2016 12:33:45 | CIMC | Entity presence FAN4_PRSNT #0x0c | Device Present | Asserted
5:2016 Dec 13 12:33:46 GMT:BMC:selparser:1662: selparser.c:706: # EC 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 25 1E 00 00 00 08 01 FF FF # 4ec | 12/13/2016 12:33:45 | CIMC | Entity presence RISER2_PRESENT #0x1e | Device Present | Asserted
5:2016 Dec 13 12:33:46 GMT:BMC:selparser:1662: selparser.c:706: # ED 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 25 24 00 00 00 08 01 FF FF # 4ed | 12/13/2016 12:33:45 | CIMC | Entity presence RISER1_PRESENT_1 #0x24 | Device Present | Asserted
5:2016 Dec 13 12:33:46 GMT:BMC:selparser:1662: selparser.c:706: # EE 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 24 36 00 00 00 7F 01 FF FF # 4ee | 12/13/2016 12:33:45 | CIMC | Platform alert LED_PSU_STATUS #0x36 | LED is on | Asserted
5:2016 Dec 13 12:33:46 GMT:BMC:selparser:1662: selparser.c:706: # EF 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 24 36 00 00 00 7F 04 FF FF # 4ef | 12/13/2016 12:33:45 | CIMC | Platform alert LED_PSU_STATUS #0x36 | LED color is green | Asserted
5:2016 Dec 13 12:33:46 GMT:BMC:selparser:1662: selparser.c:706: # F0 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 24 38 00 00 00 7F 01 FF FF # 4f0 | 12/13/2016 12:33:45 | CIMC | Platform alert LED_FAN_STATUS #0x38 | LED is on | Asserted
5:2016 Dec 13 12:33:46 GMT:BMC:selparser:1662: selparser.c:706: # F1 04 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 24 38 00 00 00 7F 04 FF FF # 4f1 | 12/13/2016 12:33:45 | CIMC | Platform alert LED_FAN_STATUS #0x38 | LED color is green | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x14 : Status = 0x80
5:2016 Dec 13 12:33:47 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x1 : Status = 0x80
5:2016 Dec 13 12:33:47 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x4 : Status = 0x80
5:2016 Dec 13 12:33:47 GMT:BMC:kernel:-:<5>[__do_power_off]:325:__do_power_off
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # F2 04 00 00 01 02 00 00 AA EA 4F 58 20 00 04 25 09 00 00 00 08 01 FF FF # 4f2 | 12/13/2016 12:33:46 | CIMC | Entity presence FAN1_PRSNT #0x09 | Device Present | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # F3 04 00 00 01 02 00 00 AA EA 4F 58 20 00 04 25 0B 00 00 00 08 01 FF FF # 4f3 | 12/13/2016 12:33:46 | CIMC | Entity presence FAN3_PRSNT #0x0b | Device Present | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # F4 04 00 00 01 02 00 00 AA EA 4F 58 20 00 04 25 0D 00 00 00 08 01 FF FF # 4f4 | 12/13/2016 12:33:46 | CIMC | Entity presence FAN5_PRSNT #0x0d | Device Present | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # F5 04 00 00 01 02 00 00 AA EA 4F 58 20 00 04 25 1F 00 00 00 08 01 FF FF # 4f5 | 12/13/2016 12:33:46 | CIMC | Entity presence RISER1_PRESENT #0x1f | Device Present | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # F6 04 00 00 01 02 00 00 AA EA 4F 58 20 00 04 25 23 00 00 00 08 01 FF FF # 4f6 | 12/13/2016 12:33:46 | CIMC | Entity presence RISER2_PRESENT_1 #0x23 | Device Present | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # F7 04 00 00 01 02 00 00 AA EA 4F 58 20 00 04 24 37 00 00 00 7F 01 FF FF # 4f7 | 12/13/2016 12:33:46 | CIMC | Platform alert LED_TEMP_STATUS #0x37 | LED is on | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # F8 04 00 00 01 02 00 00 AA EA 4F 58 20 00 04 24 37 00 00 00 7F 04 FF FF # 4f8 | 12/13/2016 12:33:46 | CIMC | Platform alert LED_TEMP_STATUS #0x37 | LED color is green | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # F9 04 00 00 01 02 00 00 AA EA 4F 58 20 00 04 24 39 00 00 00 7F 01 FF FF # 4f9 | 12/13/2016 12:33:46 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED is on | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # FA 04 00 00 01 02 00 00 AA EA 4F 58 20 00 04 24 39 00 00 00 7F 04 FF FF # 4fa | 12/13/2016 12:33:46 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED color is green | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # FB 04 00 00 01 02 00 00 AB EA 4F 58 20 00 04 25 A1 00 00 00 08 01 FF FF # 4fb | 12/13/2016 12:33:47 | CIMC | Entity presence P2_PRESENT #0xa1 | Device Present | Asserted
5:2016 Dec 13 12:33:48 GMT:BMC:selparser:1662: selparser.c:706: # FC 04 00 00 01 02 00 00 AC EA 4F 58 20 00 04 25 A0 00 00 00 08 01 FF FF # 4fc | 12/13/2016 12:33:48 | CIMC | Entity presence P1_PRESENT #0xa0 | Device Present | Asserted
5:2016 Dec 13 12:33:50 GMT:BMC:doctor-bmc:1851: app_monitor.c:234:Process, alertmgr, successfully started.
5:2016 Dec 13 12:33:56 GMT:BMC:selparser:1662: selparser.c:706: # FD 04 00 00 01 02 00 00 B4 EA 4F 58 20 00 04 08 25 00 00 00 6F 30 FF 00 # 4fd | 12/13/2016 12:33:56 | CIMC | Power supply PSU1_STATUS #0x25 | Presence detected |  | Asserted
5:2016 Dec 13 12:33:56 GMT:BMC:selparser:1662: selparser.c:706: # FE 04 00 00 01 02 00 00 B4 EA 4F 58 20 00 04 08 26 00 00 00 6F 30 FF 00 # 4fe | 12/13/2016 12:33:56 | CIMC | Power supply PSU2_STATUS #0x26 | Presence detected |  | Asserted
5:2016 Dec 13 12:33:57 GMT:BMC:selparser:1662: selparser.c:706: # FF 04 00 00 01 02 00 00 B5 EA 4F 58 20 00 04 08 3A 00 00 00 0B 00 FF FF # 4ff | 12/13/2016 12:33:57 | CIMC | Power supply PS_RDNDNT_MODE #0x3a | Fully Redundant | Asserted
5:2016 Dec 13 12:33:58 GMT:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2402:USB1 VDD power off
5:2016 Dec 13 12:34:00 GMT:BMC:selparser:1662: selparser.c:706: # 00 05 00 00 01 02 00 00 B8 EA 4F 58 20 00 04 08 2F 00 00 00 03 01 FF FF # 500 | 12/13/2016 12:34:00 | CIMC | Power supply PSU1_AC_OK #0x2f | State Asserted | Asserted
5:2016 Dec 13 12:34:00 GMT:BMC:selparser:1662: selparser.c:706: # 01 05 00 00 01 02 00 00 B8 EA 4F 58 20 00 04 08 31 00 00 00 03 01 FF FF # 501 | 12/13/2016 12:34:00 | CIMC | Power supply PSU2_AC_OK #0x31 | State Asserted | Asserted
5:2016 Dec 13 12:34:07 GMT:BMC:doctor-bmc:2032: app_monitor.c:234:Process, ciscoNET, successfully started.
5:2016 Dec 13 12:34:08 GMT:BMC:doctor-bmc-app-mon:2052: app_monitor.c:726:Started application monitor (2052)
5:2016 Dec 13 12:34:08 GMT:BMC:doctor-bmc-app-mon:2052: app_monitor.c:481:cmp_proc_node_ctime: stat(/proc/1609) failed, errno 2 (No such file or directory)
5:2016 Dec 13 12:34:08 GMT:BMC:doctor-bmc-app-mon:2052: app_monitor.c:636:cmp_proc_node_ctime sel_pigeon_cntrd stat(/proc/1609) returned errno 2 (No such file or directory)
4:2016 Dec 13 12:34:08 GMT:BMC:doctor-bmc-app-mon:2052: app_monitor.c:592:Restarting Process sel_pigeon_cntrd
5:2016 Dec 13 12:34:08 GMT:BMC:doctor-bmc:2060: app_monitor.c:234:Process, ucsm_state_manager, successfully started.
5:2016 Dec 13 12:34:09 GMT:BMC:sel_pigeon_cntr:2058: sel_pigeon_cntr.c:917:Opening connection to SEL_PIGEON_CNTR_FIFO
4:2016 Dec 13 12:34:13 GMT:BMC:kernel:-:<4>setting perfect hw filtering mode (c70554f8)
5:2016 Dec 13 12:34:20 GMT:BMC:hw-ether:2188: hw-ether.c:254:eth0's hardware address changed to f8:72:ea:a3:d6:ee
4:2016 Dec 13 12:34:20 GMT:BMC:kernel:-:<4>setting perfect hw filtering mode (c70554f8)
4:2016 Dec 13 12:34:24 GMT:BMC:kernel:-:last message repeated 6 times
4:2016 Dec 13 12:34:24 GMT:BMC:ciscoNET:2034: network_manager.c:2082:Error: Can not open file, /etc/resolv.conf, with mode, r: 0x2.
5:2016 Dec 13 12:34:24 GMT:BMC:ciscoNET:2034: cisco_cards_manager.c:204:There are no cisco configurable cards attached.
5:2016 Dec 13 12:34:25 GMT:BMC:GDSCommDmn:-: GDSCommSVC.c:209:GDSComm started taking input connections.
5:2016 Dec 13 12:34:25 GMT:BMC:IPMI:1591: Bridge.c:1468:audit from:kcs Fn:0x6 Cmd:0x56 Data: 0x1 0x0 0x1
5:2016 Dec 13 12:34:25 GMT:BMC:IPMI:1591: Bridge.c:1474:audit Resp:0x0
5:2016 Dec 13 12:34:44 GMT:BMC:doctor-bmc:2400: app_monitor.c:234:Process, ntpd, successfully started.
3:2016 Dec 13 12:34:48 GMT:BMC:update-ir:2344: ../../src/update-ir.c:234:Host should be powered-on for IR configuration update
5:2016 Dec 13 12:35:00 GMT:BMC:root:-: DDNS: CIMC IP acquired: 192.168.1.207
5:2016 Dec 13 12:35:00 GMT:BMC:root:-: DDNS: GATEWAY IP acquired: 192.168.1.254
4:2016 Dec 13 12:35:11 GMT:BMC:kernel:-:<4>process `doctor-bmc' is using deprecated sysctl (syscall) net.ipv6.neigh.default.retrans_time; Use net.ipv6.neigh.default.retrans_time_ms instead.
3:2017 May 29 13:27:19 BST:BMC:crond:1296: time disparity of 240472 minutes detected
5:2017 May 29 13:28:33 BST:BMC:selparser:1662: selparser.c:706: # 02 05 00 00 01 02 00 00 F1 13 2C 59 20 00 04 08 2F 00 00 00 03 00 FF FF # 502 | 05/29/2017 13:28:33 | CIMC | Power supply PSU1_AC_OK #0x2f | State Deasserted | Asserted
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ16
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ17
5:2016 Dec 13 12:33:43 GMT:BMC:doctor-bmc:1745: app_monitor.c:234:Process, fault-engined, successfully started.
5:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<5>0x000004000000-0x000004800000 : "P2_NV_0"
5:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<5>0x000004800000-0x000004940000 : "P2_OBFL"
5:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<5>0x000004940000-0x000004c80000 : "NV_3"
5:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<5>0x000004c80000-0x000004fc0000 : "NV_4"
4:2016 Dec 13 12:33:48 GMT:BMC:kernel:-:last message repeated 4 times
5:2016 Dec 13 12:33:46 GMT:BMC:selparser:1662: selparser.c:706: # 03 05 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 24 08 00 00 00 04 00 FF FF # 503 | 12/13/2016 12:33:45 | CIMC | Platform alert POWER_ON_FAIL #0x08 | Predictive Failure deasserted | Asserted
5:2016 Dec 13 12:33:46 GMT:BMC:selparser:1662: selparser.c:706: # 04 05 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 25 0A 00 00 00 08 01 FF FF # 504 | 12/13/2016 12:33:45 | CIMC | Entity presence FAN2_PRSNT #0x0a | Device Present | Asserted
5:2016 Dec 13 12:33:46 GMT:BMC:selparser:1662: selparser.c:706: # 05 05 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 25 0C 00 00 00 08 01 FF FF # 505 | 12/13/2016 12:33:45 | CIMC | Entity presence FAN4_PRSNT #0x0c | Device Present | Asserted
5:2016 Dec 13 12:33:46 GMT:BMC:selparser:1662: selparser.c:706: # 06 05 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 25 1E 00 00 00 08 01 FF FF # 506 | 12/13/2016 12:33:45 | CIMC | Entity presence RISER2_PRESENT #0x1e | Device Present | Asserted
5:2016 Dec 13 12:33:46 GMT:BMC:selparser:1662: selparser.c:706: # 07 05 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 25 24 00 00 00 08 01 FF FF # 507 | 12/13/2016 12:33:45 | CIMC | Entity presence RISER1_PRESENT_1 #0x24 | Device Present | Asserted
5:2016 Dec 13 12:33:46 GMT:BMC:selparser:1662: selparser.c:706: # 08 05 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 24 36 00 00 00 7F 01 FF FF # 508 | 12/13/2016 12:33:45 | CIMC | Platform alert LED_PSU_STATUS #0x36 | LED is on | Asserted
5:2016 Dec 13 12:33:46 GMT:BMC:selparser:1662: selparser.c:706: # 09 05 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 24 36 00 00 00 7F 04 FF FF # 509 | 12/13/2016 12:33:45 | CIMC | Platform alert LED_PSU_STATUS #0x36 | LED color is green | Asserted
5:2016 Dec 13 12:33:46 GMT:BMC:selparser:1662: selparser.c:706: # 0A 05 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 24 38 00 00 00 7F 01 FF FF # 50a | 12/13/2016 12:33:45 | CIMC | Platform alert LED_FAN_STATUS #0x38 | LED is on | Asserted
5:2016 Dec 13 12:33:46 GMT:BMC:selparser:1662: selparser.c:706: # 0B 05 00 00 01 02 00 00 A9 EA 4F 58 20 00 04 24 38 00 00 00 7F 04 FF FF # 50b | 12/13/2016 12:33:45 | CIMC | Platform alert LED_FAN_STATUS #0x38 | LED color is green | Asserted
5:2016 Dec 13 12:33:46 GMT:BMC:lv_dimm:1739: lv_dimm.c:403:[handle_event_enable_tick]enable sensor event
5:2016 Dec 13 12:33:46 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x83.
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # 0C 05 00 00 01 02 00 00 AA EA 4F 58 20 00 04 25 09 00 00 00 08 01 FF FF # 50c | 12/13/2016 12:33:46 | CIMC | Entity presence FAN1_PRSNT #0x09 | Device Present | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # 0D 05 00 00 01 02 00 00 AA EA 4F 58 20 00 04 25 0B 00 00 00 08 01 FF FF # 50d | 12/13/2016 12:33:46 | CIMC | Entity presence FAN3_PRSNT #0x0b | Device Present | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # 0E 05 00 00 01 02 00 00 AA EA 4F 58 20 00 04 25 0D 00 00 00 08 01 FF FF # 50e | 12/13/2016 12:33:46 | CIMC | Entity presence FAN5_PRSNT #0x0d | Device Present | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # 0F 05 00 00 01 02 00 00 AA EA 4F 58 20 00 04 25 1F 00 00 00 08 01 FF FF # 50f | 12/13/2016 12:33:46 | CIMC | Entity presence RISER1_PRESENT #0x1f | Device Present | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # 10 05 00 00 01 02 00 00 AA EA 4F 58 20 00 04 25 23 00 00 00 08 01 FF FF # 510 | 12/13/2016 12:33:46 | CIMC | Entity presence RISER2_PRESENT_1 #0x23 | Device Present | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # 11 05 00 00 01 02 00 00 AA EA 4F 58 20 00 04 24 37 00 00 00 7F 01 FF FF # 511 | 12/13/2016 12:33:46 | CIMC | Platform alert LED_TEMP_STATUS #0x37 | LED is on | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # 12 05 00 00 01 02 00 00 AA EA 4F 58 20 00 04 24 37 00 00 00 7F 04 FF FF # 512 | 12/13/2016 12:33:46 | CIMC | Platform alert LED_TEMP_STATUS #0x37 | LED color is green | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # 13 05 00 00 01 02 00 00 AA EA 4F 58 20 00 04 24 39 00 00 00 7F 01 FF FF # 513 | 12/13/2016 12:33:46 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED is on | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # 14 05 00 00 01 02 00 00 AB EA 4F 58 20 00 04 24 39 00 00 00 7F 04 FF FF # 514 | 12/13/2016 12:33:47 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED color is green | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1662: selparser.c:706: # 15 05 00 00 01 02 00 00 AB EA 4F 58 20 00 04 25 A1 00 00 00 08 01 FF FF # 515 | 12/13/2016 12:33:47 | CIMC | Entity presence P2_PRESENT #0xa1 | Device Present | Asserted
5:2016 Dec 13 12:33:48 GMT:BMC:selparser:1662: selparser.c:706: # 16 05 00 00 01 02 00 00 AC EA 4F 58 20 00 04 25 A0 00 00 00 08 01 FF FF # 516 | 12/13/2016 12:33:48 | CIMC | Entity presence P1_PRESENT #0xa0 | Device Present | Asserted
5:2016 Dec 13 12:33:49 GMT:BMC:doctor-bmc:1827: app_monitor.c:234:Process, monkey, successfully started.
5:2016 Dec 13 12:33:49 GMT:BMC:bios-update:1842: main.c:236:Running as Daemon
5:2016 Dec 13 12:33:50 GMT:BMC:doctor-bmc:1858: app_monitor.c:234:Process, alertmgr, successfully started.
5:2016 Dec 13 12:33:52 GMT:BMC:bios-update:1842: activate.c:142:Setting BIOS Version
5:2016 Dec 13 12:33:56 GMT:BMC:selparser:1662: selparser.c:706: # 17 05 00 00 01 02 00 00 B4 EA 4F 58 20 00 04 08 25 00 00 00 6F 30 FF 00 # 517 | 12/13/2016 12:33:56 | CIMC | Power supply PSU1_STATUS #0x25 | Presence detected |  | Asserted
5:2016 Dec 13 12:33:56 GMT:BMC:selparser:1662: selparser.c:706: # 18 05 00 00 01 02 00 00 B4 EA 4F 58 20 00 04 08 25 00 00 00 6F 33 FF 00 # 518 | 12/13/2016 12:33:56 | CIMC | Power supply PSU1_STATUS #0x25 | Power supply input lost (AC/DC) |  | Asserted
5:2016 Dec 13 12:33:56 GMT:BMC:selparser:1662: selparser.c:706: # 19 05 00 00 01 02 00 00 B4 EA 4F 58 20 00 04 08 26 00 00 00 6F 30 FF 00 # 519 | 12/13/2016 12:33:56 | CIMC | Power supply PSU2_STATUS #0x26 | Presence detected |  | Asserted
5:2016 Dec 13 12:33:56 GMT:BMC:selparser:1662: selparser.c:706: # 1A 05 00 00 01 02 00 00 B4 EA 4F 58 20 00 04 24 36 00 00 00 7F 05 FF FF # 51a | 12/13/2016 12:33:56 | CIMC | Platform alert LED_PSU_STATUS #0x36 | LED color is amber | Asserted
5:2016 Dec 13 12:33:56 GMT:BMC:selparser:1662: selparser.c:706: # 1B 05 00 00 01 02 00 00 B4 EA 4F 58 20 00 04 24 36 00 00 00 FF 04 FF FF # 51b | 12/13/2016 12:33:56 | CIMC | Platform alert LED_PSU_STATUS #0x36 | LED color is green | Deasserted
5:2016 Dec 13 12:33:56 GMT:BMC:selparser:1662: selparser.c:706: # 1C 05 00 00 01 02 00 00 B4 EA 4F 58 20 00 04 24 39 00 00 00 7F 05 FF FF # 51c | 12/13/2016 12:33:56 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED color is amber | Asserted
5:2016 Dec 13 12:33:56 GMT:BMC:selparser:1662: selparser.c:706: # 1D 05 00 00 01 02 00 00 B4 EA 4F 58 20 00 04 24 39 00 00 00 FF 04 FF FF # 51d | 12/13/2016 12:33:56 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED color is green | Deasserted
5:2016 Dec 13 12:33:57 GMT:BMC:selparser:1662: selparser.c:706: # 1E 05 00 00 01 02 00 00 B5 EA 4F 58 20 00 04 08 3A 00 00 00 0B 03 FF FF # 51e | 12/13/2016 12:33:57 | CIMC | Power supply PS_RDNDNT_MODE #0x3a | Non-redundant | Asserted
5:2016 Dec 13 12:34:00 GMT:BMC:selparser:1662: selparser.c:706: # 1F 05 00 00 01 02 00 00 B8 EA 4F 58 20 00 04 08 2F 00 00 00 03 00 FF FF # 51f | 12/13/2016 12:34:00 | CIMC | Power supply PSU1_AC_OK #0x2f | State Deasserted | Asserted
5:2016 Dec 13 12:34:00 GMT:BMC:selparser:1662: selparser.c:706: # 20 05 00 00 01 02 00 00 B8 EA 4F 58 20 00 04 08 31 00 00 00 03 01 FF FF # 520 | 12/13/2016 12:34:00 | CIMC | Power supply PSU2_AC_OK #0x31 | State Asserted | Asserted
5:2016 Dec 13 12:34:06 GMT:BMC:doctor-bmc:1985: app_monitor.c:234:Process, kvm, successfully started.
5:2016 Dec 13 12:34:06 GMT:BMC:doctor-bmc:1992: app_monitor.c:234:Process, vkvm_pm, successfully started.
5:2016 Dec 13 12:34:07 GMT:BMC:doctor-bmc:2016: app_monitor.c:234:Process, sshd, successfully started.
5:2016 Dec 13 12:34:07 GMT:BMC:doctor-bmc:2028: app_monitor.c:234:Process, cisco_pm, successfully started.
5:2016 Dec 13 12:34:08 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [ciscoNET]
5:2016 Dec 13 12:34:08 GMT:BMC:doctor-bmc:2040: app_monitor.c:234:Process, ciscoNET, successfully started.
