UCS Ethernet uplink Portchannel LACP mode
davidcheung
As UCS just support LACP for uplin portchannel, could anybody advise which mode(active, passive or on) the portchannel LACP is running on?
Thank you very much!
I've checked and "Active" mode is the only option in both EHM and Switch mode.
Robert
Robert Burns
The Fabric Interconnects only support LACP Active in End-Host-Mode.  As with Cisco best practice, host access is active, while your Dist. switches would likely be passive (Best Practice) or active.
Robert
Hi Robert,
Thank you very much for your prompt reply.
So do you mean that UCS will run LACP on active mode when FI is configured in end host mode?
Robert
