UCS Fabric Interconnect After Failover(primary,subordinate)
JO BO
     Dear Team,
After the failover of FI-A to FI-B when we check show cluster status its show FI-B as primary and FI-A as subordinate
Now the FI-A is Back on line and HA shows as ready, but when we check show cluster status its still shows FI-B as primary and FI-A as subordinate
Will the FI-A revert back itself as primary or do we need to give the command force lead from FI-B to make FI-A as primary again?
Thanks and Regards
Jose
sprasath
Hi Jose,
FI A won't revert back to being primary again. The primary/sub-ordinate is purely from a management perspective and nothing else (both FIs forward traffic etc). So there is no problem in having FI B as primary or vice-versa.
On a side note, if you want to trigger a failover manually, you can do it from the CLI by going to the local-mgmt context of the primary FI:
UCS-B# connect local-mgmt b
UCS-B(local-mgmt)# cluster lead a
Shankar
sprasath
Hi Jose,
Shankar
Thank you  :)