5:2016 Dec 13 12:34:08 GMT:BMC:ciscoNET:2042: ciscoNET.c:122:Application Starting
5:2016 Dec 13 12:34:08 GMT:BMC:doctor-bmc-app-mon:2061: app_monitor.c:726:Started application monitor (2061)
5:2016 Dec 13 12:34:08 GMT:BMC:doctor-bmc-app-mon:2061: app_monitor.c:481:cmp_proc_node_ctime: stat(/proc/1609) failed, errno 2 (No such file or directory)
5:2016 Dec 13 12:34:08 GMT:BMC:doctor-bmc-app-mon:2061: app_monitor.c:636:cmp_proc_node_ctime sel_pigeon_cntrd stat(/proc/1609) returned errno 2 (No such file or directory)
4:2016 Dec 13 12:34:08 GMT:BMC:doctor-bmc-app-mon:2061: app_monitor.c:592:Restarting Process sel_pigeon_cntrd
5:2016 Dec 13 12:34:09 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [ucsm_state_manager]
5:2016 Dec 13 12:34:09 GMT:BMC:doctor-bmc:2071: app_monitor.c:234:Process, ucsm_state_manager, successfully started.
5:2016 Dec 13 12:34:09 GMT:BMC:ciscoNET:2042: network_manager.c:549:Configuring the network.
5:2016 Dec 13 12:34:09 GMT:BMC:sel_pigeon_cntr:2069: sel_pigeon_cntr.c:917:Opening connection to SEL_PIGEON_CNTR_FIFO
5:2016 Dec 13 12:34:10 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [GDSCommDmn]
5:2016 Dec 13 12:34:10 GMT:BMC:doctor-bmc:2091: app_monitor.c:234:Process, GDSCommDmn, successfully started.
5:2016 Dec 13 12:34:10 GMT:BMC:doctor-bmc:2096: app_monitor.c:234:Process, rack_monitor, successfully started.
5:2016 Dec 13 12:34:11 GMT:BMC:rack_monitor:-: rack_monitor.c:397:RACK Montior in Stand-alone mode
5:2016 Dec 13 12:34:11 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [sam_master]
5:2016 Dec 13 12:34:11 GMT:BMC:doctor-bmc:2101: app_monitor.c:234:Process, sam_master, successfully started.
5:2016 Dec 13 12:34:11 GMT:BMC:doctor-bmc:2107: app_monitor.c:234:Process, ciscovmd, successfully started.
5:2016 Dec 13 12:34:12 GMT:BMC:ciscoNET:2042: network_manager.c:793:Error: killall udhcpc returned exit code: 256
5:2016 Dec 13 12:34:12 GMT:BMC:doctor-bmc:2114: app_monitor.c:234:Process, video_triggerd, successfully started.
5:2016 Dec 13 12:34:12 GMT:BMC:ciscoNET:2042: network_manager.c:795:Error: killall udhcpc6 returned exit code: 256
5:2016 Dec 13 12:34:20 GMT:BMC:hw-ether:2196: hw-ether.c:254:eth0's hardware address changed to f8:72:ea:a3:d6:ee
4:2016 Dec 13 12:34:24 GMT:BMC:ciscoNET:2042: network_manager.c:2082:Error: Can not open file, /etc/resolv.conf, with mode, r: 0x2.
5:2016 Dec 13 12:34:24 GMT:BMC:ciscoNET:2042: cisco_cards_manager.c:204:There are no cisco configurable cards attached.
5:2016 Dec 13 12:34:34 GMT:BMC:dataserver:1794: eventsubscribemgnt.c:91:IsShmRestoreRequired: Restoration required!
5:2016 Dec 13 12:34:34 GMT:BMC:dataserver:1794: eventsubscribemgnt.c:1193:RestoreEvtSubscCfg: Restored event subscription configuration successfully!
5:2016 Dec 13 12:34:36 GMT:BMC:doctor-bmc:-: doctor-bmc.c:308:doctor-bmc-app stop [snmp-subagentd]
5:2016 Dec 13 12:34:37 GMT:BMC:root:-: CIMC booted after a chassis power on!!
5:2016 Dec 13 12:34:37 GMT:BMC:root:-: Waiting for MB FRU data to get populated..
5:2016 Dec 13 12:34:37 GMT:BMC:root:-: MB FRU data populated successfully
5:2016 Dec 13 12:34:42 GMT:BMC:root:-: NTP: CIMC IP acquired: 192.168.1.207
5:2016 Dec 13 12:34:43 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [ntpd]
5:2016 Dec 13 12:34:43 GMT:BMC:doctor-bmc:2408: app_monitor.c:234:Process, ntpd, successfully started.
3:2016 Dec 13 12:34:46 GMT:BMC:update-ir:2351: ../../src/update-ir.c:234:Host should be powered-on for IR configuration update
5:2016 Dec 13 12:35:41 GMT:BMC:AUDIT:2506: Login success (user:admin, ip:192.168.1.129, service:sshd)
5:2016 Dec 13 12:35:41 GMT:BMC:AUDIT:2033: Session open (user:admin, ip:192.168.1.129, id:1, type:CLI)
5:2016 Dec 13 12:35:41 GMT:BMC:AUDIT:2506: Session open (user:admin, ip:192.168.1.129, id:1, type:CLI)
3:2017 May 29 13:52:12 BST:BMC:crond:1296: time disparity of 240497 minutes detected
5:2017 May 29 13:56:31 BST:BMC:dataserver:1794: bootordermgnt.cpp:1916:RestoreDevieCfg: Restored boot order configuration successfully!
5:2017 May 29 13:56:31 BST:BMC:dataserver:1794: bootordermgnt.cpp:1515:RestoreOneBootDevieCfg 1515> -1 -1
5:2017 May 29 14:08:54 BST:BMC:selparser:1662: selparser.c:706: # 21 05 00 00 01 02 00 00 65 1D 2C 59 20 00 04 08 2F 00 00 00 03 01 FF FF # 521 | 05/29/2017 14:08:53 | CIMC | Power supply PSU1_AC_OK #0x2f | State Asserted | Asserted
5:2017 May 29 14:08:59 BST:BMC:selparser:1662: selparser.c:706: # 22 05 00 00 01 02 00 00 6A 1D 2C 59 20 00 04 08 3A 00 00 00 0B 00 FF FF # 522 | 05/29/2017 14:08:58 | CIMC | Power supply PS_RDNDNT_MODE #0x3a | Fully Redundant | Asserted
5:2017 May 29 14:09:01 BST:BMC:selparser:1662: selparser.c:706: # 23 05 00 00 01 02 00 00 6C 1D 2C 59 20 00 04 08 25 00 00 00 EF 33 FF 00 # 523 | 05/29/2017 14:09:00 | CIMC | Power supply PSU1_STATUS #0x25 | Power supply input lost (AC/DC) |  | Deasserted
5:2017 May 29 14:09:01 BST:BMC:selparser:1662: selparser.c:706: # 24 05 00 00 01 02 00 00 6C 1D 2C 59 20 00 04 24 36 00 00 00 7F 04 FF FF # 524 | 05/29/2017 14:09:00 | CIMC | Platform alert LED_PSU_STATUS #0x36 | LED color is green | Asserted
5:2017 May 29 14:09:01 BST:BMC:selparser:1662: selparser.c:706: # 25 05 00 00 01 02 00 00 6C 1D 2C 59 20 00 04 24 36 00 00 00 FF 05 FF FF # 525 | 05/29/2017 14:09:00 | CIMC | Platform alert LED_PSU_STATUS #0x36 | LED color is amber | Deasserted
5:2017 May 29 14:09:01 BST:BMC:selparser:1662: selparser.c:706: # 26 05 00 00 01 02 00 00 6C 1D 2C 59 20 00 04 24 39 00 00 00 7F 04 FF FF # 526 | 05/29/2017 14:09:00 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED color is green | Asserted
5:2017 May 29 14:09:01 BST:BMC:selparser:1662: selparser.c:706: # 27 05 00 00 01 02 00 00 6C 1D 2C 59 20 00 04 24 39 00 00 00 FF 05 FF FF # 527 | 05/29/2017 14:09:00 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED color is amber | Deasserted
5:2017 May 29 14:09:16 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 14:09:16 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 14:09:16 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 14:12:20 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 14:12:20 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 14:12:20 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 14:12:22 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 14:12:22 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 14:12:22 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 14:12:24 BST:BMC:kernel:-:<5>[passthrough_pin2_isr]:160:x86 Host Power Button Press
5:2017 May 29 14:12:24 BST:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2295:USB FS: VDD Power WAKEUP- Power Good = OFF
5:2017 May 29 14:12:24 BST:BMC:kernel:-:<5>[se_pilot2_wakeup_interrupt]:2563:USB HS: VDD Power = OFF
5:2017 May 29 14:13:48 BST:BMC:fcgi:-: pam_local_manager(webgui:account): requirement "privilege=0x01" was met by user "admin"
5:2017 May 29 14:13:48 BST:BMC:AUDIT:1809: Login success (user:admin, ip:192.168.1.129, service:webgui)
5:2017 May 29 14:13:48 BST:BMC:AUDIT:2033: Session open (user:admin, ip:192.168.1.129, id:2, type:webgui)
5:2017 May 29 14:13:48 BST:BMC:AUDIT:1809: Session open (user:admin, ip:192.168.1.129, id:2, type:webgui)
5:2017 May 29 14:14:10 BST:BMC:IPMI:1591: Bridge.c:1468:audit from:kcs Fn:0x0 Cmd:0x2 Data: 0x1
5:2017 May 29 14:14:10 BST:BMC:IPMI:1591: Bridge.c:1474:audit Resp:0x0
5:2017 May 29 14:14:10 BST:BMC:kernel:-:<5>[__do_power_on]:385:__do_power_on
5:2017 May 29 14:14:10 BST:BMC:kernel:-:<5>[__do_power_on]:401:Power Driver: Power On Logic Pulse for 250ms @ 1218592
5:2017 May 29 14:14:10 BST:BMC:AUDIT:1794: Server power state modify (op:power-on)
2:2017 May 29 14:14:30 BST:BMC:kernel:-:<2>[__do_power_on]:428:Power Driver: Power On Fail Asserted @ 1238924 RegInfo -> SWSTAT0[0x10] WKCFG0[0x11]
5:2017 May 29 14:14:30 BST:BMC:IPMI:1591: Pilot2SrvPower.c:189:Pilot2SrvPowerOn
4:2017 May 29 14:14:30 BST:BMC:IPMI:1591: Pilot2SrvPower.c:191:Pilot2SrvPowerOn: Failed to Power On [Timer expired]
5:2017 May 29 14:14:31 BST:BMC:IPMI:1591: Pilot2SrvPower.c:466:Blade Power Changed To: [ ON ]
5:2017 May 29 14:14:31 BST:BMC:video_trigger:-: video_trigger.c:280:Sending event_ipmi_power_state_change (ON) ..
5:2017 May 29 14:14:31 BST:BMC:IPMI:1591: Rack_FanCtrl.c:1272:fscUpdateActualFanPolicyFile: Applied Policy: N/A, Configuration Status: PENDING - BIOS POST not completed
0:2017 May 29 14:14:31 BST:BMC:POF_MONITOR_DAEMON:1381: pof_monitord.c:93:Host Failed Power On Please Check [ /var/log/power-on-fail.log ]
5:2017 May 29 14:14:31 BST:BMC:selparser:1662: selparser.c:706: # 28 05 00 00 01 02 00 00 B7 1E 2C 59 20 00 04 24 08 00 00 00 04 01 FF FF # 528 | 05/29/2017 14:14:31 | CIMC | Platform alert POWER_ON_FAIL #0x08 | Predictive Failure asserted | Asserted
5:2017 May 29 14:14:31 BST:BMC:selparser:1662: selparser.c:706: # 29 05 00 00 01 02 00 00 B7 1E 2C 59 20 00 04 24 39 00 00 00 7F 05 FF FF # 529 | 05/29/2017 14:14:31 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED color is amber | Asserted
5:2017 May 29 14:14:31 BST:BMC:selparser:1662: selparser.c:706: # 2A 05 00 00 01 02 00 00 B7 1E 2C 59 20 00 04 24 39 00 00 00 FF 04 FF FF # 52a | 05/29/2017 14:14:31 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED color is green | Deasserted
5:2017 May 29 14:14:33 BST:BMC:video_trigger:-: video_trigger.c:207:Sending event_server_crash for host NMI ..
