09-01-2014 02:26 AM - edited 03-01-2019 11:49 AM
The server hangs at 'configuring and testing platform hardware'. This happened after adding a virtual disk with CIMC trying to see the hard disk for installing OS. After this change, the server hangs at 'configuring and testing platform hardware'.
The only thing we can do is to access CIMC. We have tried to reset bios and Clear BIOS CMOS with the CIMC tools without success. We are attaching CIMC system event log.
Any advice? Thanks in advance.
09-01-2014 02:29 AM
09-01-2014 04:52 AM
Try to access the KVM console,
If you can't access the KVM use the o'reliable keyboard and mouse
Reboot/reset the server, and try to create the virtual disks(RAID) through the WebBIOS itself.
To access the webBIOS, let the server boot and once it prompts CTRL+H, well do it.
Once you are in the webbios, try to clear the configuration and try to RAID.
09-01-2014 06:39 AM
Thanks for the answer,
I can access KVM console but there is no way to access the WebBIOS. No option of doing CTRL+H.
Startup hangs in
"Configuring platform hardware" .
09-01-2014 12:43 PM
Just to verify
Has this server been working already?
Just wanted to check if all your RAMs(DIMM) slots are in the right place.
Take note that every server model has a different way of populating the RAMs
Kindly verify and maybe psuh them a bit.
If issue still persist you might want to open a TAC case.
03-23-2015 02:16 PM
Having a similar error. Were you able to have the issue fixed, if so what was it?
09-01-2014 05:52 AM
Hi @fernando.lerendegui,
Please, follow this link to further investigation:
https://supportforums.cisco.com/discussion/11835656/ucs-c240-m3-stuck-configuring-and-testing-memory#comment-8654186
HTH.
Rgrds,
Martin, IT Specialist
09-01-2014 07:12 AM
I only can access parameters via CIMC and Onboard Storage Support appears as 'Diabled'. So, it seems to be correctly configured.
I cannot access BIOS pressing Ctrl options at start up, it hangs before that step.
Fernando L
12-27-2016 01:50 PM
I'd follow the link you've provided since I'm having this exact issue, but it's saying that I don't have permissions to view the page which is odd since I do have an active SmartNet Contract for my UCS C240. I have an active case for this unit right now, but was hoping to find some answers myself as my ticket has been open for nearly 2 months now...
