11-10-2017 07:30 AM - edited 03-01-2019 01:21 PM
Hello everyone! Well, i have always had a doubt regarding to upgrade the servers. If one server is turn-off and then assign a service-profile (with host package firmware in default) to it, will it upgrade before to work? Should i configure that police or check anything?
Second question, i have to do an upgrade next days, is it possible to upgrade to 3.2 from 3.0 or 3.1?
I can´t find the information about it, i was thinking to do it with auto install.
Thanks in advance!!!!
Solved! Go to Solution.
11-10-2017 07:33 AM
First, you should ensure you maintenance policy is set for "User-Ack" that way nothing reboots without your approval.
Next, create a host firmware package for the new version or use default. If you use default, all service profiles that do not have a host firmware package defined will be updated. Yes, if you apply a service profile with a host firmware package to a blade, it will automagically upgrade the components.
You can go directly from 3.0 to 3.2. Please use auto-install.
11-10-2017 07:33 AM
11-10-2017 07:55 AM
Thanks Austin!! You have been very clear!
Regards!
11-10-2017 08:02 AM
A final question, haha, i was doing the configurations by CLI, but i didn´t find the way to configure a service profile template, is it possible by CLI?
Thanks!
11-10-2017 08:56 AM