5:2017 May 29 14:14:35 BST:BMC:selparser:1662: selparser.c:706: # 2B 05 00 00 01 02 00 00 BB 1E 2C 59 20 00 04 25 01 00 00 00 08 01 FF FF # 52b | 05/29/2017 14:14:35 | CIMC | Entity presence BIOS_POST_CMPLT #0x01 | Device Present | Asserted
5:2017 May 29 14:14:35 BST:BMC:selparser:1662: selparser.c:706: # 2C 05 00 00 01 02 00 00 BB 1E 2C 59 20 00 04 07 02 00 00 00 04 01 FF FF # 52c | 05/29/2017 14:14:35 | CIMC | Processor P_CATERR_N #0x02 | Predictive Failure asserted | Asserted
5:2017 May 29 14:14:35 BST:BMC:selparser:1662: selparser.c:706: # 2D 05 00 00 01 02 00 00 BB 1E 2C 59 20 00 04 07 27 00 00 00 05 01 FF FF # 52d | 05/29/2017 14:14:35 | CIMC | Processor P1_PROCHOT #0x27 | Limit Exceeded | Asserted
5:2017 May 29 14:14:35 BST:BMC:selparser:1662: selparser.c:706: # 2E 05 00 00 01 02 00 00 BB 1E 2C 59 20 00 04 07 28 00 00 00 05 01 FF FF # 52e | 05/29/2017 14:14:35 | CIMC | Processor P2_PROCHOT #0x28 | Limit Exceeded | Asserted
5:2017 May 29 14:14:35 BST:BMC:selparser:1662: selparser.c:706: # 2F 05 00 00 01 02 00 00 BB 1E 2C 59 20 00 04 07 29 00 00 00 05 01 FF FF # 52f | 05/29/2017 14:14:35 | CIMC | Processor PVCCD_P1_VRHOT #0x29 | Limit Exceeded | Asserted
5:2017 May 29 14:14:35 BST:BMC:selparser:1662: selparser.c:706: # 30 05 00 00 01 02 00 00 BB 1E 2C 59 20 00 04 07 2A 00 00 00 05 01 FF FF # 530 | 05/29/2017 14:14:35 | CIMC | Processor PVCCP_P1_VRHOT #0x2a | Limit Exceeded | Asserted
5:2017 May 29 14:14:35 BST:BMC:selparser:1662: selparser.c:706: # 31 05 00 00 01 02 00 00 BB 1E 2C 59 20 00 04 07 2B 00 00 00 05 01 FF FF # 531 | 05/29/2017 14:14:35 | CIMC | Processor PVCCD_P2_VRHOT #0x2b | Limit Exceeded | Asserted
5:2017 May 29 14:14:36 BST:BMC:selparser:1662: selparser.c:706: # 32 05 00 00 01 02 00 00 BB 1E 2C 59 20 00 04 07 2C 00 00 00 05 01 FF FF # 532 | 05/29/2017 14:14:35 | CIMC | Processor PVCCP_P2_VRHOT #0x2c | Limit Exceeded | Asserted
5:2017 May 29 14:14:36 BST:BMC:selparser:1662: selparser.c:706: # 33 05 00 00 01 02 00 00 BB 1E 2C 59 20 00 04 08 2E 00 00 00 03 00 FF FF # 533 | 05/29/2017 14:14:35 | CIMC | Power supply PSU1_PWRGD #0x2e | State Deasserted | Asserted
5:2017 May 29 14:14:36 BST:BMC:selparser:1662: selparser.c:706: # 34 05 00 00 01 02 00 00 BC 1E 2C 59 20 00 04 08 30 00 00 00 03 00 FF FF # 534 | 05/29/2017 14:14:36 | CIMC | Power supply PSU2_PWRGD #0x30 | State Deasserted | Asserted
4:2017 May 29 14:14:36 BST:BMC:IPMI:1591: Pilot3Peci.c:87:Pilot_PECI: Transaction aborted! --> [0xFFFFFFFF], ResultCode = 0, LPC Reset State = 1
5:2017 May 29 14:14:36 BST:BMC:IPMI:1591: Pilot3Peci.c:1034:Pilot_PECI: PECI Temp Transaction To CPU-0 Failed!  RC: 0
4:2017 May 29 14:14:36 BST:BMC:IPMI:1591: Pilot3Peci.c:87:Pilot_PECI: Transaction aborted! --> [0xFFFFFFFF], ResultCode = 77, LPC Reset State = 1
5:2017 May 29 14:14:36 BST:BMC:IPMI:1591: Pilot3Peci.c:1034:Pilot_PECI: PECI Temp Transaction To CPU-1 Failed!  RC: 4d
5:2017 May 29 14:14:38 BST:BMC:selparser:1662: selparser.c:706: # 35 05 00 00 01 02 00 00 BC 1E 2C 59 20 00 04 07 32 00 00 00 05 01 FF FF # 535 | 05/29/2017 14:14:36 | CIMC | Processor P1_MEM23_MEMHOT #0x32 | Limit Exceeded | Asserted
5:2017 May 29 14:14:38 BST:BMC:selparser:1662: selparser.c:706: # 36 05 00 00 01 02 00 00 BC 1E 2C 59 20 00 04 07 33 00 00 00 05 01 FF FF # 536 | 05/29/2017 14:14:36 | CIMC | Processor P1_MEM01_MEMHOT #0x33 | Limit Exceeded | Asserted
5:2017 May 29 14:14:38 BST:BMC:selparser:1662: selparser.c:706: # 37 05 00 00 01 02 00 00 BC 1E 2C 59 20 00 04 07 34 00 00 00 05 01 FF FF # 537 | 05/29/2017 14:14:36 | CIMC | Processor P2_MEM23_MEMHOT #0x34 | Limit Exceeded | Asserted
5:2017 May 29 14:14:38 BST:BMC:selparser:1662: selparser.c:706: # 38 05 00 00 01 02 00 00 BC 1E 2C 59 20 00 04 07 35 00 00 00 05 01 FF FF # 538 | 05/29/2017 14:14:36 | CIMC | Processor P2_MEM01_MEMHOT #0x35 | Limit Exceeded | Asserted
5:2017 May 29 14:14:38 BST:BMC:selparser:1662: selparser.c:706: # 39 05 00 00 01 02 00 00 BC 1E 2C 59 20 00 04 0D 42 00 00 00 6F 00 FF FF # 539 | 05/29/2017 14:14:36 | CIMC | Drive slot(Bay) HDD1_STATUS #0x42 | Drive Presence | Asserted
5:2017 May 29 14:14:38 BST:BMC:selparser:1662: selparser.c:706: # 3A 05 00 00 01 02 00 00 BC 1E 2C 59 20 00 04 0D 43 00 00 00 6F 00 FF FF # 53a | 05/29/2017 14:14:36 | CIMC | Drive slot(Bay) HDD2_STATUS #0x43 | Drive Presence | Asserted
5:2017 May 29 14:14:38 BST:BMC:selparser:1662: selparser.c:706: # 3B 05 00 00 01 02 00 00 BC 1E 2C 59 20 00 04 0D 44 00 00 00 6F 00 FF FF # 53b | 05/29/2017 14:14:36 | CIMC | Drive slot(Bay) HDD3_STATUS #0x44 | Drive Presence | Asserted
5:2017 May 29 14:14:38 BST:BMC:selparser:1662: selparser.c:706: # 3C 05 00 00 01 02 00 00 BC 1E 2C 59 20 00 04 0D 45 00 00 00 6F 00 FF FF # 53c | 05/29/2017 14:14:36 | CIMC | Drive slot(Bay) HDD4_STATUS #0x45 | Drive Presence | Asserted
5:2017 May 29 14:14:38 BST:BMC:selparser:1662: selparser.c:706: # 3D 05 00 00 01 02 00 00 BC 1E 2C 59 20 00 04 0D 46 00 00 00 6F 00 FF FF # 53d | 05/29/2017 14:14:36 | CIMC | Drive slot(Bay) HDD5_STATUS #0x46 | Drive Presence | Asserted
5:2017 May 29 14:14:38 BST:BMC:selparser:1662: selparser.c:706: # 3E 05 00 00 01 02 00 00 BC 1E 2C 59 20 00 04 0D 47 00 00 00 6F 00 FF FF # 53e | 05/29/2017 14:14:36 | CIMC | Drive slot(Bay) HDD6_STATUS #0x47 | Drive Presence | Asserted
5:2017 May 29 14:14:38 BST:BMC:selparser:1662: selparser.c:706: # 3F 05 00 00 01 02 00 00 BE 1E 2C 59 20 00 04 0D 48 00 00 00 6F 00 FF FF # 53f | 05/29/2017 14:14:38 | CIMC | Drive slot(Bay) HDD7_STATUS #0x48 | Drive Presence | Asserted
5:2017 May 29 14:14:38 BST:BMC:selparser:1662: selparser.c:706: # 40 05 00 00 01 02 00 00 BE 1E 2C 59 20 00 04 0D 49 00 00 00 6F 00 FF FF # 540 | 05/29/2017 14:14:38 | CIMC | Drive slot(Bay) HDD8_STATUS #0x49 | Drive Presence | Asserted
5:2017 May 29 14:14:38 BST:BMC:update-ir:2351: ../../src/update-ir.c:99:lock state = 0
3:2017 May 29 14:14:38 BST:BMC:update-ir:2351: ../../src/update-ir.c:111:Cannot modify/get front panel locks: 0xd  0xffffffff
5:2017 May 29 14:14:39 BST:BMC:selparser:1662: selparser.c:706: # 41 05 00 00 01 02 00 00 BE 1E 2C 59 20 00 04 24 4C 00 00 00 7F 01 FF FF # 541 | 05/29/2017 14:14:38 | CIMC | Platform alert P1_DIMM_A1_LED #0x4c | LED is on | Asserted
5:2017 May 29 14:14:39 BST:BMC:selparser:1662: selparser.c:706: # 42 05 00 00 01 02 00 00 BE 1E 2C 59 20 00 04 24 4C 00 00 00 7F 05 FF FF # 542 | 05/29/2017 14:14:38 | CIMC | Platform alert P1_DIMM_A1_LED #0x4c | LED color is amber | Asserted
5:2017 May 29 14:14:39 BST:BMC:selparser:1662: selparser.c:706: # 43 05 00 00 01 02 00 00 BE 1E 2C 59 20 00 04 24 52 00 00 00 7F 01 FF FF # 543 | 05/29/2017 14:14:38 | CIMC | Platform alert P1_DIMM_B1_LED #0x52 | LED is on | Asserted
5:2017 May 29 14:14:39 BST:BMC:selparser:1662: selparser.c:706: # 44 05 00 00 01 02 00 00 BE 1E 2C 59 20 00 04 24 52 00 00 00 7F 05 FF FF # 544 | 05/29/2017 14:14:38 | CIMC | Platform alert P1_DIMM_B1_LED #0x52 | LED color is amber | Asserted
5:2017 May 29 14:14:39 BST:BMC:selparser:1662: selparser.c:706: # 45 05 00 00 01 02 00 00 BE 1E 2C 59 20 00 04 24 58 00 00 00 7F 01 FF FF # 545 | 05/29/2017 14:14:38 | CIMC | Platform alert P1_DIMM_C1_LED #0x58 | LED is on | Asserted
5:2017 May 29 14:14:39 BST:BMC:selparser:1662: selparser.c:706: # 46 05 00 00 01 02 00 00 BE 1E 2C 59 20 00 04 24 58 00 00 00 7F 05 FF FF # 546 | 05/29/2017 14:14:38 | CIMC | Platform alert P1_DIMM_C1_LED #0x58 | LED color is amber | Asserted
5:2017 May 29 14:14:39 BST:BMC:selparser:1662: selparser.c:706: # 47 05 00 00 01 02 00 00 BE 1E 2C 59 20 00 04 24 5E 00 00 00 7F 01 FF FF # 547 | 05/29/2017 14:14:38 | CIMC | Platform alert P1_DIMM_D1_LED #0x5e | LED is on | Asserted
5:2017 May 29 14:14:39 BST:BMC:selparser:1662: selparser.c:706: # 48 05 00 00 01 02 00 00 BE 1E 2C 59 20 00 04 24 5E 00 00 00 7F 05 FF FF # 548 | 05/29/2017 14:14:38 | CIMC | Platform alert P1_DIMM_D1_LED #0x5e | LED color is amber | Asserted
5:2017 May 29 14:14:39 BST:BMC:selparser:1662: selparser.c:706: # 49 05 00 00 01 02 00 00 BE 1E 2C 59 20 00 04 24 64 00 00 00 7F 01 FF FF # 549 | 05/29/2017 14:14:38 | CIMC | Platform alert P2_DIMM_E1_LED #0x64 | LED is on | Asserted
5:2017 May 29 14:14:39 BST:BMC:selparser:1662: selparser.c:706: # 4A 05 00 00 01 02 00 00 BE 1E 2C 59 20 00 04 24 64 00 00 00 7F 05 FF FF # 54a | 05/29/2017 14:14:38 | CIMC | Platform alert P2_DIMM_E1_LED #0x64 | LED color is amber | Asserted
5:2017 May 29 14:14:39 BST:BMC:selparser:1662: selparser.c:706: # 4B 05 00 00 01 02 00 00 BE 1E 2C 59 20 00 04 24 6A 00 00 00 7F 01 FF FF # 54b | 05/29/2017 14:14:38 | CIMC | Platform alert P2_DIMM_F1_LED #0x6a | LED is on | Asserted
5:2017 May 29 14:14:39 BST:BMC:selparser:1662: selparser.c:706: # 4C 05 00 00 01 02 00 00 BE 1E 2C 59 20 00 04 24 6A 00 00 00 7F 05 FF FF # 54c | 05/29/2017 14:14:38 | CIMC | Platform alert P2_DIMM_F1_LED #0x6a | LED color is amber | Asserted
5:2017 May 29 14:14:39 BST:BMC:selparser:1662: selparser.c:706: # 4D 05 00 00 01 02 00 00 BE 1E 2C 59 20 00 04 24 70 00 00 00 7F 01 FF FF # 54d | 05/29/2017 14:14:38 | CIMC | Platform alert P2_DIMM_G1_LED #0x70 | LED is on | Asserted
5:2017 May 29 14:14:39 BST:BMC:selparser:1662: selparser.c:706: # 4E 05 00 00 01 02 00 00 BE 1E 2C 59 20 00 04 24 70 00 00 00 7F 05 FF FF # 54e | 05/29/2017 14:14:38 | CIMC | Platform alert P2_DIMM_G1_LED #0x70 | LED color is amber | Asserted
5:2017 May 29 14:14:39 BST:BMC:selparser:1662: selparser.c:706: # 4F 05 00 00 01 02 00 00 BE 1E 2C 59 20 00 04 24 76 00 00 00 7F 01 FF FF # 54f | 05/29/2017 14:14:38 | CIMC | Platform alert P2_DIMM_H1_LED #0x76 | LED is on | Asserted
5:2017 May 29 14:14:39 BST:BMC:selparser:1662: selparser.c:706: # 50 05 00 00 01 02 00 00 BE 1E 2C 59 20 00 04 24 76 00 00 00 7F 05 FF FF # 550 | 05/29/2017 14:14:38 | CIMC | Platform alert P2_DIMM_H1_LED #0x76 | LED color is amber | Asserted
5:2017 May 29 14:14:39 BST:BMC:selparser:1662: selparser.c:706: # 51 05 00 00 01 02 00 00 BE 1E 2C 59 20 00 04 07 BD 00 00 00 05 01 FF FF # 551 | 05/29/2017 14:14:38 | CIMC | Processor P1_THERMTRIP_N #0xbd | Limit Exceeded | Asserted
5:2017 May 29 14:14:39 BST:BMC:selparser:1662: selparser.c:706: # 52 05 00 00 01 02 00 00 BE 1E 2C 59 20 00 04 07 BE 00 00 00 05 01 FF FF # 552 | 05/29/2017 14:14:38 | CIMC | Processor P2_THERMTRIP_N #0xbe | Limit Exceeded | Asserted
5:2017 May 29 14:14:40 BST:BMC:IPMI:1591: Rack_FanCtrl.c:1272:fscUpdateActualFanPolicyFile: Applied Policy: Balanced, Configuration Status: SUCCESS
2:2017 May 29 14:14:43 BST:BMC:IPMI:1591: PowerOnFail.c:55:PowerOnFail_Read:PowerOnFail on for 10 Scan Cycles Turning Power Off
2:2017 May 29 14:14:43 BST:BMC:kernel:-:<2>[host_power_ioctl]:957:POWER ON FAILURE has been detected
5:2017 May 29 14:14:43 BST:BMC:kernel:-:<5>[__do_power_off]:325:__do_power_off
5:2017 May 29 14:14:43 BST:BMC:IPMI:1591: Pilot2SrvPower.c:346:Pilot2SrvPowerOff
5:2017 May 29 14:14:43 BST:BMC:IPMI:1591: Pilot2SrvPower.c:466:Blade Power Changed To: [ OFF ]
5:2017 May 29 14:14:44 BST:BMC:video_trigger:-: video_trigger.c:280:Sending event_ipmi_power_state_change (OFF) ..
5:2017 May 29 14:14:44 BST:BMC:IPMI:1591: Rack_FanCtrl.c:1272:fscUpdateActualFanPolicyFile: Applied Policy: N/A, Configuration Status: PENDING - Host powered off
5:2017 May 29 14:14:45 BST:BMC:selparser:1662: selparser.c:706: # 53 05 00 00 01 02 00 00 C4 1E 2C 59 20 00 04 24 08 00 00 00 04 00 FF FF # 553 | 05/29/2017 14:14:44 | CIMC | Platform alert POWER_ON_FAIL #0x08 | Predictive Failure deasserted | Asserted
5:2017 May 29 14:14:45 BST:BMC:selparser:1662: selparser.c:706: # 54 05 00 00 01 02 00 00 C4 1E 2C 59 20 00 04 24 39 00 00 00 7F 04 FF FF # 554 | 05/29/2017 14:14:44 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED color is green | Asserted
5:2017 May 29 14:14:45 BST:BMC:selparser:1662: selparser.c:706: # 55 05 00 00 01 02 00 00 C4 1E 2C 59 20 00 04 24 39 00 00 00 FF 05 FF FF # 555 | 05/29/2017 14:14:44 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED color is amber | Deasserted
5:2017 May 29 14:14:47 BST:BMC:IPMI:1591: Bridge.c:1468:audit from:kcs Fn:0x0 Cmd:0x8 Data: 0x5 0x80 0x18 0x0 0x0 0x0
5:2017 May 29 14:14:47 BST:BMC:IPMI:1591: Bridge.c:1474:audit Resp:0x0
5:2017 May 29 14:14:59 BST:BMC:IPMI:1591: Bridge.c:1468:audit from:kcs Fn:0x0 Cmd:0x2 Data: 0x2
5:2017 May 29 14:14:59 BST:BMC:IPMI:1591: Bridge.c:1474:audit Resp:0xd5
5:2017 May 29 14:15:00 BST:BMC:IPMI:1591: Bridge.c:1468:audit from:kcs Fn:0x0 Cmd:0x2 Data: 0x2
5:2017 May 29 14:15:00 BST:BMC:IPMI:1591: Bridge.c:1474:audit Resp:0xd5
5:2017 May 29 14:15:01 BST:BMC:AUDIT:1794: Server power state modify (op:power-cycle)
5:2017 May 29 14:15:32 BST:BMC:IPMI:1591: Bridge.c:1468:audit from:kcs Fn:0x0 Cmd:0x2 Data: 0x2
5:2017 May 29 14:15:32 BST:BMC:IPMI:1591: Bridge.c:1474:audit Resp:0xd5
5:2017 May 29 14:15:33 BST:BMC:IPMI:1591: Bridge.c:1468:audit from:kcs Fn:0x0 Cmd:0x2 Data: 0x2
5:2017 May 29 14:15:33 BST:BMC:IPMI:1591: Bridge.c:1474:audit Resp:0xd5
5:2017 May 29 14:15:33 BST:BMC:AUDIT:1794: Server power state modify (op:power-cycle)
5:2017 May 29 14:15:50 BST:BMC:AUDIT:1794: CIMC reboot
5:2017 May 29 14:15:50 BST:BMC:REBOOT:8094: reboot.c:159:Called by init -> forkexecproxyd -> forkexecproxyd -> reboot
5:2017 May 29 14:15:50 BST:BMC:REBOOT:8094: reboot.c:145:Executing Extended Shutdown Script
5:2017 May 29 14:15:50 BST:BMC:WatchDogKick:1284: WatchDogKick.c:140:Reset is in progress.
5:2017 May 29 14:15:50 BST:BMC:doctor-bmc:-: doctor-bmc.c:308:doctor-bmc-app stop [ipmi]
5:2017 May 29 14:15:50 BST:BMC:doctor-bmc:8098: app_monitor.c:170:Application ipmi is stopped.
5:2017 May 29 14:15:50 BST:BMC:sel_pigeon_cntr:2069: sel_pigeon_cntr.c:1002:SEL_PIGEON_CNTR_FIFO unexpectedly closed.  Re-opening...
4:2017 May 29 14:15:50 BST:BMC:kernel:-:<4>Non-raid image running. Shutdown notification not issued
3:2017 May 29 14:15:50 BST:BMC:disconnect_pport:-: disconnect_pport.c:43:Failed to notify Astoria about CIMC shutdown(-1 1024)
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ11
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ12
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ13
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ14
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ15
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ18
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ19
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ20
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ21
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ22
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ23
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ24
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ25
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ26
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ27
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ28
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ29
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ30
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ31
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ32
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ33
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ34
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ35
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ36
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ37
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ38
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ39
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ40
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ41
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ42
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ43
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ44
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ45
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ46
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ47
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ48
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ49
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ50
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ51
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ52
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ53
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ54
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ55
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ56
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ57
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ58
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ59
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ60
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ61
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ62
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ63
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ64
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ65
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ66
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ67
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ68
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ69
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ70
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ71
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ72
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ73
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ74
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ75
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ76
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ77
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Trying to install interrupt handler for IRQ78
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Pilot3 Interrupt Controller Enabled and Configured.
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Pilot-II Timer Initialized
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Pilot-II Timer Started
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Console: colour dummy device 80x30
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>Mount-cache hash table entries: 512
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>bio: create slab <bio-0> at 0
5:2016 Dec 13 12:33:42 GMT:BMC:IPMI:1591: Rack_FanCtrl.c:1272:fscUpdateActualFanPolicyFile: Applied Policy: N/A, Configuration Status: PENDING - Host powered off
4:2016 Dec 13 12:33:42 GMT:BMC:kernel:-:<4>NetWinder Floating Point Emulator V0.97 (double precision)
5:2016 Dec 13 12:33:42 GMT:BMC:pmbus_pwrsply_mngr:1552: pmbus_pwrsply_mngr.c:1757:Power Supply 0x1 Presence Changed to present.
5:2016 Dec 13 12:33:42 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [sm]
5:2016 Dec 13 12:33:42 GMT:BMC:doctor-bmc:1720: app_monitor.c:234:Process, sm, successfully started.
5:2016 Dec 13 12:33:43 GMT:BMC:pmbus_pwrsply_mngr:1552: pmbus_pwrsply_mngr.c:1757:Power Supply 0x2 Presence Changed to present.
5:2016 Dec 13 12:33:43 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [bioscomd]
5:2016 Dec 13 12:33:43 GMT:BMC:doctor-bmc:1728: app_monitor.c:234:Process, bioscomd, successfully started.
5:2016 Dec 13 12:33:43 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [lv_dimmd]
5:2016 Dec 13 12:33:43 GMT:BMC:doctor-bmc:1737: app_monitor.c:234:Process, lv_dimmd, successfully started.
3:2016 Dec 13 12:33:43 GMT:BMC:crond:1296: time disparity of 24693873 minutes detected
5:2016 Dec 13 12:33:44 GMT:BMC:doctor-bmc:1745: app_monitor.c:234:Process, fault-engined, successfully started.
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>name is Pilot3 Tulip
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>BROADCOM: PHY found at phy address 19!!
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>MV Switch Port 5 Enable status: 7f
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>Nand Astoria Mark 17
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>EMS CLI Work queue is created successfully
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Entered m25pxx_init
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Fast clk is set
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>C220 EVT1/P1 board detected. If wrong, fix CPLD programming
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Strap is SET for HOST spi
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Warning: unable to open an initial console.
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>[host_power_init]:1458:INIT Blade Power State is ... [ OFF ]
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>Pilot3 SPI Flash mapping: 0x4000000 at 0x0
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>No of banks = 6
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Probing for Flash at Bank # 0
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>SPI: probing for intel s33 devices ...
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>SPI: probing for atmel devices ...
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>SPI: probing for m25pxx devices ...
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>20 0 0 262144
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Probing for Flash at Bank # 1
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>19 0 0 262144
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Probing for Flash at Bank # 2
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>18 0 0 262144
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Probing for Flash at Bank # 3
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>17 0 0 262144
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Probing for Flash at Bank # 4
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>16 0 0 262144
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>Probing for Flash at Bank # 5
4:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<4>15 0 0 262144
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>Concatenating MTD devices:
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>(0): "Pilot3 SPI MAP"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>(1): "Pilot3 SPI MAP"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>(2): "Pilot3 SPI MAP"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>(3): "Pilot3 SPI MAP"
5:2016 Dec 13 12:33:44 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [gdsd]
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>(4): "Pilot3 SPI MAP"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>(5): "Pilot3 SPI MAP"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>into device "Concat Ractrends"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>Creating 15 MTD partitions on "Concat Ractrends":
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000000000000-0x000006000000 : "all"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000000000000-0x000000080000 : "U-Boot"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000000080000-0x0000000c0000 : "boot.conf"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x0000000c0000-0x000000100000 : "RSVD"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000000100000-0x000000880000 : "Linux1"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000000880000-0x000001000000 : "Linux2"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000001000000-0x000001800000 : "NV_0"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000001800000-0x000002000000 : "OBFL"
5:2016 Dec 13 12:33:44 GMT:BMC:lv_dimm:1739: lv_dimm.c:200:[transition_function]Starting Transition to [High Voltage Mode] from [Unknown Mode]
5:2016 Dec 13 12:33:44 GMT:BMC:lv_dimm:1739: common.c:941:Disabling Sensor scan for sensor 0x83.
5:2016 Dec 13 12:33:44 GMT:BMC:lv_dimm:1739: common.c:941:Disabling Sensor scan for sensor 0x84.
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000002000000-0x000003000000 : "NV_1"
5:2016 Dec 13 12:33:44 GMT:BMC:kernel:-:<5>0x000003000000-0x000004000000 : "NV_2"
5:2016 Dec 13 12:33:45 GMT:BMC:lv_dimm:1739: lv_dimm.c:220:[transition_function]Transition to [High Voltage Mode] Success
5:2016 Dec 13 12:33:45 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [mem_throttled]
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> Fan tach  Interrupt Register
5:2016 Dec 13 12:33:45 GMT:BMC:doctor-bmc:1767: app_monitor.c:234:Process, mem_throttled, successfully started.
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> PWM control & stat reg , enables counter resolution
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>Counter resolution reg, sets no of clock cycles for PWM
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCRVR2: 1e, addr: c794601c
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCRVR3: 1e, addr: c7946020
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> PWM pre scale register, sets clock divider for PWM
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> PWM  duty cycle reg, sets no of high pulses
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWPSR0: a, addr: c7946040
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWDCR0: 15, addr: c7946044
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWPSR1: a
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWDCR1: 15
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWPSR2: a
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWDCR2: 15
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWPSR3: a
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWDCR3: 15
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> Fan tach threshold reg, sets max no of clock between pulses
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR0: ff, addr: c7946060
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR1: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR2: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR3: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR4: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR5: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR6: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR7: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> Fan tach speed reg, set automatically
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR0: 0, addr c7946064
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR1: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR2: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR3: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR4: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR5: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR6: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR7: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> Fan tach control& stat reg,
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR0: 60 addr c7946068
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR1: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR2: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR3: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR4: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR5: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR6: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR7: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> Fan Tach filter select reg, sets filter value if filter is enabled
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMPFSR0: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMPFSR1: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4> SET2 - PWM and Fan tach configuration registers
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCFG1: 55  addr: c7946100
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCFG1: ff  addr: c7946104
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWOCF1: 0  addr: c7946108
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FTISR1: 0  addr: c794610c
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCRCSR1: 55, addr: c7946110
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCRVR4: 1e, addr: c7946114
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCRVR5: 1e, addr: c7946118
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCRVR6: 1e, addr: c794611c
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWCRVR7: 1e, addr: c7946120
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWPSR4: a, addr: c7946140
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWDCR4: 15, addr: c7946144
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWPSR5: a
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWDCR5: 15
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWPSR6: a
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWDCR6: 15
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWPSR7: a
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>PWDCR7: 15
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR8: ff, addr: c7946160
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR9: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR10: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR11: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR12: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR13: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR14: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMTHR15: ff
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR8: 0 addr c7946164
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR9: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR10: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR11: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR12: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR13: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR14: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMSPR15: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR8: 60 addr c7946168
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR9: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR10: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR11: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR12: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR13: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR14: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMCSR15: 60
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMPFSR2: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>FMPFSR3: 0
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>***************PWM Driver has been initialized****************
5:2016 Dec 13 12:33:45 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [qpi_loggerd]
5:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2773:USB FS: VDD Power Good = OFF
5:2016 Dec 13 12:33:45 GMT:BMC:doctor-bmc:1775: app_monitor.c:234:Process, qpi_loggerd, successfully started.
5:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<5> CyAnDevice: Astoria FW type 0 already loaded
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>setting perfect hw filtering mode (c63d34f8)
4:2016 Dec 13 12:33:45 GMT:BMC:kernel:-:<4>setting perfect hw filtering mode (c708f4f8)
4:2016 Dec 13 12:33:47 GMT:BMC:kernel:-:last message repeated 5 times
4:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<4>EXT2-fs (loop0): warning: mounting unchecked fs, running e2fsck is recommended
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x30 : Status = 0x83
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x31 : Status = 0x80
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x33 : Status = 0x83
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x34 : Status = 0x80
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x20 : Status = 0x83
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x21 : Status = 0x80
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x23 : Status = 0x83
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x24 : Status = 0x80
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x10 : Status = 0x83
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x11 : Status = 0x80
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x13 : Status = 0x83
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x14 : Status = 0x80
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x0 : Status = 0x83
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x1 : Status = 0x80
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x3 : Status = 0x83
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[SetDimmBlackListStatus]:122:DIMM ID = 0x4 : Status = 0x80
5:2016 Dec 13 12:33:46 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [xapid]
5:2016 Dec 13 12:33:46 GMT:BMC:doctor-bmc:1799: app_monitor.c:234:Process, xapid, successfully started.
5:2016 Dec 13 12:33:46 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[10]: Turning LED[10] (LED_FAN2_FAULT) OFF
5:2016 Dec 13 12:33:46 GMT:BMC:kernel:-:<5>[__do_power_off]:325:__do_power_off
5:2016 Dec 13 12:33:46 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[12]: Turning LED[12] (LED_FAN4_FAULT) OFF
5:2016 Dec 13 12:33:47 GMT:BMC:lv_dimm:1739: lv_dimm.c:403:[handle_event_enable_tick]enable sensor event
5:2016 Dec 13 12:33:47 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x83.
5:2016 Dec 13 12:33:47 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x84.
5:2016 Dec 13 12:33:47 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x85.
5:2016 Dec 13 12:33:47 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x86.
5:2016 Dec 13 12:33:47 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x89.
5:2016 Dec 13 12:33:47 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x8a.
5:2016 Dec 13 12:33:47 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x91.
5:2016 Dec 13 12:33:47 GMT:BMC:lv_dimm:1739: common.c:946:Enabling sensor scan for sensor 0x92.
5:2016 Dec 13 12:33:47 GMT:BMC:lv_dimm:1739: sanluis1/platform.c:117:platform_event_enable_tick_end: Configuring IR from CIMC
5:2016 Dec 13 12:33:47 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [fcgi]
4:2016 Dec 13 12:33:47 GMT:BMC:IPMI:1591: PSRedundantMode.c:51:PSRdntMode_Read --> Failed to open file /var/pmbus/ps_redundancy_state for read.
5:2016 Dec 13 12:33:47 GMT:BMC:doctor-bmc:1805: app_monitor.c:234:Process, fcgi, successfully started.
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1661: selparser.c:706: # 56 05 00 00 01 02 00 00 AA EA 4F 58 20 00 04 24 08 00 00 00 04 00 FF FF # 556 | 12/13/2016 12:33:46 | CIMC | Platform alert POWER_ON_FAIL #0x08 | Predictive Failure deasserted | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1661: selparser.c:706: # 57 05 00 00 01 02 00 00 AA EA 4F 58 20 00 04 25 0A 00 00 00 08 01 FF FF # 557 | 12/13/2016 12:33:46 | CIMC | Entity presence FAN2_PRSNT #0x0a | Device Present | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1661: selparser.c:706: # 58 05 00 00 01 02 00 00 AA EA 4F 58 20 00 04 25 0C 00 00 00 08 01 FF FF # 558 | 12/13/2016 12:33:46 | CIMC | Entity presence FAN4_PRSNT #0x0c | Device Present | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1661: selparser.c:706: # 59 05 00 00 01 02 00 00 AA EA 4F 58 20 00 04 25 1E 00 00 00 08 01 FF FF # 559 | 12/13/2016 12:33:46 | CIMC | Entity presence RISER2_PRESENT #0x1e | Device Present | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1661: selparser.c:706: # 5A 05 00 00 01 02 00 00 AA EA 4F 58 20 00 04 25 24 00 00 00 08 01 FF FF # 55a | 12/13/2016 12:33:46 | CIMC | Entity presence RISER1_PRESENT_1 #0x24 | Device Present | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1661: selparser.c:706: # 5B 05 00 00 01 02 00 00 AA EA 4F 58 20 00 04 24 36 00 00 00 7F 01 FF FF # 55b | 12/13/2016 12:33:46 | CIMC | Platform alert LED_PSU_STATUS #0x36 | LED is on | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1661: selparser.c:706: # 5C 05 00 00 01 02 00 00 AA EA 4F 58 20 00 04 24 36 00 00 00 7F 04 FF FF # 55c | 12/13/2016 12:33:46 | CIMC | Platform alert LED_PSU_STATUS #0x36 | LED color is green | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1661: selparser.c:706: # 5D 05 00 00 01 02 00 00 AB EA 4F 58 20 00 04 24 38 00 00 00 7F 01 FF FF # 55d | 12/13/2016 12:33:47 | CIMC | Platform alert LED_FAN_STATUS #0x38 | LED is on | Asserted
5:2016 Dec 13 12:33:47 GMT:BMC:selparser:1661: selparser.c:706: # 5E 05 00 00 01 02 00 00 AB EA 4F 58 20 00 04 24 38 00 00 00 7F 04 FF FF # 55e | 12/13/2016 12:33:47 | CIMC | Platform alert LED_FAN_STATUS #0x38 | LED color is green | Asserted
5:2016 Dec 13 12:33:48 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[9]: Turning LED[9] (LED_FAN1_FAULT) OFF
5:2016 Dec 13 12:33:48 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[11]: Turning LED[11] (LED_FAN3_FAULT) OFF
5:2016 Dec 13 12:33:48 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[13]: Turning LED[13] (LED_FAN5_FAULT) OFF
5:2016 Dec 13 12:33:48 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[255]: Turning LED[25] (LED_DIMM_FAULT_P1_A2) OFF
5:2016 Dec 13 12:33:48 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[255]: Turning LED[27] (LED_DIMM_FAULT_P1_B2) OFF
5:2016 Dec 13 12:33:48 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[255]: Turning LED[29] (LED_DIMM_FAULT_P1_C2) OFF
5:2016 Dec 13 12:33:48 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[255]: Turning LED[31] (LED_DIMM_FAULT_P1_D2) OFF
5:2016 Dec 13 12:33:48 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[255]: Turning LED[33] (LED_DIMM_FAULT_P2_E2) OFF
5:2016 Dec 13 12:33:48 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[255]: Turning LED[35] (LED_DIMM_FAULT_P2_F2) OFF
5:2016 Dec 13 12:33:48 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[255]: Turning LED[37] (LED_DIMM_FAULT_P2_G2) OFF
5:2016 Dec 13 12:33:48 GMT:BMC:IPMI:1591: LED_Control.c:81:    -> Sensor[255]: Turning LED[39] (LED_DIMM_FAULT_P2_H2) OFF
5:2016 Dec 13 12:33:48 GMT:BMC:selparser:1661: selparser.c:706: # 5F 05 00 00 01 02 00 00 AC EA 4F 58 20 00 04 25 09 00 00 00 08 01 FF FF # 55f | 12/13/2016 12:33:48 | CIMC | Entity presence FAN1_PRSNT #0x09 | Device Present | Asserted
5:2016 Dec 13 12:33:48 GMT:BMC:selparser:1661: selparser.c:706: # 60 05 00 00 01 02 00 00 AC EA 4F 58 20 00 04 25 0B 00 00 00 08 01 FF FF # 560 | 12/13/2016 12:33:48 | CIMC | Entity presence FAN3_PRSNT #0x0b | Device Present | Asserted
5:2016 Dec 13 12:33:48 GMT:BMC:selparser:1661: selparser.c:706: # 61 05 00 00 01 02 00 00 AC EA 4F 58 20 00 04 25 0D 00 00 00 08 01 FF FF # 561 | 12/13/2016 12:33:48 | CIMC | Entity presence FAN5_PRSNT #0x0d | Device Present | Asserted
5:2016 Dec 13 12:33:48 GMT:BMC:selparser:1661: selparser.c:706: # 62 05 00 00 01 02 00 00 AC EA 4F 58 20 00 04 25 1F 00 00 00 08 01 FF FF # 562 | 12/13/2016 12:33:48 | CIMC | Entity presence RISER1_PRESENT #0x1f | Device Present | Asserted
5:2016 Dec 13 12:33:48 GMT:BMC:selparser:1661: selparser.c:706: # 63 05 00 00 01 02 00 00 AC EA 4F 58 20 00 04 25 23 00 00 00 08 01 FF FF # 563 | 12/13/2016 12:33:48 | CIMC | Entity presence RISER2_PRESENT_1 #0x23 | Device Present | Asserted
5:2016 Dec 13 12:33:48 GMT:BMC:selparser:1661: selparser.c:706: # 64 05 00 00 01 02 00 00 AC EA 4F 58 20 00 04 24 37 00 00 00 7F 01 FF FF # 564 | 12/13/2016 12:33:48 | CIMC | Platform alert LED_TEMP_STATUS #0x37 | LED is on | Asserted
5:2016 Dec 13 12:33:48 GMT:BMC:selparser:1661: selparser.c:706: # 65 05 00 00 01 02 00 00 AC EA 4F 58 20 00 04 24 37 00 00 00 7F 04 FF FF # 565 | 12/13/2016 12:33:48 | CIMC | Platform alert LED_TEMP_STATUS #0x37 | LED color is green | Asserted
5:2016 Dec 13 12:33:48 GMT:BMC:selparser:1661: selparser.c:706: # 66 05 00 00 01 02 00 00 AC EA 4F 58 20 00 04 24 39 00 00 00 7F 01 FF FF # 566 | 12/13/2016 12:33:48 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED is on | Asserted
5:2016 Dec 13 12:33:48 GMT:BMC:selparser:1661: selparser.c:706: # 67 05 00 00 01 02 00 00 AC EA 4F 58 20 00 04 24 39 00 00 00 7F 04 FF FF # 567 | 12/13/2016 12:33:48 | CIMC | Platform alert LED_HLTH_STATUS #0x39 | LED color is green | Asserted
5:2016 Dec 13 12:33:48 GMT:BMC:selparser:1661: selparser.c:706: # 68 05 00 00 01 02 00 00 AC EA 4F 58 20 00 04 25 A1 00 00 00 08 01 FF FF # 568 | 12/13/2016 12:33:48 | CIMC | Entity presence P2_PRESENT #0xa1 | Device Present | Asserted
5:2016 Dec 13 12:33:49 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [monkey]
5:2016 Dec 13 12:33:49 GMT:BMC:doctor-bmc:1824: app_monitor.c:234:Process, monkey, successfully started.
5:2016 Dec 13 12:33:49 GMT:BMC:selparser:1661: selparser.c:706: # 69 05 00 00 01 02 00 00 AD EA 4F 58 20 00 04 25 A0 00 00 00 08 01 FF FF # 569 | 12/13/2016 12:33:49 | CIMC | Entity presence P1_PRESENT #0xa0 | Device Present | Asserted
5:2016 Dec 13 12:33:49 GMT:BMC:bios-update:1838: main.c:236:Running as Daemon
5:2016 Dec 13 12:33:50 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [alertmgr]
5:2016 Dec 13 12:33:50 GMT:BMC:doctor-bmc:1849: app_monitor.c:234:Process, alertmgr, successfully started.
5:2016 Dec 13 12:33:52 GMT:BMC:bios-update:1838: activate.c:142:Setting BIOS Version
4:2016 Dec 13 12:33:52 GMT:BMC:IPMI:1591: PSRedundantMode.c:51:PSRdntMode_Read --> Failed to open file /var/pmbus/ps_redundancy_state for read.
5:2016 Dec 13 12:33:57 GMT:BMC:selparser:1661: selparser.c:706: # 6A 05 00 00 01 02 00 00 B5 EA 4F 58 20 00 04 08 25 00 00 00 6F 30 FF 00 # 56a | 12/13/2016 12:33:57 | CIMC | Power supply PSU1_STATUS #0x25 | Presence detected |  | Asserted
5:2016 Dec 13 12:33:57 GMT:BMC:selparser:1661: selparser.c:706: # 6B 05 00 00 01 02 00 00 B5 EA 4F 58 20 00 04 08 26 00 00 00 6F 30 FF 00 # 56b | 12/13/2016 12:33:57 | CIMC | Power supply PSU2_STATUS #0x26 | Presence detected |  | Asserted
5:2016 Dec 13 12:33:57 GMT:BMC:kernel:-:<5>drivers/bmc/usb/usb1.1/se_pilot2_udc_usb1_1.c:2402:USB1 VDD power off
5:2016 Dec 13 12:33:58 GMT:BMC:selparser:1661: selparser.c:706: # 6C 05 00 00 01 02 00 00 B6 EA 4F 58 20 00 04 08 3A 00 00 00 0B 00 FF FF # 56c | 12/13/2016 12:33:58 | CIMC | Power supply PS_RDNDNT_MODE #0x3a | Fully Redundant | Asserted
5:2016 Dec 13 12:34:02 GMT:BMC:selparser:1661: selparser.c:706: # 6D 05 00 00 01 02 00 00 B9 EA 4F 58 20 00 04 08 2F 00 00 00 03 01 FF FF # 56d | 12/13/2016 12:34:01 | CIMC | Power supply PSU1_AC_OK #0x2f | State Asserted | Asserted
5:2016 Dec 13 12:34:02 GMT:BMC:selparser:1661: selparser.c:706: # 6E 05 00 00 01 02 00 00 B9 EA 4F 58 20 00 04 08 31 00 00 00 03 01 FF FF # 56e | 12/13/2016 12:34:01 | CIMC | Power supply PSU2_AC_OK #0x31 | State Asserted | Asserted
5:2016 Dec 13 12:34:03 GMT:BMC:kernel:-:<5>Slow work thread pool: Starting up
5:2016 Dec 13 12:34:03 GMT:BMC:kernel:-:<5>Slow work thread pool: Ready
5:2016 Dec 13 12:34:05 GMT:BMC:DimmBL-DbSyncTask:1471: DimmBL-DbSyncTask.c:224:InitializeDimmBLSyncTask: SUCCESS
5:2016 Dec 13 12:34:06 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [kvm]
5:2016 Dec 13 12:34:06 GMT:BMC:doctor-bmc:1977: app_monitor.c:234:Process, kvm, successfully started.
5:2016 Dec 13 12:34:06 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [vkvm_pm]
5:2016 Dec 13 12:34:06 GMT:BMC:doctor-bmc:1985: app_monitor.c:234:Process, vkvm_pm, successfully started.
5:2016 Dec 13 12:34:07 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [sshd]
5:2016 Dec 13 12:34:07 GMT:BMC:doctor-bmc:2009: app_monitor.c:234:Process, sshd, successfully started.
5:2016 Dec 13 12:34:07 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [cisco_pm]
5:2016 Dec 13 12:34:07 GMT:BMC:doctor-bmc:2021: app_monitor.c:234:Process, cisco_pm, successfully started.
5:2016 Dec 13 12:34:07 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [ciscoNET]
5:2016 Dec 13 12:34:07 GMT:BMC:doctor-bmc:2032: app_monitor.c:234:Process, ciscoNET, successfully started.
5:2016 Dec 13 12:34:08 GMT:BMC:ciscoNET:2034: ciscoNET.c:122:Application Starting
5:2016 Dec 13 12:34:08 GMT:BMC:doctor-bmc-app-mon:2053: app_monitor.c:726:Started application monitor (2053)
5:2016 Dec 13 12:34:08 GMT:BMC:doctor-bmc-app-mon:2053: app_monitor.c:481:cmp_proc_node_ctime: stat(/proc/1609) failed, errno 2 (No such file or directory)
5:2016 Dec 13 12:34:08 GMT:BMC:doctor-bmc-app-mon:2053: app_monitor.c:636:cmp_proc_node_ctime sel_pigeon_cntrd stat(/proc/1609) returned errno 2 (No such file or directory)
4:2016 Dec 13 12:34:08 GMT:BMC:doctor-bmc-app-mon:2053: app_monitor.c:592:Restarting Process sel_pigeon_cntrd
5:2016 Dec 13 12:34:08 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [ucsm_state_manager]
5:2016 Dec 13 12:34:08 GMT:BMC:doctor-bmc:2060: app_monitor.c:234:Process, ucsm_state_manager, successfully started.
5:2016 Dec 13 12:34:09 GMT:BMC:ciscoNET:2034: network_manager.c:549:Configuring the network.
5:2016 Dec 13 12:34:09 GMT:BMC:sel_pigeon_cntr:2061: sel_pigeon_cntr.c:917:Opening connection to SEL_PIGEON_CNTR_FIFO
5:2016 Dec 13 12:34:09 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [GDSCommDmn]
5:2016 Dec 13 12:34:09 GMT:BMC:doctor-bmc:2083: app_monitor.c:234:Process, GDSCommDmn, successfully started.
5:2016 Dec 13 12:34:10 GMT:BMC:GDSCommDmn:-: GDSCommSVC.c:116:GDSComm SVC started
5:2016 Dec 13 12:34:10 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [rack_monitor]
5:2016 Dec 13 12:34:10 GMT:BMC:doctor-bmc:2088: app_monitor.c:234:Process, rack_monitor, successfully started.
5:2016 Dec 13 12:34:10 GMT:BMC:rack_monitor:-: rack_monitor.c:397:RACK Montior in Stand-alone mode
5:2016 Dec 13 12:34:10 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [sam_master]
5:2016 Dec 13 12:34:11 GMT:BMC:doctor-bmc:2093: app_monitor.c:234:Process, sam_master, successfully started.
5:2016 Dec 13 12:34:11 GMT:BMC:sam_master:-: sam_master.c:61:Stopping PTPD on Monitor Request
5:2016 Dec 13 12:34:11 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [ciscovmd]
5:2016 Dec 13 12:34:11 GMT:BMC:ciscoNET:2034: network_manager.c:793:Error: killall udhcpc returned exit code: 256
5:2016 Dec 13 12:34:11 GMT:BMC:doctor-bmc:2100: app_monitor.c:234:Process, ciscovmd, successfully started.
5:2016 Dec 13 12:34:12 GMT:BMC:doctor-bmc:-: doctor-bmc.c:308:doctor-bmc-app stop [ptpd]
5:2016 Dec 13 12:34:12 GMT:BMC:doctor-bmc:-: doctor-bmc.c:292:doctor-bmc-app start [video_triggerd]
5:2016 Dec 13 12:34:12 GMT:BMC:ciscoNET:2034: network_manager.c:795:Error: killall udhcpc6 returned exit code: 256
5:2016 Dec 13 12:34:12 GMT:BMC:doctor-bmc:2108: app_monitor.c:234:Process, video_triggerd, successfully started.
4:2016 Dec 13 12:34:13 GMT:BMC:kernel:-:<4>setting perfect hw filtering mode (c708f4f8)
5:2016 Dec 13 12:34:21 GMT:BMC:hw-ether:2198: hw-ether.c:254:eth0's hardware address changed to f8:72:ea:a3:d6:ee
4:2016 Dec 13 12:34:21 GMT:BMC:kernel:-:<4>setting perfect hw filtering mode (c708f4f8)
4:2016 Dec 13 12:34:24 GMT:BMC:kernel:-:last message repeated 6 times
4:2016 Dec 13 12:34:24 GMT:BMC:ciscoNET:2034: network_manager.c:2082:Error: Can not open file, /etc/resolv.conf, with mode, r: 0x2.
5:2016 Dec 13 12:34:25 GMT:BMC:ciscoNET:2034: cisco_cards_manager.c:204:There are no cisco configurable cards attached.
5:2016 Dec 13 12:34:25 GMT:BMC:GDSCommDmn:-: GDSCommSVC.c:209:GDSComm started taking input connections.
5:2016 Dec 13 12:34:26 GMT:BMC:IPMI:1591: Bridge.c:1468:audit from:kcs Fn:0x6 Cmd:0x56 Data: 0x1 0x0 0x1
5:2016 Dec 13 12:34:26 GMT:BMC:IPMI:1591: Bridge.c:1474:audit Resp:0x0
5:2016 Dec 13 12:34:37 GMT:BMC:doctor-bmc:-: doctor-bmc.c:308:doctor-bmc-app stop [snmp-subagentd]
5:2016 Dec 13 12:34:37 GMT:BMC:root:-: CIMC booted after a warm reboot!!
5:2016 Dec 13 12:34:43 GMT:BMC:root:-: NTP: CIMC IP acquired: 192.168.1.207
3:2016 Dec 13 12:34:47 GMT:BMC:update-ir:2352: ../../src/update-ir.c:234:Host should be powered-on for IR configuration update
5:2016 Dec 13 12:35:00 GMT:BMC:root:-: DDNS: CIMC IP acquired: 192.168.1.207
5:2016 Dec 13 12:35:00 GMT:BMC:root:-: DDNS: GATEWAY IP acquired: 192.168.1.254
4:2016 Dec 13 12:35:19 GMT:BMC:kernel:-:<4>process `doctor-bmc' is using deprecated sysctl (syscall) net.ipv6.neigh.default.retrans_time; Use net.ipv6.neigh.default.retrans_time_ms instead.
5:2016 Dec 13 12:35:25 GMT:BMC:AUDIT:2476: Login success (user:admin, ip:192.168.1.129, service:sshd)
5:2016 Dec 13 12:35:25 GMT:BMC:AUDIT:2024: Session open (user:admin, ip:192.168.1.129, id:1, type:CLI)
5:2016 Dec 13 12:35:25 GMT:BMC:AUDIT:2476: Session open (user:admin, ip:192.168.1.129, id:1, type:CLI)
3:2017 May 29 14:19:17 BST:BMC:crond:1296: time disparity of 240524 minutes detected
5:2017 May 29 14:19:33 BST:BMC:DFU:-: Command: obfl
5:2017 May 29 14:20:20 BST:BMC:DFU:-:last message repeated 2 times
5:2017 May 29 14:20:44 BST:BMC:DFU:-: Command: Q
5:2017 May 29 14:20:45 BST:BMC:DFU:-: Command: help
5:2017 May 29 14:21:36 BST:BMC:DFU:-:last message repeated 5 times
5:2017 May 29 14:21:36 BST:BMC:DFU:-: Command: sensors
5:2017 May 29 14:21:44 BST:BMC:DFU:-: Command: Q
5:2017 May 29 14:21:53 BST:BMC:DFU:-: Command: exit
5:2017 May 29 14:22:14 BST:BMC:DFU:-: Command: obfl
5:2017 May 29 14:24:56 BST:BMC:DFU:-: Command: exit
5:2017 May 29 14:25:55 BST:BMC:DFU:-: Command: sensors
5:2017 May 29 14:26:37 BST:BMC:DFU:-: Command: exit
5:2017 May 29 14:26:53 BST:BMC:DFU:-: Command: obfl
[ obfl ]#
Kirk J
Greetings.
Would need to look at the overall tech support file to further look at what is causing post failure.  I would open a TAC case at this point.
You could try resetting the BIOS/CMOS from CIMC, BIOS menu.
Was this a functioning server that all of a sudden crashed, and wouldn't power on anymore?
Or did this occur after a firmware upgrade, etc?
2:2017 May 29 13:06:30 BST:BMC:IPMI:1591: PowerOnFail.c:55:PowerOnFail_Read:PowerOnFail on for 10 Scan Cycles Turning Power Off
2:2017 May 29 13:06:30 BST:BMC:kernel:-:<2>[host_power_ioctl]:957:POWER ON FAILURE has been detected
5:2017 May 29 12:26:31 BST:BMC:kernel:-:<5>[__do_power_on]:385:__do_power_on
5:2017 May 29 12:26:31 BST:BMC:kernel:-:<5>[__do_power_on]:401:Power Driver: Power On Logic Pulse for 250ms @ 4294889566
5:2017 May 29 12:26:31 BST:BMC:AUDIT:1796: Server power state modify (op:power-on)
2:2017 May 29 12:26:52 BST:BMC:kernel:-:<2>[__do_power_on]:428:Power Driver: Power On Fail Asserted @ 4294909897 RegInfo -> SWSTAT0[0x11] WKCFG0[0x11]
5:2017 May 29 12:26:52 BST:BMC:IPMI:1591: Pilot2SrvPower.c:189:Pilot2SrvPowerOn
4:2017 May 29 12:26:52 BST:BMC:IPMI:1591: Pilot2SrvPower.c:191:Pilot2SrvPowerOn: Failed to Power On [Timer expired]
0:2017 May 29 12:26:52 BST:BMC:POF_MONITOR_DAEMON:1381: pof_monitord.c:93:Host Failed Power On Please Check [ /var/log/power-on-fail.log ]
5:2017 May 29 12:26:52 BST:BMC:IPMI:1591: Pilot2SrvPower.c:466:Blade Power Changed To: [ ON ]
5:2017 May 29 12:26:52 BST:BMC:video_trigger:-: video_trigger.c:280:Sending event_ipmi_power_state_change (ON) ..
5:2017 May 29 12:26:52 BST:BMC:IPMI:1591: Rack_FanCtrl.c:1272:fscUpdateActualFanPolicyFile: Applied Policy: N/A, Configuration Status: PENDING - BIOS POST not completed
5:2017 May 29 12:26:53 BST:BMC:selparser:1662: selparser.c:706: # 2D 04 00 00 01 02 00 00 7D 05 2C 59 20 00 04 24 08 00 00 00 04 01 FF FF # 42d | 05/29/2017 12:26:53 | CIMC | Platform alert POWER_ON_FAIL #0x08 | Predictive Failure asserted | Asserted
5:2017 May 29 12:26:54 BST:BMC:video_trigger:-: video_trigger.c:207:Sending event_server_crash for host NMI ..
4:2017 May 29 12:26:57 BST:BMC:IPMI:1591: Pilot3Peci.c:87:Pilot_PECI: Transaction aborted! --> [0xFFFFFFFF], ResultCode = 0, LPC Reset State = 1
5:2017 May 29 12:26:57 BST:BMC:IPMI:1591: Pilot3Peci.c:1034:Pilot_PECI: PECI Temp Transaction To CPU-0 Failed!  RC: 0
Hi Kirk
it was Ok but this started happening soon after an upgrade via HUU.
TAC isn't an option for me unfortunately
Rich
Hi Kirk,
Tried Reset BIOS CMOS - no joy. As TAC isn't an option I'm not sure where to go next :(
I've tried swapping CPU.RAID card, PSU,DIMMs with a working server I have-no joy.
I'm thinking this is either motherboard or BIOS issue but not sure how to test either
Rich
Under CIMC, admin Tab, Firmware Management, try activating the previous version available (i.e. 3.01a bios is current, activate 2.0x)  Do this for BIOS 1st,,, and see if this resolves the issue.  After bios re-ack of older version and still not working, do the same for the CIMC.
Kirk...
Tried - no joy. I was hoping to upload the same bios again in case it got corrupted but I can't get hold of the bios only firmware for version 3 (.it isn't in the zip file unlike previous versions)
Greetings.
One last thing to try.
SSH to CIMC
C220-# scope chassis
C220-/chassis # scope firmware
C220-/chassis/firmware # show detail
C220-/chassis/firmware # update-all
C220-/chassis/firmware #show detail  (see if the firmware update is running)
Let that run for a bit.
This is an exercise to see if we have a low level component such as FPGA, power sequencer, etc, that has a firmware issue.
Kirk...
